    动手学ros2中第7章的坐标变换发布监听python实现的课程演示代码报错
    tf2 坐标变换 ros2
    • 10392910161
      1039291016
      import rclpy
      from rclpy.node import Node
      from geometry_msgs.msg import TransformStamped
      from tf2_ros import StaticTransformBroadcaster
      rclpy.init()
      node = Node("transform_node")
      static_tf_pub = StaticTransformBroadcaster(node)
      t = TransformStamped()
      t.header.stamp = node.get_clock().now().to_msg()
      #parent-name:基坐标系B
      t.header.frame_id = 'B'
      #child-name:相机坐标系C
      t.header.frame_id = 'C'
      #平移关系,单位m
      t.transform.translation.x = 0.0
      t.transform.translation.y = 0.0
      t.transform.translation.z = 3.0
      #旋转关系,四元数形式,我们需要将欧拉角的形式转换成四元数
      t.transform.rotation.x = 1.0
      t.transform.rotation.y = 0.0
      t.transform.rotation.z = 0.0
      t.transform.rotation.w = 0.0
      static_tf_pub.sendTransform(t)
      !ros2 run tf2_ros tf2_echo B C
      就从这一步监听坐标关系执行开始报错
      [INFO] [1692175408.030060629] [tf2_echo]: Waiting for transform B -> 😄 Invalid frame ID "B" passed to canTransform argument target_frame - frame does not exist
      Error: TF_NO_CHILD_FRAME_ID: Ignoring transform from authority "Authority undetectable" because child_frame_id not set
      at line 217 in /tmp/binarydeb/ros-rolling-tf2-0.21.0/src/buffer_core.cpp
      [INFO] [1692175409.999420236] [tf2_echo]: Waiting for transform B -> 😄 Invalid frame ID "B" passed to canTransform argument target_frame - frame does not exist
      然后就一直循环报错提示目标帧不存在
      想问问这是哪里有问题呢?
        小鱼 技术大佬 @1039291016
        @1039291016
