    安装Fast DDS依赖项的 repos 文件时出现404:Not Found
    27
    23.6k
    • 4885513104
      488551310 @小鱼
      @小鱼 还是显示 正在连接 downloads.gradle-dn.com (downloads.gradle-dn.com)|47.91.170.222|:443... 失败:拒绝连接。
      5910584005 1 条回复 最后回复 回复 引用 0
      • 5910584005
        妆台秋思 @488551310
        @488551310 应该是把原来的网址改一下吧,我也登不上这个gradle网址。试试https://services.gradle.org/distributions/gradle-6.4-bin.zip看看行吗
        14127502001 SwanseaS 2 条回复 最后回复 回复 引用 1
        • 14127502001
          点点尘丶 @591058400
          @591058400 有用的,谢谢大佬
          • 21041138042
            qiaoyabing
            vcs import src < fastrtps.repos
            EEEEE
            === src/fastcdr (git) ===
            Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-CDR.git/':Failed to connect to ghproxy.com port 443: 连接超时
            === src/fastddsgen (git) ===
            Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-DDS-Gen.git/':Failed to connect to ghproxy.com port 443: 连接超时
            === src/fastddsgen/thirdparty/idl-parser (git) ===
            Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/IDL-Parser.git/':Failed to connect to ghproxy.com port 443: 连接超时
            === src/fastrtps (git) ===
            Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/Fast-DDS.git/':Failed to connect to ghproxy.com port 443: 连接超时
            === src/foonathan_memory_vendor (git) ===
            Could not determine ref type of version: fatal: 无法访问 'https://ghproxy.com/https://github.com/eProsima/foonathan_memory_vendor.git/':Failed to connect to ghproxy.com port 443: 连接超时
            出现上方这种连接超时的情况,请问一下该如何处理
            24437894432 1 条回复 最后回复 回复 引用 0
            • 24437894432
              shmily @2104113804
              @2104113804 解决好了吗
                小鱼 技术大佬 @2443789443
                @2443789443 ghproxy已经挂了,可以换成 github.fishros.org
                995455989 5 2 条回复 最后回复 回复 引用 0
                • 995455989
                  坚定 @小鱼
                  @小鱼 wget https://mirrors.aliyun.com/macports/distfiles/gradle/gradle-6.4-bin.zip
                  995455989 1 条回复 最后回复 回复 引用 0
                  • 995455989
                    坚定 @99545598
                    @99545598
                    git clone https://gitclone.com/github.com/eProsima/foonathan_memory_vendor.git
                    git clone https://gitclone.com/github.com/eProsima/Fast-CDR.git
                    git clone https://gitclone.com/github.com/eProsima/Fast-DDS.git
                    git clone https://gitclone.com/github.com/eProsima/Fast-DDS-Gen.git
                    git clone https://gitclone.com/github.com/eProsima/IDL-Parser.git
                    ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/foonathan_memory_vendor.git
                    Cloning into 'foonathan_memory_vendor'...
                    remote: 对象计数中: 232, 完成.
                    remote: 压缩对象中: 100% (146/146), 完成.
                    remote: Total 232 (delta 144), reused 135 (delta 85)
                    Receiving objects: 100% (232/232), 68.44 KiB | 181.00 KiB/s, done.
                    Resolving deltas: 100% (144/144), done.
                    ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/Fast-CDR.git
                    Cloning into 'Fast-CDR'...
                    remote: 对象计数中: 5140, 完成.
                    remote: 压缩对象中: 100% (2276/2276), 完成.
                    remote: Total 5140 (delta 2778), reused 4268 (delta 2232)
                    Receiving objects: 100% (5140/5140), 4.17 MiB | 259.00 KiB/s, done.
                    Resolving deltas: 100% (2778/2778), done.
                    ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/Fast-DDS.git
                    Cloning into 'Fast-DDS'...
                    remote: 对象计数中: 135615, 完成.
                    remote: 压缩对象中: 100% (32890/32890), 完成.
                    remote: Total 135615 (delta 95894), reused 130935 (delta 92304)
                    Receiving objects: 100% (135615/135615), 92.97 MiB | 236.00 KiB/s, done.
                    Resolving deltas: 100% (95894/95894), done.
                    ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ git clone https://gitclone.com/github.com/eProsima/IDL-Parser.git
                    Cloning into 'IDL-Parser'...
                    remote: 对象计数中: 2496, 完成.
                    remote: 压缩对象中: 100% (1067/1067), 完成.
                    remote: Total 2496 (delta 1053), reused 1749 (delta 718)
                    Receiving objects: 100% (2496/2496), 551.12 KiB | 81.00 KiB/s, done.
                    Resolving deltas: 100% (1053/1053), done.
                    995455989 南京嵌入之梦南 2 条回复 最后回复 回复 引用 1
                    • 995455989
                      坚定 @99545598
                      ros2@ros2-virtual-machine:~/d2lros2/fastdds_ws$ ls
                      build fastrtps.repos gradle-6.4-bin.zip log
                      Fast-CDR foonathan_memory_vendor IDL-Parser src
                      Fast-DDS gradle-6.4 install
                      这样下载下来的文件怎么编译呢
                      • 995455989
                        坚定 @99545598
                        @99545598
                        pwd
                        /home/ros2/d2lros2/fastdds_ws
                        mv Fast-DDS foonathan_memory_vendor IDL-Parser ./src
                        12618461531 1 条回复 最后回复 回复 引用 0
                        • 12618461531
                          ゝ沉默の姿色 @99545598
                          有出现这个问题的吗?
                          • 28170249812
                            马克 ROS2开发者 @小鱼
                            @小鱼 vcs命令之后是这样的报错,不知道正常嘛,如果不正确有没有可以更正的方法
                              小鱼 技术大佬 @2817024981
                              @2817025981 不要放桌面
                              • 5
                                54997824 @小鱼
                                @小鱼 你好小鱼,这边还是不太行,能给个完整一些的代码吗?
                                以下是我改的,依然连接被拒绝:
                                repositories:
                                foonathan_memory_vendor:
                                type: git
                                url: https://github.fishros.org/https://github.com/eProsima/foonathan_memory_vendor.git
                                version: master
                                fastcdr:
                                type: git
                                url: https://github.fishros.org/https://github.com/eProsima/Fast-CDR.git
                                version: master
                                fastrtps:
                                type: git
                                url: https://github.fishros.org/https://github.com/eProsima/Fast-DDS.git
                                version: master
                                fastddsgen:
                                type: git
                                url: https://github.fishros.org/https://github.com/eProsima/Fast-DDS-Gen.git
                                version: master
                                fastddsgen/thirdparty/idl-parser:
                                type: git
                                url: https://github.fishros.org/https://github.com/eProsima/IDL-Parser.git
                                version: master
                                1 2 2 条回复 最后回复 回复 引用 0
                                  Supersonic @54997824
                                  @54997824
                                  fastrtps.repos内容这么写试试
                                  repositories:
                                          type: git
                                          url: https://github.com/eProsima/foonathan_memory_vendor.git
                                          version: master
                                      fastcdr:
                                          type: git
                                          url: https://github.com/eProsima/Fast-CDR.git
                                          version: master
                                      fastrtps:
                                          type: git
                                          url: https://github.com/eProsima/Fast-DDS.git
                                          version: master
                                      fastddsgen:
                                          type: git
                                          url: https://github.com/eProsima/Fast-DDS-Gen.git
                                          version: master
                                          type: git
                                          url: https://github.com/eProsima/IDL-Parser.git
                                          version: master
                                  Y 1 条回复 最后回复 回复 引用 1
                                    yunchuwei @1647546850
                                    @1647546850 还是不太行
                                      2974749756 @54997824
                                      @小鱼 这个问题还是解决不了
                                      • 南京嵌入之梦南
                                        南京嵌入之梦
                                        @小鱼 在 安装Fast DDS依赖项的 repos 文件时出现404:Not Found 中说:
                                        2817025981
                                        这个不安装对后面使用有影响吗?
                                        我也没有成功。
                                        • 南京嵌入之梦南
                                          南京嵌入之梦 @99545598
                                          @99545598 我按照你的方式分别下载了包,前面没有安装成功,但却生成了相关的目录。
                                          我按照内容将下载的拷贝到对应目录下(注意:那个Fast_DDS拷贝到 fastrpts,IDL-Parser拷贝到 fastddsgen\thirdparty下),后面就按照操作即可编译成功。
                                          不过我安装完成后,在后一遍编译DDS示例程序时失败了,出错提示:
                                          error: ‘DDS_CDR’ is not a member of ‘eprosima::fastcdr::Cdr’
                                          我又晕了,暂时搁置。
                                            liuzh297 @小鱼
                                            @小鱼 我手动编辑 fastrtps.repos,去掉 ghproxy.com 代理前缀:
                                            repositories:
                                                    type: git
                                                    version: master
                                                fastcdr:
                                                    type: git
                                                    version: master
                                                fastrtps:
                                                    type: git
                                                    version: master
                                                fastddsgen:
                                                    type: git
                                                    version: master
                                                    type: git
                                                    version: master
                                            然后clone成功
                                            Guided by GPT
