    使用colcon构建工作区时出错
    环境ubuntu22.04 colcon build
    1.1k
      枯叶流水
      最后由 280390510 编辑
      我在跟着例程文档使用colcon构建工作区进行学习,在进行到colcon build时发生了如下错误:
      WARNING: given --rosdistro melodic but ROS_DISTRO is "humble". Ignoring environment.
      #All required rosdeps installed successfully
      yyh@yyh-device:~/ros_dev_ws$ colcon build
      [0.193s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      	'turtlesim' is in: /opt/ros/humble
      If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      	--allow-overriding turtlesim
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> turtlesim
      --- stderr: turtlesim
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp: In member function ‘void TeleopTurtle::sendGoal(float)’:
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5: error: no match for ‘operator=’ (operand types are ‘rclcpp_action::Client<turtlesim::action::RotateAbsolute>::GoalResponseCallback’ {aka ‘std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>’} and ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’)
        200 |     };
      In file included from /usr/include/c++/11/future:47,
                       from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:18,
                       from /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:1:
      /usr/include/c++/11/bits/std_function.h:530:9: note: candidate: ‘template<class _Functor> std::function<_Res(_ArgTypes ...)>::_Requires<std::function<_Res(_ArgTypes ...)>::_Callable<_Functor>, std::function<_Res(_ArgTypes ...)>&> std::function<_Res(_ArgTypes ...)>::operator=(_Functor&&) [with _Functor = _Functor; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        530 |         operator=(_Functor&& __f)
      /usr/include/c++/11/bits/std_function.h:530:9: note:   template argument deduction/substitution failed:
      In file included from /usr/include/c++/11/bits/move.h:57,
                       from /usr/include/c++/11/bits/stl_pair.h:59,
                       from /usr/include/c++/11/bits/stl_algobase.h:64,
                       from /usr/include/c++/11/memory:63,
                       from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:153,
      /usr/include/c++/11/type_traits: In substitution of ‘template<bool _Cond, class _Tp> using __enable_if_t = typename std::enable_if::type [with bool _Cond = false; _Tp = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&]’:
      /usr/include/c++/11/bits/std_function.h:353:8:   required by substitution of ‘template<class _Res, class ... _ArgTypes> template<class _Cond, class _Tp> using _Requires = std::__enable_if_t<_Cond::value, _Tp> [with _Cond = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Callable<TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>, TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>, std::__invoke_result<TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>&, std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > > >; _Tp = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
      /usr/include/c++/11/bits/std_function.h:530:2:   required by substitution of ‘template<class _Functor> std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Requires<std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Callable<_Functor, typename std::enable_if<(! std::is_same<typename std::remove_cv<typename std::remove_reference<_Tp>::type>::type, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)> >::value), std::decay<_Tp> >::type::type, std::__invoke_result<typename std::enable_if<(! std::is_same<typename std::remove_cv<typename std::remove_reference<_Tp>::type>::type, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)> >::value), std::decay<_Tp> >::type::type&, std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > > >, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&> std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::operator=<_Functor>(_Functor&&) [with _Functor = TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>]’
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5:   required from here
      /usr/include/c++/11/type_traits:2205:11: error: no type named ‘type’ in ‘struct std::enable_if<false, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&>’
       2205 |     using __enable_if_t = typename enable_if<_Cond, _Tp>::type;
      /usr/include/c++/11/bits/std_function.h:540:9: note: candidate: ‘template<class _Functor> std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::reference_wrapper<_Functor>) [with _Functor = _Functor; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        540 |         operator=(reference_wrapper<_Functor> __f) noexcept
      /usr/include/c++/11/bits/std_function.h:540:9: note:   template argument deduction/substitution failed:
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5: note:   ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ is not derived from ‘std::reference_wrapper<_Tp>’
        200 |     };
      /usr/include/c++/11/bits/std_function.h:469:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(const std::function<_Res(_ArgTypes ...)>&) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        469 |       operator=(const function& __x)
      /usr/include/c++/11/bits/std_function.h:469:33: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘const std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&’
      /usr/include/c++/11/bits/std_function.h:487:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::function<_Res(_ArgTypes ...)>&&) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        487 |       operator=(function&& __x) noexcept
      /usr/include/c++/11/bits/std_function.h:487:28: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&&’
      /usr/include/c++/11/bits/std_function.h:501:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::nullptr_t) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}; std::nullptr_t = std::nullptr_t]’
        501 |       operator=(nullptr_t) noexcept
      /usr/include/c++/11/bits/std_function.h:501:17: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘std::nullptr_t’
      gmake[2]: *** [CMakeFiles/turtle_teleop_key.dir/build.make:76:CMakeFiles/turtle_teleop_key.dir/tutorials/teleop_turtle_key.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:628:CMakeFiles/turtle_teleop_key.dir/all] 错误 2
      Failed   <<< turtlesim [2.10s, exited with code 2]
      Summary: 0 packages finished [2.25s]
        1 package failed: turtlesim
        1 package had stderr output: turtlesim
      系统环境ubuntu22.04,ros2安装正确,前面的教程反馈正常
      在不加入turtlesim时使用空文件colcon build成功
      请问这种情况该怎么解决?😵
      • 2 280390510 将这个主题转为问答主题,在
      • 2 280390510 删除了该主题于
      • 2 280390510 恢复了该主题于
        小鱼 技术大佬 @280390510
        @280390510 在 使用colcon构建工作区时出错 中说:
        given --rosdistro melodic but ROS_DISTRO is "humble" 是不是bashrc有什么配置错误的地方
