    humble编译 FishBot主仓库-https://github.com/fishros/fishbot 代码报错
    ros2-humble fishbot cartographer
    1.9k
    • 27616077292
      赤诚
      最后由 2761607729 编辑
      在编译到cartographer_ros功能包时报错
      [1.697s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'cartographer_ros' is in: /home/hjq/fishbot/install/cartographer_ros, /opt/ros/humble
      If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      --allow-overriding cartographer_ros
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> cartographer_ros
      --- stderr: cartographer_ros
      /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp: In member function ‘virtual void cartographer_ros::ScopedRosLogSink::send(google::LogSeverity, const char*, const char*, int, const tm*, const char*, size_t)’:
      /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp:49:46: error: cannot convert ‘const tm* const’ to ‘const google::LogMessageTime&’
      49 | severity, GetBasename(filename), line, tm_time, message, message_len);
      | const tm* const
      In file included from /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/include/cartographer_ros/ros_log_sink.h:22,
      from /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp:17:
      /usr/local/include/glog/logging.h:1777:53: note: initializing argument 4 of ‘static std::string google::LogSink::ToString(google::LogSeverity, const char*, int, const google::LogMessageTime&, const char*, size_t)’
      1777 | const LogMessageTime &logmsgtime,
      gmake[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:188:CMakeFiles/cartographer_ros.dir/src/ros_log_sink.cpp.o] 错误 1
      gmake[2]: *** 正在等待未完成的任务....
      gmake[1]: *** [CMakeFiles/Makefile2:151:CMakeFiles/cartographer_ros.dir/all] 错误 2
      gmake: *** [Makefile:146:all] 错误 2****************************
      Failed <<< cartographer_ros [13.5s, exited with code 2]
      Summary: 0 packages finished [14.7s]
      1 package failed: cartographer_ros
      1 package had stderr output: cartographer_ros
        小鱼 技术大佬 @2761607729
        @2761607729 请直接二进制安装使用
        27616077292 1 条回复 最后回复 回复 引用 0
        • 27616077292
          赤诚 @小鱼
          @小鱼 具体怎么安装,是直接安装cartographer_ros这个功能包嘛
            小鱼 技术大佬 @2761607729
            @2761607729 对的 sudo apt 安装的就是二进制的
            • 27616077292
              赤诚 @小鱼
              @小鱼具体指令是什么呢
                小鱼 技术大佬 @2761607729
                @2761607729 https://fishros.org.cn/forum/topic/111/ros-ros2功能包在线索引网站 先到这里检索是否发布,发布了的就是
                sudo apt install ros-版本名称(如 humble)-xxx-xxx
                EG:
                sudo apt install ros-humble-ros-humble-cartographer
