Message Filter dropping message
Message Filter dropping message: frame 'camera_optical_frame' at time 1692621038.320 for reason 'the timestamp on the message is earlier than all the data in the transform cache',有uu在ros2-humble遇到过这个问题吗,可以给一个大致的问题来源判断吗,或者帮我解释下这个问题的产生原因,后面我可以自己根据代码找问题
@3110379921 请问你是使用static tf 去发布 camera_optical_frame 到 base_link(或者其他的joint) 的 tf 关系吗?
还有, 你能不能跑以下 ros2 run tf2_tools view_frames,看一下tf 树的关系对不对
@杜守钰 你好,非常感谢你的答复,问题我已解决.我的代码中是读取了一段视频,发现是视频格式导致的问题,我将视频由avi转为mp4便成功解决了.再次感谢你的答复!
佬,我也是运行rm_vision时出现了一样的问题,你是怎么解决的,可以详细聊下吗?
[armor_tracker_node-2] [INFO] [1702624428.901272177] [armor_tracker]: Message Filter dropping message: frame 'camera_optical_frame' at time 1702624428.866 for reason 'discarding message because the queue is full'
[armor_tracker_node-2] [INFO] [1702624429.915076638] [armor_tracker]: Message Filter dropping message: frame 'camera_optical_frame' at time 1702624428.878 for reason 'the timestamp on the message is earlier than all the data in the transform cache' -
@1747826733 方便问问解决了吗
@2927970764 将gimbal_link与odom之间的tf关系未能建立,我修改了gimbal_joint的type成fixed,并设置了两者之间的位置关系,然后就没有出现这种问题,对之后结果的影响暂时没有发现。
[rviz]: Message Filter dropping message: frame 'odom' at time 138.192 for reason 'Unknown'
有大佬知道我这个问题怎么解决吗 -
@杜守钰 你好,我这边是用static tf 去发布传感器到base_link之间的tf关系的,我也遇到了大量的message filter刷屏打印,有什么解决方式吗?
Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.014318191] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic0_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.014931107] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic1_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.015221857] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic2_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.015437316] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic6_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.015832274] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic4_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.016089482] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic7_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.016267982] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic5_link' at time 1762416381.483 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.355357149] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic2_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.355915649] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic4_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.356171608] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic5_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.356385066] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic0_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.356576066] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic1_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.356965941] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic6_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache' Nov 05 23:06:22 localhost.localdomain bash[1489]: [controller_server-5] [INFO] [1762416382.357157149] [local_costmap.local_costmap]: Message Filter dropping message: frame 'ultrasonic7_link' at time 1762416381.846 for reason 'the timestamp on the message is earlier than all the data in the transform cache'```
