一个IMU的ROS包,不太明白其中的一些代码
不太明白为什么开头要用参数服务器设置参数呢
还有在下面定义发布方的时候imu_pub_ = create_publisher<sensor_msgs::msg::Imu>(imu_topic.c_str(), 10);测试了一下发布方的名称是
imu,这个也是因为参数服务器里面设置了如下的参数嘛this->declare_parameter<std::string>("imu_topic","/imu"); this->get_parameter("imu_topic", imu_topic);但为什么是
"/imu"而不是imu呢
下面是完整的文件:#include <ahrs_driver.h> //#include <Eigen/Eigen> rclcpp::Node::SharedPtr nh_=nullptr; namespace FDILink { ahrsBringup::ahrsBringup() : rclcpp::Node ("ahrs_bringup") { //topic_name & frame_id 加载参数服务器 this->declare_parameter("if_debug_",false); this->get_parameter("if_debug_", if_debug_); this->declare_parameter<std::int8_t>("device_type_",1); this->get_parameter("device_type_", device_type_); this->declare_parameter<std::string>("imu_topic","/imu"); this->get_parameter("imu_topic", imu_topic); this->declare_parameter<std::string>("imu_frame_id_","gyro_link"); this->get_parameter("imu_frame_id_", imu_frame_id_); this->declare_parameter<std::string>("mag_pose_2d_topic","/mag_pose_2d"); this->get_parameter("mag_pose_2d_topic", mag_pose_2d_topic); this->declare_parameter<std::string>("Euler_angles_topic","/euler_angles"); this->get_parameter("Euler_angles_topic", Euler_angles_topic); this->declare_parameter<std::string>("gps_topic","/gps/fix"); this->get_parameter("gps_topic", gps_topic); this->declare_parameter<std::string>("Magnetic_topic","/magnetic"); this->get_parameter("Magnetic_topic", Magnetic_topic); this->declare_parameter<std::string>("twist_topic","/system_speed"); this->get_parameter("twist_topic", twist_topic); this->declare_parameter<std::string>("NED_odom_topic","/NED_odometry"); this->get_parameter("NED_odom_topic", NED_odom_topic); this->declare_parameter<std::string>("serial_port_","/dev/fdilink_ahrs"); this->get_parameter("serial_port_", serial_port_); this->declare_parameter<std::int64_t>("serial_baud_",921600); this->get_parameter("serial_baud_", serial_baud_); //pravite_nh.param("debug", if_debug_, false); //pravite_nh.param("device_type", device_type_, 1); // default: single imu // pravite_nh.param("imu_topic", imu_topic_, std::string("/imu")); // pravite_nh.param("imu_frame", imu_frame_id_, std::string("imu")); // pravite_nh.param("mag_pose_2d_topic", mag_pose_2d_topic_, std::string("/mag_pose_2d")); // pravite_nh.param("Euler_angles_pub_", Euler_angles_topic_, std::string("/euler_angles")); // pravite_nh.param("Magnetic_pub_", Magnetic_topic_, std::string("/magnetic")); //serial //pravite_nh.param("port", serial_port_, std::string("/dev/ttyTHS1")); //pravite_nh.param("baud", serial_baud_, 115200); //publisher imu_pub_ = create_publisher<sensor_msgs::msg::Imu>(imu_topic.c_str(), 10); gps_pub_ = create_publisher<sensor_msgs::msg::NavSatFix>(gps_topic.c_str(), 10); mag_pose_pub_ = create_publisher<geometry_msgs::msg::Pose2D>(mag_pose_2d_topic.c_str(), 10); Euler_angles_pub_ = create_publisher<geometry_msgs::msg::Vector3>(Euler_angles_topic.c_str(), 10); Magnetic_pub_ = create_publisher<geometry_msgs::msg::Vector3>(Magnetic_topic.c_str(), 10); twist_pub_ = create_publisher<geometry_msgs::msg::Twist>(twist_topic.c_str(), 10); NED_odom_pub_ = create_publisher<nav_msgs::msg::Odometry>(NED_odom_topic.c_str(), 10); //setp up serial 设置串口参数并打开串口 try { serial_.setPort(serial_port_); serial_.setBaudrate(serial_baud_); serial_.setFlowcontrol(serial::flowcontrol_none); serial_.setParity(serial::parity_none); //default is parity_none serial_.setStopbits(serial::stopbits_one); serial_.setBytesize(serial::eightbits); serial::Timeout time_out = serial::Timeout::simpleTimeout(serial_timeout_); serial_.setTimeout(time_out); serial_.open(); } catch (serial::IOException &e) // 抓取异常 { RCLCPP_ERROR(this->get_logger(),"Unable to open port "); exit(0); } if (serial_.isOpen()) { RCLCPP_INFO(this->get_logger(),"Serial Port initialized"); } else { RCLCPP_ERROR(this->get_logger(),"Unable to initial Serial port "); exit(0); } processLoop(); } ahrsBringup::~ahrsBringup() // 析构函数关闭串口通道 { if (serial_.isOpen()) serial_.close(); } void ahrsBringup::processLoop() // 数据处理过程 { RCLCPP_INFO(this->get_logger(),"ahrsBringup::processLoop: start"); while (rclcpp::ok()) { if (!serial_.isOpen()) { RCLCPP_WARN(this->get_logger(),"serial unopen"); } //check head start 检查起始 数据帧头 uint8_t check_head[1] = {0xff}; size_t head_s = serial_.read(check_head, 1); if (if_debug_){ if (head_s != 1) { RCLCPP_ERROR(this->get_logger(),"Read serial port time out! can't read pack head."); } std::cout << std::endl; std::cout << "check_head: " << std::hex << (int)check_head[0] << std::dec << std::endl; } if (check_head[0] != FRAME_HEAD) { continue; } //check head type 检查数据类型 uint8_t head_type[1] = {0xff}; size_t type_s = serial_.read(head_type, 1); if (if_debug_){ std::cout << "head_type: " << std::hex << (int)head_type[0] << std::dec << std::endl; } if (head_type[0] != TYPE_IMU && head_type[0] != TYPE_AHRS && head_type[0] != TYPE_INSGPS && head_type[0] != TYPE_GEODETIC_POS && head_type[0] != 0x50 && head_type[0] != TYPE_GROUND&& head_type[0] != 0xff) { RCLCPP_WARN(this->get_logger(),"head_type error: %02X",head_type[0]); continue; } //check head length 检查对应数据类型的长度是否符合 uint8_t check_len[1] = {0xff}; size_t len_s = serial_.read(check_len, 1); if (if_debug_){ std::cout << "check_len: "<< std::dec << (int)check_len[0] << std::endl; } if (head_type[0] == TYPE_IMU && check_len[0] != IMU_LEN) { RCLCPP_WARN(this->get_logger(),"head_len error (imu)"); continue; }else if (head_type[0] == TYPE_AHRS && check_len[0] != AHRS_LEN) { RCLCPP_WARN(this->get_logger(),"head_len error (ahrs)"); continue; }else if (head_type[0] == TYPE_INSGPS && check_len[0] != INSGPS_LEN) { RCLCPP_WARN(this->get_logger(),"head_len error (insgps)"); continue; }else if (head_type[0] == TYPE_GEODETIC_POS && check_len[0] != GEODETIC_POS_LEN) { RCLCPP_WARN(this->get_logger(),"head_len error (GEODETIC_POS)"); continue; } else if (head_type[0] == TYPE_GROUND || head_type[0] == 0x50) // 未知数据,防止记录失败 { uint8_t ground_sn[1]; size_t ground_sn_s = serial_.read(ground_sn, 1); if (++read_sn_ != ground_sn[0]) { if ( ground_sn[0] < read_sn_) { if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } sn_lost_ += 256 - (int)(read_sn_ - ground_sn[0]); read_sn_ = ground_sn[0]; // continue; } else { if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } sn_lost_ += (int)(ground_sn[0] - read_sn_); read_sn_ = ground_sn[0]; // continue; } } uint8_t ground_ignore[500]; size_t ground_ignore_s = serial_.read(ground_ignore, (check_len[0]+4)); continue; } //read head sn uint8_t check_sn[1] = {0xff}; size_t sn_s = serial_.read(check_sn, 1); uint8_t head_crc8[1] = {0xff}; size_t crc8_s = serial_.read(head_crc8, 1); uint8_t head_crc16_H[1] = {0xff}; uint8_t head_crc16_L[1] = {0xff}; size_t crc16_H_s = serial_.read(head_crc16_H, 1); size_t crc16_L_s = serial_.read(head_crc16_L, 1); if (if_debug_){ std::cout << "check_sn: " << std::hex << (int)check_sn[0] << std::dec << std::endl; std::cout << "head_crc8: " << std::hex << (int)head_crc8[0] << std::dec << std::endl; std::cout << "head_crc16_H: " << std::hex << (int)head_crc16_H[0] << std::dec << std::endl; std::cout << "head_crc16_L: " << std::hex << (int)head_crc16_L[0] << std::dec << std::endl; } // put header & check crc8 & count sn lost // check crc8 进行crc8数据校验 if (head_type[0] == TYPE_IMU) { imu_frame_.frame.header.header_start = check_head[0]; imu_frame_.frame.header.data_type = head_type[0]; imu_frame_.frame.header.data_size = check_len[0]; imu_frame_.frame.header.serial_num = check_sn[0]; imu_frame_.frame.header.header_crc8 = head_crc8[0]; imu_frame_.frame.header.header_crc16_h = head_crc16_H[0]; imu_frame_.frame.header.header_crc16_l = head_crc16_L[0]; uint8_t CRC8 = CRC8_Table(imu_frame_.read_buf.frame_header, 4); if (CRC8 != imu_frame_.frame.header.header_crc8) { RCLCPP_WARN(this->get_logger(),"header_crc8 error"); continue; } if(!frist_sn_){ read_sn_ = imu_frame_.frame.header.serial_num - 1; frist_sn_ = true; } //check sn ahrsBringup::checkSN(TYPE_IMU); } else if (head_type[0] == TYPE_AHRS) { ahrs_frame_.frame.header.header_start = check_head[0]; ahrs_frame_.frame.header.data_type = head_type[0]; ahrs_frame_.frame.header.data_size = check_len[0]; ahrs_frame_.frame.header.serial_num = check_sn[0]; ahrs_frame_.frame.header.header_crc8 = head_crc8[0]; ahrs_frame_.frame.header.header_crc16_h = head_crc16_H[0]; ahrs_frame_.frame.header.header_crc16_l = head_crc16_L[0]; uint8_t CRC8 = CRC8_Table(ahrs_frame_.read_buf.frame_header, 4); if (CRC8 != ahrs_frame_.frame.header.header_crc8) { RCLCPP_WARN(this->get_logger(),"header_crc8 error"); continue; } if(!frist_sn_){ read_sn_ = ahrs_frame_.frame.header.serial_num - 1; frist_sn_ = true; } //check sn ahrsBringup::checkSN(TYPE_AHRS); } else if (head_type[0] == TYPE_INSGPS) { insgps_frame_.frame.header.header_start = check_head[0]; insgps_frame_.frame.header.data_type = head_type[0]; insgps_frame_.frame.header.data_size = check_len[0]; insgps_frame_.frame.header.serial_num = check_sn[0]; insgps_frame_.frame.header.header_crc8 = head_crc8[0]; insgps_frame_.frame.header.header_crc16_h = head_crc16_H[0]; insgps_frame_.frame.header.header_crc16_l = head_crc16_L[0]; uint8_t CRC8 = CRC8_Table(insgps_frame_.read_buf.frame_header, 4); if (CRC8 != insgps_frame_.frame.header.header_crc8) { RCLCPP_WARN(this->get_logger(),"header_crc8 error"); continue; } else if(if_debug_) { std::cout << "header_crc8 matched." << std::endl; } ahrsBringup::checkSN(TYPE_INSGPS); } else if (head_type[0] == TYPE_GEODETIC_POS) { Geodetic_Position_frame_.frame.header.header_start = check_head[0]; Geodetic_Position_frame_.frame.header.data_type = head_type[0]; Geodetic_Position_frame_.frame.header.data_size = check_len[0]; Geodetic_Position_frame_.frame.header.serial_num = check_sn[0]; Geodetic_Position_frame_.frame.header.header_crc8 = head_crc8[0]; Geodetic_Position_frame_.frame.header.header_crc16_h = head_crc16_H[0]; Geodetic_Position_frame_.frame.header.header_crc16_l = head_crc16_L[0]; uint8_t CRC8 = CRC8_Table(Geodetic_Position_frame_.read_buf.frame_header, 4); if (CRC8 != Geodetic_Position_frame_.frame.header.header_crc8) { RCLCPP_WARN(this->get_logger(),"header_crc8 error"); continue; } if(!frist_sn_){ read_sn_ = Geodetic_Position_frame_.frame.header.serial_num - 1; frist_sn_ = true; } ahrsBringup::checkSN(TYPE_GEODETIC_POS); } // check crc16 进行crc16数据校验 if (head_type[0] == TYPE_IMU) { uint16_t head_crc16_l = imu_frame_.frame.header.header_crc16_l; uint16_t head_crc16_h = imu_frame_.frame.header.header_crc16_h; uint16_t head_crc16 = head_crc16_l + (head_crc16_h << 8); size_t data_s = serial_.read(imu_frame_.read_buf.read_msg, (IMU_LEN + 1)); //48+1 // if (if_debug_){ // for (size_t i = 0; i < (IMU_LEN + 1); i++) // { // std::cout << std::hex << (int)imu_frame_.read_buf.read_msg[i] << " "; // } // std::cout << std::dec << std::endl; // } uint16_t CRC16 = CRC16_Table(imu_frame_.frame.data.data_buff, IMU_LEN); if (if_debug_) { std::cout << "CRC16: " << std::hex << (int)CRC16 << std::dec << std::endl; std::cout << "head_crc16: " << std::hex << (int)head_crc16 << std::dec << std::endl; std::cout << "head_crc16_h: " << std::hex << (int)head_crc16_h << std::dec << std::endl; std::cout << "head_crc16_l: " << std::hex << (int)head_crc16_l << std::dec << std::endl; bool if_right = ((int)head_crc16 == (int)CRC16); std::cout << "if_right: " << if_right << std::endl; } if (head_crc16 != CRC16) { RCLCPP_WARN(this->get_logger(),"check crc16 faild(imu)."); continue; } else if(imu_frame_.frame.frame_end != FRAME_END) { RCLCPP_WARN(this->get_logger(),"check frame end."); continue; } } else if (head_type[0] == TYPE_AHRS) { uint16_t head_crc16_l = ahrs_frame_.frame.header.header_crc16_l; uint16_t head_crc16_h = ahrs_frame_.frame.header.header_crc16_h; uint16_t head_crc16 = head_crc16_l + (head_crc16_h << 8); size_t data_s = serial_.read(ahrs_frame_.read_buf.read_msg, (AHRS_LEN + 1)); //48+1 // if (if_debug_){ // for (size_t i = 0; i < (AHRS_LEN + 1); i++) // { // std::cout << std::hex << (int)ahrs_frame_.read_buf.read_msg[i] << " "; // } // std::cout << std::dec << std::endl; // } uint16_t CRC16 = CRC16_Table(ahrs_frame_.frame.data.data_buff, AHRS_LEN); if (if_debug_){ std::cout << "CRC16: " << std::hex << (int)CRC16 << std::dec << std::endl; std::cout << "head_crc16: " << std::hex << (int)head_crc16 << std::dec << std::endl; std::cout << "head_crc16_h: " << std::hex << (int)head_crc16_h << std::dec << std::endl; std::cout << "head_crc16_l: " << std::hex << (int)head_crc16_l << std::dec << std::endl; bool if_right = ((int)head_crc16 == (int)CRC16); std::cout << "if_right: " << if_right << std::endl; } if (head_crc16 != CRC16) { RCLCPP_WARN(this->get_logger(),"check crc16 faild(ahrs)."); continue; } else if(ahrs_frame_.frame.frame_end != FRAME_END) { RCLCPP_WARN(this->get_logger(),"check frame end."); continue; } } else if (head_type[0] == TYPE_INSGPS) { uint16_t head_crc16_l = insgps_frame_.frame.header.header_crc16_l; uint16_t head_crc16_h = insgps_frame_.frame.header.header_crc16_h; uint16_t head_crc16 = head_crc16_l + (head_crc16_h << 8); size_t data_s = serial_.read(insgps_frame_.read_buf.read_msg, (INSGPS_LEN + 1)); //48+1 // if (if_debug_){ // for (size_t i = 0; i < (AHRS_LEN + 1); i++) // { // std::cout << std::hex << (int)ahrs_frame_.read_buf.read_msg[i] << " "; // } // std::cout << std::dec << std::endl; // } uint16_t CRC16 = CRC16_Table(insgps_frame_.frame.data.data_buff, INSGPS_LEN); if (if_debug_){ std::cout << "CRC16: " << std::hex << (int)CRC16 << std::dec << std::endl; std::cout << "head_crc16: " << std::hex << (int)head_crc16 << std::dec << std::endl; std::cout << "head_crc16_h: " << std::hex << (int)head_crc16_h << std::dec << std::endl; std::cout << "head_crc16_l: " << std::hex << (int)head_crc16_l << std::dec << std::endl; bool if_right = ((int)head_crc16 == (int)CRC16); std::cout << "if_right: " << if_right << std::endl; } if (head_crc16 != CRC16) { RCLCPP_WARN(this->get_logger(),"check crc16 faild(ahrs)."); continue; } else if(insgps_frame_.frame.frame_end != FRAME_END) { RCLCPP_WARN(this->get_logger(),"check frame end."); continue; } } else if (head_type[0] == TYPE_GEODETIC_POS) { uint16_t head_crc16_l = Geodetic_Position_frame_.frame.header.header_crc16_l; uint16_t head_crc16_h = Geodetic_Position_frame_.frame.header.header_crc16_h; uint16_t head_crc16 = head_crc16_l + (head_crc16_h << 8); size_t data_s = serial_.read(Geodetic_Position_frame_.read_buf.read_msg, (GEODETIC_POS_LEN + 1)); //24+1 // if (if_debug_){ // for (size_t i = 0; i < (AHRS_LEN + 1); i++) // { // std::cout << std::hex << (int)ahrs_frame_.read_buf.read_msg[i] << " "; // } // std::cout << std::dec << std::endl; // } uint16_t CRC16 = CRC16_Table(Geodetic_Position_frame_.frame.data.data_buff, GEODETIC_POS_LEN); if (if_debug_){ std::cout << "CRC16: " << std::hex << (int)CRC16 << std::dec << std::endl; std::cout << "head_crc16: " << std::hex << (int)head_crc16 << std::dec << std::endl; std::cout << "head_crc16_h: " << std::hex << (int)head_crc16_h << std::dec << std::endl; std::cout << "head_crc16_l: " << std::hex << (int)head_crc16_l << std::dec << std::endl; bool if_right = ((int)head_crc16 == (int)CRC16); std::cout << "if_right: " << if_right << std::endl; } if (head_crc16 != CRC16) { RCLCPP_WARN(this->get_logger(),"check crc16 faild(gps)."); continue; } else if(Geodetic_Position_frame_.frame.frame_end != FRAME_END) { RCLCPP_WARN(this->get_logger(),"check frame end."); continue; } } // publish magyaw topic //读取IMU数据进行解析,并发布相关话题 if (head_type[0] == TYPE_IMU) { // publish imu topic sensor_msgs::msg::Imu imu_data; imu_data.header.stamp = rclcpp::Node::now(); imu_data.header.frame_id = imu_frame_id_.c_str(); Eigen::Quaterniond q_ahrs(ahrs_frame_.frame.data.data_pack.Qw, ahrs_frame_.frame.data.data_pack.Qx, ahrs_frame_.frame.data.data_pack.Qy, ahrs_frame_.frame.data.data_pack.Qz); Eigen::Quaterniond q_r = Eigen::AngleAxisd( PI, Eigen::Vector3d::UnitZ()) * Eigen::AngleAxisd( PI, Eigen::Vector3d::UnitY()) * Eigen::AngleAxisd( 0.00000, Eigen::Vector3d::UnitX()); Eigen::Quaterniond q_rr = Eigen::AngleAxisd( 0.00000, Eigen::Vector3d::UnitZ()) * Eigen::AngleAxisd( 0.00000, Eigen::Vector3d::UnitY()) * Eigen::AngleAxisd( PI, Eigen::Vector3d::UnitX()); Eigen::Quaterniond q_xiao_rr = Eigen::AngleAxisd( PI/2, Eigen::Vector3d::UnitZ()) * Eigen::AngleAxisd( 0.00000, Eigen::Vector3d::UnitY()) * Eigen::AngleAxisd( PI, Eigen::Vector3d::UnitX()); if (device_type_ == 0) //未经变换的原始数据 { imu_data.orientation.w = ahrs_frame_.frame.data.data_pack.Qw; imu_data.orientation.x = ahrs_frame_.frame.data.data_pack.Qx; imu_data.orientation.y = ahrs_frame_.frame.data.data_pack.Qy; imu_data.orientation.z = ahrs_frame_.frame.data.data_pack.Qz; imu_data.angular_velocity.x = imu_frame_.frame.data.data_pack.gyroscope_x; imu_data.angular_velocity.y = imu_frame_.frame.data.data_pack.gyroscope_y; imu_data.angular_velocity.z = imu_frame_.frame.data.data_pack.gyroscope_z; imu_data.linear_acceleration.x = imu_frame_.frame.data.data_pack.accelerometer_x; imu_data.linear_acceleration.y = imu_frame_.frame.data.data_pack.accelerometer_y; imu_data.linear_acceleration.z = imu_frame_.frame.data.data_pack.accelerometer_z; } else if (device_type_ == 1) //imu单品rclcpp标准下的坐标变换 { Eigen::Quaterniond q_out = q_r * q_ahrs * q_rr; imu_data.orientation.w = q_out.w(); imu_data.orientation.x = q_out.x(); imu_data.orientation.y = q_out.y(); imu_data.orientation.z = q_out.z(); imu_data.angular_velocity.x = imu_frame_.frame.data.data_pack.gyroscope_x; imu_data.angular_velocity.y = -imu_frame_.frame.data.data_pack.gyroscope_y; imu_data.angular_velocity.z = -imu_frame_.frame.data.data_pack.gyroscope_z; imu_data.linear_acceleration.x = imu_frame_.frame.data.data_pack.accelerometer_x; imu_data.linear_acceleration.y = -imu_frame_.frame.data.data_pack.accelerometer_y; imu_data.linear_acceleration.z = -imu_frame_.frame.data.data_pack.accelerometer_z; } imu_pub_->publish(imu_data); } //读取AHRS数据进行解析,并发布相关话题 else if (head_type[0] == TYPE_AHRS) { geometry_msgs::msg::Pose2D pose_2d; pose_2d.theta = ahrs_frame_.frame.data.data_pack.Heading; mag_pose_pub_->publish(pose_2d); //std::cout << "YAW: " << pose_2d.theta << std::endl; geometry_msgs::msg::Vector3 Euler_angles_2d,Magnetic; Euler_angles_2d.x = ahrs_frame_.frame.data.data_pack.Roll; Euler_angles_2d.y = ahrs_frame_.frame.data.data_pack.Pitch; Euler_angles_2d.z = ahrs_frame_.frame.data.data_pack.Heading; Magnetic.x = imu_frame_.frame.data.data_pack.magnetometer_x; Magnetic.y = imu_frame_.frame.data.data_pack.magnetometer_y; Magnetic.z = imu_frame_.frame.data.data_pack.magnetometer_z; Euler_angles_pub_->publish(Euler_angles_2d); Magnetic_pub_->publish(Magnetic); } //读取gps_pos数据进行解析,并发布相关话题 else if (head_type[0] == TYPE_GEODETIC_POS) { sensor_msgs::msg::NavSatFix gps_data; gps_data.header.stamp = rclcpp::Node::now(); gps_data.header.frame_id = "navsat_link"; gps_data.latitude = Geodetic_Position_frame_.frame.data.data_pack.Latitude / DEG_TO_RAD; gps_data.longitude = Geodetic_Position_frame_.frame.data.data_pack.Longitude / DEG_TO_RAD; gps_data.altitude = Geodetic_Position_frame_.frame.data.data_pack.Height; //std::cout << "lat: " << Geodetic_Position_frame_.frame.data.data_pack.Latitude << std::endl; //std::cout << "lon: " << Geodetic_Position_frame_.frame.data.data_pack.Longitude << std::endl; //std::cout << "h: " << Geodetic_Position_frame_.frame.data.data_pack.Height << std::endl; gps_pub_->publish(gps_data); } //读取INSGPS数据进行解析,并发布相关话题 else if (head_type[0] == TYPE_INSGPS) { nav_msgs::msg::Odometry odom_msg; odom_msg.header.stamp = rclcpp::Node::now(); // odom_msg.header.frame_id = odom_frame_id; // Odometer TF parent coordinates //里程计TF父坐标 odom_msg.pose.pose.position.x = insgps_frame_.frame.data.data_pack.Location_North; //Position //位置 odom_msg.pose.pose.position.y = insgps_frame_.frame.data.data_pack.Location_East; odom_msg.pose.pose.position.z = insgps_frame_.frame.data.data_pack.Location_Down; // odom_msg.child_frame_id = robot_frame_id; // Odometer TF subcoordinates //里程计TF子坐标 odom_msg.twist.twist.linear.x = insgps_frame_.frame.data.data_pack.Velocity_North; //Speed in the X direction //X方向速度 odom_msg.twist.twist.linear.y = insgps_frame_.frame.data.data_pack.Velocity_East; //Speed in the Y direction //Y方向速度 odom_msg.twist.twist.linear.z = insgps_frame_.frame.data.data_pack.Velocity_Down; NED_odom_pub_->publish(odom_msg); geometry_msgs::msg::Twist speed_msg; speed_msg.linear.x = insgps_frame_.frame.data.data_pack.BodyVelocity_X; speed_msg.linear.y = insgps_frame_.frame.data.data_pack.BodyVelocity_Y; speed_msg.linear.z = insgps_frame_.frame.data.data_pack.BodyVelocity_Z; twist_pub_->publish(speed_msg); // std::cout << "N: " << insgps_frame_.frame.data.data_pack.Location_North << std::endl; // std::cout << "E: " << insgps_frame_.frame.data.data_pack.Location_East << std::endl; // std::cout << "D: " << insgps_frame_.frame.data.data_pack.Location_Down << std::endl; } } } void ahrsBringup::magCalculateYaw(double roll, double pitch, double &magyaw, double magx, double magy, double magz) { double temp1 = magy * cos(roll) + magz * sin(roll); double temp2 = magx * cos(pitch) + magy * sin(pitch) * sin(roll) - magz * sin(pitch) * cos(roll); magyaw = atan2(-temp1, temp2); if(magyaw < 0) { magyaw = magyaw + 2 * PI; } // return magyaw; } void ahrsBringup::checkSN(int type) { switch (type) { case TYPE_IMU: if (++read_sn_ != imu_frame_.frame.header.serial_num) { if ( imu_frame_.frame.header.serial_num < read_sn_) { sn_lost_ += 256 - (int)(read_sn_ - imu_frame_.frame.header.serial_num); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } else { sn_lost_ += (int)(imu_frame_.frame.header.serial_num - read_sn_); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } } read_sn_ = imu_frame_.frame.header.serial_num; break; case TYPE_AHRS: if (++read_sn_ != ahrs_frame_.frame.header.serial_num) { if ( ahrs_frame_.frame.header.serial_num < read_sn_) { sn_lost_ += 256 - (int)(read_sn_ - ahrs_frame_.frame.header.serial_num); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } else { sn_lost_ += (int)(ahrs_frame_.frame.header.serial_num - read_sn_); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } } read_sn_ = ahrs_frame_.frame.header.serial_num; break; case TYPE_INSGPS: if (++read_sn_ != insgps_frame_.frame.header.serial_num) { if ( insgps_frame_.frame.header.serial_num < read_sn_) { sn_lost_ += 256 - (int)(read_sn_ - insgps_frame_.frame.header.serial_num); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } else { sn_lost_ += (int)(insgps_frame_.frame.header.serial_num - read_sn_); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } } read_sn_ = insgps_frame_.frame.header.serial_num; break; case TYPE_GEODETIC_POS: if (++read_sn_ != Geodetic_Position_frame_.frame.header.serial_num) { if ( Geodetic_Position_frame_.frame.header.serial_num < read_sn_) { sn_lost_ += 256 - (int)(read_sn_ - Geodetic_Position_frame_.frame.header.serial_num); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } else { sn_lost_ += (int)(Geodetic_Position_frame_.frame.header.serial_num - read_sn_); if(if_debug_){ RCLCPP_WARN(this->get_logger(),"detected sn lost."); } } } read_sn_ = Geodetic_Position_frame_.frame.header.serial_num; break; default: break; } } } //namespace FDILink int main(int argc, char **argv) { rclcpp::init(argc, argv); FDILink::ahrsBringup bp; return 0; }-
- 列表
@chenxz 乌龟的屁股——规定
