    ROS2 gazebo深度相机话题发布频率无法改变
    ros2 humble gazebo camera topic
    1.3k
    • 19061074851
      1906107485
      ROS版本:ROS2 humble
      Ubuntu版本:22.04
      urdf文件代码:
      <gazebo reference="camera_link">
          <sensor name="camera" type="depth">
            <always_on>true</always_on>
            <update_rate>100</update_rate>
            <camera>
              <horizontal_fov>1.047198</horizontal_fov>
              <image>
                <width>640</width>
                <height>480</height>
                <format>R8G8B8</format>
              </image>
              <clip>
                <near>0.05</near>
                <far>2</far>
              </clip>
            </camera>
            <plugin name="depth_controller" filename="libgazebo_ros_camera.so">
              <baseline>0.2</baseline>
              <camera_name>camera</camera_name>
              <frame_name>camera_link</frame_name>
              <ros>
                <namespace>camera_ns</namespace>
                <remapping>camera/image_raw:=camera/image</remapping>
                <remapping>camera/image_depth:=camera/image_depth</remapping>
                <remapping>camera/camera_info:=camera/info_raw</remapping>
                <remapping>camera/camera_info_depth:=camera/info_depth</remapping>
                <remapping>camera/points:=camera/points</remapping>
              </ros>
              <min_depth>0.05</min_depth>
              <max_depth>3.0</max_depth>
              <hack_baseline>0</hack_baseline>
            </plugin>
          </sensor>
        </gazebo>
      <update_rate></update_rate>参数怎么改都没用,相机话题发布频率一直是个位数(一般在二点几左右,有时候稍微高一点),但其他参数都有效。
      终端测试:
      -virtual-machine:~$ ros2 topic hz /camera_ns/camera/points
      average rate: 2.670
      	min: 0.086s max: 0.633s std dev: 0.23781s window: 5
      average rate: 2.437
      	min: 0.077s max: 0.856s std dev: 0.27464s window: 8
      average rate: 2.178
      	min: 0.077s max: 1.112s std dev: 0.31849s window: 11
      average rate: 2.269
      	min: 0.077s max: 1.112s std dev: 0.30068s window: 14
      average rate: 2.337
      	min: 0.077s max: 1.112s std dev: 0.27097s window: 18
      average rate: 2.227
      	min: 0.077s max: 1.189s std dev: 0.31681s window: 20
      average rate: 2.167
      	min: 0.076s max: 1.189s std dev: 0.34131s window: 22
      average rate: 2.042
      	min: 0.076s max: 1.308s std dev: 0.37178s window: 25
      average rate: 2.258
      	min: 0.076s max: 1.308s std dev: 0.35621s window: 30
      average rate: 2.302
      	min: 0.067s max: 1.308s std dev: 0.35243s window: 33
      求助
        你好
        同样遇到这个问题,相机的频率很低,该怎么解决呢“?”
