    四次换源均失败了
    一键安装 ros
    • 8388544358
      流年
      ./fishros: 3: ./fishros: source: not found
      E: 无法获得锁 /var/lib/dpkg/lock-frontend - open (11: 资源暂时不可用)
      E: 无法获取 dpkg 前端锁 (/var/lib/dpkg/lock-frontend),是否有其他进程正占用它?
      ./fishros: 10: [: -eq: unexpected operator
      --2023-04-21 10:09:56-- http://fishros.com/install/install1s/tools/base.py
      已发出 HTTP 请求,正在等待回应... 200 OK
      长度: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/tools/ba 100%[=====================================>] 41.21K --.-KB/s 用时 0.06s
      2023-04-21 10:09:56 (714 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42195/42195])
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2023-04-21 10:10:09-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      /tmp/fishinstall/tools/to 100%[=====================================>] 18.60K --.-KB/s 用时 0.03s
      2023-04-21 10:10:09 (727 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19050/19050])
      --2023-04-21 10:10:09-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      /tmp/fishinstall/tools/to 100%[=====================================>] 2.40K --.-KB/s 用时 0s
      2023-04-21 10:10:09 (214 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
      --2023-04-21 10:10:09-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      /tmp/fishinstall/tools/to 100%[=====================================>] 7.33K --.-KB/s 用时 0s
      2023-04-21 10:10:09 (724 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7511/7511])
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:code:100 EY F42ED6FBAB17C654[4,680 B]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: GPG 错误:https://packages.ros.org/ros/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “https://packages.ros.org/ros/ubuntu bionic InRelease” 没有数字签名。\n', 'W: GPG 错误:https://packages.ros.org/ros2/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “https://packages.ros.org/ros2/ubuntu bionic InRelease” 没有数字签名。\n']
      [-]Result:success
      [-]Result:success
      [-]Result:code:100 /ros/ubuntu bionic Release.gpg [833 B]]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: GPG 错误:http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease” 没有数字签名。\n', 'W: GPG 错误:http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release” 没有数字签名。\n']
      [-]Result:success e development metapackageKerberos
      [-]Result:success
      [-]Result:code:100 untu bionic Release.gpg [833 B]]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: GPG 错误:https://repo.huaweicloud.com/ros2/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “https://repo.huaweicloud.com/ros2/ubuntu bionic InRelease” 没有数字签名。\n', 'W: GPG 错误:https://repo.huaweicloud.com/ros/ubuntu bionic Release: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “https://repo.huaweicloud.com/ros/ubuntu bionic Release” 没有数字签名。\n']
      [-]Result:success
      [-]Result:code:100 EY F42ED6FBAB17C6544,680 B]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: GPG 错误:http://packages.ros.org/ros/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “http://packages.ros.org/ros/ubuntu bionic InRelease” 没有数字签名。\n', 'W: GPG 错误:http://packages.ros.org/ros2/ubuntu bionic InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY F42ED6FBAB17C654\n', 'E: 仓库 “http://packages.ros.org/ros2/ubuntu bionic InRelease” 没有数字签名。\n']
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'https://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
      [-]Result:code:2
      [-]Result:code:2
      ./fishros: 13: /root/.bashrc: shopt: not found
      ./fishros: 21: /root/.bashrc: shopt: not found
      请问该如何解决这个问题?感谢
        小鱼 技术大佬 @838854435
        @838854435 该问题已经修复,请再次尝试
