    gazebo仿真模型沉到地下,ros-control不能控制车运行
    gazebo ros
    1.6k
    • 小丑汪小
      WOW995
      下面是我的xacro文件:
      <?xml version="1.0" encoding="utf-8"?>
      <robot name="xul307a" xmlns:xacro="http://www.ros.org/wiki/xacro">
        <xacro:include filename="$(find velodyne_description)/urdf/HDL-32E.urdf.xacro"/>
        <xacro:include filename="$(find velodyne_description)/urdf/VLP-16.urdf.xacro"/>
        <link name="base_footprint">
              <visual>
                  <geometry>
                      <sphere radius="0.001" />
                  </geometry>
              </visual>
        </link>
        <link name="base_link">
          <inertial>
            <origin xyz="0 0 0" rpy="0 0 0" />
            <mass value="4049.8" />
              <!-- <inertia
              ixx="7926.94"
              ixy="0"
              ixz="0"
              iyy="7723.8"
              iyz="0"
              izz="613.68" /> -->
            <inertia
              ixx="613.68"
              ixy="0"
              ixz="0"
              iyy="7723.8"
              iyz="0"
              izz="7926.94" />
          </inertial>
          <visual>
            <geometry>
              <box size="4.72 0.78 1.1" />
            </geometry>
            <material name="">
              <color rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint name="base_link2base_footprint" type="fixed">
            <parent link="base_footprint" />
            <child link="base_link"/>
            <origin xyz="0 0 1.067" />
        </joint>
      <link name="back_right_wheel">
          <inertial>
            <mass value="639.613" />
            <inertia
              ixx="87.55"
              ixy="0.00"
              ixz="0.00"
              iyy="87.55"
              iyz="0.00"
              izz="156.705" />
          </inertial>
          <visual>
            <geometry>
              <cylinder radius="0.7" length="0.415" />
            </geometry>
            <material name="">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="back_right_wheel2base_link"
          type="continuous">
          <origin
            xyz="0.59665 -0.7504 -0.3671"
            rpy="1.5708 0 0" />
          <parent
            link="base_link" />
          <child
            link="back_right_wheel" />
          <axis
            xyz="0 0 -1" />
        </joint>
        <link
          name="back_left_wheel">
          <inertial>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <mass
              value="639.613" />
            <inertia
              ixx="87.55"
              ixy="0.00"
              ixz="0.00"
              iyy="87.55"
              iyz="0.00"
              izz="156.705" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="back_left_wheel2base_link"
          type="continuous">
          <origin
            xyz="0.59665 0.7504 -0.3671"
            rpy="1.5707 0 -3.1416" />
          <parent
            link="base_link" />
          <child
            link="back_left_wheel" />
          <axis
            xyz="0 0 -1" />
        </joint>
        <link
          name="steering_hinge_link">
          <inertial>
            <origin
              xyz="2.127 0 0"
              rpy="0 0 0" />
            <mass
              value="2985.8" />
            <!-- <inertia
              ixx="3314.3"
              ixy="0"
              ixz="0"
              iyy="3164.6"
              iyz="0"
              izz="452.45" /> -->
              <inertia
              ixx="452.45"
              ixy="0"
              ixz="0"
              iyy="3314.3"
              iyz="0"
              izz="3164.6" />
          </inertial>
          <visual>
            <origin
              xyz="2.127 0 0"
              rpy="0 0 0" />
            <geometry>
              <box size="3.48 0.78 1.1" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="2.127 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="steering_hinge2base_link"
          type="revolute">
          <origin
            xyz="2.36 0 0"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="steering_hinge_link" />
          <axis
            xyz="0 0 -1" />
          <limit
            lower="-0.74"
            upper="0.74"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="front_right_wheel">
          <inertial>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <mass
              value="639.613" />
            <inertia
              ixx="87.55"
              ixy="0.00"
              ixz="0.00"
              iyy="87.55"
              iyz="0.00"
              izz="156.705" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="front_right_wheel2steering_hinge"
          type="continuous">
          <origin
            xyz="1.42 -0.75 -0.366"
            rpy="1.57 0 0" />
          <parent
          <child
            link="front_right_wheel" />
          <axis
            xyz="0 0 -1" />
        </joint>
        <link
          name="front_left_wheel">
          <inertial>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <mass
              value="639.613" />
            <inertia
              ixx="87.55"
              ixy="0.00"
              ixz="0.00"
              iyy="87.55"
              iyz="0.00"
              izz="156.705" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="front_left_wheel2steering_hinge"
          type="continuous">
          <origin
            xyz="1.42 0.75 -0.366"
            rpy="1.57 0 -3.14" />
          <parent
          <child
            link="front_left_wheel" />
          <axis
            xyz="0 0 -1" />
        </joint>
        <VLP-16 parent="base_link" name="velodyne_front" topic="/velodyne_points_front" hz="10" samples="1801"  min_range="0.8" max_range="130.0" min_angle="-${M_PI}" max_angle="${M_PI}" >
          <origin xyz="2.505 0 1.26" rpy="0 0 0" />
        </VLP-16>
        <VLP-16 parent="base_link" name="velodyne_back" topic="/velodyne_points_back" hz="10" samples="1801"  min_range="0.8" max_range="130.0" min_angle="-${M_PI}" max_angle="${M_PI}" >
          <origin xyz="-2.2056 0 0.7538" rpy="0 0 3.14" />
        </VLP-16>
      <!-- motors and transmissions for the two rear wheels -->
        <transmission name="tran1">
          <type>transmission_interface/SimpleTransmission</type>
          <joint name="back_right_wheel2base_link">
            <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>
          </joint>
          <actuator name="motor1">
            <mechanicalReduction>1</mechanicalReduction>
          </actuator>
        </transmission>
        <transmission name="tran2">
          <joint name="back_left_wheel2base_link">
          </joint>
          <actuator name="motor2">
          </actuator>
        </transmission>
        <!-- EPS and transmissions for the front steering -->
        <transmission name="tran3">
          <joint name="steering_hinge2base_link">
            <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
          </joint>
          <actuator name="eps">
            <motorTorqueConstant>1000000</motorTorqueConstant>
          </actuator>
        </transmission>
        <!-- Friction Parametres -->
        <gazebo reference="back_right_wheel">
          <mu1>10000000</mu1>
          <mu2>10000000</mu2>
          <kp>10000000</kp>
          <kd>1</kd>
        </gazebo>
        <gazebo reference="back_left_wheel">
          <mu1>10000000</mu1>
          <mu2>10000000</mu2>
          <kp>10000000</kp>
          <kd>1</kd>
        </gazebo>
        <gazebo reference="front_right_wheel">
          <mu1>10000000</mu1>
          <mu2>10000000</mu2>
          <kp>10000000</kp>
          <kd>1</kd>
        </gazebo>
        <gazebo reference="front_left_wheel">
          <mu1>10000000</mu1>
          <mu2>10000000</mu2>
          <kp>10000000</kp>
          <kd>1</kd>
        </gazebo>
        <!-- Gazebo Plugins -->
        <gazebo>
          <plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
            <robotNamespace>/xul307a</robotNamespace>
            <robotParam>robot_description</robotParam>
            <robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType>
            <!-- <legacyModeNS>true</legacyModeNS> -->
          </plugin>
        </gazebo>
        <gazebo>
          <plugin name="joint_state_publisher" filename="libgazebo_ros_joint_state_publisher.so">
            <jointName>back_right_wheel2base_link, back_left_wheel2base_link, steering_hinge2base_link,front_right_wheel2steering_hinge,front_left_wheel2steering_hinge</jointName>
            <updateRate>50.0</updateRate>
            <alwaysOn>true</alwaysOn>
          </plugin>
        </gazebo>
      </robot>
      小鱼小 1 条回复 最后回复 回复 引用 1
        小鱼 技术大佬 @小丑汪
        @小丑汪 在 gazebo仿真模型沉到地下,ros-control不能控制车运行 中说:
        无法承受机器之重,你的质量可能太大了,受力面积又小,物体刚性系数估计也不够,被强制压入地面了
        小丑汪小 1 条回复 最后回复 回复 引用 1
        • 小丑汪小
          WOW995 @小鱼
          @小鱼 好的,谢谢您。我把质量调小试一下。
            小鱼 技术大佬 @小丑汪
            @小丑汪 质量小对应惯性矩阵也要调整哦
            1 条回复 最后回复 回复 引用 1
            • 小丑汪小 小丑汪 将这个主题标记为已解决,在
