    更换源的问题,选择1会装失败(自己更换过源的情况下)
    一键安装报错 更换源的问题
    4.4k
    • 22298814592
      unbridle gang
        小鱼 技术大佬 @2229881459
        @2229881459 贴一下日志~~~
        6270705966 1 条回复 最后回复 回复 引用 0
        • 6270705966
          :-D @小鱼
          Run CMD Task:[sudo aptitude install ros-melodic-desktop-full -y]
          libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.58.0-2ubuntu3.22[/] libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.58.0-2ubuntu3.22[] libx11-dev : Depends: libx11-6 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5[-]Result:success ing 0 B will be used.upgraded.
          [-]Result:success e and 9 not upgraded.
          []python-rosdep2 - rosdep package manager abstraction tool for Robot OS (Python[-]Result:success nager abstraction tool for ROS
          [-]Result:code:2
          [-]Result:code:2
            小鱼 技术大佬 @627070596
            @627070596 全部日志,错误在上面
            6270705966 4 条回复 最后回复 回复 引用 0
            • 6270705966
              :-D @小鱼
              @小鱼 内容太长,我分开发
              RUN Choose Task:[请输入括号内的数字]
              请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
              [1]:melodic(ROS1)桌面版
              [2]:melodic(ROS1)基础版(小)
              [0]:quit
              请输入[]内的数字以选择:1
              [|]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]libcwidget-dev - high-level terminal interface library for C++ (development f[-]apticron-systemd - Simple tool to mail about pending package updates - system[]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[-]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[/]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[-]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[-]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[-]Result:success end for Debian
              [-]Result:success e and 0 not upgraded.
              Reading package lists... Done
              Building dependency tree
              Some packages could not be installed. This may mean that you have
              requested an impossible situation or if you are using the unstable
              distribution that some required packages have not yet been created
              or been moved out of Incoming.
              The following information may help to resolve the situation:
              ros-melodic-desktop-full : Depends: ros-melodic-desktop but it is not going to be installed
              Depends: ros-melodic-perception but it is not going to be installed
              Depends: ros-melodic-simulators but it is not going to be installed
              Depends: ros-melodic-urdf-sim-tutorial but it is not going to be installed
              E: Unable to correct problems, you have held broken packages.
              ros-melodic-desktop-full : Depends: ros-melodic-desktop but it is not going [/] Depends: ros-melodic-perception but it is not goi[] Depends: ros-melodic-simulators but it is not goi[|] Depends: ros-melodic-urdf-sim-tutorial but it is [-]Result:code:100
              确认了解情况,请输入回车继续安装
              • 6270705966
                :-D @小鱼
                Run CMD Task:[sudo aptitude install ros-melodic-desktop-full]
                The following NEW packages will be installed:
                cmake{a} cmake-data{a} cython{a} default-libmysqlclient-dev{a}
                dh-python{a} fltk1.3-doc{a} fluid{a} fonts-lato{a} freeglut3{a}
                freeglut3-dev{a} gazebo9{a} gazebo9-common{a} gazebo9-plugin-base{a}
                gdal-data{a} gir1.2-gtk-2.0{a} gir1.2-harfbuzz-0.0{a} google-mock{a}
                googletest{a} hddtemp{a} hdf5-helpers{a} ibverbs-providers{a}
                icu-devtools{a} libaacs0{a} libaec-dev{a} libaec0{a} libapr1{a}
                libapr1-dev{a} libaprutil1{a} libaprutil1-dev{a} libarmadillo-dev{a}
                libarmadillo8{a} libarpack2{a} libarpack2-dev{a} libass9{a}
                libassimp-dev{a} libassimp4{a} libassuan-dev{a} libatk1.0-dev{a}
                libavcodec-dev{a} libavcodec57{a} libavdevice-dev{a} libavdevice57{a}
                libavfilter-dev{a} libavfilter6{a} libavformat-dev{a} libavformat57{a}
                libavresample-dev{a} libavresample3{a} libavutil-dev{a} libavutil55{a}
                libbdplus0{a} libblas-dev{a} libblas3{a} libbluray2{a}
                libboost-all-dev{a} libboost-atomic-dev{a} libboost-atomic1.65-dev{a}
                libboost-atomic1.65.1{a} libboost-chrono-dev{a}
                libboost-chrono1.65-dev{a} libboost-chrono1.65.1{a}
                libboost-container-dev{a} libboost-container1.65-dev{a}
                libboost-container1.65.1{a} libboost-context-dev{a}
                libboost-context1.65-dev{a} libboost-context1.65.1{a}
                libboost-coroutine-dev{a} libboost-coroutine1.65-dev{a}
                libboost-coroutine1.65.1{a} libboost-date-time-dev{a}
                libboost-date-time1.65-dev{a} libboost-dev{a} libboost-exception-dev{a}
                libboost-exception1.65-dev{a} libboost-fiber-dev{a}
                libboost-fiber1.65-dev{a} libboost-fiber1.65.1{a}
                libboost-filesystem-dev{a} libboost-filesystem1.65-dev{a}
                libboost-graph-dev{a} libboost-graph-parallel-dev{a}
                libboost-graph-parallel1.65-dev{a} libboost-graph-parallel1.65.1{a}
                libboost-graph1.65-dev{a} libboost-graph1.65.1{a}
                libboost-iostreams-dev{a} libboost-iostreams1.65-dev{a}
                libboost-locale-dev{a} libboost-locale1.65-dev{a} libboost-log-dev{a}
                libboost-log1.65-dev{a} libboost-log1.65.1{a} libboost-math-dev{a}
                libboost-math1.65-dev{a} libboost-math1.65.1{a} libboost-mpi-dev{a}
                libboost-mpi-python-dev{a} libboost-mpi-python1.65-dev{a}
                libboost-mpi-python1.65.1{a} libboost-mpi1.65-dev{a}
                libboost-mpi1.65.1{a} libboost-numpy-dev{a} libboost-numpy1.65-dev{a}
                libboost-numpy1.65.1{a} libboost-program-options-dev{a}
                libboost-program-options1.65-dev{a} libboost-program-options1.65.1{a}
                libboost-python-dev{a} libboost-python1.65-dev{a}
                libboost-python1.65.1{a} libboost-random-dev{a}
                libboost-random1.65-dev{a} libboost-random1.65.1{a} libboost-regex-dev{a}
                libboost-regex1.65-dev{a} libboost-regex1.65.1{a}
                libboost-serialization-dev{a} libboost-serialization1.65-dev{a}
                libboost-serialization1.65.1{a} libboost-signals-dev{a}
                libboost-signals1.65-dev{a} libboost-signals1.65.1{a}
                libboost-stacktrace-dev{a} libboost-stacktrace1.65-dev{a}
                libboost-stacktrace1.65.1{a} libboost-system-dev{a}
                libboost-system1.65-dev{a} libboost-test-dev{a} libboost-test1.65-dev{a}
                libboost-test1.65.1{a} libboost-thread-dev{a} libboost-thread1.65-dev{a}
                libboost-timer-dev{a} libboost-timer1.65-dev{a} libboost-timer1.65.1{a}
                libboost-tools-dev{a} libboost-type-erasure-dev{a}
                libboost-type-erasure1.65-dev{a} libboost-type-erasure1.65.1{a}
                libboost-wave-dev{a} libboost-wave1.65-dev{a} libboost-wave1.65.1{a}
                libboost1.65-dev{a} libboost1.65-tools-dev{a} libbs2b0{a}
                libbullet-dev{a} libbullet2.87{a} libbz2-dev{a}
                libcairo-script-interpreter2{a} libcairo2-dev{a} libccd-dev{a} libccd2{a}
                libcharls1{a} libchromaprint1{a} libconsole-bridge-dev{a}
                libconsole-bridge0.4{a} libcurl4-gnutls-dev{ab} libcurl4-openssl-dev{ab}
                libdap-dev{a} libdap25{a} libdapclient6v5{a} libdapserver7v5{a}
                libdc1394-22{a} libdc1394-22-dev{a} libdrm-dev{a} libdrm-etnaviv1{a}
                libdrm-freedreno1{a} libdrm-tegra0{a} libegl1-mesa-dev{a}
                libeigen3-dev{a} libepsilon-dev{a} libepsilon1{a} libexif-dev{a}
                libexif-doc{a} libexpat1-dev{a} libflann-dev{a} libflann1.9{a}
                libflite1{a} libfltk-cairo1.3{a} libfltk-forms1.3{a} libfltk-gl1.3{a}
                libfltk-images1.3{a} libfltk1.3{a} libfltk1.3-dev{a}
                libfontconfig1-dev{a} libfreeimage-dev{a} libfreeimage3{a}
                libfreetype6-dev{a} libfreexl-dev{a} libfreexl1{a} libfyba-dev{a}
                libfyba0{a} libgazebo9{a} libgazebo9-dev{a} libgdal-dev{a} libgdal20{a}
                libgdcm2-dev{a} libgdcm2.8{a} libgdk-pixbuf2.0-dev{a} libgeos-3.6.2{a}
                libgeos-c1v5{a} libgeos-dev{a} libgeotiff-dev{a} libgeotiff2{a}
                libgfortran4{a} libgif-dev{a} libgif7{a} libgl1-mesa-dev{a}
                libgl2ps-dev{a} libgl2ps1.4{a} libgles1{a} libgles2-mesa-dev{a}
                libglib2.0-dev{a} libglib2.0-dev-bin{a} libglu1-mesa-dev{a}
                libglvnd-core-dev{a} libglvnd-dev{a} libgme0{a} libgpg-error-dev{a}
                libgpgme-dev{ab} libgphoto2-dev{a} libgraphite2-dev{a} libgraphviz-dev{a}
                libgsm1{a} libgtest-dev{a} libgtk2.0-dev{a} libgts-dev{a}
                libgvc6-plugins-gtk{a} libharfbuzz-dev{a} libharfbuzz-gobject0{a}
                libhdf4-0-alt{a} libhdf4-alt-dev{a} libhdf5-100{a} libhdf5-cpp-100{a}
                libhdf5-dev{a} libhdf5-mpi-dev{a} libhdf5-openmpi-100{a}
                libhdf5-openmpi-dev{a} libhwloc-dev{a} libhwloc-plugins{a} libhwloc5{a}
                libibverbs-dev{a} libibverbs1{a} libice-dev{a} libicu-dev{a}
                libicu-le-hb-dev{a} libicu-le-hb0{a} libiculx60{a}
                libignition-cmake-dev{a} libignition-common{a} libignition-common-dev{a}
                libignition-fuel-tools1-1{a} libignition-fuel-tools1-dev{a}
                libignition-math4{a} libignition-math4-dev{a} libignition-msgs{a}
                libignition-msgs-dev{a} libignition-transport4{a}
                libignition-transport4-dev{a} libilmbase-dev{a} libjbig-dev{a}
                libjpeg-dev{a} libjpeg-turbo8-dev{a} libjpeg8-dev{a} libjs-jquery-ui{a}
                libjson-c-dev{a} libjsoncpp-dev{a} libjsoncpp1{a} libjxr0{a}
                libkml-dev{a} libkmlbase1{a} libkmlconvenience1{a} libkmldom1{a}
                libkmlengine1{a} libkmlregionator1{a} libkmlxsd1{a} liblapack-dev{a}
                liblapack3{a} libldap2-dev{a} liblept5{a} liblog4cxx-dev{a}
                liblog4cxx10v5{a} liblz4-dev{a} liblzma-dev{a} libminizip-dev{a}
                libminizip1{a} libmysofa0{a} libmysqlclient-dev{a} libnetcdf-c++4{a}
                libnetcdf-cxx-legacy-dev{a} libnetcdf-dev{a} libnetcdf13{a}
                libnl-route-3-200{a} libnorm1{a} libnuma-dev{a} libodbc1{a} libogdi3.2{a}
                libogdi3.2-dev{a} libogg-dev{a} libogre-1.9-dev{a} libogre-1.9.0v5{a}
                libopenal-data{a} libopenal-dev{a} libopenal1{a} libopencv-calib3d-dev{a}
                libopencv-calib3d3.2{a} libopencv-contrib-dev{a} libopencv-contrib3.2{a}
                libopencv-core-dev{a} libopencv-core3.2{a} libopencv-dev{a}
                libopencv-features2d-dev{a} libopencv-features2d3.2{a}
                libopencv-flann-dev{a} libopencv-flann3.2{a} libopencv-highgui-dev{a}
                libopencv-highgui3.2{a} libopencv-imgcodecs-dev{a}
                libopencv-imgcodecs3.2{a} libopencv-imgproc-dev{a}
                libopencv-imgproc3.2{a} libopencv-ml-dev{a} libopencv-ml3.2{a}
                libopencv-objdetect-dev{a} libopencv-objdetect3.2{a}
                libopencv-photo-dev{a} libopencv-photo3.2{a} libopencv-shape-dev{a}
                libopencv-shape3.2{a} libopencv-stitching-dev{a}
                libopencv-stitching3.2{a} libopencv-superres-dev{a}
                libopencv-superres3.2{a} libopencv-ts-dev{a} libopencv-video-dev{a}
                libopencv-video3.2{a} libopencv-videoio-dev{a} libopencv-videoio3.2{a}
                libopencv-videostab-dev{a} libopencv-videostab3.2{a} libopencv-viz-dev{a}
                libopencv-viz3.2{a} libopencv3.2-java{a} libopencv3.2-jni{a}
                libopenexr-dev{a} libopengl0{a} libopenjp2-7{a} libopenjp2-7-dev{a}
                libopenmpi-dev{a} libopenmpi2{a} libopenmpt0{a} libopenni-dev{a}
                libopenni-sensor-pointclouds0{a} libopenni0{a} libopenni2-0{a}
                libopenni2-dev{a} libpango1.0-dev{a} libpcl-apps1.8{a}
                libpcl-common1.8{a} libpcl-dev{a} libpcl-features1.8{a}
                libpcl-filters1.8{a} libpcl-io1.8{a} libpcl-kdtree1.8{a}
                libpcl-keypoints1.8{a} libpcl-ml1.8{a} libpcl-octree1.8{a}
                libpcl-outofcore1.8{a} libpcl-people1.8{a} libpcl-recognition1.8{a}
                libpcl-registration1.8{a} libpcl-sample-consensus1.8{a}
                libpcl-search1.8{a} libpcl-segmentation1.8{a} libpcl-stereo1.8{a}
                libpcl-surface1.8{a} libpcl-tracking1.8{a} libpcl-visualization1.8{a}
                libpcre16-3{a} libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a}
                libpgm-5.2-0{a} libpixman-1-dev{a} libpng-dev{a} libpng-tools{a}
                libpoco-dev{a} libpococrypto50{a} libpocodata50{a} libpocodatamysql50{a}
                libpocodataodbc50{a} libpocodatasqlite50{a} libpocofoundation50{a}
                libpocojson50{a} libpocomongodb50{a} libpoconet50{a} libpoconetssl50{a}
                libpocoredis50{a} libpocoutil50{a} libpocoxml50{a} libpocozip50{a}
                libpoppler-dev{a} libpoppler-private-dev{a} libpostproc-dev{a}
                libpostproc54{a} libpq-dev{a} libpq5{a} libproj-dev{a} libproj12{a}
                libprotobuf-dev{a} libprotobuf-lite10{a} libprotoc-dev{a} libprotoc10{a}
                libpthread-stubs0-dev{a} libpython-dev{a} libpython2.7-dev{a}
                libpython3-dev{a} libpython3.6-dev{a} libqhull-dev{a} libqhull-r7{a}
                libqhull7{a} libqt5concurrent5{a} libqt5designer5{a}
                libqt5designercomponents5{a} libqt5help5{a} libqt5opengl5{a}
                libqt5opengl5-dev{a} libqt5positioning5{a} libqt5printsupport5{a}
                libqt5qml5{a} libqt5quick5{a} libqt5quickparticles5{a}
                libqt5quicktest5{a} libqt5quickwidgets5{a} libqt5sensors5{a}
                libqt5sql5{a} libqt5sql5-sqlite{a} libqt5test5{a} libqt5webchannel5{a}
                libqt5webkit5{a} libqt5webkit5-dev{a} libqt5xml5{a}
                libqtpropertybrowser4{a} libqwt-headers{a} libqwt-qt5-6{a}
                libqwt-qt5-dev{a} libraw1394-dev{a} libraw1394-tools{a} librhash0{a}
                librubberband2{a} libruby2.5{a} libsctp-dev{a} libsctp1{a}
                libsdformat6{a} libsdformat6-dev{a} libsdl2-2.0-0{a} libshine3{a}
                libsimbody-dev{a} libsimbody3.5v5{a} libsm-dev{a} libsnappy1v5{a}
                libsocket++1{a} libsoxr0{a} libspatialite-dev{a} libspatialite7{a}
                libspnav0{a} libsqlite3-dev{a} libssh-gcrypt-4{a} libssl-dev{a}
                libsuperlu-dev{a} libsuperlu5{a} libswresample-dev{a} libswresample2{a}
                libswscale-dev{a} libswscale4{a} libsz2{a} libtar-dev{a} libtar0{a}
                libtbb-dev{a} libtbb2{a} libtesseract4{a} libtheora-dev{a} libtiff-dev{a}
                libtiff5-dev{a} libtiffxx5{a} libtinyxml-dev{a} libtinyxml2-6{a}
                libtinyxml2-dev{a} liburdfdom-dev{a} liburdfdom-headers-dev{a}
                liburdfdom-model{a} liburdfdom-model-state{a} liburdfdom-sensor{a}
                liburdfdom-world{a} liburiparser-dev{a} liburiparser1{a}
                libusb-1.0-0-dev{a} libusb-1.0-doc{a} libva-drm2{a} libva-x11-2{a}
                libva2{a} libvdpau1{a} libvtk6-dev{a} libvtk6-java{a} libvtk6-jni{a}
                libvtk6-qt-dev{a} libvtk6.3{a} libvtk6.3-qt{a} libwayland-bin{a}
                libwayland-dev{a} libwebp-dev{a} libwxbase3.0-0v5{a}
                libwxgtk3.0-gtk3-0v5{a} libx11-dev{ab} libx11-doc{a} libx11-xcb-dev{ab}
                libx264-152{a} libx265-146{a} libxau-dev{a} libxcb-dri2-0-dev{a}
                libxcb-dri3-dev{a} libxcb-glx0-dev{a} libxcb-present-dev{a}
                libxcb-randr0-dev{a} libxcb-render0-dev{a} libxcb-shape0-dev{a}
                libxcb-shm0-dev{a} libxcb-sync-dev{a} libxcb-xfixes0-dev{a}
                libxcb1-dev{a} libxcomposite-dev{a} libxcursor-dev{a} libxdamage-dev{a}
                libxdmcp-dev{a} libxdot4{a} libxerces-c-dev{a} libxerces-c3.2{a}
                libxext-dev{a} libxfixes-dev{a} libxft-dev{a} libxi-dev{a}
                libxinerama-dev{a} libxml2-dev{a} libxml2-utils{a} libxmu-dev{a}
                libxmu-headers{a} libxrandr-dev{a} libxrender-dev{a} libxshmfence-dev{a}
                libxss-dev{a} libxt-dev{a} libxvidcore4{a} libxxf86vm-dev{a}
                libyaml-cpp-dev{a} libyaml-cpp0.5v5{a} libyaml-dev{a} libzip-dev{a}
                libzip4{a} libzmq3-dev{a} libzmq5{a} libzvbi-common{a} libzvbi0{a}
                libzzip-0-13{a} mesa-common-dev{a} mesa-va-drivers{a}
                mesa-vdpau-drivers{a} mpi-default-bin{a} mpi-default-dev{a} odbcinst{a}
                odbcinst1debian2{a} opencv-data{a} openmpi-bin{a} openmpi-common{a}
                openni-utils{a} pkg-config{a} proj-bin{a} proj-data{a}
                protobuf-compiler{a} pyqt5-dev{a} python-asn1crypto{a} python-attr{a}
                python-autobahn{a} python-automat{a}
                python-backports.functools-lru-cache{a} python-cairo{a} python-cbor{a}
                python-cffi-backend{a} python-click{a} python-colorama{a}
                python-constantly{a} python-cryptography{a} python-cycler{a}
                python-defusedxml{a} python-dev{a} python-empy{a} python-enum34{a}
                python-gnupg{a} python-hyperlink{a} python-idna{a} python-incremental{a}
                python-ipaddress{a} python-lz4{a} python-matplotlib{a}
                python-matplotlib-data{a} python-mpi4py{a} python-nacl{a}
                python-netifaces{a} python-nose{a} python-numpy{a} python-opencv{a}
                python-opengl{a} python-openssl{a} python-pam{a} python-paramiko{a}
                python-psutil{a} python-pyasn1{a} python-pyasn1-modules{a}
                python-pycryptodome{a} python-pydot{a} python-pyqt5{a}
                python-pyqt5.qtopengl{a} python-pyqt5.qtsvg{a} python-pyqt5.qtwebkit{a}
                python-qrcode{a} python-rospkg{a} python-serial{a}
                python-service-identity{a} python-sip{a} python-sip-dev{a}
                python-snappy{a} python-subprocess32{a} python-trie{a} python-twisted{a}
                python-twisted-bin{a} python-twisted-core{a} python-txaio{a} python-tz{a}
                python-u-msgpack{a} python-ubjson{a} python-vtk6{a} python-wsaccel{a}
                python-wxgtk3.0{a} python-wxtools{a} python-wxversion{a}
                python-zope.interface{a} python2.7-dev{a} python3-dev{a}
                python3-distutils{a} python3-lib2to3{a} python3.6-dev{a} qt5-assistant{a}
                qt5-qmake{a} qt5-qmake-bin{a} qt5-qmltooling-plugins{a} qtbase5-dev{a}
                qtbase5-dev-tools{a} qtdeclarative5-dev{a} qttools5-dev{a}
                qttools5-dev-tools{a} qttools5-private-dev{a} rake{a}
                ros-melodic-actionlib{a} ros-melodic-actionlib-msgs{a}
                ros-melodic-actionlib-tutorials{a} ros-melodic-angles{a}
                ros-melodic-bond{a} ros-melodic-bond-core{a} ros-melodic-bondcpp{a}
                ros-melodic-bondpy{a} ros-melodic-camera-calibration{a}
                ros-melodic-camera-calibration-parsers{a}
                ros-melodic-camera-info-manager{a} ros-melodic-catkin{a}
                ros-melodic-class-loader{a} ros-melodic-cmake-modules{a}
                ros-melodic-common-msgs{a} ros-melodic-common-tutorials{a}
                ros-melodic-compressed-depth-image-transport{a}
                ros-melodic-compressed-image-transport{a} ros-melodic-control-msgs{a}
                ros-melodic-control-toolbox{a} ros-melodic-controller-interface{a}
                ros-melodic-controller-manager{a} ros-melodic-controller-manager-msgs{a}
                ros-melodic-cpp-common{a} ros-melodic-cv-bridge{a}
                ros-melodic-depth-image-proc{a} ros-melodic-desktop{a}
                ros-melodic-desktop-full ros-melodic-diagnostic-aggregator{a}
                ros-melodic-diagnostic-analysis{a}
                ros-melodic-diagnostic-common-diagnostics{a}
                ros-melodic-diagnostic-msgs{a} ros-melodic-diagnostic-updater{a}
                ros-melodic-diagnostics{a} ros-melodic-diff-drive-controller{a}
                ros-melodic-dynamic-reconfigure{a} ros-melodic-eigen-conversions{a}
                ros-melodic-executive-smach{a} ros-melodic-filters{a}
                ros-melodic-forward-command-controller{a} ros-melodic-gazebo-dev{a}
                ros-melodic-gazebo-msgs{a} ros-melodic-gazebo-plugins{a}
                ros-melodic-gazebo-ros{a} ros-melodic-gazebo-ros-control{a}
                ros-melodic-gazebo-ros-pkgs{a} ros-melodic-gencpp{a}
                ros-melodic-geneus{a} ros-melodic-genlisp{a} ros-melodic-genmsg{a}
                ros-melodic-gennodejs{a} ros-melodic-genpy{a} ros-melodic-geometry{a}
                ros-melodic-geometry-msgs{a} ros-melodic-geometry-tutorials{a}
                ros-melodic-gl-dependency{a} ros-melodic-hardware-interface{a}
                ros-melodic-image-common{a} ros-melodic-image-geometry{a}
                ros-melodic-image-pipeline{a} ros-melodic-image-proc{a}
                ros-melodic-image-publisher{a} ros-melodic-image-rotate{a}
                ros-melodic-image-transport{a} ros-melodic-image-transport-plugins{a}
                ros-melodic-image-view{a} ros-melodic-interactive-marker-tutorials{a}
                ros-melodic-interactive-markers{a} ros-melodic-joint-limits-interface{a}
                ros-melodic-joint-state-controller{a}
                ros-melodic-joint-state-publisher{a} ros-melodic-kdl-conversions{a}
                ros-melodic-kdl-parser{a} ros-melodic-kdl-parser-py{a}
                ros-melodic-laser-assembler{a} ros-melodic-laser-filters{a}
                ros-melodic-laser-geometry{a} ros-melodic-laser-pipeline{a}
                ros-melodic-librviz-tutorial{a} ros-melodic-map-msgs{a}
                ros-melodic-media-export{a} ros-melodic-message-filters{a}
                ros-melodic-message-generation{a} ros-melodic-message-runtime{a}
                ros-melodic-mk{a} ros-melodic-nav-msgs{a} ros-melodic-nodelet{a}
                ros-melodic-nodelet-core{a} ros-melodic-nodelet-topic-tools{a}
                ros-melodic-nodelet-tutorial-math{a} ros-melodic-orocos-kdl{a}
                ros-melodic-pcl-conversions{a} ros-melodic-pcl-msgs{a}
                ros-melodic-pcl-ros{a} ros-melodic-perception{a}
                ros-melodic-perception-pcl{a} ros-melodic-pluginlib{a}
                ros-melodic-pluginlib-tutorials{a} ros-melodic-polled-camera{a}
                ros-melodic-position-controllers{a} ros-melodic-python-orocos-kdl{a}
                ros-melodic-python-qt-binding{a} ros-melodic-qt-dotgraph{a}
                ros-melodic-qt-gui{a} ros-melodic-qt-gui-cpp{a}
                ros-melodic-qt-gui-py-common{a} ros-melodic-qwt-dependency{a}
                ros-melodic-realtime-tools{a} ros-melodic-resource-retriever{a}
                ros-melodic-robot{a} ros-melodic-robot-state-publisher{a}
                ros-melodic-ros{a} ros-melodic-ros-base{a} ros-melodic-ros-comm{a}
                ros-melodic-ros-core{a} ros-melodic-ros-environment{a}
                ros-melodic-ros-tutorials{a} ros-melodic-rosbag{a}
                ros-melodic-rosbag-migration-rule{a} ros-melodic-rosbag-storage{a}
                ros-melodic-rosbash{a} ros-melodic-rosboost-cfg{a}
                ros-melodic-rosbuild{a} ros-melodic-rosclean{a} ros-melodic-rosconsole{a}
                ros-melodic-rosconsole-bridge{a} ros-melodic-roscpp{a}
                ros-melodic-roscpp-core{a} ros-melodic-roscpp-serialization{a}
                ros-melodic-roscpp-traits{a} ros-melodic-roscpp-tutorials{a}
                ros-melodic-roscreate{a} ros-melodic-rosgraph{a}
                ros-melodic-rosgraph-msgs{a} ros-melodic-roslang{a}
                ros-melodic-roslaunch{a} ros-melodic-roslib{a} ros-melodic-roslint{a}
                ros-melodic-roslisp{a} ros-melodic-roslz4{a} ros-melodic-rosmake{a}
                ros-melodic-rosmaster{a} ros-melodic-rosmsg{a} ros-melodic-rosnode{a}
                ros-melodic-rosout{a} ros-melodic-rospack{a} ros-melodic-rosparam{a}
                ros-melodic-rospy{a} ros-melodic-rospy-tutorials{a}
                ros-melodic-rosservice{a} ros-melodic-rostest{a} ros-melodic-rostime{a}
                ros-melodic-rostopic{a} ros-melodic-rosunit{a} ros-melodic-roswtf{a}
                ros-melodic-rqt-action{a} ros-melodic-rqt-bag{a}
                ros-melodic-rqt-bag-plugins{a} ros-melodic-rqt-common-plugins{a}
                ros-melodic-rqt-console{a} ros-melodic-rqt-dep{a}
                ros-melodic-rqt-graph{a} ros-melodic-rqt-gui{a}
                ros-melodic-rqt-gui-cpp{a} ros-melodic-rqt-gui-py{a}
                ros-melodic-rqt-image-view{a} ros-melodic-rqt-launch{a}
                ros-melodic-rqt-logger-level{a} ros-melodic-rqt-moveit{a}
                ros-melodic-rqt-msg{a} ros-melodic-rqt-nav-view{a}
                ros-melodic-rqt-plot{a} ros-melodic-rqt-pose-view{a}
                ros-melodic-rqt-publisher{a} ros-melodic-rqt-py-common{a}
                ros-melodic-rqt-py-console{a} ros-melodic-rqt-reconfigure{a}
                ros-melodic-rqt-robot-dashboard{a} ros-melodic-rqt-robot-monitor{a}
                ros-melodic-rqt-robot-plugins{a} ros-melodic-rqt-robot-steering{a}
                ros-melodic-rqt-runtime-monitor{a} ros-melodic-rqt-rviz{a}
                ros-melodic-rqt-service-caller{a} ros-melodic-rqt-shell{a}
                ros-melodic-rqt-srv{a} ros-melodic-rqt-tf-tree{a} ros-melodic-rqt-top{a}
                ros-melodic-rqt-topic{a} ros-melodic-rqt-web{a} ros-melodic-rviz{a}
                ros-melodic-rviz-plugin-tutorials{a} ros-melodic-rviz-python-tutorial{a}
                ros-melodic-self-test{a} ros-melodic-sensor-msgs{a}
                ros-melodic-shape-msgs{a} ros-melodic-simulators{a} ros-melodic-smach{a}
                ros-melodic-smach-msgs{a} ros-melodic-smach-ros{a} ros-melodic-smclib{a}
                ros-melodic-stage{a} ros-melodic-stage-ros{a} ros-melodic-std-msgs{a}
                ros-melodic-std-srvs{a} ros-melodic-stereo-image-proc{a}
                ros-melodic-stereo-msgs{a} ros-melodic-tf{a}
                ros-melodic-tf-conversions{a} ros-melodic-tf2{a} ros-melodic-tf2-eigen{a}
                ros-melodic-tf2-geometry-msgs{a} ros-melodic-tf2-kdl{a}
                ros-melodic-tf2-msgs{a} ros-melodic-tf2-py{a} ros-melodic-tf2-ros{a}
                ros-melodic-theora-image-transport{a} ros-melodic-topic-tools{a}
                ros-melodic-trajectory-msgs{a} ros-melodic-transmission-interface{a}
                ros-melodic-turtle-actionlib{a} ros-melodic-turtle-tf{a}
                ros-melodic-turtle-tf2{a} ros-melodic-turtlesim{a} ros-melodic-urdf{a}
                ros-melodic-urdf-parser-plugin{a} ros-melodic-urdf-sim-tutorial{a}
                ros-melodic-urdf-tutorial{a} ros-melodic-urdfdom-py{a}
                ros-melodic-vision-opencv{a}
                ros-melodic-visualization-marker-tutorials{a}
                ros-melodic-visualization-msgs{a} ros-melodic-visualization-tutorials{a}
                ros-melodic-viz{a} ros-melodic-webkit-dependency{a} ros-melodic-xacro{a}
                ros-melodic-xmlrpcpp{a} ruby{a} ruby-did-you-mean{a} ruby-minitest{a}
                ruby-net-telnet{a} ruby-power-assert{a} ruby-test-unit{a} ruby2.5{a}
                rubygems-integration{a} sbcl{a} sdformat-sdf{a} sip-dev{a} tcl-dev{a}
                tcl-vtk6{a} tcl8.6-dev{a} tk-dev{a} tk8.6-dev{a} ttf-dejavu-core{a}
                unixodbc-dev{a} uuid-dev{a} va-driver-all{a} vdpau-driver-all{a} vtk6{a}
                x11proto-composite-dev{a} x11proto-core-dev{a} x11proto-damage-dev{a}
                x11proto-dev{a} x11proto-fixes-dev{a} x11proto-input-dev{a}
                x11proto-randr-dev{a} x11proto-scrnsaver-dev{a} x11proto-xext-dev{a}
                x11proto-xf86vidmode-dev{a} x11proto-xinerama-dev{a}
                xorg-sgml-doctools{a} xtrans-dev{a} zlib1g-dev{a}
                0 packages upgraded, 935 newly installed, 0 to remove and 0 not upgraded.
                Need to get 450 MB of archives. After unpacking 2,082 MB will be used.
                libx11-xcb-dev : Depends: libx11-xcb1 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5 is installed
                libgpgme-dev : Depends: libgpgme11 (= 1.10.0-1ubuntu2) but 1.10.0-1ubuntu2.1 is installed
                libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.58.0-2ubuntu3.22 is to be installed
                libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.58.0-2ubuntu3.22 is to be installed
                libx11-dev : Depends: libx11-6 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5 is installed
                The following actions will resolve these dependencies:
                   Keep the following packages at their current version:
                1.   freeglut3-dev [Not Installed]
                2.   libcairo2-dev [Not Installed]
                3.   libcurl4-gnutls-dev [Not Installed]
                4.   libegl1-mesa-dev [Not Installed]
                5.   libfltk1.3-dev [Not Installed]
                6.   libgazebo9-dev [Not Installed]
                7.   libgdk-pixbuf2.0-dev [Not Installed]
                8.   libgl1-mesa-dev [Not Installed]
                9.   libgles2-mesa-dev [Not Installed]
                10.  libglu1-mesa-dev [Not Installed]
                11.  libgpgme-dev [Not Installed]
                12.  libgtk2.0-dev [Not Installed]
                13.  libpango1.0-dev [Not Installed]
                14.  libpcl-dev [Not Installed]
                15.  libqt5opengl5-dev [Not Installed]
                16.  libqt5webkit5-dev [Not Installed]
                17.  libsimbody-dev [Not Installed]
                18.  libvtk6-dev [Not Installed]
                19.  libvtk6-qt-dev [Not Installed]
                20.  libx11-dev [Not Installed]
                21.  libx11-xcb-dev [Not Installed]
                22.  libxcomposite-dev [Not Installed]
                23.  libxcursor-dev [Not Installed]
                24.  libxdamage-dev [Not Installed]
                25.  libxext-dev [Not Installed]
                26.  libxfixes-dev [Not Installed]
                27.  libxft-dev [Not Installed]
                28.  libxi-dev [Not Installed]
                29.  libxinerama-dev [Not Installed]
                30.  libxmu-dev [Not Installed]
                31.  libxmu-headers [Not Installed]
                32.  libxrandr-dev [Not Installed]
                33.  libxrender-dev [Not Installed]
                34.  libxss-dev [Not Installed]
                35.  libxt-dev [Not Installed]
                36.  libxxf86vm-dev [Not Installed]
                37.  mesa-common-dev [Not Installed]
                38.  qtbase5-dev [Not Installed]
                39.  qtdeclarative5-dev [Not Installed]
                40.  qttools5-dev [Not Installed]
                41.  qttools5-private-dev [Not Installed]
                42.  ros-melodic-actionlib [Not Installed]
                43.  ros-melodic-actionlib-tutorials [Not Installed]
                44.  ros-melodic-common-tutorials [Not Installed]
                45.  ros-melodic-compressed-depth-image-transport [Not Installed]
                46.  ros-melodic-compressed-image-transport [Not Installed]
                47.  ros-melodic-control-toolbox [Not Installed]
                48.  ros-melodic-controller-manager [Not Installed]
                49.  ros-melodic-controller-manager-msgs [Not Installed]
                50.  ros-melodic-depth-image-proc [Not Installed]
                51.  ros-melodic-desktop [Not Installed]
                52.  ros-melodic-desktop-full [Not Installed]
                53.  ros-melodic-diagnostic-analysis [Not Installed]
                54.  ros-melodic-diagnostic-common-diagnostics [Not Installed]
                55.  ros-melodic-diagnostics [Not Installed]
                56.  ros-melodic-diff-drive-controller [Not Installed]
                57.  ros-melodic-dynamic-reconfigure [Not Installed]
                58.  ros-melodic-executive-smach [Not Installed]
                59.  ros-melodic-forward-command-controller [Not Installed]
                60.  ros-melodic-gazebo-dev [Not Installed]
                61.  ros-melodic-gazebo-plugins [Not Installed]
                62.  ros-melodic-gazebo-ros [Not Installed]
                63.  ros-melodic-gazebo-ros-control [Not Installed]
                64.  ros-melodic-gazebo-ros-pkgs [Not Installed]
                65.  ros-melodic-geometry [Not Installed]
                66.  ros-melodic-geometry-tutorials [Not Installed]
                67.  ros-melodic-image-pipeline [Not Installed]
                68.  ros-melodic-image-proc [Not Installed]
                69.  ros-melodic-image-publisher [Not Installed]
                70.  ros-melodic-image-rotate [Not Installed]
                71.  ros-melodic-image-transport-plugins [Not Installed]
                72.  ros-melodic-image-view [Not Installed]
                73.  ros-melodic-interactive-marker-tutorials [Not Installed]
                74.  ros-melodic-interactive-markers [Not Installed]
                75.  ros-melodic-joint-state-controller [Not Installed]
                76.  ros-melodic-laser-assembler [Not Installed]
                77.  ros-melodic-laser-filters [Not Installed]
                78.  ros-melodic-laser-geometry [Not Installed]
                79.  ros-melodic-laser-pipeline [Not Installed]
                80.  ros-melodic-librviz-tutorial [Not Installed]
                81.  ros-melodic-nodelet-core [Not Installed]
                82.  ros-melodic-nodelet-topic-tools [Not Installed]
                83.  ros-melodic-pcl-conversions [Not Installed]
                84.  ros-melodic-pcl-ros [Not Installed]
                85.  ros-melodic-perception [Not Installed]
                86.  ros-melodic-perception-pcl [Not Installed]
                87.  ros-melodic-position-controllers [Not Installed]
                88.  ros-melodic-realtime-tools [Not Installed]
                89.  ros-melodic-robot [Not Installed]
                90.  ros-melodic-robot-state-publisher [Not Installed]
                91.  ros-melodic-ros-base [Not Installed]
                92.  ros-melodic-ros-comm [Not Installed]
                93.  ros-melodic-ros-core [Not Installed]
                94.  ros-melodic-rosbag [Not Installed]
                95.  ros-melodic-rosbag-storage [Not Installed]
                96.  ros-melodic-rosmsg [Not Installed]
                97.  ros-melodic-rosnode [Not Installed]
                98.  ros-melodic-rosservice [Not Installed]
                99.  ros-melodic-rostopic [Not Installed]
                100. ros-melodic-roswtf [Not Installed]
                101. ros-melodic-rqt-action [Not Installed]
                102. ros-melodic-rqt-bag [Not Installed]
                103. ros-melodic-rqt-bag-plugins [Not Installed]
                104. ros-melodic-rqt-common-plugins [Not Installed]
                105. ros-melodic-rqt-console [Not Installed]
                106. ros-melodic-rqt-dep [Not Installed]
                107. ros-melodic-rqt-graph [Not Installed]
                108. ros-melodic-rqt-launch [Not Installed]
                109. ros-melodic-rqt-logger-level [Not Installed]
                110. ros-melodic-rqt-moveit [Not Installed]
                111. ros-melodic-rqt-msg [Not Installed]
                112. ros-melodic-rqt-nav-view [Not Installed]
                113. ros-melodic-rqt-plot [Not Installed]
                114. ros-melodic-rqt-pose-view [Not Installed]
                115. ros-melodic-rqt-publisher [Not Installed]
                116. ros-melodic-rqt-py-common [Not Installed]
                117. ros-melodic-rqt-reconfigure [Not Installed]
                118. ros-melodic-rqt-robot-dashboard [Not Installed]
                119. ros-melodic-rqt-robot-monitor [Not Installed]
                120. ros-melodic-rqt-robot-plugins [Not Installed]
                121. ros-melodic-rqt-robot-steering [Not Installed]
                122. ros-melodic-rqt-rviz [Not Installed]
                123. ros-melodic-rqt-service-caller [Not Installed]
                124. ros-melodic-rqt-srv [Not Installed]
                125. ros-melodic-rqt-tf-tree [Not Installed]
                126. ros-melodic-rqt-topic [Not Installed]
                127. ros-melodic-rviz [Not Installed]
                128. ros-melodic-rviz-plugin-tutorials [Not Installed]
                129. ros-melodic-rviz-python-tutorial [Not Installed]
                130. ros-melodic-simulators [Not Installed]
                131. ros-melodic-smach-ros [Not Installed]
                132. ros-melodic-stage [Not Installed]
                133. ros-melodic-stage-ros [Not Installed]
                134. ros-melodic-stereo-image-proc [Not Installed]
                135. ros-melodic-tf [Not Installed]
                136. ros-melodic-tf-conversions [Not Installed]
                137. ros-melodic-tf2-geometry-msgs [Not Installed]
                138. ros-melodic-tf2-kdl [Not Installed]
                139. ros-melodic-tf2-ros [Not Installed]
                140. ros-melodic-theora-image-transport [Not Installed]
                141. ros-melodic-turtle-actionlib [Not Installed]
                142. ros-melodic-turtle-tf [Not Installed]
                143. ros-melodic-turtle-tf2 [Not Installed]
                144. ros-melodic-urdf-sim-tutorial [Not Installed]
                145. ros-melodic-urdf-tutorial [Not Installed]
                146. ros-melodic-visualization-tutorials [Not Installed]
                147. ros-melodic-viz [Not Installed]
                148. tk-dev [Not Installed]
                149. tk8.6-dev [Not Installed]
                  Leave the following dependencies unresolved:
                150. fluid recommends libfltk1.3-dev
                Accept this solution? [Y/n/q/?] n
                • 6270705966
                  :-D @小鱼
                  3.   libcurl4-openssl-dev [Not Installed]
                  13.  libignition-fuel-tools1-dev [Not Installed]
                  14.  libpango1.0-dev [Not Installed]
                  15.  libpcl-dev [Not Installed]
                  16.  libqt5opengl5-dev [Not Installed]
                  17.  libqt5webkit5-dev [Not Installed]
                  18.  libsimbody-dev [Not Installed]
                  19.  libvtk6-dev [Not Installed]
                  20.  libvtk6-qt-dev [Not Installed]
                  21.  libx11-dev [Not Installed]
                  22.  libx11-xcb-dev [Not Installed]
                  23.  libxcomposite-dev [Not Installed]
                  24.  libxcursor-dev [Not Installed]
                  25.  libxdamage-dev [Not Installed]
                  26.  libxext-dev [Not Installed]
                  27.  libxfixes-dev [Not Installed]
                  28.  libxft-dev [Not Installed]
                  29.  libxi-dev [Not Installed]
                  30.  libxinerama-dev [Not Installed]
                  31.  libxmu-dev [Not Installed]
                  32.  libxmu-headers [Not Installed]
                  33.  libxrandr-dev [Not Installed]
                  34.  libxrender-dev [Not Installed]
                  35.  libxss-dev [Not Installed]
                  36.  libxt-dev [Not Installed]
                  37.  libxxf86vm-dev [Not Installed]
                  38.  mesa-common-dev [Not Installed]
                  39.  qtbase5-dev [Not Installed]
                  40.  qtdeclarative5-dev [Not Installed]
                  41.  qttools5-dev [Not Installed]
                  42.  qttools5-private-dev [Not Installed]
                  43.  ros-melodic-actionlib [Not Installed]
                  44.  ros-melodic-actionlib-tutorials [Not Installed]
                  45.  ros-melodic-common-tutorials [Not Installed]
                  46.  ros-melodic-compressed-depth-image-transport [Not Installed]
                  47.  ros-melodic-compressed-image-transport [Not Installed]
                  48.  ros-melodic-control-toolbox [Not Installed]
                  49.  ros-melodic-controller-manager [Not Installed]
                  50.  ros-melodic-controller-manager-msgs [Not Installed]
                  51.  ros-melodic-depth-image-proc [Not Installed]
                  52.  ros-melodic-desktop [Not Installed]
                  53.  ros-melodic-desktop-full [Not Installed]
                  54.  ros-melodic-diagnostic-analysis [Not Installed]
                  55.  ros-melodic-diagnostic-common-diagnostics [Not Installed]
                  56.  ros-melodic-diagnostics [Not Installed]
                  57.  ros-melodic-diff-drive-controller [Not Installed]
                  58.  ros-melodic-dynamic-reconfigure [Not Installed]
                  59.  ros-melodic-executive-smach [Not Installed]
                  60.  ros-melodic-forward-command-controller [Not Installed]
                  61.  ros-melodic-gazebo-dev [Not Installed]
                  62.  ros-melodic-gazebo-plugins [Not Installed]
                  63.  ros-melodic-gazebo-ros [Not Installed]
                  64.  ros-melodic-gazebo-ros-control [Not Installed]
                  65.  ros-melodic-gazebo-ros-pkgs [Not Installed]
                  66.  ros-melodic-geometry [Not Installed]
                  67.  ros-melodic-geometry-tutorials [Not Installed]
                  68.  ros-melodic-image-pipeline [Not Installed]
                  69.  ros-melodic-image-proc [Not Installed]
                  70.  ros-melodic-image-publisher [Not Installed]
                  71.  ros-melodic-image-rotate [Not Installed]
                  72.  ros-melodic-image-transport-plugins [Not Installed]
                  73.  ros-melodic-image-view [Not Installed]
                  74.  ros-melodic-interactive-marker-tutorials [Not Installed]
                  75.  ros-melodic-interactive-markers [Not Installed]
                  76.  ros-melodic-joint-state-controller [Not Installed]
                  77.  ros-melodic-laser-assembler [Not Installed]
                  78.  ros-melodic-laser-filters [Not Installed]
                  79.  ros-melodic-laser-geometry [Not Installed]
                  80.  ros-melodic-laser-pipeline [Not Installed]
                  81.  ros-melodic-librviz-tutorial [Not Installed]
                  82.  ros-melodic-nodelet-core [Not Installed]
                  83.  ros-melodic-nodelet-topic-tools [Not Installed]
                  84.  ros-melodic-pcl-conversions [Not Installed]
                  85.  ros-melodic-pcl-ros [Not Installed]
                  86.  ros-melodic-perception [Not Installed]
                  87.  ros-melodic-perception-pcl [Not Installed]
                  88.  ros-melodic-position-controllers [Not Installed]
                  89.  ros-melodic-realtime-tools [Not Installed]
                  90.  ros-melodic-robot [Not Installed]
                  91.  ros-melodic-robot-state-publisher [Not Installed]
                  92.  ros-melodic-ros-base [Not Installed]
                  93.  ros-melodic-ros-comm [Not Installed]
                  94.  ros-melodic-ros-core [Not Installed]
                  95.  ros-melodic-rosbag [Not Installed]
                  96.  ros-melodic-rosbag-storage [Not Installed]
                  97.  ros-melodic-rosmsg [Not Installed]
                  98.  ros-melodic-rosnode [Not Installed]
                  99.  ros-melodic-rosservice [Not Installed]
                  100. ros-melodic-rostopic [Not Installed]
                  101. ros-melodic-roswtf [Not Installed]
                  102. ros-melodic-rqt-action [Not Installed]
                  103. ros-melodic-rqt-bag [Not Installed]
                  104. ros-melodic-rqt-bag-plugins [Not Installed]
                  105. ros-melodic-rqt-common-plugins [Not Installed]
                  106. ros-melodic-rqt-console [Not Installed]
                  107. ros-melodic-rqt-dep [Not Installed]
                  108. ros-melodic-rqt-graph [Not Installed]
                  109. ros-melodic-rqt-launch [Not Installed]
                  110. ros-melodic-rqt-logger-level [Not Installed]
                  111. ros-melodic-rqt-moveit [Not Installed]
                  112. ros-melodic-rqt-msg [Not Installed]
                  113. ros-melodic-rqt-nav-view [Not Installed]
                  114. ros-melodic-rqt-plot [Not Installed]
                  115. ros-melodic-rqt-pose-view [Not Installed]
                  116. ros-melodic-rqt-publisher [Not Installed]
                  117. ros-melodic-rqt-py-common [Not Installed]
                  118. ros-melodic-rqt-reconfigure [Not Installed]
                  119. ros-melodic-rqt-robot-dashboard [Not Installed]
                  120. ros-melodic-rqt-robot-monitor [Not Installed]
                  121. ros-melodic-rqt-robot-plugins [Not Installed]
                  122. ros-melodic-rqt-robot-steering [Not Installed]
                  123. ros-melodic-rqt-rviz [Not Installed]
                  124. ros-melodic-rqt-service-caller [Not Installed]
                  125. ros-melodic-rqt-srv [Not Installed]
                  126. ros-melodic-rqt-tf-tree [Not Installed]
                  127. ros-melodic-rqt-topic [Not Installed]
                  128. ros-melodic-rviz [Not Installed]
                  129. ros-melodic-rviz-plugin-tutorials [Not Installed]
                  130. ros-melodic-rviz-python-tutorial [Not Installed]
                  131. ros-melodic-simulators [Not Installed]
                  132. ros-melodic-smach-ros [Not Installed]
                  133. ros-melodic-stage [Not Installed]
                  134. ros-melodic-stage-ros [Not Installed]
                  135. ros-melodic-stereo-image-proc [Not Installed]
                  136. ros-melodic-tf [Not Installed]
                  137. ros-melodic-tf-conversions [Not Installed]
                  138. ros-melodic-tf2-geometry-msgs [Not Installed]
                  139. ros-melodic-tf2-kdl [Not Installed]
                  140. ros-melodic-tf2-ros [Not Installed]
                  141. ros-melodic-theora-image-transport [Not Installed]
                  142. ros-melodic-turtle-actionlib [Not Installed]
                  143. ros-melodic-turtle-tf [Not Installed]
                  144. ros-melodic-turtle-tf2 [Not Installed]
                  145. ros-melodic-urdf-sim-tutorial [Not Installed]
                  146. ros-melodic-urdf-tutorial [Not Installed]
                  147. ros-melodic-visualization-tutorials [Not Installed]
                  148. ros-melodic-viz [Not Installed]
                  149. tk-dev [Not Installed]
                  150. tk8.6-dev [Not Installed]
                  151. fluid recommends libfltk1.3-dev
                  Accept this solution? [Y/n/q/?] y
                  No packages will be installed, upgraded, or removed.
                  0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B of archives. After unpacking 0 B will be used.
                    小鱼 技术大佬 @627070596
                    @627070596 ny不行,就n,ny 和 nnny 和 nnnny都试一试
                    • 6270705966
                      :-D @小鱼
                      [-]Result:code:2
                      [-]Result:code:2
                      • 6270705966
                        :-D @小鱼
                        @小鱼 成功了!谢谢大佬!
                          小鱼 技术大佬 @627070596
                          @627070596 代码格式整理下
                          • 小伊小 小伊 将这个主题转为问答主题,在
                          • 小伊小 小伊 将这个主题标记为已解决,在
