    安装上位机agent有问题,没有docker的指令
    ros2 linux agent
    • Q
      22E12E
      最后由 qmdream1 编辑
      输入:sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged --net=host microros/micro-ros-agent:$ROS_DISTRO serial --dev /dev/ttyUSB0 -v6
      sudo: docker: command not found
      结果:以下是安装agent的过程
      cyh@cyh-OMEN-by-HP-Gaming-Laptop-16-wf0xxx:~$ wget http://fishros.com/install -O fishros && . fishros
      --2024-07-24 14:11:32-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2024-07-24 14:11:32-- http://fishros.com/install/
      Length: 579 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================>] 579 --.-KB/s in 0s
      2024-07-24 14:11:32 (80.6 MB/s) - ‘fishros’ saved [579/579]
      [sudo] password for cyh:
      Reading package lists... Done
      python3-distro is already the newest version (1.7.0-1).
      python3-yaml is already the newest version (5.4.1-1ubuntu1).
      You might want to run 'apt --fix-broken install' to correct these.
      docker-desktop : Depends: qemu-system-x86 (>= 5.2.0) but it is not going to be installed
      Depends: docker-ce-cli but it is not installable
      Depends: pass but it is not going to be installed
      Depends: uidmap
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      --2024-07-24 14:11:36-- http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 44650 (44K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 43.60K --.-KB/s in 0.04s
      2024-07-24 14:11:36 (1.04 MB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [44650/44650]
      [-]Result:success
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [14]:一键安装:科学上网代理工具
      [15]:一键安装:QQ for Linux
      配置工具:
      [13]:一键配置:python国内源
      请输入[]内的数字以选择:8
      --2024-07-24 14:11:44-- http://mirror.fishros.com/install/tools/tool_install_docker.py
      Length: 2882 (2.8K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’
      /tmp/fishinstall/to 100%[===================>] 2.81K --.-KB/s in 0s
      2024-07-24 14:11:44 (242 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2882/2882]
      欢迎使用一键安装Docker,支持amd64和arm64架构系统,本工具由作者alyssa提供
      开始根据系统架构,为你下载对应版本的docker~
      [/]Get:8 https://dl.google.com/linux/chrome/deb stable/main amd64 Packages [1,08[|]Get:10 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages [[/]Get:12 http://cn.archive.ubuntu.com/ubuntu jammy-updates/main i386 Packages [[]Get:13 http://cn.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [|]Get:14 http://security.ubuntu.com/ubuntu jammy-security/main i386 Packages [5[-]Get:15 http://cn.archive.ubuntu.com/ubuntu jammy-updates/main Translation-en [/]Get:16 http://cn.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Pac[]Get:17 http://security.ubuntu.com/ubuntu jammy-security/main Translation-en [[|]Get:18 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packag[-]Get:19 http://security.ubuntu.com/ubuntu jammy-security/universe i386 Package[/]Get:20 http://cn.archive.ubuntu.com/ubuntu jammy-updates/restricted Translati[]Get:21 http://cn.archive.ubuntu.com/ubuntu jammy-updates/universe i386 Packag[|]Get:22 http://cn.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packa[-]Result:success t --upgradable' to see them.
      Run CMD Task:[sudo apt install apt-transport-https ca-certificates curl software-properties-common -y]
      [|] docker-desktop : Depends: qemu-system-x86 (>= 5.2.0) but it is not going to [-]Result:code:100 not going to be installed
      Run CMD Task:[curl -fsSL https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu/gpg | sudo apt-key add -]
      [-]Result:success
      Run CMD Task:[sudo apt-key fingerprint 0EBFCD88]
      [-]Result:success CE deb) docker@docker.com
      Run CMD Task:[sudo add-apt-repository "deb [arch=amd64] https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu $(lsb_release -cs) stable" -y]
      File "/usr/bin/add-apt-repository", line 363, in <module>
      addaptrepo = AddAptRepository()
      File "/usr/bin/add-apt-repository", line 41, in init
      self.distro.get_sources(self.sourceslist)
      File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 91, in get_sources
      raise NoDistroTemplateException(
      aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Atzlinux/bookworm
      下载完成,接下来升级apt索引~
      开始安装最新版本docker CE~
      Run CMD Task:[sudo apt --fix-broken install -y]
      []The following packages were automatically installed and are no longer require[|]Failed to connect to bus: $DBUS_SESSION_BUS_ADDRESS and $XDG_RUNTIME_DIR not defined (consider using --machine=<user>@.host --user to connect to bus of other[-]Result:success s (0.26-1ubuntu3) ...
      Run CMD Task:[sudo apt search docker-ce ]
      [-]Result:success
      File "/tmp/fishinstall/install.py", line 124, in <module>
      File "/tmp/fishinstall/install.py", line 116, in main
      File "/tmp/fishinstall/tools/base.py", line 1297, in run_tool_file
      File "/tmp/fishinstall/tools/tool_install_docker.py", line 64, in run
      self.install_docker()
      File "/tmp/fishinstall/tools/tool_install_docker.py", line 55, in install_docker
      AptUtils.install_pkg_check_dep("docker-ce")
      File "/tmp/fishinstall/tools/base.py", line 1247, in install_pkg_check_dep
      result = AptUtils.install_pkg(name)
      File "/tmp/fishinstall/tools/base.py", line 1236, in install_pkg
      for key in dic.keys():
      AttributeError: 'NoneType' object has no attribute 'keys'
      cyh@cyh-OMEN-by-HP-Gaming-Laptop-16-wf0xxx:~$ sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged --net=host microros/micro-ros-agent:$ROS_DISTRO serial --dev /dev/ttyUSB0 -v6
        错误提示 sudo: docker: command not found 表明 Docker 没有安装在您的系统上,或者 Docker 命令没有正确地添加到您的 PATH 环境变量中。
        根据您提供的安装过程,您已经尝试使用了一个一键安装脚本,但是出现了几个问题:
        1. docker-desktop 依赖问题:这通常是为桌面环境设计的 Docker 版本,可能并不适用于您正在使用的服务器或开发环境。您可能想要安装 Docker Engine - Community 版本。
        2. aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Atzlinux/bookworm:这表明安装脚本试图为一个不存在的 Linux 发行版(Atzlinux)配置 Docker 仓库,这可能是由于您的系统环境变量或系统信息被错误地识别了。
        为了解决这个问题,您可以按照以下步骤操作:
        1. 移除任何已损坏的 Docker 安装和配置:
          sudo apt-get remove docker docker-engine docker.io containerd runc
          sudo rm -rf /var/lib/docker
          sudo rm -rf /var/lib/containerd
        2. 安装 Docker Engine - Community:
          # 更新软件包列表
          sudo apt update
          # 安装必要的软件包以允许apt通过HTTPS使用存储库
          # 添加Docker的官方GPG密钥
          curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
          # 添加Docker存储库
          sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
          # 再次更新软件包列表
          sudo apt update
          # 安装Docker CE
          sudo apt install docker-ce docker-ce-cli containerd.io
        3. 启动 Docker 服务并验证安装:
          sudo systemctl start docker
          sudo systemctl status docker
          # 运行 hello-world 容器来验证 Docker 是否正常工作
          sudo docker run hello-world
        4. 现在您应该能够运行您之前的命令而不会出现 sudo: docker: command not found 的错误。
          请注意,您需要将 $ROS_DISTRO 替换为您实际使用的 ROS 发行版名称(如 galactic、humble 等)。
        如果问题仍然存在,请确保 $ROS_DISTRO 环境变量已被正确设置,或者您可以直接在命令中指定 ROS 发行版名称。
          小鱼 技术大佬 @qmdream1
          @qmdream1 在 安装上位机agent有问题,没有docker的指令 中说:
          试试这个
