    鱼哥鱼哥,rviz2加载地图时无法出现地图
    rviz2不显示地图 动手学ros,rviz
    3.5k
      香芋派
      在slam建图的进阶篇章节中激活了map_server但是还是无法出现地图
      具体细节和上下文:
      在rviz中无法在fixed frame找到任何一个可选项
      map这里有个警告,不太清楚为什么。而且我看社区也有人问过,说改qos,但是改了好像也无济于事
      然后我看rqt的节点关系
      感觉map都发送到rviz了,不知道为什么就是无法显示出来
      运行rviz2:
      lua:
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        map_frame = "map",
        tracking_frame = "imu_link",
        published_frame = "odom",
        odom_frame = "odom",
        provide_odom_frame = false,
        publish_frame_projected_to_2d = true,
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        num_laser_scans = 1,
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 0,
        submap_publish_period_sec = 0.3,
        odometry_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
      TRAJECTORY_BUILDER_2D.min_range = 0.12
      TRAJECTORY_BUILDER_2D.max_range = 3.5
      TRAJECTORY_BUILDER_2D.missing_data_ray_length = 3.
      TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching = true
      TRAJECTORY_BUILDER_2D.motion_filter.max_angle_radians = math.rad(0.1)
      POSE_GRAPH.constraint_builder.min_score = 0.65
      POSE_GRAPH.constraint_builder.global_localization_min_score = 0.7
      -- POSE_GRAPH.optimize_every_n_nodes = 0
      return options
      launch:
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='fishbot_cartographer').find('fishbot_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间,我们用gazebo,这里设置成true
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          # 地图的分辨率
          resolution = LaunchConfiguration('resolution', default='0.05')
          # 地图的发布周期
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='fishbot_2d.lua')
          rviz_config_dir = os.path.join(pkg_share, 'config')+"/cartographer.rviz"
          print(f"rviz config in {rviz_config_dir}")
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename])
          cartographer_occupancy_grid_node = Node(
              executable='cartographer_occupancy_grid_node',
              name='cartographer_occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
          #===============================================定义启动文件========================================================
          ld = LaunchDescription()
          ld.add_action(cartographer_node)
          ld.add_action(cartographer_occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
        根据您提供的信息,这里有几个可能的原因导致RViz2中无法加载和显示地图:
        1. Fixed Frame问题:RViz2中无法在Fixed Frame下拉列表中找到任何选项,这通常意味着RViz2没有接收到任何TF(Transform)数据,或者这些TF数据还没有被完全发布。确保您的机器人/仿真环境中的传感器数据(如激光雷达扫描或里程计数据)正在被发布,并且tf或tf2包正在处理这些数据。
        2. Map Server未正确激活:虽然您提到激活了map_server,但请确保map_server节点实际上已经启动,并且地图文件路径正确无误。您可以通过ros2 node list查看当前运行的节点,确保map_server在其中。
        3. 地图文件问题:确保地图文件没有损坏,并且格式正确(如PGM或PNG)。您可以使用图像查看器打开地图文件来检查其是否可读取。
        4. RViz2配置问题:检查RViz2的配置文件(.rviz),确保地图显示的相关设置是正确的。比如,在RViz2的Display面板中,您应该有一个名为Map的显示项,其Topic应该设置为/map(或您map_server发布地图的topic)。
        5. QoS设置问题:虽然您提到更改QoS设置似乎无济于事,但确保所有相关的节点(包括cartographer_node、cartographer_occupancy_grid_node、map_server和RViz2)都使用兼容的QoS设置是很重要的。有时,如果某个节点使用默认的QoS设置,而其他节点使用非默认设置,它们之间可能无法正确通信。
        6. 时间同步问题:确保所有节点都使用相同的时间源(模拟时间或实时时间),并且它们之间的时间同步是正确的。时间不同步可能会导致TF转换失败,从而导致地图无法在RViz2中显示。
        7. ROS 2通信问题:由于ROS 2的分布式特性,确保所有节点都在同一网络中,并且ROS 2的通信没有问题。您可以使用ros2 topic echo或ros2 topic list来检查话题是否正在被发布和接收。
        为了进一步诊断问题,您可以尝试以下步骤:
        • 使用ros2 topic echo /map(或您map_server发布地图的topic)来查看地图数据是否正在被发布。
        • 使用ros2 run tf2_ros tf2_echo map odom(或您想要查询的任意两个frame)来检查TF转换是否可用。
        • 在RViz2中,尝试手动添加Map显示项,并设置正确的Topic。
        • 检查RViz2的日志文件或控制台输出,看是否有任何错误或警告信息。
        如果以上步骤都无法解决问题,您可能需要更深入地检查您的ROS 2设置和配置,或者寻求社区或论坛的帮助,提供更多的细节和日志信息以便他人能够帮助您。
          小鱼 技术大佬 @1877846919
          @1877846919 看看TF是否正常
          1 2 条回复 最后回复 回复 引用 0
            香芋派 @小鱼
              香芋派 @小鱼
              好像也不正常
                小鱼 技术大佬 @1877846919
                @1877846919 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                  香芋派 @小鱼
                  这个截图吗
                    小鱼 技术大佬 @1877846919
                    @1877846919 你的操作上下文,系统信息之类的
                      香芋派 @小鱼
                      @小鱼 我是上面问了问题然后这边回复你的tf是否正常的问题的,我这边进到rqt看节点关系跟位姿,截的图
                      然后我就想看一下一直监听一下/map然后激活会发送什么数据,结果也是0000
                        小鱼 技术大佬 @1877846919
                        @1877846919 话题有数据就是有地图,所以你需要打开RVIZ2,修改好fix frame 和 Qos应该就可以正常显示了
                          WingSong
                          原因:topic:/map发布了一次,rviz2 后启动接收不到,参考:
                          https://blog.csdn.net/chenlin41204050/article/details/136439108
