    ROS2 humble spawn_entity[Err] [Visual.cc:2956] No mesh specified
    ros2 humble gazebo11
    2.1k
    • 2849210182
      曲径通幽
      我是ROS2的新手,近期在尝试将xacro文件导入gazebo中,urdf文件可以在Rviz中使用,但是导入gazebo的时候就不可以了,它会报如下错误
          [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wp/ros2_ws/install/manipulater/share/manipulater/__pycache__"
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wp/ros2_ws/install/manipulater/share/manipulater/hook"
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wp/ros2_ws/install/manipulater/share/manipulater/meshes"
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wp/ros2_ws/install/manipulater/share/manipulater/rviz"
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wp/ros2_ws/install/manipulater/share/manipulater/urdf"
      [gazebo-1] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
      [gazebo-1] [Wrn] [FuelModelDatabase.
      cc:313] URI not supported by Fuel [$(find manipulater)/meshes/visual/con_1.STL]
          [gazebo-1] [Wrn] [SystemPaths.cc:459] File or path does not exist [""] [$(find manipulater)/meshes/visual/con_1.STL]
          [gazebo-1] [Wrn] [FuelModelDatabase.cc:313] URI not supported by Fuel [file://$(find manipulater)/meshes/visual/con_1.STL]
          [gazebo-1] [Wrn] [SystemPaths.cc:459] File or path does not exist [""] [file://$(find manipulater)/meshes/visual/con_1.STL]
          [gazebo-1] [Err] [Visual.cc:2956] No
              mesh specified
              [gazebo-1] [Wrn] [FuelModelDatabase.cc:313] URI not supported by Fuel [$(find manipulater)/meshes/visual/con_1.STL]
              [gazebo-1] [Err] [Visual.cc:2956] No mesh specified
      我尝试了export GAZEBO_MODEL_PATH=$GAZEBO_MODEL_PATH:/home/wp/ros2_ws/install/manipulater/share/manipulater
      但是不起作用,我也将xacro文件中mesh中的filename="package://manipulater/meshes/visual/base_link.STL" 变成 filename="file://$(find manipulater)/meshes/visual/base_link.STL",但是也不起作用
      我不知道问题出在哪里,感谢帮助我的人
      我使用 ROS2 humbe,Ubuntu 22.04.2 ,VM16 pro
      my directory tree
      ├── launch
      │   ├── display_launch.py
      │   ├── gazebo1.launch.py
      │   └── gazebo2.launch.py
      ├── manipulater
      │   └── __init__.py
      ├── meshes
      │   ├── collision
      │   │   ├── base_link.STL
      │   │   ├── con_1.STL
      │   │   ├── con_2.STL
      │   │   ├── con_3.STL
      │   │   ├── con_4.STL
      │   │   ├── con_5.STL
      │   │   ├── con_6.STL
      │   │   ├── con_7.STL
      │   │   ├── con_8.STL
      │   │   ├── link_1.STL
      │   │   ├── link_2.STL
      │   │   ├── link_3.STL
      │   │   ├── link_4.STL
      │   │   ├── link_5.STL
      │   │   ├── link_6.STL
      │   │   ├── link_7.STL
      │   │   └── link_8.STL
      │   └── visual
      │       ├── base_link.STL
      │       ├── con_1.STL
      │       ├── con_2.STL
      │       ├── con_3.STL
      │       ├── con_4.STL
      │       ├── con_5.STL
      │       ├── con_6.STL
      │       ├── con_7.STL
      │       ├── con_8.STL
      │       ├── link_1.STL
      │       ├── link_2.STL
      │       ├── link_3.STL
      │       ├── link_4.STL
      │       ├── link_5.STL
      │       ├── link_6.STL
      │       ├── link_7.STL
      │       └── link_8.STL
      ├── package.xml
      ├── resource
      │   └── manipulater
      ├── rviz
      │   └── view.rviz
      ├── scripts
      │   ├── 00_dofbot_move.py
      │   ├── 01_set_move.py
      │   ├── 02_motion_plan.py
      │   ├── 03_attached_object.py
      │   ├── 04_Set_Scene.py
      │   └── __init__.py
      ├── setup.cfg
      ├── setup.py
      └── urdf
          ├── manipulater.gv
          ├── manipulater.pdf
          ├── sd_mani_test.urdf
          ├── sd_mani.urdf
          └── sd_mani.xacro
      9 directories, 54 files
      my xacro file
       <?xml version="1.0"?>
          <!-- This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
           Commit Version: 1.6.0-4-g7f85cfe  Build Version: 1.6.7995.38578
           For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
      <robot  name="manipulater" xmlns:xacro="http://ros.org/wiki/xacro">
        <link
          name="base_link">
          <inertial><!--旋转惯量矩阵是用于描述物体的惯性的,在做动力学仿真的时候,这些参数尤为重要-->
            <origin
              xyz="-0.40335 -4.5727E-09 -0.022176"
              rpy="1.5708 0 0" />
            <mass
              value="50" /><!--描述link的质量-->
             <inertia
              ixx="2.7711"
              ixy="5.2286E-07"
              ixz="-0.013648"
              iyy="3.0095"
              iyz="1.0857E-09"
              izz="3.0504" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="1.5708 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/base_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision><!--我们可以可以在link标签下添加collison子标签来对物体的形状进行描述-->
            <origin
              xyz="0 0 0"
              rpy="1.5708 0 0" /><!--表示碰撞体的中心位姿-->
            <geometry><!--用于表示用于碰撞检测的几何形状-->
              <mesh
            </geometry>
          </collision>
        </link>
        <link
          name="con_1">
          <inertial>
            <origin
              xyz="-4.147E-11 1.5501E-08 -1.3172E-07"
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="4.006E-13"
              ixz="3.9983E-13"
              iyy="5.0984E-07"
              iyz="-8.0439E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_1.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_1"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="1.5708 0 0" />
          <parent
            link="base_link" />
          <child
            link="con_1" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_1">
          <inertial>
            <origin
              xyz="-0.40335 4.5727E-09 0.022176"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-5.2286E-07"
              ixz="0.013648"
              iyy="3.0095"
              iyz="1.0857E-09"
              izz="3.0504" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_1.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_2"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="1.5708 0 0" />
          <parent
            link="con_1" />
          <child
            link="link_1" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_2">
          <inertial>
            <origin
              xyz="-4.1467E-11 -1.2546E-08 -1.5501E-08"
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="3.9983E-13"
              ixz="-4.006E-13"
              iyy="5.0984E-07"
              iyz="8.0461E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_2.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_3"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_1" />
          <child
            link="con_2" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_2">
          <inertial>
            <origin
              xyz="-0.53185 -0.022176 1.2375E-07"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-0.013648"
              ixz="-5.2286E-07"
              iyy="3.0504"
              iyz="-1.0857E-09"
              izz="3.0095" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_2.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_4"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="-1.5708 0 0" />
          <parent
            link="con_2" />
          <child
            link="link_2" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_3">
          <inertial>
            <origin
              xyz="-4.1467E-11 1.5501E-08 -1.2546E-08"
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="4.006E-13"
              ixz="3.9983E-13"
              iyy="5.0984E-07"
              iyz="-8.0481E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_3.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_5"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_2" />
          <child
            link="con_3" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_3">
          <inertial>
            <origin
              xyz="-0.66035 1.2375E-07 0.022176"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-5.2286E-07"
              ixz="0.013648"
              iyy="3.0095"
              iyz="1.0857E-09"
              izz="3.0504" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_3.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_6"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="1.5708 0 0" />
          <parent
            link="con_3" />
          <child
            link="link_3" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_4">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="3.9983E-13"
              ixz="-4.006E-13"
              iyy="5.0984E-07"
              iyz="8.0388E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_4.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_7"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_3" />
          <child
            link="con_4" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_4">
          <inertial>
            <origin
              xyz="-0.78885 -0.022176 1.2375E-07"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-0.013648"
              ixz="-5.2286E-07"
              iyy="3.0504"
              iyz="-1.0857E-09"
              izz="3.0095" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_4.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_8"
          type="revolute">
          <origin
            xyz="0 0 0"
          <parent
            link="con_4" />
          <child
            link="link_4" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_5">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="4.006E-13"
              ixz="3.9983E-13"
              iyy="5.0984E-07"
              iyz="-8.0406E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_5.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_9"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_4" />
          <child
            link="con_5" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_5">
          <inertial>
            <origin
              xyz="-0.91735 1.2375E-07 0.022176"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-5.2286E-07"
              ixz="0.013648"
              iyy="3.0095"
              iyz="1.0857E-09"
              izz="3.0504" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_5.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_10"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="1.5707963267949 0 0" />
          <parent
            link="con_5" />
          <child
            link="link_5" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_6">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="3.9983E-13"
              ixz="-4.006E-13"
              iyy="5.0984E-07"
              iyz="8.0462E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_6.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_11"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_5" />
          <child
            link="con_6" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_6">
          <inertial>
            <origin
              xyz="-1.0458 -0.022176 1.2375E-07"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-0.013648"
              ixz="-5.2286E-07"
              iyy="3.0504"
              iyz="-1.0857E-09"
              izz="3.0095" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_6.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_12"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="-1.5707963267949 0 0" />
          <parent
            link="con_6" />
          <child
            link="link_6" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_7">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="4.006E-13"
              ixz="3.9983E-13"
              iyy="5.0984E-07"
              iyz="-8.0383E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_7.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_13"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_6" />
          <child
            link="con_7" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_7">
          <inertial>
            <origin
              xyz="-1.1743 1.2375E-07 0.022
      176"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-5.2286E-07"
              ixz="0.013648"
              iyy="3.0095"
              iyz="1.0857E-09"
              izz="3.0504" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_7.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_14"
          type="revolute">
          <origin
            xyz="0 0 0"
            rpy="1.5708 0 0" />
          <parent
            link="con_7" />
          <child
            link="link_7" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="con_8">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
              value="0.011" />
            <inertia
              ixx="8.5802E-07"
              ixy="3.9983E-13"
              ixz="-4.006E-13"
              iyy="5.0984E-07"
              iyz="8.0342E-19"
              izz="5.0984E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/con_8.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_15"
          type="revolute">
          <origin
            xyz="0.1285 0 0"
            rpy="0 0 0" />
          <parent
            link="link_7" />
          <child
            link="con_8" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
        <link
          name="link_8">
          <inertial>
            <origin
              xyz="-1.3028 -0.022176 1.2375E-07"
              rpy="0 0 0" />
            <mass
              value="0.0865" />
            <inertia
              ixx="2.7711"
              ixy="-0.013648"
              ixz="-5.2286E-07"
              iyy="3.0504"
              iyz="-1.0857E-09"
              izz="3.0095" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="file://$(find manipulater)/meshes/visual/link_8.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="joint_16"
          type="revolute">
          <origin
            xyz="0 0 0"
          <parent
            link="con_8" />
          <child
            link="link_8" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.5236"
            upper="0.5236"
            effort="2.0"
            velocity="0.5" />
        </joint>
      </robot>
      my launch file
      import os
          robot_name_in_model = 'manipulater'
          package_name = 'manipulater'
          urdf_name = "sd_mani.xacro"
          ld = LaunchDescription()
          # Start Gazebo servers
              cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so'],
              output='screen')
          # Launch the robot
          spawn_entity_cmd = Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-entity', robot_name_in_model,  '-file', urdf_model_path ], output='screen')
          return ld
      • H
        hitcxy2022
        我遇到了一模一样的问题,兄弟后来解决了吗
        H 1 条回复 最后回复 回复 引用 0
        • H
          hitcxy2022 @hitcxy2022
          @hitcxy2022 解决了,需要在package.xml文件的<export>标签中加入一行代码
          <gazebo_ros gazebo_model_path="${prefix}/.."/>
          作用为:通过该行语句可以修改ROS2的markerfile从而使得urdf文件中的package://能够正确解析到install/packagename/share中
