    Action client not connected: gluon_controller/follow_joint_trajectory
    机械臂运动规划
    moveit gazebo
    3.4k
      四季闲
      主要问题:
      Waiting for gluon_controller/follow_joint_trajectory to come up
      follow_joint_trajectory始终处于打不开的状态,可以从下面出问题机械臂和正常机械臂的rostopic 和rqt_graph看出,关键就是没有follow_joint_trajectory
      背景:
      rostopic list | grep -i goal
      出问题的机械臂
      可以正常运行ur机械臂
      rqt_graph
      出问题的机械臂
      可以正常运行ur机械臂
      tf_tree
      完整topic
      /attached_collision_object
      /calibrated
      /clicked_point
      /clock
      /collision_object
      /execute_trajectory/cancel
      /execute_trajectory/feedback
      /execute_trajectory/goal
      /execute_trajectory/result
      /execute_trajectory/status
      /gazebo/link_states
      /gazebo/model_states
      /gazebo/parameter_descriptions
      /gazebo/parameter_updates
      /gazebo/set_link_state
      /gazebo/set_model_state
      /gluon/joint_states
      /head_mount_kinect/depth_registered/camera_info
      /head_mount_kinect/depth_registered/image_raw
      /head_mount_kinect/depth_registered/points
      /initialpose
      /joint_states
      /move_base_simple/goal
      /move_group/camera_info
      /move_group/cancel
      /move_group/display_contacts
      /move_group/display_planned_path
      /move_group/feedback
      /move_group/filtered_cloud
      /move_group/filtered_cloud/compressed
      /move_group/filtered_cloud/compressed/parameter_descriptions
      /move_group/filtered_cloud/compressed/parameter_updates
      /move_group/filtered_cloud/compressedDepth
      /move_group/filtered_cloud/compressedDepth/parameter_descriptions
      /move_group/filtered_cloud/compressedDepth/parameter_updates
      /move_group/filtered_cloud/theora
      /move_group/filtered_cloud/theora/parameter_descriptions
      /move_group/filtered_cloud/theora/parameter_updates
      /move_group/filtered_label
      /move_group/filtered_label/compressed
      /move_group/filtered_label/compressed/parameter_descriptions
      /move_group/filtered_label/compressed/parameter_updates
      /move_group/filtered_label/compressedDepth
      /move_group/filtered_label/compressedDepth/parameter_descriptions
      /move_group/filtered_label/compressedDepth/parameter_updates
      /move_group/filtered_label/theora
      /move_group/filtered_label/theora/parameter_descriptions
      /move_group/filtered_label/theora/parameter_updates
      /move_group/goal
      /move_group/model_depth
      /move_group/model_depth/compressed
      /move_group/model_depth/compressed/parameter_descriptions
      /move_group/model_depth/compressed/parameter_updates
      /move_group/model_depth/compressedDepth
      /move_group/model_depth/compressedDepth/parameter_descriptions
      /move_group/model_depth/compressedDepth/parameter_updates
      /move_group/model_depth/theora
      /move_group/model_depth/theora/parameter_descriptions
      /move_group/model_depth/theora/parameter_updates
      /move_group/monitored_planning_scene
      /move_group/ompl/parameter_descriptions
      /move_group/ompl/parameter_updates
      /move_group/plan_execution/parameter_descriptions
      /move_group/plan_execution/parameter_updates
      /move_group/planning_scene_monitor/parameter_descriptions
      /move_group/planning_scene_monitor/parameter_updates
      /move_group/result
      /move_group/sense_for_plan/parameter_descriptions
      /move_group/sense_for_plan/parameter_updates
      /move_group/status
      /move_group/trajectory_execution/parameter_descriptions
      /move_group/trajectory_execution/parameter_updates
      /pickup/cancel
      /pickup/feedback
      /pickup/goal
      /pickup/result
      /pickup/status
      /place/cancel
      /place/feedback
      /place/goal
      /place/result
      /place/status
      /planning_scene
      /planning_scene_world
      /recognized_object_array
      /rosout
      /rosout_agg
      /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/feedback
      /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/update
      /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/update_full
      /rviz_rosmelodic_virtual_machine_3862_6057847670560700822/motionplanning_planning_scene_monitor/parameter_descriptions
      /rviz_rosmelodic_virtual_machine_3862_6057847670560700822/motionplanning_planning_scene_monitor/parameter_updates
      /tf
      /tf_static
      /trajectory_execution_event
      * 列表
      尝试过的思路:
      1、有东西未安装:已尝试,未果
      2、命名空间:
      许多人的解决思路是使命名空间相同,但我看我的命名空间是一致的。
      ros_controllers.yaml中名字即使换成下面这个依旧有相同报错
      joint_state_controller:
      -name:gluon/gluon_controller
      下面是yaml文件:
      gluon_controllers.yaml
      gluon:
        gluon_controller:
          type: "position_controllers/JointTrajectoryController"
          joints:
            - axis_joint_1
            - axis_joint_2
            - axis_joint_3
            - axis_joint_4
            - axis_joint_5
            - axis_joint_6
        gains:
            axis_joint_1:   {p: 100, i: 0.01, d: 10.0}
            axis_joint_2:   {p: 100, i: 0.01, d: 10.0}
            axis_joint_3:   {p: 100, i: 0.01, d: 10.0}
            axis_joint_4:   {p: 100, i: 0.01, d: 10.0}
            axis_joint_5:   {p: 100, i: 0.01, d: 10.0}
            axis_joint_6:   {p: 100, i: 0.01, d: 10.0}
      gluon_joint_state_controller.yaml
      gluon:
          type: joint_state_controller/JointStateController
          publish_rate: 50
      controller_manager_ns: ''
      controller_list:
        - name: gluon_controller
          action_ns: follow_joint_trajectory
          type: FollowJointTrajectory
          default: true
          joints:
            - axis_joint_1
            - axis_joint_2
            - axis_joint_3
            - axis_joint_4
            - axis_joint_5
            - axis_joint_6
      os_controllers.yaml对应配置文件gluon_moveit_controller_manager.launch.xml
      <launch>
        <!--Set the param that trajectory_execution_manager needs to find the controller plugin-->
        <arg name="moveit_controller_manager" default="moveit_simple_controller_manager/MoveItSimpleControllerManager" />
        <param name="moveit_controller_manager" value="$(arg moveit_controller_manager)"/>
        <!--load controller_list-->
        <rosparam file="$(find gluon_moveit_config)/config/ros_controllers.yaml"/>
      </launch>
      下面是launch文件:
      cm_gazebo_bo.launch
      <launch>
          <arg name="paused" default="false"/>
          <arg name="use_sim_time" default="true"/>
          <arg name="gui" default="true"/>
          <arg name="headless" default="false"/>
          <arg name="debug" default="false"/>
          <!-- 导入世界 -->
          <include file="$(find gazebo_ros)/launch/empty_world.launch">]
              <arg name="debug" value="$(arg debug)" />
              <arg name="gui" value="$(arg gui)" />
              <arg name="paused" value="$(arg paused)"/>
              <arg name="use_sim_time" value="$(arg use_sim_time)"/>
              <arg name="headless" value="$(arg headless)"/>
          </include>
          <!-- 导入机械臂 -->
          <param name="robot_description" textfile="$(find gluon)/urdf/gluon_moveit_sim_pos.urdf" />
          <node name="spawn_gazebo_model" pkg="gazebo_ros" type="spawn_model"
              args="-file $(find gluon)/urdf/gluon_moveit_sim_pos.urdf -urdf -model robot -z 0.25" respawn="false" output="screen" />
          <!-- 导入通用文件 -->
          <include file="$(find gluon_moveit_config)/launch/cm_gazebo_controller_utils.launch"/>
          <!-- 导入控制器 -->
          <rosparam file="$(find gluon_moveit_config)/config/gluon_controllers.yaml" command="load"/>
          <node name="arm_controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
              output="screen" ns="/gluon" args="gluon_controller"/>
      </launch>
      <launch>
          <!-- Robot state publisher -->
          <node pkg="robot_state_publisher" type="robot_state_publisher" name="robot_state_publisher">
              <param name="publish_frequency" type="double" value="50.0" />
              <param name="tf_prefix" type="string" value="" />
          </node>
          <!-- Fake Calibration -->
          <node pkg="rostopic" type="rostopic" name="fake_joint_calibration"
              args="pub /calibrated std_msgs/Bool true" />
          <!-- joint_state_controller -->
          <rosparam file="$(find gluon_moveit_config)/config/gluon_joint_state_controller.yaml" command="load"/>
          <node name="joint_controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
              output="screen" ns="/gluon" args="joint_state_controller" />
      </launch>
      moveit_planning_execution.launch
      <launch>
        <!-- Remap follow_joint_trajectory -->
        <arg name="sim" default="true" />
        <remap if="$(arg sim)" from="/follow_joint_trajectory" to="/gluon_controller/follow_joint_trajectory"/>
        <include file="$(find gluon_moveit_config)/launch/move_group.launch">
          <arg name="publish_monitored_planning_scene" value="true" />
        </include>
        <!--The visualization component of MoveIt!-->
        <include file="$(find gluon_moveit_config)/launch/moveit_rviz.launch" />
          <arg name="config" value="true"/>
          <arg name="debug" value="false"/>
        <!-- We do not have a robot connected, so publish fake joint states -->
        <node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher">
          <param name="/use_gui" value="false"/>
          <rosparam param="/source_list">[/gluon/joint_states]</rosparam>
        </node>
      </launch>
      2 2 条回复 最后回复 回复 引用 0
        四季闲 @2297403423
        @2297403423
        补充:
        运行
        roslaunch gluon_moveit_config cm_gazebo_bo.launch
        roslaunch gluon_moveit_config moveit_planning_execution.launch
        文件位置
        yaml文件在gluon_moveit_config/config中
        launch文件在gluon_moveit_config/launch中
          四季闲 @2297403423
          @2297403423 解决了,但我不知道该怎么形容这件事情
            四季闲 @2297403423
            @2297403423
            从结果上讲,就是控制器的yaml文件不要有机械臂名字
            就像下面,注释掉的方法 达咩
              publish_rate: 50
            # gluon:
            #   joint_state_controller:
            #   type: joint_state_controller/JointStateController
            #   publish_rate: 50
            gluon_controller:
              type: position_controllers/JointTrajectoryController
              joints:
                - axis_joint_1
                - axis_joint_2
                - axis_joint_3
                - axis_joint_4
                - axis_joint_5
                - axis_joint_6
            下面是注释内容
            # gluon:
            #   gluon_controller:
            #     type: position_controllers/JointTrajectoryController
            #     joints:
            #       - axis_joint_1
            #       - axis_joint_2
            #       - axis_joint_3
            #       - axis_joint_4
            #       - axis_joint_5
            #       - axis_joint_6
            同时,launch文件中内容修改如下(简单说,就是去掉ns)
              <node name="arm_controller_spawner" pkg="controller_manager" type="spawner" respawn="false" output="screen" args="gluon_controller"/>
              四季闲 @2297403423
              @2297403423
              再补充一下,如果你的gazebo中机械臂在轻微抖动,用这句话也可以解决
                四季闲 @2297403423
                @2297403423
                我是怎么想到这种方法的呢,因为我有个ur的包是正常的,所以,抄作业,爽!
                  四季闲 @2297403423
                  @2297403423
                  ros_controller.yaml修改如下
                  controller_list:
                    - name: ""
                      default: true
                      joints:
                        - axis_joint_1
                        - axis_joint_2
                        - axis_joint_3
                        - axis_joint_4
                        - axis_joint_5
                        - axis_joint_6
