    bt_navigator启动报错:Original error: Could not load library: libnav2_smooth_path_action_bt_node.so
    Nav2
    galactic nav2 btnavigator
    2.2k
    • 3748703613
      孤独的幸存者
      ros2 galactic
      Orin jetson nano平台
      我的bt_navigator参数设置:
      bt_navigator:
        ros__parameters:
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          navigators: ["navigate_to_pose", "navigate_through_poses"]
          navigate_to_pose:
            plugin: "nav2_bt_navigator/NavigateToPoseNavigator"
          navigate_through_poses:
            plugin: "nav2_bt_navigator/NavigateThroughPosesNavigator"
          plugin_lib_names:
            - nav2_smooth_path_action_bt_node
            - nav2_spin_action_bt_node
            - nav2_wait_action_bt_node
            - nav2_assisted_teleop_action_bt_node
            - nav2_back_up_action_bt_node
            - nav2_drive_on_heading_bt_node
            - nav2_globally_updated_goal_condition_bt_node
            - nav2_is_path_valid_condition_bt_node
            - nav2_are_error_codes_active_condition_bt_node
            - nav2_would_a_controller_recovery_help_condition_bt_node
            - nav2_would_a_planner_recovery_help_condition_bt_node
            - nav2_would_a_smoother_recovery_help_condition_bt_node
            - nav2_truncate_path_local_action_bt_node
            - nav2_recovery_node_bt_node
            - nav2_path_expiring_timer_condition
            - nav2_single_trigger_bt_node
            - nav2_goal_updated_controller_bt_node
            - nav2_controller_cancel_bt_node
            - nav2_path_longer_on_approach_bt_node
            - nav2_wait_cancel_bt_node
            - nav2_spin_cancel_bt_node
            - nav2_back_up_cancel_bt_node
            - nav2_assisted_teleop_cancel_bt_node
            - nav2_drive_on_heading_cancel_bt_node
            - nav2_is_battery_charging_condition_bt_node
      报错信息:
      [bt_navigator-6] [ERROR] [1698310229.538125499] []: Caught exception in callback for transition 13
      [bt_navigator-6] [ERROR] [1698309361.735674300] []: Original error: Error at line 12: -> Node not recognized: RemovePassedGoals
      [bt_navigator-6] [WARN] [1698309361.735721758] []: Error occurred while doing error handling.
      [bt_navigator-6] [FATAL] [1698309361.735738942] [bt_navigator]: Lifecycle node bt_navigator does not have error state implemented
      [lifecycle_manager-8] [ERROR] [1698309361.736910506] [lifecycle_manager_navigation]: Failed to change state for node: bt_navigator
        小鱼 技术大佬 @374870361
        @374870361 在 bt_navigator启动报错:Original error: Could not load library: libnav2_smooth_path_action_bt_node.so 中说:
        RemovePassedGoals 这个找找配置文件
        3748703613 1 条回复 最后回复 回复 引用 0
        • 3748703613
          孤独的幸存者 @小鱼
          @小鱼 这个配置文件应该在哪里找呢?
          • 31080966853
            暖光
            请问这个问题您解决了吗?
