    第十一章编译fishbot_navigation2报错,求助!!!
    ros2 第十一章 nav2
    • 4417555354
      头怎么还不秃啊
      终端日志如下
      (base) hdm@hdm-virtual-machine:~/d2lros2/nav2_ws/src/fishbot_navigation2$ colcon build
      [1.331s] WARNING:colcon.colcon_core.package_identification:Failed to parse ROS package manifest in '.': Error(s) in package './package.xml':
      Error(s):
      • The generic dependency on 'nav2_bringup' is redundant with: exec_depend
        Starting >>> fishbot_navigation2
        --- stderr: fishbot_navigation2
        Error parsing '/home/hdm/d2lros2/nav2_ws/src/fishbot_navigation2/package.xml':
        File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 150, in <module>
        File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 53, in main
        raise e
        File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 49, in main
        package = parse_package_string(
        File "/usr/lib/python3/dist-packages/catkin_pkg/package.py", line 786, in parse_package_string
        raise InvalidPackage('Error(s):%s' % (''.join(['\n- %s' % e for e in errors])), filename)
        catkin_pkg.package.InvalidPackage: Error(s) in package '/home/hdm/d2lros2/nav2_ws/src/fishbot_navigation2/package.xml':
        Error(s):
        CMake Error at /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:95 (message):
        execute_process(/usr/bin/python3.10
        /home/hdm/d2lros2/nav2_ws/src/fishbot_navigation2/build/fishbot_navigation2/ament_cmake_core/package.cmake)
        returned error code 1
        /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml)
        /opt/ros/humble/share/ament_lint_auto/cmake/ament_lint_auto_find_test_dependencies.cmake:31 (ament_package_xml)
        CMakeLists.txt:21 (ament_lint_auto_find_test_dependencies)
      Failed <<< fishbot_navigation2 [0.93s, exited with code 1]
      Summary: 0 packages finished [1.63s]
      1 package failed: fishbot_navigation2
      1 package had stderr output: fishbot_navigation2
      • 4417555354
        头怎么还不秃啊
        按照教程一步步来的,修改CMakeLists.txt和添加依赖都已经完成了
        • 4417555354
          头怎么还不秃啊
          ubuntu版本22.04 ros2版本humble
            小鱼 技术大佬 @441755535
            @441755535 在 第十一章编译fishbot_navigation2报错,求助!!! 中说:
            在 src 的同级目录编译
