    请问这个怎么解决
    ros2 编译出错
    • 24021310082
      2402131008
      编译报错
      CMake Error at CMakeLists.txt:16 (find_package):
        By not providing "Findarm_node.cmake" in CMAKE_MODULE_PATH this project has
        asked CMake to find a package configuration file provided by "arm_node",
        but CMake did not find one.
        Could not find a package configuration file provided by "arm_node" with any
        of the following names:
          arm_nodeConfig.cmake
          arm_node-config.cmake
        Add the installation prefix of "arm_node" to CMAKE_PREFIX_PATH or set
        "arm_node_DIR" to a directory containing one of the above files.  If
        "arm_node" provides a separate development package or SDK, be sure it has
        been installed.
      • ganyuanzhenG
        Elysia 技术大佬 @2402131008
        @2402131008
        按照提示,将arm_node的目录添加到CMAKE_PREFIX_PATH就好
        1 条回复 最后回复 回复 引用 1
