    gazebo, No p gain specified for pid.
    ros gazebo pid
    2.4k
    • 8212348778
      心中有梦想!
      在终端运行launch文件后,提示无法获取pid,这个错误怎么改?(错误在代码最后)
      ros1@ubuntu:~$ roslaunch ur_gazebo ur5.launch
      ... logging to /home/ros1/.ros/log/9464e26c-dc92-11ec-9691-000c2939b349/roslaunch-ubuntu-4950.log
      Press Ctrl-C to interrupt
      xacro: in-order processing became default in ROS Melodic. You can drop the option.
      started roslaunch server http://ubuntu:42715/
      SUMMARY
      PARAMETERS
       * /arm_controller/action_monitor_rate: 10
       * /arm_controller/constraints/elbow_joint/goal: 0.1
       * /arm_controller/constraints/elbow_joint/trajectory: 0.1
       * /arm_controller/constraints/goal_time: 0.6
       * /arm_controller/constraints/shoulder_lift_joint/goal: 0.1
       * /arm_controller/constraints/shoulder_lift_joint/trajectory: 0.1
       * /arm_controller/constraints/shoulder_pan_joint/goal: 0.1
       * /arm_controller/constraints/shoulder_pan_joint/trajectory: 0.1
       * /arm_controller/constraints/stopped_velocity_tolerance: 0.05
       * /arm_controller/constraints/wrist_1_joint/goal: 0.1
       * /arm_controller/constraints/wrist_1_joint/trajectory: 0.1
       * /arm_controller/constraints/wrist_2_joint/goal: 0.1
       * /arm_controller/constraints/wrist_2_joint/trajectory: 0.1
       * /arm_controller/constraints/wrist_3_joint/goal: 0.1
       * /arm_controller/constraints/wrist_3_joint/trajectory: 0.1
       * /arm_controller/joints: ['shoulder_pan_jo...
       * /arm_controller/state_publish_rate: 25
       * /arm_controller/stop_trajectory_duration: 0.5
       * /arm_controller/type: position_controll...
       * /gazebo/enable_ros_network: True
       * /joint_group_position_controller/joints: ['shoulder_pan_jo...
       * /joint_group_position_controller/type: position_controll...
       * /joint_state_controller/publish_rate: 50
       * /joint_state_controller/type: joint_state_contr...
       * /robot_description: <?xml version="1....
       * /robot_state_publisher/publish_frequency: 50.0
       * /robot_state_publisher/tf_prefix:
       * /rosdistro: melodic
       * /rosversion: 1.14.13
       * /use_sim_time: True
      NODES
          arm_controller_spawner (controller_manager/controller_manager)
          fake_joint_calibration (rostopic/rostopic)
          gazebo (gazebo_ros/gzserver)
          gazebo_gui (gazebo_ros/gzclient)
          joint_state_controller_spawner (controller_manager/controller_manager)
          robot_state_publisher (robot_state_publisher/robot_state_publisher)
          ros_control_controller_manager (controller_manager/controller_manager)
          spawn_gazebo_model (gazebo_ros/spawn_model)
      auto-starting new master
      process[master]: started with pid [4964]
      ROS_MASTER_URI=http://localhost:11311
      setting /run_id to 9464e26c-dc92-11ec-9691-000c2939b349
      process[rosout-1]: started with pid [4975]
      started core service [/rosout]
      process[gazebo-2]: started with pid [4978]
      process[gazebo_gui-3]: started with pid [4983]
      process[spawn_gazebo_model-4]: started with pid [4988]
      process[robot_state_publisher-5]: started with pid [4989]
      process[fake_joint_calibration-6]: started with pid [4990]
      process[joint_state_controller_spawner-7]: started with pid [4991]
      process[arm_controller_spawner-8]: started with pid [4992]
      process[ros_control_controller_manager-9]: started with pid [4993]
      INFO: cannot create a symlink to latest log directory: [Errno 2] No such file or directory: '/home/ros1/.ros/log/latest'
      [ INFO] [1653528273.312356156]: Finished loading Gazebo ROS API Plugin.
      [ INFO] [1653528273.313913371]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
      [ INFO] [1653528273.315547444]: Finished loading Gazebo ROS API Plugin.
      [ INFO] [1653528273.318966283]: waitForService: Service [/gazebo_gui/set_physics_properties] has not been advertised, waiting...
      [INFO] [1653528273.682005, 0.000000]: Loading model XML from ros parameter robot_description
      [INFO] [1653528273.687196, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
      [INFO] [1653528273.990580, 0.000000]: Calling service /gazebo/spawn_urdf_model
      [ INFO] [1653528274.007385787]: waitForService: Service [/gazebo/set_physics_properties] is now available.
      [INFO] [1653528274.172253, 0.080000]: Spawn status: SpawnModel: Successfully spawned entity
      [ INFO] [1653528274.181652473, 0.080000000]: Physics dynamic reconfigure ready.
      [spawn_gazebo_model-4] process has finished cleanly
      log file: /home/ros1/.ros/log/9464e26c-dc92-11ec-9691-000c2939b349/spawn_gazebo_model-4*.log
      [ INFO] [1653528274.338302231, 0.080000000]: Loading gazebo_ros_control plugin
      [ INFO] [1653528274.338409893, 0.080000000]: Starting gazebo_ros_control plugin in namespace: /
      [ INFO] [1653528274.366716428, 0.080000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
      [ERROR] [1653528274.544997120, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/shoulder_pan_joint
      [ERROR] [1653528274.545650376, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/shoulder_lift_joint
      [ERROR] [1653528274.546259007, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/elbow_joint
      [ERROR] [1653528274.546905662, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/wrist_1_joint
      [ERROR] [1653528274.547510958, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/wrist_2_joint
      [ERROR] [1653528274.548099060, 0.080000000]: No p gain specified for pid.  Namespace: /gazebo_ros_control/pid_gains/wrist_3_joint
      25911024232 1 条回复 最后回复 回复 引用 0
      • 25911024232
        灞気水笵er @821234877
        @821234877 解决了吗啊,giegie
        • 吴凯荣吴
          吴凯荣
          无视即可,无伤大雅
          1 条回复 最后回复 回复 引用 1
            小鱼 技术大佬 @2591102423
            @2591102423 无视即可,自己调的效果还不如不配的。
            1 条回复 最后回复 回复 引用 1
