    编译vins_fusion遇到opencv库链接冲突
    ros1编译 opencv版本冲突 vinsfusion vins-fusion
    • 27903416152
      细火荒原
      https://github.com/HKUST-Aerial-Robotics/VINS-Fusion
      catkin_make结果:
      [ 90%] Linking CXX executable /home/bluesea/vins_ws/devel/lib/loop_fusion/loop_fusion_node
      /usr/bin/ld: warning: libopencv_calib3d.so.3.4, needed by /home/bluesea/vins_ws/devel/lib/libcamera_models.so, may conflict with libopencv_calib3d.so.4.2
      /usr/bin/ld: warning: libopencv_imgproc.so.3.4, needed by /home/bluesea/vins_ws/devel/lib/libcamera_models.so, may conflict with libopencv_imgproc.so.4.2
      /usr/bin/ld: warning: libopencv_core.so.3.4, needed by /home/bluesea/vins_ws/devel/lib/libcamera_models.so, may conflict with libopencv_core.so.4.2
      /usr/bin/ld: warning: libopencv_video.so.4.2, needed by /home/bluesea/vins_ws/devel/lib/libvins_lib.so, may conflict with libopencv_video.so.3.4
      /usr/bin/ld: warning: libopencv_imgcodecs.so.3.4, needed by /home/bluesea/vins_ws/devel/lib/libvins_lib.so, may conflict with libopencv_imgcodecs.so.4.2
      /usr/bin/ld: warning: libopencv_core.so.3.4, needed by /usr/local/lib/libopencv_video.so.3.4.11, may conflict with libopencv_core.so.4.2
      [ 98%] Built target kitti_gps_test
      [ 98%] Built target kitti_odom_test
      [100%] Built target vins_node
      运行节点vins_node报错:段错误(核心已转储)
      尝试解决:
      https://blog.csdn.net/qq_52068373/article/details/127871743
      将/opt/ros/noetic/share/cv_bridge/cmake/cv_bridgeConfig.cmake按照博客中的修改后编译报错
      -- +++ processing catkin package: 'loop_fusion'
      -- ==> add_subdirectory(VINS-Fusion/loop_fusion)
      -- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
      CMake Error at /opt/ros/noetic/share/cv_bridge/cmake/cv_bridgeConfig.cmake:173 (message):
        Project 'loop_fusion' tried to find library
        'usr/local/lib/libopencv_calib3d.so'.  The library is neither a target nor
        built/installed properly.  Did you compile project 'cv_bridge'? Did you
        find_package() it before the subdirectory containing its code is included?
        /opt/ros/noetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
        VINS-Fusion/loop_fusion/CMakeLists.txt:9 (find_package)
      -- Configuring incomplete, errors occurred!
      请问如何解决😭
      • ganyuanzhenG
        Elysia 技术大佬 @2790341615
        @2790341615 我也遇到过。有个功能只有在高版本的OpenCV中才有实现。
        最后的解决方法为,将冲突的包在本地编译而不是安装ROS编译好的版本,就可以统一使用编译环境的OpenCV了。
        如果是一些内置包,比如CV_Bridge之类的,有许多其他包依赖无法卸载的,我的做法是拉取源码,然后把包名批量替换为my_cv_bridge,然后只在我需要不同的OpenCV版本的地方才用这个自己替换后的包,达到统一版本的效果。
        • 27903416152
          细火荒原
          十分简单和无语:不用改cv_bridgeConfig,由于ros使用4.2,只要vins也用4.2就行了,在报错的功能包cmakelist加入find_package(OpenCV 4),并将 #include "opencv2/imgcodecs/legacy/constants_c.h" 在任意一个 .cpp file(如KITTIGPSTest.cpp)就可以了
