    导航中加上 sonar,无法加持膨胀层
    Nav2
    ros2 galactic nav2 ros2 sonar
    • 11573543821
      大预言家·福尔摩斯·睿
      小鱼老师好!各位大佬好!
      系统为ubuntu20 galactic 旭日X3派
      目前在导航中加入 超声波后,出现了个问题:
      costmap 中仅仅显示了 障碍物,没有给他铺上 膨胀层
      这是啥子情况?
      另附上这部分的代码:
            static_layer:
            sonar_layer:
              plugin: "nav2_costmap_2d::RangeSensorLayer"
              enabled: True
              topics: ["/sonar3"]
              phi: 1.2
              inflate_cone: 5.0
              no_readings_timeout: 0.0
              clear_threshold: 0.2
              mark_threshold: 0.8
              clear_on_max_reading: True
              input_sensor_type: ALL
            obstacle_layer:
                    enabled: True
                    observation_sources: scan
                    scan:
                      topic: /scan
                      max_obstacle_height: 0.3
                      clearing: True
                      marking: True
                      data_type: "LaserScan"
            inflation_layer:
              cost_scaling_factor: 5.0
              inflation_radius: 0.4
      恳请解答
      11573543821 1 条回复 最后回复 回复 引用 0
      • 11573543821
        大预言家·福尔摩斯·睿 @1157354382
        @1157354382 尼玛 插件加载顺序不对,但是有出来了一个问题:
        [controller_server-11] [INFO] [1682258773.781507330] [local_costmap.local_costmap]: Range sensor layer can't transform from odom to sonar3_link
        [controller_server-11] [INFO] [1682258773.981475366] [local_costmap.local_costmap]: Range sensor layer can't transform from odom to sonar3_link
        [controller_server-11] [INFO] [1682258774.281503211] [local_costmap.local_costmap]: Range sensor layer can't transform from odom to sonar3_link
        [planner_server-12] [INFO] [1682258774.353429141] [global_costmap.global_costmap]: Range sensor layer can't transform from map to sonar3_link
        这又是 啥情况阿 各位大佬
          小鱼 技术大佬 @1157354382
          @1157354382 看起来改下urdf
          1 条回复 最后回复 回复 引用 -1
