    ROS turtlebot3 gazebo角速度跳变
    gazebo ros1 角速度跳变
    • O
      Occupy
      我在Ubuntu 20.04的noetic ros1,Gazebo 11.14上运行Gazebo Turtlebot3的仿真,但是机器人的角速度经常发生跳变。
      比如用下面这段代码:
      #include "ros/ros.h"
      #include <Eigen/Core>
      #include <Eigen/Dense>
      #include <iostream>
      #include "nav_msgs/Path.h"
      #include "nav_msgs/Odometry.h"
      #include <tf2_ros/buffer.h>
      #include <tf2/LinearMath/Matrix3x3.h>
      #include "tf2_ros/transform_listener.h"
      #include "tf2_geometry_msgs/tf2_geometry_msgs.h"
      #include "narrow_space_navigation/point_style.h"
      #include "narrow_space_navigation/utils.h"
      #include <random>
      Controller::car_state cur_pose;
      void odom_callback(const nav_msgs::Odometry::ConstPtr &msg)
          try
              geometry_msgs::Quaternion odom_quat = msg->pose.pose.orientation;
              tf2::Quaternion quat;
              tf2::fromMsg(odom_quat, quat);
              double roll, pitch, yaw;
              tf2::Matrix3x3(quat).getRPY(roll, pitch, yaw);
              cur_pose.x = msg->pose.pose.position.x;
              cur_pose.y = msg->pose.pose.position.y;
              cur_pose.yaw = yaw;
              cur_pose.v = msg->twist.twist.linear.x;
              cur_pose.w = msg->twist.twist.angular.z;
          catch(const std::exception& e)
              ROS_INFO("Some errors in the odom_callback.");
      int main(int argc, char *argv[])
          ros::init(argc,argv,"ramdom_test");
          FILE* new_log;
          new_log = fopen("new_test.txt", "w");
          ROS_INFO("ros init");
          ros::NodeHandle nh;
          ros::Publisher twist_pub = nh.advertise<geometry_msgs::Twist>("/cmd_vel", 10);
          ros::Subscriber odom_sub = nh.subscribe("/odom", 10, odom_callback);
          int multiplier = atoi(argv[1]);
          geometry_msgs::Twist control_output;
          double dt = 0.02;
          double a = 0.0;
          ros::Rate r(50);
          while (ros::ok())
              a = a + dt;
              control_output.linear.x = 0.25 * (1 - cos(a)) * multiplier;
              double w_acc = 0.25 * sin(a) * multiplier;
              control_output.angular.z = control_output.angular.z + w_acc * dt;
              r.sleep();
              ros::spinOnce();
              twist_pub.publish(control_output);
              fprintf(new_log, "%.6f "
                                   "%.6f %.6f %.6f %.6f %.6f %.6f %.6f\n",
                      cur_pose.x, cur_pose.y, cur_pose.yaw, control_output.linear.x, control_output.angular.z,
                      cur_pose.v, cur_pose.w, w_acc);
              fflush(new_log);
          return 0;
      用默认的waffle_pi进行测试,得到的图像是这样,这是因为摩擦力太小了:
      于是我修改了机器人的URDF文件:
      <?xml version="1.0"?>
      <robot name="turtlebot3_waffle_pi_sim" xmlns:xacro="http://ros.org/wiki/xacro">
        <xacro:arg name="laser_visual"  default="false"/>
        <xacro:arg name="camera_visual" default="false"/>
        <xacro:arg name="imu_visual"    default="false"/>
        <gazebo reference="base_link">
          <material>Gazebo/DarkGrey</material>
        </gazebo>
        <gazebo reference="wheel_left_link">
          <mu1>1.0</mu1>
          <mu2>1.0</mu2>
          <soft_cfm>0.0</soft_cfm>
          <soft_erp>0.2</soft_erp>
          <kp>1e15</kp>
          <kd>4e12</kd>
          <minDepth>0.001</minDepth>
          <maxVel>10</maxVel>
          <fdir1>1 0 0</fdir1>
          <material>Gazebo/FlatBlack</material>
        </gazebo>
        <gazebo reference="wheel_right_link">
          <mu1>1.0</mu1>
          <mu2>1.0</mu2>
          <kp>1e15</kp>
          <kd>4e12</kd>
          <maxVel>10</maxVel>
        </gazebo>
        <gazebo reference="caster_back_right_link">
          <mu1>0.01</mu1>
          <mu2>0.01</mu2>
          <kp>1e15</kp>
          <kd>4e12</kd>
          <maxVel>10</maxVel>
        </gazebo>
        <gazebo reference="caster_back_left_link">
          <mu1>0.01</mu1>
          <mu2>0.01</mu2>
          <kp>1e15</kp>
          <kd>4e12</kd>
          <maxVel>10</maxVel>
        </gazebo>
        <gazebo reference="imu_link">
          <sensor type="imu" name="imu">
            <always_on>true</always_on>
            <visualize>$(arg imu_visual)</visualize>
          </sensor>
          <material>Gazebo/Grey</material>
        </gazebo>
        <gazebo>
          <plugin name="turtlebot3_waffle_pi_controller" filename="libgazebo_ros_diff_drive.so">
            <commandTopic>cmd_vel</commandTopic>
            <odometryTopic>odom</odometryTopic>
            <odometryFrame>odom</odometryFrame>
            <odometrySource>world</odometrySource>
            <publishOdomTF>true</publishOdomTF>
            <robotBaseFrame>base_footprint</robotBaseFrame>
            <publishWheelTF>false</publishWheelTF>
            <publishTf>true</publishTf>
            <publishWheelJointState>true</publishWheelJointState>
            <legacyMode>false</legacyMode>
            <updateRate>100</updateRate>
            <leftJoint>wheel_left_joint</leftJoint>
            <rightJoint>wheel_right_joint</rightJoint>
            <wheelSeparation>0.287</wheelSeparation>
            <wheelDiameter>0.066</wheelDiameter>
            <wheelAcceleration>4</wheelAcceleration>
            <wheelTorque>10</wheelTorque>
            <rosDebugLevel>na</rosDebugLevel>
          </plugin>
        </gazebo>
        <gazebo>
          <plugin name="imu_plugin" filename="libgazebo_ros_imu.so">
            <alwaysOn>true</alwaysOn>
            <bodyName>imu_link</bodyName>
            <frameName>imu_link</frameName>
            <topicName>imu</topicName>
            <serviceName>imu_service</serviceName>
            <gaussianNoise>0.0</gaussianNoise>
            <updateRate>0</updateRate>
            <imu>
              <noise>
                <type>gaussian</type>
                <rate>
                  <mean>0.0</mean>
                  <stddev>2e-4</stddev>
                  <bias_mean>0.0000075</bias_mean>
                  <bias_stddev>0.0000008</bias_stddev>
                </rate>
                <accel>
                  <mean>0.0</mean>
                  <stddev>1.7e-2</stddev>
                  <bias_mean>0.1</bias_mean>
                  <bias_stddev>0.001</bias_stddev>
                </accel>
              </noise>
            </imu>
          </plugin>
        </gazebo>
        <gazebo reference="base_scan">
          <sensor type="ray" name="lds_lfcd_sensor">
            <pose>0 0 0 0 0 0</pose>
            <visualize>$(arg laser_visual)</visualize>
            <update_rate>5</update_rate>
            <ray>
              <scan>
                <horizontal>
                  <samples>360</samples>
                  <resolution>1</resolution>
                  <min_angle>0.0</min_angle>
                  <max_angle>6.28319</max_angle>
                </horizontal>
              </scan>
              <range>
                <min>0.120</min>
                <max>3.5</max>
                <resolution>0.015</resolution>
              </range>
              <noise>
                <mean>0.0</mean>
                <stddev>0.01</stddev>
              </noise>
            </ray>
            <plugin name="gazebo_ros_lds_lfcd_controller" filename="libgazebo_ros_laser.so">
              <topicName>scan</topicName>
              <frameName>base_scan</frameName>
            </plugin>
          </sensor>
        </gazebo>
      <!--link : https://www.raspberrypi.org/documentation/hardware/camera/-->
        <gazebo reference="camera_rgb_frame">
          <sensor type="camera" name="Pi Camera">
            <visualize>$(arg camera_visual)</visualize>
            <camera>
                <horizontal_fov>1.085595</horizontal_fov>
                <image>
                    <width>640</width>
                    <height>480</height>
                    <format>R8G8B8</format>
                </image>
                <clip>
                    <near>0.03</near>
                    <far>100</far>
                </clip>
            </camera>
            <plugin name="camera_controller" filename="libgazebo_ros_camera.so">
              <updateRate>30.0</updateRate>
              <cameraName>camera</cameraName>
              <frameName>camera_rgb_optical_frame</frameName>
              <imageTopicName>rgb/image_raw</imageTopicName>
              <cameraInfoTopicName>rgb/camera_info</cameraInfoTopicName>
              <hackBaseline>0.07</hackBaseline>
              <distortionK1>0.0</distortionK1>
              <distortionK2>0.0</distortionK2>
              <distortionK3>0.0</distortionK3>
              <distortionT1>0.0</distortionT1>
              <distortionT2>0.0</distortionT2>
            </plugin>
          </sensor>
        </gazebo>
      </robot>
      此时图像为:
      似乎好了不少,但是在图像开始区域出现了大的跳变。我以为是角速度和角加速度太大了,因此平滑一下(此处不是上面代码执行的,而是另一个MPC程序):
      我的控制输入似乎足够平滑了,但机器人能会出现非常离谱的跳变。后面我进一步减少角速度控制的角加速度,但让然会有非常大的跳变出现,我想知道这是为什么呢?
      如果这是模型问题,那我该怎么调整参数?如果是控制问题,是发生在哪里?
      最后,如果是Turtlebot3这个模型不支持这么大的角加速度(即便我已经调的很小了,0.5m/s^2),那我应该自己写一个吗,还是在找一个开源的模型。
      O 1 条回复 最后回复 回复 引用 0
        针对您在使用Turtlebot3在Gazebo中进行仿真时遇到的角速度跳变问题,我们可以从几个方面来分析和解决:
        1. 仿真模型参数调整
        首先,您已经对轮子的摩擦系数和物理属性进行了调整,这是一个很好的开始。然而,可能还需要进一步检查以下参数:
        • wheelTorque 和 wheelAcceleration:这些参数直接影响轮子的响应速度和力量。如果设置得过高,可能会导致模型在物理仿真中表现不稳定。尝试逐步降低这些值,看看是否有助于减少跳变。
        • 仿真步长(Simulation Step Size):Gazebo中的仿真步长(或称为时间步长)也可能影响仿真的稳定性。虽然您已经在代码中设置了较高的控制更新率(50Hz),但Gazebo的物理引擎可能以不同的步长运行。可以在Gazebo的设置中调整这个参数。
        2. 控制算法
        从您提供的代码来看,您似乎正在使用一个基于时间积分的控制算法来调整角速度。这种方法在理想条件下可能工作得很好,但在物理仿真中,由于存在各种不确定性和噪声,可能会导致不稳定的行为。
        • 平滑控制输入:除了调整角加速度的增量外,还可以考虑使用更平滑的控制算法,如PID控制器或更高级的控制策略,如模型预测控制(MPC)。
        • 限制控制输入:确保控制输入(即线性速度和角速度)在合理的物理范围内。例如,可以设置一个最大角速度限制。
        3. 仿真环境
        • 地面条件:地面的摩擦系数和不平整度也会影响仿真结果。确保地面属性(如摩擦系数)与实际情况相符。
        • 其他物体:检查仿真环境中是否有其他可能影响Turtlebot3运动的物体,如墙壁、障碍物等。
        4. 代码实现
        • 异常处理:在odom_callback中,您已经尝试捕获并处理异常,但确保这些异常处理逻辑是完整且有效的。
        • 数据同步:确保在发布控制命令和读取里程计数据之间没有显著的时间延迟。
        5. 替换模型
        如果调整以上参数和算法后问题仍未解决,可能需要考虑使用其他仿真模型。Turtlebot3的模型在大多数情况下应该足够稳定,但如果您的应用场景非常特殊或需要更高的精度,可能需要自定义模型。
        结论
        建议先从调整仿真参数和控制算法开始,因为这些通常是解决此类问题的最直接和有效的方法。如果这些方法都不能解决问题,再考虑替换模型或进一步深入分析物理仿真引擎的行为。在开发过程中,保持对控制输入和仿真输出的仔细监控,以便及时发现问题并进行调整。
        • O
          Occupy @Occupy
          @Occupy 我在 https://robotics.stackexchange.com/questions/113285/gazebo-simulation-with-a-fluctuating-angular-velocity 也发了提问,但没得到满意的回答。
          • O
            Occupy
            没有朋友知道发生的原因吗?
