    使用launch启动两个node,但是只打印了一个node的日志
    ros2 ros2 windows windows ros2 humble launch
    2.3k
    • J
      Jason_Duan
      环境:
      win11
      ros2 humble
      第一个:
      包名:pkg_cpp
      node:node_cpp
      文件内容:
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/string.hpp"      //导入订阅者的消息接口类型
      #include "std_msgs/msg/u_int32.hpp"     //
      class NodeCpp : public rclcpp::Node
      public:
          NodeCpp(std::string nodeName):Node(nodeName) //用nodeName实例化一个父类Node的匿名对象
              RCLCPP_INFO(this->get_logger(), "Hello, this is %s.", nodeName);
              //实例化一个订阅者对象
              m_subscriber = this->create_subscription<std_msgs::msg::String>("my_new_topic", 10, std::bind(&NodeCpp::sub_callback, this, std::placeholders::_1));
              //实例化一个发布者对象
              m_Publisher = this->create_publisher<std_msgs::msg::UInt32>("my_new_topic_money", 10);
              m_account.data = 10000;
      private:
          //回调函数
          void sub_callback(const std_msgs::msg::String::SharedPtr msg)
              std_msgs::msg::UInt32 msg_temp;
              msg_temp.data = 10;
              m_account.data -= msg_temp.data;
              m_Publisher->publish(msg_temp);
              RCLCPP_INFO(this->get_logger(), "node_cpp:收到消息:%s.  支付 %d 元.  剩余 %d 元.", msg->data, msg_temp.data, m_account.data);  //.c_str();
          //声明一个订阅者成员变量
          rclcpp::Subscription<std_msgs::msg::String>::SharedPtr m_subscriber;
          //声明一个发布者成员变量
          rclcpp::Publisher<std_msgs::msg::UInt32>::SharedPtr m_Publisher;
          std_msgs::msg::UInt32 m_account;
          // 初始化rclcpp
          rclcpp::init(argc, argv);
          // 产生一个名为node_cpp的节点
          auto node = std::make_shared<NodeCpp>("node_cpp");
          // 运行节点,并检测退出信号 Ctrl+C
          rclcpp::spin(node);
          // 停止运行
          rclcpp::shutdown();
          return 0;
      第二个:
      包名:pkg_py
      node:node_py
      文件内容:
      import rclpy
      from rclpy.node import Node
      from std_msgs.msg import String,UInt32
      class NodeWriter(Node):
          def __init__(self, name):
              super().__init__(name)  #初始化基类name
              self.get_logger().info(f"Hello, this is {name}")
              self.msg_publisher = self.create_publisher(String, "my_new_topic", 10)      #创建一个发布者
              self.timer_period = 5.0
              self.timer = self.create_timer(self.timer_period, self.pub_callback)
              # 创建订阅者
              self.msg_subscribe_ = self.create_subscription(UInt32,"my_new_topic_money",self.func_callback,10)
              self.account = 100.0
              self.count = 0
          def pub_callback(self):
              回调函数
              msg = String()
              msg.data = f"msg:{self.count}"
              self.count += 1
              self.msg_publisher.publish(msg)    # 调用发布者的publish方法来发布消息
              self.get_logger().info(f'发布了指令:{msg.data}')    #打印发布的数据
          def func_callback(self,money):
              self.account += money.data
              self.get_logger().info(f"node_py 收到 {money.data} 元,现在有 {self.account} 元。")
      def main(args=None):
          ros2运行该节点的入口函数
          编写ROS2节点的一般步骤
          1. 导入库文件
          2. 初始化客户端库
          3. 新建节点对象
          4. spin循环节点
          5. 关闭客户端库
          rclpy.init(args=args) # 初始化rclpy
          node = NodeWriter("node_py")  # 新建一个节点
          # node.get_logger().info("Hello, this is writer_node_py.")
          rclpy.spin(node) # 保持节点运行,检测是否收到退出指令(Ctrl+C)
          rclpy.shutdown() # 关闭rclpy
      launch文件放在pkg_py包下,
      launch文件内容:
      # 导入库
      from launch import LaunchDescription  #用于对launch文件内容进行描述
      from launch_ros.actions import Node   #用于声明节点所在的位置
          """launch内容描述函数,由ros2 launch 扫描调用"""
          node_cpp = Node(
              package="pkg_cpp",         #包名
              executable="node_cpp"      #node名
          node_py = Node(
              package="pkg_py",
              executable="node_py"
          # 创建LaunchDescription对象launch_description,用于描述launch文件
          launch_description = LaunchDescription(
              [node_cpp, node_py])
          # 返回让ROS2根据launch描述执行节点
          return launch_description
      pkg_py包的setup.py文件内容如下:
      from setuptools import find_packages, setup
      from glob import glob
      import os
      package_name = 'pkg_py'
      setup(
          name=package_name,
          version='0.0.0',
          packages=find_packages(exclude=['test']),
          data_files=[
              ('share/ament_index/resource_index/packages',
                  ['resource/' + package_name]),
              ('share/' + package_name, ['package.xml']),
              (os.path.join('share', package_name, 'launch'), glob('launch/*.launch.py')),
          install_requires=['setuptools'],
          zip_safe=True,
          maintainer='jason',
          maintainer_email='jason.duan@innovention.cn',
          description='TODO: Package description',
          license='Apache-2.0',
          tests_require=['pytest'],
          entry_points={
              'console_scripts': [
                  "node_py = pkg_py.node_py:main"
      编译后可以正常通过launch命令打开这两个node,rqt_graph显示的逻辑也是对的
      也有node_py这个节点的进程
      但是没有node_py这个节点的日志输出,只要node_cpp的日志
      这是为什么?哪位大神可以解答一下
      J 小鱼小 5 条回复 最后回复 回复 引用 0
        在你的问题中,node_py 节点没有输出日志,但 node_cpp 节点有日志输出,这通常是由于几种可能的原因导致的。以下是一些可能的原因及解决方案:
        1. 日志级别问题
        首先,确保 node_py 中的日志级别足够高以显示信息。ROS 2 默认的日志级别是 INFO,但如果你在某个地方(可能是代码或配置文件)改变了它,那么 INFO 级别的日志可能就不会显示了。
        检查方法:
        • 确认在 node_py 代码中是否修改了日志级别。
        • 检查 ROS 2 的配置文件(如 config/settings.yaml),看是否有针对整个系统的日志级别设置。
        2. 节点没有运行或崩溃
        如果节点没有正确运行或启动后立即崩溃,那么它不会输出任何日志。
        检查方法:
        • 使用 ros2 node list 确认 node_py 是否在运行。
        • 检查 node_py 的进程状态(使用如 top, ps 等命令)。
        • 查看是否有相关的错误或崩溃信息输出到控制台或日志文件。
        3. 节点启动顺序问题
        在某些情况下,如果 node_py 依赖于 node_cpp 的某些服务或话题,并且 node_cpp 还没有准备好,那么 node_py 可能会因为无法连接到所需的服务或话题而静默失败。然而,这通常会导致错误或警告日志。
        检查方法:
        • 确保 node_py 和 node_cpp 之间的依赖关系正确无误。
        • 检查 node_py 的代码,看是否有任何处理依赖失败的逻辑,可能这些逻辑会静默处理错误。
        4. 配置文件或环境问题
        有时,特定的配置文件或环境设置可能会影响节点的行为。
        检查方法:
        • 检查 node_py 和 node_cpp 的环境变量和配置文件是否一致。
        • 尝试在不同的环境中运行节点,看是否有不同的行为。
        5. 代码问题
        最后,可能是 node_py 代码中的某个部分阻止了日志的正常输出。
        检查方法:
        • 仔细检查 node_py 的代码,特别是与日志输出相关的部分。
        • 尝试在 node_py 的不同位置添加日志输出,看是否能看到任何输出。
        解决方案
        • 确保所有节点的日志级别都设置为可见(例如,INFO 或更低)。
        • 检查节点的启动和运行状态,确保它们都在正常运行。
        • 如果节点之间有依赖关系,请确保它们按正确的顺序启动。
        • 仔细检查代码和环境配置,查找可能导致问题的任何不一致之处。
        如果以上方法都不能解决问题,你可能需要更详细地检查 node_py 的代码和配置,或者尝试在更简单的环境中重现问题。
        • J
          Jason_Duan @Jason_Duan
          @Jason_Duan
          不使用launch,单独启动这俩node,node_py有日志输出
          • J
            @Jason_Duan
            将pkg_cpp这个包中的CMakeLists.txt结尾加入
            install(DIRECTORY launch
              DESTINATION share/${PROJECT_NAME}
            后,重新编译pkg_cpp包,再launch这个包的launch文件,也是同样的现象
            • J
              @Jason_Duan
              使用Ctrl + C终止运行后,最后才显示node_py节点打印的内容,但是仅有一行,图如下
              打印的信息为:
              [node_cpp.EXE-1] [INFO] [1729671693.937304300] [node_cpp]: node_cpp:收到消息:27.  支付 10 元.  剩余 9720 元.
              [node_cpp.EXE-1] [INFO] [1729671698.941970600] [node_cpp]: node_cpp:收到消息:28.  支付 10 元.  剩余 9710 元.
              [WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
              [INFO] [node_cpp.EXE-1]: process has finished cleanly [pid 8092]
              [ERROR] [node_py.EXE-2]: process has died [pid 32524, exit code 3221225786, cmd 'd:\Code\ros2project\project01\demo_proj\install\pkg_py\lib\pkg_py\node_py.EXE --ros-args'].
              [node_py.EXE-2] [INFO] [1729671553.926409700] [node_py]: Hello, this is node_py
              d:\Code\ros2project\project01\demo_proj>
              • J
                @Jason_Duan
                问题解决,但又没解决:
                使用rqt的console能看到node_py的日志
                由此确定:
                肯定不是通信的问题,
                可能是windows环境下ros2的问题,
                更可能是微软的问题
                  小鱼 技术大佬 @Jason_Duan
                  @Jason_Duan windows 不好说欸
