    在macroros教程中《控制OLED-自定义消息接口》无法编译
    MicroROS
    microros自定义接口 fishbot
    1.4k
    • ELLAWE
      ELLAW
      环境是ubuntu22,用的是小鱼脚本安装的ros2 humble
      教程章节:
      https://fishros.com/d2lros2/#/humble/chapt14/advance/1.控制OLED-自定义消息接口
      进行到该章节第2.2 编译功能包时,
      colcon build后,提示~
      Starting >>> fishbot_interfaces
      --- stderr: fishbot_interfaces
      CMake Error at /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:229 (message):
        Packages installing interfaces must include
        '<member_of_group>rosidl_interface_packages</member_of_group>' in their
        package.xml
        CMakeLists.txt:29 (rosidl_generate_interfaces)
      Failed   <<< fishbot_interfaces [3.01s, exited with code 1]
      Summary: 0 packages finished [3.20s]
        1 package failed: fishbot_interfaces
        1 package had stderr output: fishbot_interfaces
      安照错误提示,在package.xml中加上 <member_of_group>rosidl_interface_packages</member_of_group>后可以通过编译。
      继续后按照教程,编译时提示错误
      CMake Error at CMakeLists.txt:27 (find_package):
        By not providing "Findrosidl_default_generators.cmake" in CMAKE_MODULE_PATH
        this project has asked CMake to find a package configuration file provided
        by "rosidl_default_generators", but CMake did not find one.
        "rosidl_default_generators" with any of the following names:
          rosidl_default_generatorsConfig.cmake
          rosidl_default_generators-config.cmake
        Add the installation prefix of "rosidl_default_generators" to
        CMAKE_PREFIX_PATH or set "rosidl_default_generators_DIR" to a directory
        containing one of the above files.  If "rosidl_default_generators" provides
        a separate development package or SDK, be sure it has been installed.
      Failed   <<< fishbot_interfaces [0.96s, exited with code 1]
        小鱼 技术大佬 @ELLAW
        @ELLAW https://fishros.org.cn/forum/topic/1027/动手学ros2第5章进阶篇-控制oled-自定义消息接口/10
