    ros2humble自定义消息类型报错
    ros2 msg ros2-humble
    877
    • 19415486111
      曾爱鱼愿婚
      报错:
      gmake[2]: *** [CMakeFiles/my_package__rosidl_typesupport_fastrtps_c.dir/build.make:123:CMakeFiles/my_package__rosidl_typesupport_fastrtps_c.dir/rosidl_typesupport_fastrtps_c/my_package/msg/detail/my_msg__type_support_c.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:239:CMakeFiles/my_package__rosidl_typesupport_fastrtps_c.dir/all] 错误 2
      gmake[1]: *** 正在等待未完成的任务....
      gmake[2]: *** [CMakeFiles/my_package__rosidl_typesupport_fastrtps_cpp.dir/build.make:123:CMakeFiles/my_package__rosidl_typesupport_fastrtps_cpp.dir/rosidl_typesupport_fastrtps_cpp/my_package/msg/detail/dds_fastrtps/my_msg__type_support.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:291:CMakeFiles/my_package__rosidl_typesupport_fastrtps_cpp.dir/all] 错误 2
      Failed   <<< my_package [2.20s, exited with code 2]
      Summary: 0 packages finished [2.59s]
        1 package failed: my_package
        1 package had stderr output: my_package
      cmakelist.txt:
      project(my_package)
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
        "msg/MyMsg.msg"
        DEPENDENCIES std_msgs
      ament_export_dependencies(rosidl_default_runtime)
      ament_package()
      package.xml:
      <?xml version="1.0"?>
      <package format="3">
        <name>my_package</name>
        <version>0.0.1</version>
        <maintainer email="123456@qq.com">henglin</maintainer>
        <license>Apache License 2.0</license>
        <buildtool_depend>rosidl_default_generators</buildtool_depend>
        <build_depend>std_msgs</build_depend>
        <exec_depend>rosidl_default_runtime</exec_depend>
        <exec_depend>std_msgs</exec_depend>
        <export>
          <depend>std_msgs</depend>
          <depend>rosidl_default_generators</depend>
        </export>
      </package>
      msg文件:
      string publisher_id
      float64 x
      float64 y
      float64 z
      • 19415486111 1941548611 将这个主题转为问答主题,在
        小鱼 技术大佬 @1941548611
        @1941548611 把完整报错贴出来
        19415486111 1 条回复 最后回复 回复 引用 0
        • 19415486111
          曾爱鱼愿婚
          原报错非常长,好几万字符,这是部分报错:
          /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_c/more_interfaces/msg/detail/key_board_value__functions.c: In function ‘more_interfaces__msg__KeyBoardValue__create’:
          /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_c/more_interfaces/msg/detail/key_board_value__functions.c:91:3: warning: implicit declaration of function ‘memset’ [-Wimplicit-function-declaration]
             91 |   memset(msg, 0, sizeof(more_interfaces__msg__KeyBoardValue));
          /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_c/more_interfaces/msg/detail/key_board_value__functions.c:12:1: note: include ‘<string.h>’ or provide a declaration of ‘memset’
             11 | #include "rcutils/allocator.h"
            +++ |+#include <string.h>
             12 |
          /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_c/more_interfaces/msg/detail/key_board_value__functions.c:91:3: warning: incompatible implicit declaration of built-in function ‘memset’ [-Wbuiltin-declaration-mismatch]
          /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_c/more_interfaces/msg/detail/key_board_value__functions.c:91:3: note: include ‘<string.h>’ or provide a declaration of ‘memset’
          In file included from /usr/include/stdint.h:26,
                           from /usr/lib/gcc/x86_64-linux-gnu/11/include/stdint.h:9,
                           from /opt/ros/humble/include/rmw/features.h:24,
                           from /usr/include/x86_64-linux-gnu/c++/11/bits/os_defines.h:39,
                           from /usr/include/x86_64-linux-gnu/c++/11/bits/c++config.h:586,
                           from /usr/include/c++/11/utility:68,
                           from /usr/include/c++/11/algorithm:60,
                           from /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_generator_cpp/more_interfaces/msg/detail/key_board_value__struct.hpp:8,
                           from /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_typesupport_fastrtps_cpp/more_interfaces/msg/detail/key_board_value__rosidl_typesupport_fastrtps_cpp.hpp:11,
                           from /home/henglin/view_he/project_6/QtWidgetsApplication1/build/more_interfaces/rosidl_typesupport_fastrtps_cpp/more_interfaces/msg/detail/dds_fastrtps/key_board_value__type_support.cpp:4:
          /usr/include/x86_64-linux-gnu/bits/libc-header-start.h:74:17: error: missing binary operator before token "("
             74 | #if __GLIBC_USE (IEC_60559_BFP_EXT) || __GLIBC_USE (ISOC2X)
          /usr/include/x86_64-linux-gnu/bits/libc-header-start.h:80:17: error: missing binary operator before token "("
             80 | #if __GLIBC_USE (IEC_60559_BFP_EXT) || defined __STDC_WANT_IEC_60559_EXT__
          /usr/include/x86_64-linux-gnu/bits/libc-header-start.h:97:17: error: missing binary operator before token "("
             97 | #if __GLIBC_USE (IEC_60559_FUNCS_EXT) || __GLIBC_USE (ISOC2X)
          In file included from /usr/lib/gcc/x86_64-linux-gnu/11/include/stdint.h:9,
          /usr/include/stdint.h:276:17: error: missing binary operator before token "("
            276 | #if __GLIBC_USE (IEC_60559_BFP_EXT_C2X)
          In file included from /usr/include/stdio.h:27,
                           from /opt/ros/humble/include/rcutils/rcutils/testing/fault_injection.h:18,
                           from /opt/ros/humble/include/rcutils/rcutils/macros.h:146,
                           from /opt/ros/humble/include/rcutils/rcutils/allocator.h:28,
                           from /opt/ros/humble/include/rmw/features.h:26,
          In file included from /opt/ros/humble/include/rcutils/rcutils/testing/fault_injection.h:18,
          /usr/include/stdio.h:136:17: error: missing binary operator before token "("
            136 | #if __GLIBC_USE (ISOC2X)
          /usr/include/stdio.h:306:43: error: missing binary operator before token "("
            306 | #if defined __USE_XOPEN2K8 || __GLIBC_USE (LIB_EXT2)
          /usr/include/stdio.h:387:17: error: missing binary operator before token "("
            387 | #if __GLIBC_USE (LIB_EXT2)
          In file included from /usr/include/stdio.h:430,
          /usr/include/x86_64-linux-gnu/bits/floatn.h:30:22: error: missing binary operator before token "("
             30 |      ? __GNUC_PREREQ (4, 3)                                             \
          • 19415486111
            曾爱鱼愿婚 @小鱼
            @小鱼 都是一堆标准库未声明,找不到定义之类的问题
              小鱼 技术大佬 @1941548611
              @1941548611 重新换个系统或环境看看吧,目前我也看不出具体问题,感觉和上下文环境有关系
              • 19415486111
                曾爱鱼愿婚 @小鱼
                @小鱼 现在的报错情况就是,只有自定义消息类型功能用不了,其他ros2功能正常;报错中显示了gcc的头文件有问题,单独使用头文件编译都正常,生成可执行文件,现在就完全不知道啥情况,单独使用没问题,一起用就有问题
                  小鱼 技术大佬 @1941548611
                  @1941548611 考虑还是环境问题,重装麻烦可以试试docker中构建
                  • 16287993151
                    早点睡晚安吧
                    同问 解决了嘛?
