    FastDDS环境搭建的时候报错
    dds fastdds安装问题
    5
    5
    817
    • Y
      yanghong2000719
      前面的都按照步骤顺利完成,但是当我第一次执行第三步的时候
      3.编译
      colcon build
      cd src/fastddsgen/ && gradle assemble
      的时候提示我缺少gradle,于是我 get-apt install gradle 了,
      然后再执行 gradle assemble 就出现下面的错误
      (base) yz@yz-computer:~/fastdds_ws/src/fastddsgen$ gradle assemble
      FAILURE: Build failed with an exception.
      * Where:
      Build file '/home/yz/fastdds_ws/src/fastddsgen/build.gradle' line: 23
      * What went wrong:
      Could not compile build file '/home/yz/fastdds_ws/src/fastddsgen/build.gradle'.
      > startup failed:
        build file '/home/yz/fastdds_ws/src/fastddsgen/build.gradle': 23: unable to resolve class org.gradle.api.tasks.options.Option
         @ line 23, column 1.
           import org.gradle.api.tasks.options.Option;
        1 error
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
      * Get more help at https://help.gradle.org
      BUILD FAILED in 0s
      小鱼小 9 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @yanghong2000719
        @yanghong2000719 conda 保持退出 ,重新尝试
        • 9
          -_-# @yanghong2000719
          @yanghong2000719 需执行后一步添加gradle环境
          echo 'export PATH=$PATH:xxx/fastdds_ws/gradle-6.4/bin/' >> ~/.bashrc
          后再
          source ~/.bashrc
            这个问题解决了吗?我照上面的方法都试过了,还是报上面的错误:
            • Where:
              Build file '/home/d2lros2/chapt3/fastdds_ws/src/fastddsgen/build.gradle' line: 23
            • What went wrong:
              Could not compile build file '/home/d2lros2/chapt3/fastdds_ws/src/fastddsgen/build.gradle'.
            startup failed:
            build file '/home/d2lros2/chapt3/fastdds_ws/src/fastddsgen/build.gradle': 23: unable to resolve class org.gradle.api.tasks.options.Option
            1 error
            • Try:
            • Get more help at https://help.gradle.org
            BUILD FAILED in 0s
            • 沐
              沐川雨愁颜
              需要先添加环境
              echo 'export PATH=$PATH:~/fastdds_ws/gradle-6.4/bin' >> ~/.bashrc
              重启终端然后运行
              gradle --version
              显示版本号即正常
              添加一句,gradle6.4不兼容java11以上的版本,需要安装特定版本
              sudo apt update
              sudo apt install openjdk-11-jdk openjdk-11-jre
              然后切换版本,选择对应java11的编号即可
              sudo update-alternatives --config java
              sudo update-alternatives --config javac
              然后清理缓存
              rm -rf ~/.gradle/caches/
              再重新运行gradle assemble即可
