    安装Fast DDS依赖项的 repos 文件时出现404:Not Found
    27
    23.6k
      ljt-138 @小鱼
      @小鱼 window安装有文章吗?装到memory进行不下去了
      • 4885513104
        488551310 @小鱼
          小鱼 技术大佬 @488551310
          @488551310 梯子?https://fishros.org.cn/forum/topic/668/vpn-小鱼用了多五六年的vpn分享-支持linux-windows-android-ios
          4885513104 1 条回复 最后回复 回复 引用 1
          • 4885513104
            488551310 @小鱼
            @小鱼 还是显示 正在连接 downloads.gradle-dn.com (downloads.gradle-dn.com)|47.91.170.222|:443... 失败:拒绝连接。
            5910584005 1 条回复 最后回复 回复 引用 0
            • 5910584005
              妆台秋思 @488551310
              @488551310 应该是把原来的网址改一下吧,我也登不上这个gradle网址。试试https://services.gradle.org/distributions/gradle-6.4-bin.zip看看行吗
              14127502001 SwanseaS 2 条回复 最后回复 回复 引用 1
              • 14127502001
                点点尘丶 @591058400
                @591058400 有用的,谢谢大佬
                • 21041138042
                  qiaoyabing
                  vcs import src < fastrtps.repos
                  EEEEE
                  === src/fastcdr (git) ===
                  Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-CDR.git/':Failed to connect to ghproxy.com port 443: 连接超时
                  === src/fastddsgen (git) ===
                  Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-DDS-Gen.git/':Failed to connect to ghproxy.com port 443: 连接超时
                  === src/fastddsgen/thirdparty/idl-parser (git) ===
                  Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/IDL-Parser.git/':Failed to connect to ghproxy.com port 443: 连接超时
                  === src/fastrtps (git) ===
                  Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-DDS.git/':Failed to connect to ghproxy.com port 443: 连接超时
                  === src/foonathan_memory_vendor (git) ===
                  Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/foonathan_memory_vendor.git/':Failed to connect to ghproxy.com port 443: 连接超时
                  出现上方这种连接超时的情况,请问一下该如何处理
                  24437894432 1 条回复 最后回复 回复 引用 0
                  • 24437894432
                    shmily @2104113804
                    @2104113804 解决好了吗
                      小鱼 技术大佬 @2443789443
                      @2443789443 ghproxy已经挂了,可以换成 github.fishros.org
                      995455989 5 2 条回复 最后回复 回复 引用 0
                      • 995455989
                        坚定 @小鱼
                        @小鱼 wget https://mirrors.aliyun.com/macports/distfiles/gradle/gradle-6.4-bin.zip
                        995455989 1 条回复 最后回复 回复 引用 0
                        • 995455989
                          坚定 @99545598
                          @99545598
                          git clone https://gitclone.com/github.com/eProsima/foonathan_memory_vendor.git
                          git clone https://gitclone.com/github.com/eProsima/Fast-CDR.git
                          git clone https://gitclone.com/github.com/eProsima/Fast-DDS.git
                          git clone https://gitclone.com/github.com/eProsima/Fast-DDS-Gen.git
                          git clone https://gitclone.com/github.com/eProsima/IDL-Parser.git
                          ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/foonathan_memory_vendor.git
                          Cloning into 'foonathan_memory_vendor'...
                          remote: 对象计数中: 232, 完成.
                          remote: 压缩对象中: 100% (146/146), 完成.
                          remote: Total 232 (delta 144), reused 135 (delta 85)
                          Receiving objects: 100% (232/232), 68.44 KiB | 181.00 KiB/s, done.
                          Resolving deltas: 100% (144/144), done.
                          ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/Fast-CDR.git
                          Cloning into 'Fast-CDR'...
                          remote: 对象计数中: 5140, 完成.
                          remote: 压缩对象中: 100% (2276/2276), 完成.
                          remote: Total 5140 (delta 2778), reused 4268 (delta 2232)
                          Receiving objects: 100% (5140/5140), 4.17 MiB | 259.00 KiB/s, done.
                          Resolving deltas: 100% (2778/2778), done.
                          ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/Fast-DDS.git
                          Cloning into 'Fast-DDS'...
                          remote: 对象计数中: 135615, 完成.
                          remote: 压缩对象中: 100% (32890/32890), 完成.
                          remote: Total 135615 (delta 95894), reused 130935 (delta 92304)
                          Receiving objects: 100% (135615/135615), 92.97 MiB | 236.00 KiB/s, done.
                          Resolving deltas: 100% (95894/95894), done.
                          ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/IDL-Parser.git
                          Cloning into 'IDL-Parser'...
                          remote: 对象计数中: 2496, 完成.
                          remote: 压缩对象中: 100% (1067/1067), 完成.
                          remote: Total 2496 (delta 1053), reused 1749 (delta 718)
                          Receiving objects: 100% (2496/2496), 551.12 KiB | 81.00 KiB/s, done.
                          Resolving deltas: 100% (1053/1053), done.
                          995455989 南京嵌入之梦南 2 条回复 最后回复 回复 引用 1
                          • 995455989
                            坚定 @99545598
                            ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ ls
                            build fastrtps.repos gradle-6.4-bin.zip log
                            Fast-CDR foonathan_memory_vendor IDL-Parser src
                            Fast-DDS gradle-6.4 install
                            这样下载下来的文件怎么编译呢
                            • 995455989
                              坚定 @99545598
                              @99545598
                              pwd
                              /home/ros2/d2lros2/fastdds_ws
                              mv Fast-DDS foonathan_memory_vendor IDL-Parser ./src
                              12618461531 1 条回复 最后回复 回复 引用 0
                              • 12618461531
                                ゝ沉默の姿色 @99545598
                                有出现这个问题的吗?
                                • 28170249812
                                  马克 ROS2开发者 @小鱼
                                  @小鱼 vcs命令之后是这样的报错,不知道正常嘛,如果不正确有没有可以更正的方法
                                    小鱼 技术大佬 @2817024981
                                    @2817025981 不要放桌面
                                    • 5
                                      54997824 @小鱼
                                      @小鱼 你好小鱼,这边还是不太行,能给个完整一些的代码吗?
                                      以下是我改的,依然连接被拒绝:
                                      repositories:
                                      foonathan_memory_vendor:
                                      type: git
                                      url: https://github.fishros.org/https://github.com/eProsima/foonathan_memory_vendor.git
                                      version: master
                                      fastcdr:
                                      type: git
                                      url: https://github.fishros.org/https://github.com/eProsima/Fast-CDR.git
                                      version: master
                                      fastrtps:
                                      type: git
                                      url: https://github.fishros.org/https://github.com/eProsima/Fast-DDS.git
                                      version: master
                                      fastddsgen:
                                      type: git
                                      url: https://github.fishros.org/https://github.com/eProsima/Fast-DDS-Gen.git
                                      version: master
                                      fastddsgen/thirdparty/idl-parser:
                                      type: git
                                      url: https://github.fishros.org/https://github.com/eProsima/IDL-Parser.git
                                      version: master
                                      1 2 2 条回复 最后回复 回复 引用 0
                                        Supersonic @54997824
                                        @54997824
                                        fastrtps.repos内容这么写试试
                                        repositories:
                                                type: git
                                                url: https://github.com/eProsima/foonathan_memory_vendor.git
                                                version: master
                                            fastcdr:
                                                type: git
                                                url: https://github.com/eProsima/Fast-CDR.git
                                                version: master
                                            fastrtps:
                                                type: git
                                                url: https://github.com/eProsima/Fast-DDS.git
                                                version: master
                                            fastddsgen:
                                                type: git
                                                url: https://github.com/eProsima/Fast-DDS-Gen.git
                                                version: master
                                                type: git
                                                url: https://github.com/eProsima/IDL-Parser.git
                                                version: master
                                        Y 1 条回复 最后回复 回复 引用 1
                                          yunchuwei @1647546850
                                          @1647546850 还是不太行
                                            2974749756 @54997824
                                            @小鱼 这个问题还是解决不了
