    colcon build --symlink-install 出错
    动手学ROS2
    ros2 colcon colcon build colcon ros2
    1.2k
    • 13741263471
      笑饮孤鸿
      Finished <<< rm_serial_driver [0.40s]
      Finished <<< armor_detector [0.55s]
      --- stderr: armor_tracker
      /usr/bin/ld: /usr/local/lib/libgflags.a(gflags.cc.o): warning: relocation against _ZN3fLS14FLAGS_flagfileB5cxx11E' in read-only section .text.startup'
      /usr/bin/ld: /usr/local/lib/libgflags.a(gflags.cc.o): relocation R_X86_64_PC32 against symbol `stderr@@GLIBC_2.2.5' can not be used when making a shared object; recompile with -fPIC
      /usr/bin/ld: 最后的链结失败: bad value
      gmake[2]: *** [CMakeFiles/armor_tracker.dir/build.make:327:libarmor_tracker.so] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:139:CMakeFiles/armor_tracker.dir/all] 错误 2
      Failed <<< armor_tracker [1.78s, exited with code 2]
      Summary: 6 packages finished [4.08s]
      1 package failed: armor_tracker
      1 package had stderr output: armor_tracker
      2 packages not processed
      • 13741263471
        笑饮孤鸿
        大佬们,这个问题怎么解决呀
