    动手4.3.2报错
    cmake ros2
    6.7k
    • 5051060355
      looking。 @小鱼
      最后由 505106035 编辑
      消息定义文件如下:
      # 直接使用ROS2原始的数据类型
      string content
      # 图像消息,调用sensor_msgs下的Image类型
      sensor_msgs/Image image
      cmake.txt如下:
      project(village_interfaces)
      # Default to C99
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
      #添加对sensor_msgs的
      #添加消息文件和依赖
        #---msg---
        "msg/Novel.msg"
        DEPENDENCIES sensor_msgs
      if(BUILD_TESTING)
      endif()
      ament_package()
      目录结构如下:
      (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws/village_interfaces$ tree
      ├── CMakeLists.txt
      ├── include
      │   └── village_interfaces
      ├── msg
      │   └── Novel.msg
      ├── package.xml
      └── src
      4 directories, 3 files
      • 5051060355
        looking。
          小鱼 技术大佬 @505106035
          @505106035 复制粘贴你的代码我做了一下测试,编译没问题,除了packages.xml需要增加一个
          增加完后
          <?xml version="1.0"?>
          <package format="3">
            <name>village_interfaces</name>
            <version>0.0.0</version>
            <maintainer email="fishros@foxmail.com">pear</maintainer>
            <export>
            </export>
          </package>
          你可以试试
            小鱼 技术大佬 @小鱼
            @小鱼 确认上下文有ros2环境,试试colcon build指令(不加packages-select)
            5051060355 2 条回复 最后回复 回复 引用 0
            • 5051060355
              looking。 @小鱼
              @小鱼 不行。还是同样的报错。难道是我用的ubuntu18.04配置的ros2-eloquent这个版本和教程不一样?我看那个一键安装的ros2的脚本就只有到eloquent这个版本
              • 5051060355
                looking。 @小鱼
                如下:
                (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws$ ros2
                usage: ros2 [-h] Call `ros2 <command> -h` for more detailed usage. ...
                ros2 is an extensible command-line tool for ROS 2.
                optional arguments:
                  -h, --help            show this help message and exit
                Commands:
                  action     Various action related sub-commands
                  component  Various component related sub-commands
                  daemon     Various daemon related sub-commands
                  doctor     Check ROS setup and other potential issues
                  interface  Show information about ROS interfaces
                  launch     Run a launch file
                  lifecycle  Various lifecycle related sub-commands
                  msg        Various msg related sub-commands
                  multicast  Various multicast related sub-commands
                  node       Various node related sub-commands
                  param      Various param related sub-commands
                  pkg        Various package related sub-commands
                  run        Run a package specific executable
                  security   Various security related sub-commands
                  service    Various service related sub-commands
                  srv        Various srv related sub-commands
                  topic      Various topic related sub-commands
                  wtf        Use `wtf` as alias to `doctor`
                运行colcon build:
                (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws$ colcon build
                Starting >>> village_interfaces
                Starting >>> village_li
                Starting >>> village_wang
                Finished <<< village_wang [0.47s]
                --- stderr: village_interfaces
                CMake Error at /opt/ros/eloquent/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
                  CMakeLists.txt:24 (rosidl_generate_interfaces)
                CMake Error at /opt/ros/eloquent/share/rosidl_generator_cpp/cmake/rosidl_generator_cpp_generate_interfaces.cmake:57 (message):
                  Target dependency
                  '/town_ws/build/village_interfaces/rosidl_adapter/village_interfaces/msg/Novel.idl'
                  does not exist
                  /opt/ros/eloquent/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
                  /opt/ros/eloquent/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions)
                Failed   <<< village_interfaces [0.60s, exited with code 1]
                Aborted  <<< village_li [0.82s]
                Summary: 1 package finished [0.97s]
                  1 package failed: village_interfaces
                  1 package aborted: village_li
                  1 package had stderr output: village_interfaces
                还是一样的报错,就说cmake的错,
                简直头疼,不知道什么毛病。
                  小鱼 技术大佬 @505106035
                  @505106035 版本问题有很大可能,你用的版本已经停止维护有一段时间了。
                    小鱼 技术大佬 @505106035
                    @505106035 ubuntu18上没有foxy版本,只有ubuntu20才支持
                    5051060355 1 条回复 最后回复 回复 引用 0
                    • 5051060355
                      looking。 @小鱼
                      @小鱼 我用win电脑装了个vm配置了u20。装的ros2-rolling就好使。醉了
                        小鱼 技术大佬 @505106035
                        @505106035 ROS2前几个版本更新的很快,所以差异比较大
                        • 小鱼小 小鱼 将这个主题标记为已解决,在
                        • 7513651667
                          吉
                          • 7513651667
                            吉
                            最后由 751365166 编辑
                            @小鱼 鱼哥,我的系统版本是22.04.3,ROS版本是humble,和上面的问题有点类似,但感觉不太一样,应该怎么解决??
                            列表回复: 动手4.3.2报错
                            liu@liu-virtual-machine:~/桌面$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                            fatal: destination path 'fishbot' already exists and is not an empty directory.
                            liu@liu-virtual-machine:~/桌面$ cd fishbot
                            liu@liu-virtual-machine:~/桌面/fishbot$ rosdep install --from-paths src --ignore-src -y  -r # 安装依赖
                            liu@liu-virtual-machine:~/桌面/fishbot$ colcon build
                            Starting >>> fishbot_bringup
                            Finished <<< fishbot_cartographer [0.19s]
                            Finished <<< fishbot_bringup [0.28s]
                              Target dependency
                              does not exist
                            Failed   <<< fishbot_interfaces [0.44s, exited with code 1]
                            Aborted  <<< fishbot_description [0.56s]
                            Summary: 2 packages finished [1.20s]
                              1 package not processed
                            • ganyuanzhenG
                              Elysia 技术大佬 @751365166
                              @751365166 尽量避免路径中出现中文,这会产生很多未定义行为。(ROS开发者可不会想到你会输入除英文以外的路径哈哈
                              7513651667 1 条回复 最后回复 回复 引用 1
                              • 7513651667
                                吉 @ganyuanzhen
                                @ganyuanzhen 我懂了!!!感谢,问题出在,我应该新建一个英文名称的文件夹,然后在新建文件中运行终端命令!而不应该直接在桌面运行终端。
                                liu@liu-virtual-machine:~/ROS$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                Cloning into 'fishbot'...
                                remote: Total 84 (delta 21), reused 46 (delta 7), pack-reused 0
                                Receiving objects: 100% (84/84), 332.98 KiB | 422.00 KiB/s, done.
                                Resolving deltas: 100% (21/21), done.
                                liu@liu-virtual-machine:~/ROS$ cd fishbot
                                liu@liu-virtual-machine:~/ROS/fishbot$ rosdep install --from-paths src --ignore-src -y  -r # 安装依赖
                                liu@liu-virtual-machine:~/ROS/fishbot$ colcon build
                                Finished <<< fishbot_cartographer [0.53s]
                                Finished <<< fishbot_description [0.57s]
                                Finished <<< fishbot_interfaces [7.94s]
                                Finished <<< fishbot_navigation2 [0.63s]
                                Finished <<< fishbot_bringup [13.5s]
                                Summary: 5 packages finished [13.9s]
