rviz不能显示环境模型,且机器人模型也不在
各位大佬,我运行项目的时候,机器人也能在gazebo环境中加载出来,但不在rviz中显示,终端报出以下问题:
[INFO] [launch]: All log files can be found below /home/user2/.ros/log/2023-02-17-20-10-20-236922-user2-1009600 [INFO] [launch]: Default logging verbosity is set to INFO redefining global symbol: range when instantiating macro: pressure_plugin_macro (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/pressure_snippets.xacro) instantiated from: default_pressure (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/pressure_snippets.xacro) instantiated from: eca_a9_base (/home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_base.xacro) in file: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_sensors.xacro included from: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/robots/eca_a9_default.urdf.xacro redefining global symbol: gamma when instantiating macro: chemical_concentration_sensor_macro (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/chemical_concentration_snippets.xacro) instantiated from: default_chemical_concentration_sensor (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/chemical_concentration_snippets.xacro) instantiated from: eca_a9_base (/home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_base.xacro) in file: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_sensors.xacro included from: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/robots/eca_a9_default.urdf.xacro [INFO] [spawn_entity.py-1]: process started with pid [1009650] [INFO] [robot_state_publisher-2]: process started with pid [1009652] [INFO] [uuv_message_to_tf-3]: process started with pid [1009654] [INFO] [finned_uuv_teleop.py-4]: process started with pid [1009656] [INFO] [joy_node-5]: process started with pid [1009658] [INFO] [rviz2-6]: process started with pid [1009660] [rviz2-6] WARNING: CPU random generator seem to be failing, disabling hardware random number generation [rviz2-6] WARNING: RDRND generated: 0xffffffff 0xffffffff 0xffffffff 0xffffffff [rviz2-6] qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in "" [spawn_entity.py-1] [INFO] [1676635822.866889330] [eca_a9.urdf_spawner]: Spawn Entity started [spawn_entity.py-1] [INFO] [1676635822.867159779] [eca_a9.urdf_spawner]: Loading entity published on topic robot_description [spawn_entity.py-1] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead. [spawn_entity.py-1] warnings.warn( [joy_node-5] [INFO] [1676635823.094236435] [eca_a9.joystick]: No haptic (rumble) available, skipping initialization [joy_node-5] [INFO] [1676635823.094329099] [eca_a9.joystick]: Opened joystick: SHANWAN Android Gamepad. deadzone: 0.050000 [spawn_entity.py-1] [INFO] [1676635823.155215881] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [robot_state_publisher-2] [WARN] [1676635823.157768385] [kdl_parser]: The root link eca_a9/base_link has an inertia specified in the URDF, but KDL does not support a root link with an inertia. As a workaround, you can add an extra dummy link to your URDF. [robot_state_publisher-2] [INFO] [1676635823.157911755] [eca_a9.robot_state_publisher]: got segment eca_a9/base_link [robot_state_publisher-2] [INFO] [1676635823.157965126] [eca_a9.robot_state_publisher]: got segment eca_a9/battery_link [robot_state_publisher-2] [INFO] [1676635823.157972469] [eca_a9.robot_state_publisher]: got segment eca_a9/camera_link [robot_state_publisher-2] [INFO] [1676635823.157978942] [eca_a9.robot_state_publisher]: got segment eca_a9/camera_link_optical [robot_state_publisher-2] [INFO] [1676635823.157984462] [eca_a9.robot_state_publisher]: got segment eca_a9/cc_sensor_link [robot_state_publisher-2] [INFO] [1676635823.157990012] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_link [robot_state_publisher-2] [INFO] [1676635823.157995603] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar0_link [robot_state_publisher-2] [INFO] [1676635823.158002356] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar1_link [robot_state_publisher-2] [INFO] [1676635823.158007906] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar2_link [robot_state_publisher-2] [INFO] [1676635823.158013336] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar3_link [robot_state_publisher-2] [INFO] [1676635823.158019428] [eca_a9.robot_state_publisher]: got segment eca_a9/fin0 [robot_state_publisher-2] [INFO] [1676635823.158025359] [eca_a9.robot_state_publisher]: got segment eca_a9/fin1 [robot_state_publisher-2] [INFO] [1676635823.158030709] [eca_a9.robot_state_publisher]: got segment eca_a9/fin2 [robot_state_publisher-2] [INFO] [1676635823.158035308] [eca_a9.robot_state_publisher]: got segment eca_a9/fin3 [robot_state_publisher-2] [INFO] [1676635823.158040708] [eca_a9.robot_state_publisher]: got segment eca_a9/gps_link [robot_state_publisher-2] [INFO] [1676635823.158046198] [eca_a9.robot_state_publisher]: got segment eca_a9/imu_link [robot_state_publisher-2] [INFO] [1676635823.158051678] [eca_a9.robot_state_publisher]: got segment eca_a9/pose_sensor_link_default [robot_state_publisher-2] [INFO] [1676635823.158057419] [eca_a9.robot_state_publisher]: got segment eca_a9/pressure_link [robot_state_publisher-2] [INFO] [1676635823.158062920] [eca_a9.robot_state_publisher]: got segment eca_a9/sonarleft_link [robot_state_publisher-2] [INFO] [1676635823.158068490] [eca_a9.robot_state_publisher]: got segment eca_a9/sonarright_link [robot_state_publisher-2] [INFO] [1676635823.158074161] [eca_a9.robot_state_publisher]: got segment eca_a9/thruster_0 [spawn_entity.py-1] [INFO] [1676635823.198087284] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.299921918] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.402145594] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.504263923] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.603517088] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.704734641] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.806152761] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description [spawn_entity.py-1] [INFO] [1676635823.821186097] [eca_a9.urdf_spawner]: Waiting for service /spawn_entity, timeout = 30 [spawn_entity.py-1] [INFO] [1676635823.821512722] [eca_a9.urdf_spawner]: Waiting for service /spawn_entity [spawn_entity.py-1] [INFO] [1676635823.825562634] [eca_a9.urdf_spawner]: Calling service /spawn_entity [finned_uuv_teleop.py-4] [INFO] [1676635823.957493336] [eca_a9.finned_uuv_teleop]: FinnedUUVControllerNode: initializing node [rviz2-6] [INFO] [1676635824.307615459] [rviz2]: Stereo is NOT SUPPORTED [rviz2-6] [INFO] [1676635824.307686202] [rviz2]: OpenGl version: 4.3 (GLSL 4.3) [rviz2-6] [INFO] [1676635824.317527045] [rviz2]: Stereo is NOT SUPPORTED [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] [INFO] [1676635824.431045751] [rviz2]: Stereo is NOT SUPPORTED [spawn_entity.py-1] [INFO] [1676635824.435702135] [eca_a9.urdf_spawner]: Spawn status: SpawnEntity: Successfully spawned entity [eca_a9] [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [INFO] [spawn_entity.py-1]: process has finished cleanly [pid 1009650] [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [finned_uuv_teleop.py-4] [INFO] [1676635824.615084982] [eca_a9.finned_uuv_teleop]: Thruster #0 - proportional - thrusters/id_0/input [finned_uuv_teleop.py-4] [INFO] [1676635824.615507727] [eca_a9.finned_uuv_teleop]: Thruster model: [finned_uuv_teleop.py-4] [INFO] [1676635824.615786171] [eca_a9.finned_uuv_teleop]: Gain=4.9e-05 [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist [rviz2-6] at line 93 in ./src/buffer_core.cpp其rviz配置文件如下:
Panels: - Class: rviz_common/Displays Help Height: 78 Name: Displays Property Tree Widget: Expanded: - /Global Options1 - /Status1 - /RobotModel1 - /Sonar left1 - /Sonar right1 - /Waypoint path1 - /Fin 0 - Wrench1 - /Fin 1 - Wrench1 - /Fin 2 - Wrench1 - /Fin 3 - Wrench1 - /Thrust Wrench1 Splitter Ratio: 0.5 Tree Height: 486 - Class: rviz_common/Selection Name: Selection - Class: rviz_common/Tool Properties Expanded: - /2D Pose Estimate1 - /2D Nav Goal1 - /Publish Point1 Name: Tool Properties Splitter Ratio: 0.588679016 - Class: rviz_common/Views Expanded: - /Current View1 Name: Views Splitter Ratio: 0.5 - Class: rviz_common/Time Experimental: false Name: Time SyncMode: 0 SyncSource: Sonar left Visualization Manager: Class: "" Displays: - Alpha: 0.5 Cell Size: 1 Class: rviz_default_plugins/Grid Color: 160; 160; 164 Enabled: true Line Style: Line Width: 0.0299999993 Value: Lines Name: Grid Normal Cell Count: 0 Offset: X: 0 Y: 0 Z: 0 Plane: XY Plane Cell Count: 10 Reference Frame: <Fixed Frame> Value: true - Alpha: 1 Class: rviz_default_plugins/RobotModel Collision Enabled: false Enabled: true Links: All Links Enabled: true Expand Joint Details: false Expand Link Details: false Expand Tree: false Link Tree Style: Links in Alphabetic Order eca_a9/base_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/battery_link: Alpha: 1 Show Axes: false Show Trail: false eca_a9/camera_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/camera_link_optical: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/cc_sensor_link: Alpha: 1 Show Axes: false Show Trail: false eca_a9/dvl_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/dvl_sonar0_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/dvl_sonar1_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/dvl_sonar2_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/dvl_sonar3_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/fin0: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/fin1: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/fin2: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/fin3: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/gps_link: Alpha: 1 Show Axes: false Show Trail: false eca_a9/imu_link: Alpha: 1 Show Axes: false Show Trail: false eca_a9/pose_sensor_link_default: Alpha: 1 Show Axes: false Show Trail: false eca_a9/pressure_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/sonarleft_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/sonarright_link: Alpha: 1 Show Axes: false Show Trail: false Value: true eca_a9/thruster_0: Alpha: 1 Show Axes: false Show Trail: false Value: true Name: RobotModel Robot Description: eca_a9/robot_description TF Prefix: "" Update Interval: 0 Value: true Visual Enabled: true - Class: rviz_default_plugins/TF Enabled: true Frame Timeout: 15 Frames: All Enabled: true eca_a9/base_footprint: Value: true eca_a9/base_link: Value: true eca_a9/base_link_ned: Value: true eca_a9/base_stabilized: Value: true eca_a9/battery_link: Value: true eca_a9/camera_link: Value: true eca_a9/camera_link_optical: Value: true eca_a9/cc_sensor_link: Value: true eca_a9/dvl_link: Value: true eca_a9/dvl_sonar0_link: Value: true eca_a9/dvl_sonar1_link: Value: true eca_a9/dvl_sonar2_link: Value: true eca_a9/dvl_sonar3_link: Value: true eca_a9/fin0: Value: true eca_a9/fin1: Value: true eca_a9/fin2: Value: true eca_a9/fin3: Value: true eca_a9/gps_link: Value: true eca_a9/imu_link: Value: true eca_a9/pose_sensor_link_default: Value: true eca_a9/pressure_link: Value: true eca_a9/sonarleft_link: Value: true eca_a9/sonarright_link: Value: true eca_a9/thruster_0: Value: true world: Value: true world_ned: Value: true Marker Scale: 1 Name: TF Show Arrows: true Show Axes: true Show Names: true Tree: world: eca_a9/base_footprint: eca_a9/base_stabilized: eca_a9/base_link: eca_a9/base_link_ned: {} eca_a9/battery_link: {} eca_a9/camera_link: eca_a9/camera_link_optical: {} eca_a9/cc_sensor_link: {} eca_a9/dvl_link: eca_a9/dvl_sonar0_link: {} eca_a9/dvl_sonar1_link: {} eca_a9/dvl_sonar2_link: {} eca_a9/dvl_sonar3_link: {} eca_a9/fin0: {} eca_a9/fin1: {} eca_a9/fin2: {} eca_a9/fin3: {} eca_a9/gps_link: {} eca_a9/imu_link: {} eca_a9/pose_sensor_link_default: {} eca_a9/pressure_link: {} eca_a9/sonarleft_link: {} eca_a9/sonarright_link: {} eca_a9/thruster_0: {} world_ned: {} Update Interval: 0 Value: true - Class: rviz_default_plugins/MarkerArray Enabled: true Marker Topic: /world_models Name: World models Namespaces: "": true Queue Size: 100 Value: true - Alpha: 1 Autocompute Intensity Bounds: true Autocompute Value Bounds: Max Value: -91.8094254 Min Value: -95.5871582 Value: true Axis: Z Channel Name: intensity Class: rviz_default_plugins/LaserScan Color: 255; 255; 255 Color Transformer: AxisColor Decay Time: 300 Enabled: true Invert Rainbow: false Max Color: 255; 255; 255 Max Intensity: 0 Min Color: 0; 0; 0 Min Intensity: 0 Name: Sonar left Position Transformer: XYZ Queue Size: 10 Selectable: true Size (Pixels): 3 Size (m): 0.00999999978 Style: Points Topic: /eca_a9/sss_left Unreliable: false Use Fixed Frame: true Use rainbow: true Value: true - Alpha: 1 Autocompute Intensity Bounds: true Autocompute Value Bounds: Max Value: -75.8892899 Min Value: -95.6470261 Value: true Axis: Z Channel Name: intensity Class: rviz_default_plugins/LaserScan Color: 255; 255; 255 Color Transformer: AxisColor Decay Time: 300 Enabled: true Invert Rainbow: false Max Color: 255; 255; 255 Max Intensity: 0 Min Color: 0; 0; 0 Min Intensity: 0 Name: Sonar right Position Transformer: XYZ Queue Size: 10 Selectable: true Size (Pixels): 3 Size (m): 0.00999999978 Style: Points Topic: /eca_a9/sss_right Unreliable: false Use Fixed Frame: true Use rainbow: true Value: true - Angle Tolerance: 0.100000001 Class: rviz_default_plugins/Odometry Covariance: Orientation: Alpha: 0.5 Color: 255; 255; 127 Color Style: Unique Frame: Local Offset: 1 Scale: 1 Value: true Position: Alpha: 0.300000012 Color: 204; 51; 204 Scale: 1 Value: true Value: true Enabled: true Keep: 100 Name: Odometry Position Tolerance: 0.100000001 Shape: Alpha: 1 Axes Length: 1 Axes Radius: 0.100000001 Color: 255; 25; 0 Head Length: 0.300000012 Head Radius: 0.100000001 Shaft Length: 1 Shaft Radius: 0.0500000007 Value: Arrow Topic: /eca_a9/pose_gt Unreliable: false Value: true - Alpha: 1 Buffer Length: 1 Class: rviz_default_plugins/Path Color: 255; 85; 255 Enabled: true Head Diameter: 0.300000012 Head Length: 0.200000003 Length: 0.300000012 Line Style: Lines Line Width: 0.0299999993 Name: Trajectory Offset: X: 0 Y: 0 Z: 0 Pose Color: 255; 85; 255 Pose Style: None Radius: 0.0299999993 Shaft Diameter: 0.100000001 Shaft Length: 0.100000001 Topic: /eca_a9/trajectory_marker Unreliable: false Value: true - Class: rviz_default_plugins/MarkerArray Enabled: true Marker Topic: /eca_a9/waypoint_markers Name: Waypoints Namespaces: "": true Queue Size: 100 Value: true - Alpha: 1 Buffer Length: 1 Class: rviz_default_plugins/Path Color: 255; 85; 0 Enabled: true Head Diameter: 0.300000012 Head Length: 0.200000003 Length: 0.300000012 Line Style: Lines Line Width: 0.0299999993 Name: Waypoint path Offset: X: 0 Y: 0 Z: 0 Pose Color: 255; 85; 255 Pose Style: None Radius: 0.0299999993 Shaft Diameter: 0.100000001 Shaft Length: 0.100000001 Topic: /eca_a9/waypoint_path_marker Unreliable: false Value: true - Alpha: 1 Arrow Width: 0.200000003 Class: rviz_default_plugins/Wrench Enabled: true Force Arrow Scale: 0.100000001 Force Color: 204; 51; 51 History Length: 1 Name: Fin 0 - Wrench Topic: /eca_a9/fins/0/wrench_topic Torque Arrow Scale: 2 Torque Color: 204; 204; 51 Unreliable: false Value: true - Alpha: 1 Arrow Width: 0.300000012 Class: rviz_default_plugins/Wrench Enabled: true Force Arrow Scale: 0.100000001 Force Color: 204; 51; 51 History Length: 1 Name: Fin 1 - Wrench Topic: /eca_a9/fins/1/wrench_topic Torque Arrow Scale: 2 Torque Color: 204; 204; 51 Unreliable: false Value: true - Alpha: 1 Arrow Width: 0.300000012 Class: rviz_default_plugins/Wrench Enabled: true Force Arrow Scale: 0.100000001 Force Color: 204; 51; 51 History Length: 1 Name: Fin 2 - Wrench Topic: /eca_a9/fins/2/wrench_topic Torque Arrow Scale: 2 Torque Color: 204; 204; 51 Unreliable: false Value: true - Alpha: 1 Arrow Width: 0.300000012 Class: rviz_default_plugins/Wrench Enabled: true Force Arrow Scale: 0.100000001 Force Color: 204; 51; 51 History Length: 1 Name: Fin 3 - Wrench Topic: /eca_a9/fins/3/wrench_topic Torque Arrow Scale: 2 Torque Color: 204; 204; 51 Unreliable: false Value: true - Alpha: 1 Arrow Width: 0.300000012 Class: rviz_default_plugins/Wrench Enabled: true Force Arrow Scale: 0.100000001 Force Color: 53; 98; 204 History Length: 1 Name: Thrust Wrench Topic: /eca_a9/thrusters/0/thrust_wrench Torque Arrow Scale: 2 Torque Color: 204; 204; 51 Unreliable: false Value: true - Class: rviz_default_plugins/Image Enabled: true Image Topic: /eca_a9/camera/camera_image Max Value: 1 Median window: 5 Min Value: 0 Name: Image Normalize Range: true Queue Size: 2 Transport Hint: raw Unreliable: false Value: true - Class: rviz_default_plugins/Marker Enabled: true Marker Topic: /eca_a9/reference_marker Name: Reference Marker Namespaces: "": true Queue Size: 100 Value: true - Class: rviz_default_plugins/MarkerArray Enabled: true Marker Topic: /eca_a9/interpolator_visual_markers Name: MarkerArray Namespaces: dubins: true Queue Size: 100 Value: true Enabled: true Global Options: Background Color: 48; 48; 48 Fixed Frame: world Frame Rate: 30 Name: root Tools: - Class: rviz_default_plugins/Interact Hide Inactive Objects: true - Class: rviz_default_plugins/MoveCamera - Class: rviz_default_plugins/Select - Class: rviz_default_plugins/FocusCamera - Class: rviz_default_plugins/Measure - Class: rviz_default_plugins/SetInitialPose Topic: /initialpose - Class: rviz_default_plugins/SetGoal Topic: /goal_pose #Topic: /move_base_simple/goal - Class: rviz_default_plugins/PublishPoint Single click: true Topic: /clicked_point Value: true Views: Current: Class: rviz_default_plugins/Orbit Distance: 303.795349 Enable Stereo Rendering: Stereo Eye Separation: 0.0599999987 Stereo Focal Distance: 1 Swap Stereo Eyes: false Value: false Focal Point: X: 0 Y: 0 Z: 0 Focal Shape Fixed Size: true Focal Shape Size: 0.0500000007 Invert Z Axis: false Name: Current View Near Clip Distance: 0.00999999978 Pitch: 0.525398612 Target Frame: eca_a9/base_link Value: Orbit (rviz) Yaw: 2.36903524 Saved: ~ Window Geometry: Displays: collapsed: false Height: 1176 Hide Left Dock: false Hide Right Dock: false Image: collapsed: false QMainWindow State: 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 Selection: collapsed: false Time: collapsed: false Tool Properties: collapsed: false Views: collapsed: false Width: 1920 X: 1920 Y: 24请问这是怎么回事呢?
此回复已被删除! -
此回复已被删除! -
Y yudonghou123 将这个主题转为问答主题,在
Y yudonghou123 删除了该主题于
Y yudonghou123 恢复了该主题于
@yudonghou123 看错误tf有问题,检查tf
Y yudonghou123 将这个主题标记为已解决,在
大佬,请问怎么解决的
