    No executable found(ros2 run的时候找不到头文件)
    ros2humble ros2编译 python3 节点与话题
    5
    11
    4.2k
    • M
      march_xiong
      最后由 march_xiong 编辑
      ubuntu20.04
      在B站视频《面向过程思想编写cpp节点》
      https://www.bilibili.com/video/BV1gr4y1Q7j5/?p=25&spm_id_from=pageDriver&vd_source=5340b8baff6fb33e9d5215026c441964
      中。最后会出现此问题
      ros2@ros2-virtual-machine:~/town_ws$ ros2 run village_wang wang2_node
      No executable found
      查阅资料说 使用ros2 run的时候找不到头文件,是因为现在和ros1不一样了。你必须要将可执行文件注册,ros2命令才找得到。但是此前已经在CMakeLists头文件中进行注册了
      下面文档CMakeLists.txt中有关的部分代码
      ament_package()
      add_executable(wang2_node src/wang2.cpp)
      ament_target_dependencies(wang2_node rclcpp)
      install(TARGETS wang2_node
      ament_package()
      下面是wang.cpp代码
      #include "rclcpp/rclcpp.hpp"
      int main(int argc,char ** argv)
          rclcpp::init(argc,argv);
          auto node = std::make_shared<rclcpp::Node>("wang2");
          RCLCPP_INFO(node->get_logger(),"大家好,我是单身狗wang2.");
          rclcpp::spin(node);
          rclcpp::shutdown();
      下面是运行中的结果
      ros2@ros2-virtual-machine:~/town_ws$ colcon build --packages-select village_wang
      Starting >>> village_wang
      Finished <<< village_wang [0.19s]
      Summary: 1 package finished [0.40s]
      ros2@ros2-virtual-machine:~/town_ws$ source install/setup.bash
      ros2@ros2-virtual-machine:~/town_ws$ ros2 pkg list | grep vill
      village_li
      village_wang
      No executable found
      小鱼小 1 条回复 最后回复 回复 引用 1
        小鱼 技术大佬 @march_xiong
        @march_xiong 试试这个指令,看看会显示什么
        cd  src/village_wang
        mkdir build
        cd build
        cmake ..
        make
        M 1 条回复 最后回复 回复 引用 1
        • M
          march_xiong @小鱼
          最后由 march_xiong 编辑
          运行上述后的结果
          ros2@ros2-virtual-machine:~/town_ws$ cd  src/village_wang
          ros2@ros2-virtual-machine:~/town_ws/src/village_wang$ mkdir build
          mkdir: 无法创建目录 "build": 文件已存在
          ros2@ros2-virtual-machine:~/town_ws/src/village_wang$ cd build
          ros2@ros2-virtual-machine:~/town_ws/src/village_wang/build$ cmake ..
          -- Found ament_cmake: 1.3.3 (/opt/ros/humble/share/ament_cmake/cmake)
          -- Found rclcpp: 16.0.3 (/opt/ros/humble/share/rclcpp/cmake)
          -- Found rosidl_generator_c: 3.1.4 (/opt/ros/humble/share/rosidl_generator_c/cmake)
          -- Found rosidl_adapter: 3.1.4 (/opt/ros/humble/share/rosidl_adapter/cmake)
          -- Found rosidl_generator_cpp: 3.1.4 (/opt/ros/humble/share/rosidl_generator_cpp/cmake)
          -- Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c
          -- Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp
          -- Found rmw_implementation_cmake: 6.1.1 (/opt/ros/humble/share/rmw_implementation_cmake/cmake)
          -- Found rmw_fastrtps_cpp: 6.2.2 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake)
          -- Using RMW implementation 'rmw_fastrtps_cpp' as default
          -- Found ament_lint_auto: 0.12.5 (/opt/ros/humble/share/ament_lint_auto/cmake)
          -- Added test 'cppcheck' to perform static code analysis on C / C++ code
          -- Configured cppcheck include dirs:
          -- Configured cppcheck exclude dirs and/or files:
          -- Added test 'lint_cmake' to check CMake code style
          -- Added test 'uncrustify' to check C / C++ code style
          -- Configured uncrustify additional arguments:
          -- Added test 'xmllint' to check XML markup files
          -- Configuring done
          -- Generating done
          -- Build files have been written to: /home/ros2/town_ws/src/village_wang/build
          ros2@ros2-virtual-machine:~/town_ws/src/village_wang/build$ make
          然后我在新的终端重新执行ros2 run程序,结果
          Finished <<< village_wang [0.17s]
          Summary: 1 package finished [0.35s]
          village_li
          village_wang
          No executable found
          发现报相同错误
          No executable found
          后续发现找不到wang2这个节点
          ros2@ros2-virtual-machine:~/town_ws$ ros2 node list
          /li4
          ros2@ros2-virtual-machine:~/town_ws$ ros2 node info /wang2
          Unable to find node '/wang2'
          醉后不知天在水醉 2 条回复 最后回复 回复 引用 0
          • 醉后不知天在水醉
            醉后不知天在水 活跃VIP @march_xiong
            @march_xiong 1.尝试检查一下CMakeLists.txt是否写入
            2.工作空间是否创建错误,
            文件目录为.
            └── src
            └── example_topic_rclcpp
            ├── CMakeLists.txt
            ├── include
            │ └── example_topic_rclcpp
            ├── package.xml
            └── src
            └── topic_publisher_01.cpp
            5 directories, 3 files
            • 醉后不知天在水醉
              @march_xiong 具体参考https://fishros.com/d2lros2foxy/#/chapt3/3.6.1%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AAC++%E5%8A%9F%E8%83%BD%E5%8C%85
              M 1 条回复 最后回复 回复 引用 0
              • M
                march_xiong @醉后不知天在水
                @醉后不知天在水
                目录如下
                就是多了个构造build后的文件夹
                重新编译后报错情况如下
                --- stderr: village_wang
                CMake Error at /opt/ros/humble/share/ament_cmake_core/cmake/environment_hooks/ament_environment_hooks.cmake:29 (message):
                  ament_environment_hooks() must be called before
                  ament_generate_package_environment() (which is invoked by ament_package())
                  /opt/ros/humble/share/ament_cmake_core/cmake/environment_hooks/ament_cmake_environment_hooks_package_hook.cmake:20 (ament_environment_hooks)
                  /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package.cmake:66 (ament_execute_extensions)
                  CMakeLists.txt:33 (ament_package)
                gmake: *** [Makefile:226:cmake_check_build_system] 错误 1
                Failed   <<< village_wang [1.41s, exited with code 2]
                Summary: 0 packages finished [1.76s]
                  1 package failed: village_wang
                  1 package had stderr output: village_wang
                主要是这块
                就是这个环境的声明问题,不过CMakelist中的这行代码是照着视频敲的
                CMakelist进行了读写
                project(village_wang)
                endif()
                # find dependencies
                find_package(rclcpp REQUIRED)
                if(BUILD_TESTING)
                endif()
                ament_package()
                最下面的三段是视频的教程
                这个
                ament_package()
                网上查找结果
                因为ament package是构建系统独立的,所以有各种各样的ament包,比如ament CMake package、ament Python package等。
                所以这个报错,不知道应该如何解决
                  @march_xiong 将ament_package() 移到最后一行
                  project(example_cpp)
                  endif()
                  # find dependencies
                  if(BUILD_TESTING)
                  endif()
                  add_executable(node_01 src/node_01.cpp)
                  ament_target_dependencies(node_01 rclcpp)
                  add_executable(node_03 src/node_03.cpp)
                  ament_target_dependencies(node_03 rclcpp)
                  install(TARGETS
                    node_01
                  install(TARGETS
                    node_03
                  ament_package()
                  M 13183088151 2 3 条回复 最后回复 回复 引用 0
                  • M
                    march_xiong @小鱼
                    更改后确实运行正常了 小鱼好厉害👍 😊
                    不过有点好奇这个库要最后声明么?
                    • 13183088151
                      学不会的ROS2 @小鱼
                      @小鱼 cmake_minimum_required(VERSION 3.8)
                      project(cpp01_launch)
                      endif()
                      find dependencies
                      if(BUILD_TESTING)
                      endif()
                      install(DIRECTORY launch DESTINATION share/${PROJECT_NAME})
                      ament_package()
                      我的ament_package()就是在最后一行 为什么运行后的结果还是No executable found
                        2041525450 @小鱼
                        @小鱼 9be6f6e9-4f9b-40d3-9eb5-fb37af575e8d-image.png ament_package()在最后一行还是不行
                          小鱼 技术大佬 @2041525450
                          @2041525450 我保证,视频和书里绝对没有你敲的这句命令
