    如何在ros2中使用cuda
    cuda ros2 galactic cmake colcon build
    • 3748703613
      孤独的幸存者
      各位大佬好,现在有个问题,我自己用cmake写了一个cuda的静态库,用来加速处理图像,但是我用cmake编译没有问题,但是使用colcon buildi编译/usr/bin/ld就会报错:找不到静态库里的符号,请问各位大佬有思路解决吗?
      • ganyuanzhenG
        Elysia 技术大佬
        参考 colcon build 的使用帮助
        Arguments for 'cmake' packages:
          --cmake-args [* [* ...]]
                                Pass arguments to CMake projects. Arguments matching other options must be
                                prefixed by a space,
                                e.g. --cmake-args " --help" (stdout might not be shown by default, e.g.
                                add `--event-handlers console_cohesion+`)
          --cmake-target CMAKE_TARGET
                                Build a specific target instead of the default target
          --cmake-target-skip-unavailable
                                Skip building packages which don't have the target passed to --cmake-
                                target
          --cmake-clean-cache   Remove CMake cache before the build (implicitly forcing CMake configure
                                step)
          --cmake-clean-first   Build target 'clean' first, then build (to only clean use '--cmake-target
                                clean')
          --cmake-force-configure
                                Force CMake configure step
        Arguments for 'ros.ament_cmake' packages:
          --ament-cmake-args [* [* ...]]
                                Pass arguments to 'ament_cmake' packages. Arguments matching other options
                                must be prefixed by a space
        Arguments for 'ros.catkin' packages:
          --catkin-cmake-args [* [* ...]]
                                Pass arguments to 'catkin' packages. Arguments matching other options must
          --catkin-skip-building-tests
                                By default the 'tests' target of 'catkin' packages is invoked. If running
                                'colcon test' later isn't intended this can be skipped
        比如:
        $ colcon build  --ament-cmake-args -DTEST_PARAM="Test"
        Starting >>> example_ros2_interfaces
        Starting >>> example_cpp
        --- stderr: example_cpp
        CMake Error at CMakeLists.txt:9 (message):
          Test param detected! Aborting,
        使用了--ament-cmake-args 为cmake指定参数
        • ganyuanzhenG
          Elysia 技术大佬 @374870361
          可以这样将参数传递给cmake
          • 3748703613 374870361 将这个主题标记为已解决,在
