    [Fishbot-Nav2] 使用官方代码和套件导航部分出错
    fishbot 导航 nav导航出错 nav2教程中遇到的问题
    1.2k
      wusenyao
      FishBot基础版*1台
      装有Ubuntu22.04和ROS2 foxy的台式机
      在烧录成功之后直接按照网站上的步骤进行操作的
      建图之后,启动雷达并进行导航出现问题
      ab9a301b-bb69-47d3-abce-55ffb429028e-导航问题1 navigation状态为inactive.png file:///home/water/%E5%9B%BE%E7%89%87/%E5%AF%BC%E8%88%AA%E9%97%AE%E9%A2%981%20navigation%E7%8A%B6%E6%80%81%E4%B8%BAinactive.png
      在导航设置小车位置的过程点击 2F Point Estimate 设置点和方向之后,rviz中navigation状态为激活(inactive),无法进行设置Nav2 Goal进行导航
      图2:bring_up终端输出
      f72d9851-afe9-45bf-a430-6ded2ba77789-运行一段时间后的雷达终端.png /home/water/图片/运行一段时间后的雷达终端.png
      图三:雷达终端输出:提示无法成功获取激光扫描数据,但rviz界面中雷达能够实时检测到新出现和拿走的障碍物
      图4:未发布NAV2 goal时rviz终端输出:[rviz2-10] [INFO] [1704165843.579489071] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1704165842.209 for reason 'Unknown'
      [rviz2-10] [INFO] [1704165843.675628045] [rviz2]: Message Filter dropping message: frame 'odom' at time 1704165841.670 for reason 'Unknown'
      [rviz2-10] [INFO] [1704165843.707778356] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1704165842.339 for reason 'Unknown'
      [planner_server-5] [INFO] [1704165843.697214607] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'laser_frame' at time 1704165837.161 for reason 'Unknown'
      [planner_server-5] [INFO] [1704165843.833627778] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'laser_frame' at time 1704165837.351 for reason 'Unknown'
      显示消息过滤器错误,
      [planner_server-5] [ERROR] [1704165843.777807751] [getCurrentPose]: Extrapolation Error looking up robot pose: Lookup would require extrapolation into the past. Requested time 1704165381.698632 but the earliest data is at time 1704165833.635287, when looking up transform from frame [base_link] to frame [map]
      在planner_server的getCurrentPose函数中发生了坐标变换错误
      图5:导航失败的rviz终端输出:目标被服务器拒绝,出现节点状态转换问题,map_server 状态转换问题
      以下为节点列表
      (base) water@water-MS-7C95:~/fishbot$ ros2 topic list
      /bt_navigator/transition_event
      /clicked_point
      /cmd_vel
      /controller_server/transition_event
      /cost_cloud
      /downsampled_costmap
      /downsampled_costmap_updates
      /evaluation
      /global_costmap/costmap
      /global_costmap/costmap_raw
      /global_costmap/costmap_updates
      /global_costmap/footprint
      /global_costmap/global_costmap/transition_event
      /global_costmap/published_footprint
      /global_costmap/voxel_marked_cloud
      /goal_pose
      /imu
      /initialpose
      /joint_states
      /local_costmap/clearing_endpoints
      /local_costmap/costmap
      /local_costmap/costmap_raw
      /local_costmap/costmap_updates
      /local_costmap/footprint
      /local_costmap/local_costmap/transition_event
      /local_costmap/published_footprint
      /local_costmap/voxel_grid
      /local_costmap/voxel_marked_cloud
      /local_plan
      /map
      /map_server/transition_event
      /map_updates
      /marker
      /mobile_base/sensors/bumper_pointcloud
      /odom
      /parameter_events
      /particlecloud
      /plan
      /planner_server/transition_event
      /received_global_plan
      /recoveries_server/transition_event
      /robot_description
      /rosout
      /scan
      /tf
      /tf_static
      /transformed_global_plan
      /waypoint_follower/transition_event
      /waypoints
      以下为tf树
      rviz界面雷达能正常识别出现和拿走的障碍物
        小鱼 技术大佬 @wusenyao
        @wusenyao 在 [Fishbot-Nav2] 使用官方代码和套件导航部分出错 中说:
        ROS2 foxy
        请更换为 humble版本
