    容器未满足VS Code服务器的所有要求
    vscode终端 ubuntu 22.04 vscode服务器 容器 melodic
    • 12131121571
      studyhard
      在ubuntu22.04中一键安装melodic,安装成功,在vscode中打开容器失败
      vscode终端中显示如下:
      [66 ms] Dev Containers 0.338.1 in VS Code 1.86.0 (05047486b6df5eb8d44b2ecd70ea3bdf775fd937).
      [65 ms] Start: 正在解析远程
      [67 ms] Setting up container: /melodic1
      [68 ms] Start: Run: docker inspect --type container /melodic1
      [100 ms] Start: Check Docker is running
      [100 ms] Start: Run: docker version
      [130 ms] Client: Docker Engine - Community
       Version:           25.0.1
       API version:       1.44
       Go version:        go1.21.6
       Git commit:        29cf629
       Built:             Tue Jan 23 23:09:23 2024
       OS/Arch:           linux/amd64
       Context:           default
      Server: Docker Engine - Community
       Engine:
      [130 ms]   Version:          25.0.1
        API version:      1.44 (minimum version 1.24)
        Git commit:       71fa3ab
        Experimental:     false
       containerd:
        Version:          1.6.27
        GitCommit:        a1496014c916f9e62104b33d1bb5bd03b0858e59
       runc:
        Version:          1.1.11
        GitCommit:        v1.1.11-0-g4bccb38
       docker-init:
        Version:          0.19.0
        GitCommit:        de40ad0
      [133 ms] Start: Run: /usr/share/code/code /home/sun/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js set-up --container-id 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f --user-data-folder /home/sun/.config/Code/User/globalStorage/ms-vscode-remote.remote-containers/data --container-session-data-folder /tmp/devcontainers-3a928d76-8c29-4c02-8312-02a2e0c2b5b41706933479471 --log-level debug --log-format json --default-user-env-probe loginInteractiveShell --skip-post-create
      [580 ms] @devcontainers/cli 0.56.0. Node.js v18.17.1. linux 6.5.8-custom x64.
      [580 ms] Start: Run: docker buildx version
      [730 ms] github.com/docker/buildx v0.12.1 30feaa1
      [731 ms]
      [731 ms] Start: Run: docker inspect --type container 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f
      [753 ms] Start: Inspecting container
      [754 ms] Start: Run: docker inspect --type container 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f
      [775 ms] Start: Run in container: /bin/sh
      [780 ms] Start: Run in container: uname -m
      [861 ms] x86_64
      [861 ms]
      [861 ms] Start: Run in container: (cat /etc/os-release || cat /usr/lib/os-release) 2>/dev/null
      [863 ms] NAME="Ubuntu"
      VERSION="18.04.6 LTS (Bionic Beaver)"
      ID=ubuntu
      ID_LIKE=debian
      PRETTY_NAME="Ubuntu 18.04.6 LTS"
      VERSION_ID="18.04"
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      VERSION_CODENAME=bionic
      UBUNTU_CODENAME=bionic
      [864 ms]
      [864 ms] Start: Run in container:  (command -v getent >/dev/null 2>&1 && getent passwd 'root' || grep -E '^root|^[^:]*:[^:]*:root:' /etc/passwd || true)
      [867 ms] Start: Run in container: test -f '/var/devcontainer/.patchEtcEnvironmentMarker'
      [868 ms]
      [868 ms]
      [868 ms] Start: Run in container: test -f '/var/devcontainer/.patchEtcProfileMarker'
      [869 ms]
      [869 ms]
      [878 ms] Start: Run: /usr/share/code/code /home/sun/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js read-configuration --container-id 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f --log-level debug --log-format json --include-merged-configuration --mount-workspace-git-root
      [1202 ms] @devcontainers/cli 0.56.0. Node.js v18.17.1. linux 6.5.8-custom x64.
      [1202 ms] Start: Run: docker inspect --type container 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f
      [1226 ms] Start: Inspecting container
      [1226 ms] Start: Run: docker inspect --type container 1a88edfaa10e13445e9faed1b50a971791d72e959d678f5c2e3e215575507c0f
      [1247 ms] Start: Run in container: /bin/sh
      [1252 ms] Start: Run in container: uname -m
      [1327 ms] x86_64
      [1327 ms]
      [1327 ms] Start: Run in container: (cat /etc/os-release || cat /usr/lib/os-release) 2>/dev/null
      [1329 ms] NAME="Ubuntu"
      ID=ubuntu
      ID_LIKE=debian
      VERSION_ID="18.04"
      [1329 ms]
      [1329 ms] Start: Run in container:  (command -v getent >/dev/null 2>&1 && getent passwd 'root' || grep -E '^root|^[^:]*:[^:]*:root:' /etc/passwd || true)
      [1332 ms] Start: Run in container: test -d '/root/.vscode-server'
      [1333 ms]
      [1333 ms]
      [1333 ms] Start: Run in container: test ! -f '/root/.vscode-server/data/Machine/.writeMachineSettingsMarker' && set -o noclobber && mkdir -p '/root/.vscode-server/data/Machine' && { > '/root/.vscode-server/data/Machine/.writeMachineSettingsMarker' ; } 2> /dev/null
      [1335 ms]
      [1335 ms]
      [1335 ms] Exit code 1
      [1335 ms] Start: Run in container: cat /root/.vscode-server/data/Machine/settings.json
      [1337 ms]
      [1337 ms] cat: /root/.vscode-server/data/Machine/settings.json: No such file or directory
      [1337 ms] Exit code 1
      [1338 ms] Start: Run in container: test -d '/root/.vscode-server/bin/05047486b6df5eb8d44b2ecd70ea3bdf775fd937'
      [1338 ms]
      [1338 ms]
      [1339 ms] Start: Run in container: test -x '/root/.vscode-server/bin/05047486b6df5eb8d44b2ecd70ea3bdf775fd937/bin/helpers/check-requirements.sh'
      [1339 ms]
      [1339 ms]
      [1340 ms] Start: Run in container: '/root/.vscode-server/bin/05047486b6df5eb8d44b2ecd70ea3bdf775fd937/bin/helpers/check-requirements.sh'
      [1375 ms] Warning: Missing GLIBC >= 2.28! from /lib/x86_64-linux-gnu/libc-2.27.so
      Error: Missing required dependencies. Please refer to our FAQ https://aka.ms/vscode-remote/faq/old-linux for additional information.
      [1375 ms]
      [1375 ms] Exit code 99
      [1379 ms] Command in container failed: '/root/.vscode-server/bin/05047486b6df5eb8d44b2ecd70ea3bdf775fd937/bin/helpers/check-requirements.sh'
      [1379 ms] Warning: Missing GLIBC >= 2.28! from /lib/x86_64-linux-gnu/libc-2.27.so
      [1379 ms] Exit code 99
      ganyuanzhenG 2 条回复 最后回复 回复 引用 0
      • ganyuanzhenG
        Elysia 技术大佬 @1213112157
        @1213112157 你的VSCode版本过高。Ubuntu 18.04 的libc 太老了,VSCode不兼容。
        • ganyuanzhenG
          @1213112157 在 容器未满足VS Code服务器的所有要求 中说:
          看看能否升级容器内的libc版本
