    colcon build报错法
    ros2 colcon
    2.3k
      动手建模按照步骤操作到这步骤就出现无法编译
      (colcon build)
      /home/zj/.local/lib/python3.6/site-packages/setuptools/dist.py:726: UserWarning: Usage of dash-separated 'script-dir' will not be supported in future versions. Please use the underscore name 'script_dir' instead
        % (opt, underscore_opt)
      /home/zj/.local/lib/python3.6/site-packages/setuptools/dist.py:726: UserWarning: Usage of dash-separated 'install-scripts' will not be supported in future versions. Please use the underscore name 'install_scripts' instead
      --- stderr: fishbot_description
      /home/zj/.local/lib/python3.6/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
        setuptools.SetuptoolsDeprecationWarning,
      Finished <<< fishbot_description [1.27s]
      Summary: 1 package finished [1.58s]
        1 package had stderr output: fishbot_description
        小鱼 技术大佬 @15014960082
        @15014960082
        看这句话:
        在 colcon build报错法 中说:
        其实已经编译成功了,只不过编译工具有些bug,可以继续往下学。
        这个WAENING应该是setuptools版本造成的,后面保持和教程同样的foxy应该没问题了。
          15014960082 @小鱼
          @小鱼好的,谢谢您
          • 小鱼小 小鱼 从 中的 动手学ROS2 移动了该主题
