    按crtl+c之后弹出信息:[INFO] [1713769737.106169624] [rclcpp]: signal_handler(signum=2)
    ros2 humble 问题 通信 ros
      gravity
      这是我在学习ros2通信基础的时候遇到的问题,以下是我的代码,我的代码和网上提供的代码整体逻辑应该是一致的,但是我在终端按crtl+c的时候会弹出signal_handler(signum=2),我不清楚这是什么意思;其次我还想请问:
      if (!rclcpp::ok())
      RCLCPP_ERROR(this->get_logger(), "等待服务的过程中被打断...");
      return;
      这段代码什么时候加上呢?我发现不加上这段代码,crtl+C就无法暂停我的程序
      wang2.cpp
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/string.hpp"
      #include "std_msgs/msg/u_int32.hpp"
      #include "village_interfaces/srv/sell_novel.hpp"
      #include <queue>
      using std::placeholders::_1;
      using std::placeholders::_2;
      创建一个类节点,名字叫做SingleDogNode,继承自Node.
      class SingleDogNode : public rclcpp::Node
      public:
      // 构造函数,有一个参数为节点名称
      SingleDogNode(std::string name) : Node(name)
      // 打印一句自我介绍
      RCLCPP_INFO(this->get_logger(), "大家好,我是单身狗%s.", name.c_str());
      // 创建一个订阅者来订阅李四写的小说,通过名字sexy_girl
      sub_novel = this->create_subscription<std_msgs::msg::String>("sexy_girl", 10, std::bind(&SingleDogNode::topic_callback, this, _1));
      // 创建发布者
      pub_money = this->create_publisher<std_msgs::msg::UInt32>("sexy_girl_money", 10);
          sell_novels_callback_group = this->create_callback_group(rclcpp::CallbackGroupType::MutuallyExclusive);
          sell_server = this->create_service<village_interfaces::srv::SellNovel>("sell_novel", std::bind(&SingleDogNode::sell_novel_callback, this, _1, _2),
        rmw_qos_profile_services_default, sell_novels_callback_group);
      private:
      std::queuestd::string novels_queue;
      // 声明一个订阅者(成员变量),用于订阅小说
      rclcpp::Subscription<std_msgs::msg::String>::SharedPtr sub_novel;
      // 声明一个发布者(成员变量),用于给李四钱
      rclcpp::Publisher<std_msgs::msg::UInt32>::SharedPtr pub_money;
      rclcpp::CallbackGroup::SharedPtr sell_novels_callback_group;
      rclcpp::Service<village_interfaces::srv::SellNovel>::SharedPtr sell_server;
      // maishu
      void sell_novel_callback(const village_interfaces::srv::SellNovel::Request::SharedPtr request,
                              const village_interfaces::srv::SellNovel::Response::SharedPtr response)
          RCLCPP_INFO(this->get_logger(), "shoudaole %d", request->money);
          unsigned int num = (int)request->money;
          if(num > novels_queue.size())
              RCLCPP_INFO(this->get_logger(), "%ld<%d", novels_queue.size(), num);
              rclcpp::Rate rate(1);
              while (novels_queue.size() < num)
                  if(!rclcpp::ok())
                      RCLCPP_ERROR(this->get_logger(), "程序被终止了");
                      return ;
                  RCLCPP_INFO(this->get_logger(), "%ld", num - novels_queue.size());
                  rate.sleep();
          RCLCPP_INFO(this->get_logger(), "%ld > %d", novels_queue.size(), num);
          for(int i = 0; i<(int)num; i++)
              response->novels.push_back(novels_queue.front());
              novels_queue.pop();
      // 收到话题数据的回调函数
      void topic_callback(const std_msgs::msg::String::SharedPtr msg)
          // 新建一张人民币
          std_msgs::msg::UInt32 money;
          money.data = 10;
          // 发送人民币给李四
          pub_money->publish(money);
          novels_queue.push(msg->data);
          RCLCPP_INFO(this->get_logger(), "朕已阅:'%s',打赏李四:%d 元的稿费", msg->data.c_str(), money.data);
      int main(int argc, char argv)
      rclcpp::init(argc, argv);
      /产生一个Wang2的节点/
      auto node = std::make_shared<SingleDogNode>("wang2");
      rclcpp::executors::MultiThreadedExecutor executor;
      executor.add_node(node);
      运行节点,并检测退出信号
      executor.spin();
      rclcpp::shutdown();
      return 0;
      zhang3.cpp#include "rclcpp/rclcpp.hpp"
      // 提前声明的占位符,留着创建客户端的时候用
      创建一个类节点,名字叫做PoorManNode,继承自Node.
      class PoorManNode : public rclcpp::Node
      public:
      /* 构造函数 */
      PoorManNode(std::string name) : Node(name)
      // 打印一句自我介绍
      RCLCPP_INFO(this->get_logger(), "大家好,我是得了穷病的张三.");
      novel_client = this->create_client<village_interfaces::srv::SellNovel>("sell_novel");
      void buy_novels()
          while (!novel_client->wait_for_service(std::chrono::seconds(1)))
              //等待时检测rclcpp的状态
              if (!rclcpp::ok())
                  return;
              RCLCPP_INFO(this->get_logger(), "等待服务端上线中");
          auto request = std::make_shared<village_interfaces::srv::SellNovel_Request>();
          request->money = 5;
          novel_client->async_send_request(request, std::bind(&PoorManNode::novels_callback, this, _1));
      private:
      rclcpp::Client<village_interfaces::srv::SellNovel>::SharedPtr novel_client;
      void novels_callback(rclcpp::Client<village_interfaces::srv::SellNovel>::SharedFuture response)
      auto result = response.get();
          RCLCPP_INFO(this->get_logger(), "ok %ld", result->novels.size());
          for(const std::string& novel:result->novels)
              RCLCPP_INFO(this->get_logger(), "%s", novel.c_str());
      /主函数/
      /产生一个Zhang3的节点/
      auto node = std::make_shared<PoorManNode>("zhang3");
      node->buy_novels();
      运行节点,并检测rclcpp状态
      rclcpp::spin(node);
      rclcpp::shutdown();
      return 0;
        小鱼 技术大佬 @3278537301
        @3278537301 在 按crtl+c之后弹出信息:[INFO] [1713769737.106169624] [rclcpp]: signal_handler(signum=2) 中说:
        这个没什么问题,收到了退出信号
