    ROS订阅多个话题,但是始终无法进入回调函数内
    ros 回调函数 话题订阅
    1.7k
    • 22293647192
      编写的C++程序,订阅了两个话题,通过
      message_filters::TimeSynchronizer
      进行了同步然后传入回调函数处理,但是话题一直无法传入回调函数内,订阅的相关话题也均有内容发布并不是未发布或者错误话题。在编译和运行的过程中没有出现警告和错误。
      原始代码如下:
      #include <iostream>
      #include <boost/bind.hpp>
      #include <opencv2/opencv.hpp>
      #include <opencv2/core/core.hpp>
      #include <opencv2/highgui/highgui.hpp>
      #include <opencv2/imgproc.hpp>
      #include <cv_bridge/cv_bridge.h>
      #include <ros/ros.h>
      #include <message_filters/subscriber.h>
      #include <message_filters/time_synchronizer.h>
      #include <message_filters/sync_policies/approximate_time.h>
      #include <sensor_msgs/Image.h>
      #include "depthai_ros_msgs/SpatialDetection.h"
      #include "depthai_ros_msgs/SpatialDetectionArray.h"
      #include "detectmsg/pose2D.h"
      #include "detectmsg/multi_pedestrian_pose.h"
      void Callback(const depthai_ros_msgs::SpatialDetectionArray::ConstPtr& , const sensor_msgs::Image::ConstPtr& image)
        ROS_INFO("In!");
        cv::Mat img;
        cv_bridge::CvImagePtr cv_ptr;
        cv_ptr = cv_bridge::toCvCopy(image, "bgr8");//"bgr8"、"rgb8"、"mono8"
        cv_ptr->image.copyTo(img);
        cv::imshow("YOLO", img);
        cv::waitKey(3);
      int main(int argc, char **argv){
          ros::init(argc, argv, "obj_publish_node");
          ros::NodeHandle nh;
          message_filters::Subscriber<depthai_ros_msgs::SpatialDetectionArray> obj_sub_(nh, "/yolov4_publisher/color/yolov4_Spatial_detections", 1);
          message_filters::Subscriber<sensor_msgs::Image> image_sub_(nh, "/yolov4_publisher/color/image", 1);
          message_filters::TimeSynchronizer<depthai_ros_msgs::SpatialDetectionArray, sensor_msgs::Image> sync(obj_sub_, image_sub_, 1000);
          sync.registerCallback(boost::bind(&Callback, _1, _2));
          ros::spin();
          return 0;
      两个话题的发布情况如下:
      so@so-QiTianM437-A449:~/v5ros$ rostopic hz /yolov4_publisher/color/image
      subscribed to [/yolov4_publisher/color/image]
      average rate: 7.071
      	min: 0.011s max: 0.331s std dev: 0.12130s window: 6
      average rate: 7.210
      	min: 0.008s max: 0.331s std dev: 0.10411s window: 14
      average rate: 7.740
      	min: 0.005s max: 0.331s std dev: 0.08521s window: 23
      average rate: 7.706
      	min: 0.005s max: 0.331s std dev: 0.08848s window: 30
      average rate: 7.739
      	min: 0.001s max: 0.331s std dev: 0.08873s window: 37
      average rate: 7.737
      	min: 0.001s max: 0.331s std dev: 0.08291s window: 46
      average rate: 7.799
      	min: 0.001s max: 0.331s std dev: 0.07954s window: 50
      so@so-QiTianM437-A449:~/v5ros$ rostopic hz /yolov4_publisher/color/yolov4_Spatial_detections
      subscribed to [/yolov4_publisher/color/yolov4_Spatial_detections]
      average rate: 6.753
      	min: 0.001s max: 0.270s std dev: 0.08529s window: 7
      average rate: 7.090
      	min: 0.001s max: 0.301s std dev: 0.09249s window: 14
      average rate: 7.763
      	min: 0.001s max: 0.301s std dev: 0.08885s window: 23
      average rate: 7.554
      	min: 0.001s max: 0.301s std dev: 0.09299s window: 29
      average rate: 7.384
      	min: 0.001s max: 0.339s std dev: 0.09336s window: 37
      average rate: 7.631
      	min: 0.001s max: 0.339s std dev: 0.09092s window: 45
      average rate: 7.625
      	min: 0.001s max: 0.339s std dev: 0.09341s window: 50
          两个话题均是同一个节点所发,不存在频率差异过大等问题。也尝试将c++的代码改写为python,但也是一样无法进入回调函数内。
          同样的代码我在另外一套程序中订阅可以顺利进入回调,但是在该程序中迟迟无法进入回调,这个问题我无法解决,请有懂得的大佬帮我分析下是哪个环节出现了问题呢?
      小鱼小 A 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @2229364719
        @2229364719 核对下消息类型和时间戳,深度和彩色图像大小应该不同,传输速度不同,虽然频率接近,但可能存在时检差
        • A
          guyuechaocc @2229364719
          @2229364719 要不用Synchronizer ApproximateTime试一下
          https://blog.csdn.net/weixin_42803820/article/details/127113959
