    colcon build时出现编码错误
    ros2 编译 编码错误
    1.8k
      迷途知返
      File "/usr/lib/python3/dist-packages/colcon_core/executor/init.py", line 91, in call
      rc = await self.task(*args, **kwargs)
      File "/usr/lib/python3/dist-packages/colcon_core/task/init.py", line 93, in call
      return await task_method(*args, **kwargs)
      File "/usr/lib/python3/dist-packages/colcon_ros/task/ament_cmake/build.py", line 59, in build
      rc = await extension.build(
      File "/usr/lib/python3/dist-packages/colcon_cmake/task/cmake/build.py", line 87, in build
      rc = await self._reconfigure(args, env)
      File "/usr/lib/python3/dist-packages/colcon_cmake/task/cmake/build.py", line 133, in _reconfigure
      buildfile = get_buildfile(cmake_cache)
      File "/usr/lib/python3/dist-packages/colcon_cmake/task/cmake/init.py", line 110, in get_buildfile
      generator = get_variable_from_cmake_cache(
      File "/usr/lib/python3/dist-packages/colcon_cmake/task/cmake/init.py", line 174, in get_variable_from_cmake_cache
      lines = _get_cmake_cache_lines(path)
      File "/usr/lib/python3/dist-packages/colcon_cmake/task/cmake/init.py", line 193, in _get_cmake_cache_lines
      content = h.read()
      File "/usr/lib/python3.8/codecs.py", line 322, in decode
      (result, consumed) = self._buffer_decode(data, self.errors, final)
      UnicodeDecodeError: 'utf-8' codec can't decode byte 0xda in position 1: invalid continuation byte
        小鱼 技术大佬 @2863819718
        @2863819718 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
