    ubuntu22.04,求助microros下载出现问题
    microros ubuntu22.04 ros2-humble
    • 25644694982
      陌角停落丶
      ubuntu版本22.04,ros2版本humble。在参考microros教程的时候,执行如下代码
      Source the ROS 2 installation
      source /opt/ros/$ROS_DISTRO/setup.bash
      Create a workspace and download the micro-ROS tools
      mkdir microros_ws
      cd microros_ws
      git clone -b $ROS_DISTRO https://github.com/micro-ROS/micro_ros_setup.git src/micro_ros_setup
      Update dependencies using rosdep
      sudo apt update && rosdep update
      rosdep install --from-paths src --ignore-src -y
      在rosdep install --from-paths src --ignore-src -y这一步报错(之前可以通过,现在不知道为什么不行了,这两个文件不知道去哪下)😧
      to system dependencies:
      rosidl_typesupport_microxrcedds_c: Cannot locate rosdep definition for [microcdr]
      rosidl_typesupport_microxrcedds_test_msg: Cannot locate rosdep definition for [rmw_microxrcedds]
      • 25644694982
        陌角停落丶
        把文件删除重新在来一遍就好了,不知道哪一步有问题
        1 条回复 最后回复 回复 引用 1
