    在使用Gazebo接入ros2_control的时候出现parameter无法解析的错误
    动手学ros2 gazebo ros2 control
    7
    9
    4.4k
    • Y
      yepraywong
      以下是根据小鱼的课程编辑的代码:
      1. fishbot.ros2_contro.xacro
      <?xml version="1.0"?>
          <xacro:macro name="fishbot_ros2_control">
              <!-- This '<ros2_control>' will be seen by '<gazebo>' -->
              <ros2_control name="FishBotGazeboSystem" type="system">
                  <hardware>
                      <plugin>gazebo_ros2_control/GazeboSystem</plugin>
                  </hardware>
                  <joint name="left_wheel_joint">
                      <!-- 利用速度接口控制轮子输出的转速 -->
                      <command_interface name="velocity">
                          <param name="min">-1</param>
                          <param name="max">1</param>
                      </command_interface>
                      <!-- 利用速度接口控制轮子输出的力 -->
                      <command_interface name="effort">
                          <param name="min">-0.1</param>
                          <param name="max">0.1</param>
                      <!-- position 表示轮子转了多少度 -->
                      <!-- velocity 轮子转速 -->
                      <!-- effort 轮子输出的力 -->
                      <state_interface name="position" />
                      <state_interface name="velocity" />
                      <state_interface name="effort" />
                  </joint>
                  <joint name="right_wheel_joint">
                  </joint>
              </ros2_control>
          <gazebo>
              <plugin filename="libgazebo_ros2_control.so" name="gazebo_ros2_control">
                  <parameters>$(find fishbot_description)/config/fishbot_ros2_controller.yaml</parameters>
              </plugin>
          </gazebo>
          </xacro:macro>
      </robot>
      1. fishbot_ros2_controller.yaml
      controller_manager:
        ros__parameters:
          update_rate: 100  # Hz
          use_sim_time: true
      1. fishbot.urdf.xacro
      <robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="fish_robot">
      <!-- base -->
      <!-- 'find fishbot_description' is to find pkgs' share directory -->
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/base.urdf.xacro"/>
      <!-- sensors -->
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/imu.urdf.xacro"/>
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/camera.urdf.xacro"/>
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/laser.urdf.xacro"/>
      <!-- wheels -->
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/actuator/wheel.urdf.xacro"/>
      <!-- casters -->
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/actuator/caster.urdf.xacro"/>
      <!-- plugins -->
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/plugins/gazebo_control_plugin.xacro"/>
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/plugins/gazebo_sensor_plugin.xacro"/>
      <xacro:include filename="$(find fishbot_description)/urdf/fishbot/fishbot.ros2_control.xacro"/>
      <xacro:base_xacro length="0.12" radius='0.10'/>
      <xacro:imu_xacro xyz="0.0 0.0 0.02"/>
      <xacro:camera_xacro xyz="0.10 0.0 0.075"/>
      <xacro:laser_xacro xyz="0.0 0.0 0.10"/>
      <xacro:wheel_xacro wheel_name="left_wheel" xyz="0 0.10 -0.06"/>
      <xacro:wheel_xacro wheel_name="right_wheel" xyz="0 -0.10 -0.06"/>
      <!-- 0.076 = 0.06(half of base link's height) + 0.032(wheels' radius) - 0.016(caster's radius) -->
      <xacro:caster_xacro caster_name="back_caster" xyz="-0.08 0.0 -0.076"/>
      <xacro:caster_xacro caster_name="front_caster" xyz="0.08 0.0 -0.076"/>
      <!-- using plugins -->
      <!-- 因为使用两轮差速控制硬件和gazebo ros2 control相冲突 -->
      <!-- 所以在使用ros2 control的时候需要把两轮差速控制硬件的插件注释掉 -->
      <xacro:gazebo_sensor_plugin />
      <xacro:fishbot_ros2_control />
      </robot>
      1. gazebo_sim.launch.py
      import launch
      import launch.launch_description_sources
      import launch_ros
      # find first_robot.urdf file's directory
      import os
      from launch.substitutions import Command, LaunchConfiguration
      import launch_ros.parameter_descriptions
          # the code below return the fishbot_description path under the 'share' directory
          urdf_package_path = get_package_share_directory('fishbot_description')
          # obtain the xacro file's path
          default_xacro_path = os.path.join(urdf_package_path, 'urdf', 'fishbot/fishbot.urdf.xacro')
          # default gazebo file's path
          default_gazebo_world_path = os.path.join(urdf_package_path, 'world', 'custom_room.world')
          # declare a param for the xacro directory
              name='model',default_value=str(default_xacro_path),description='file path of loaded model'
          substituted_command_result = Command(['xacro ', LaunchConfiguration('model')])
          robot_description_value = launch_ros.parameter_descriptions.ParameterValue(substituted_command_result, value_type=str)
          action_robot_state_publisher = launch_ros.actions.Node(
              parameters=[{'robot_description':robot_description_value}]
              # 这里的parameters参数是用来向节点传递配置参数的,来获取机器人的 URDF 文件内容
          # launch gazebo
          action_launch_gazebo = launch.actions.IncludeLaunchDescription(
              launch.launch_description_sources.PythonLaunchDescriptionSource(
                  [get_package_share_directory('gazebo_ros'),'/launch','/gazebo.launch.py']
              launch_arguments=[('world',default_gazebo_world_path),('verbose','true')]
          action_spawn_entity = launch_ros.actions.Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-topic','/robot_description','-entity','fishbot']
              action_declare_arg_mode_path,
              action_robot_state_publisher,
              action_launch_gazebo,
              action_spawn_entity
      build并source了之后,运行命令:ros2 launch fishbot_description gazebo_sim.launch.py出现如下错误信息:
      [INFO] [launch]: All log files can be found below /home/rayray/.ros/log/2024-11-03-15-32-19-623161-ruirui-6405
      [INFO] [robot_state_publisher-1]: process started with pid [6417]
      [INFO] [gzserver-2]: process started with pid [6419]
      [INFO] [gzclient-3]: process started with pid [6421]
      [INFO] [spawn_entity.py-4]: process started with pid [6423]
      [robot_state_publisher-1] [INFO] [1730619140.442733183] [robot_state_publisher]: got segment back_caster_link
      [robot_state_publisher-1] [INFO] [1730619140.442932242] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-1] [INFO] [1730619140.442947571] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1730619140.442955913] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-1] [INFO] [1730619140.442963330] [robot_state_publisher]: got segment camera_optical_link
      [robot_state_publisher-1] [INFO] [1730619140.442970904] [robot_state_publisher]: got segment front_caster_link
      [robot_state_publisher-1] [INFO] [1730619140.443010637] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-1] [INFO] [1730619140.443018315] [robot_state_publisher]: got segment laser_cylinder_link
      [robot_state_publisher-1] [INFO] [1730619140.443025876] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-1] [INFO] [1730619140.443038634] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-1] [INFO] [1730619140.443046157] [robot_state_publisher]: got segment right_wheel_link
      [gzclient-3]
      [gzserver-2]
      [spawn_entity.py-4] [INFO] [1730619140.932122723] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-4] [INFO] [1730619140.932722353] [spawn_entity]: Loading entity published on topic /robot_description
      [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-4]   warnings.warn(
      [spawn_entity.py-4] [INFO] [1730619140.935257380] [spawn_entity]: Waiting for entity xml on /robot_description
      [spawn_entity.py-4] [INFO] [1730619140.947043458] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-4] [INFO] [1730619140.947584792] [spawn_entity]: Waiting for service /spawn_entity
      [spawn_entity.py-4] [INFO] [1730619141.703951446] [spawn_entity]: Calling service /spawn_entity
      [gzserver-2] [Msg] Waiting for master.
      [gzserver-2] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
      [gzserver-2] [Msg] Publicized address: 192.168.1.7
      [gzserver-2] [Msg] Loading world file [/home/rayray/URDFLearning/URDFLearn_ws/install/fishbot_description/share/fishbot_description/world/custom_room.world]
      [gzserver-2] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
      [gzclient-3]
      [gzclient-3] libcurl: (5) Unsupported proxy syntax in 'http://127.0.0.1 :7890/'
      [gzserver-2] [INFO] [1730619142.516533608] [depth_camera]: Publishing camera info to [/camera_sensor/camera_info]
      [gzserver-2] [INFO] [1730619142.517603375] [depth_camera]: Publishing depth camera info to [/camera_sensor/depth/camera_info]
      [gzserver-2] [INFO] [1730619142.518202683] [depth_camera]: Publishing pointcloud to [/camera_sensor/points]
      [spawn_entity.py-4] [INFO] [1730619142.670410667] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
      [gzclient-3] [Msg] Publicized address: 192.168.1.7
      [gzclient-3] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
      [gzserver-2] [INFO] [1730619142.792004313] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin
      [gzserver-2] [INFO] [1730619142.798491513] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in namespace: /
      [gzserver-2] [INFO] [1730619142.798567602] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros2_control
      [gzserver-2] [INFO] [1730619142.809044792] [gazebo_ros2_control]: connected to service!! robot_state_publisher
      [gzserver-2] [INFO] [1730619142.812920852] [gazebo_ros2_control]: Received urdf from param server, parsing...
      [gzserver-2] [INFO] [1730619142.812998897] [gazebo_ros2_control]: Loading parameter files /home/rayray/URDFLearning/URDFLearn_ws/install/fishbot_description/share/fishbot_description/config/fishbot_ros2_controller.yaml
      [gzserver-2] [rcutils|error_handling.c:65] an error string (message, file name, or formatted message) will be truncated
      [gzserver-2] [ERROR] [1730619142.813820165] [gazebo_ros2_control]: parser error Couldn't parse parameter override rule: '--param robot_description:=<?xml version="1.0" ?>
      [gzserver-2] <!-- =================================================================================== -->
      [gzserver-2] <!-- |    This document was autogenerated by xacro from /home/rayray/URDFLearning/URDFLearn_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro | -->
      [gzserver-2] <!-- |    EDITING THIS FILE BY HAND IS NOT RECOMMENDED                                 | -->
      [gzserver-2] <robot name="fish_robot">
      [gzserver-2]   <link name="base_footprint"/>
      [gzserver-2]   <link name="base_link">
      [gzserver-2]     <!-- Components' appearance -->
      [gzserver-2]     <visual>
      [gzserver-2]       <!-- Offset and rotation along it's own geometric center -->
      [gzserver-2]       <ori, at ./src/rcl/arguments.c:343
      [gzserver-2]
      [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 6423]
      [INFO] [gzclient-3]: process has finished cleanly [pid 6421]
      应该就是parser error Couldn't parse parameter override rule: '--param robot_description:=<?xml version="1.0" ?>这个错误一直解决不了,排除了很久的代码也没有找到问题,恳请各位大佬前辈帮帮忙,有前辈遇到过类似的问题吗
        您遇到的问题是由于Gazebo尝试解析通过--param传递的机器人描述(URDF/XACRO)字符串时出错。这通常发生在Gazebo的ROS 2插件尝试从参数服务器获取URDF信息时,但获取到的格式不正确或解析方式有误。
        从错误信息来看,Gazebo尝试解析的URDF字符串被错误地直接放在了命令行参数中,而通常这应该是通过参数服务器正确加载的XML格式文件。这里的错误提示显示XML内容被直接作为字符串解析,导致解析失败。
        解决步骤
        1. 确保URDF/XACRO文件正确加载:
          • 确保fishbot.urdf.xacro文件正确无误,并且所有包含的文件路径都是正确的。
          • 使用xacro命令行工具检查XACRO文件是否可以被正确解析:
            xacro --inorder fishbot_description/urdf/fishbot/fishbot.urdf.xacro
            确保输出是一个有效的URDF XML。
        2. 检查参数服务器上的robot_description:
          • 在运行Gazebo之前,确保robot_description参数已经被正确设置到参数服务器上。您可以通过ROS 2命令行工具查看:
            ros2 param get /robot_state_publisher robot_description
            这应该输出您的URDF XML内容。
        3. 检查Gazebo的ROS 2插件配置:
          • 在您的fishbot.ros2_control.xacro文件中,您配置了Gazebo的ROS 2控制插件来加载fishbot_ros2_controller.yaml。确保这个YAML文件正确无误,并且路径正确。
          • 确保Gazebo的ROS 2插件配置正确,并且它应该通过参数服务器获取robot_description,而不是直接从命令行参数获取。
        4. 修改启动文件:
          • 您的gazebo_sim.launch.py文件看起来是正确设置了robot_description参数。但是,确保在Gazebo尝试访问这个参数之前,robot_state_publisher已经运行并发布了这个参数。
          • 您可以尝试调整节点启动的顺序,确保robot_state_publisher在Gazebo之前完全启动并运行。
        5. 调试和日志:
          • 增加日志输出,特别是在设置robot_description参数和Gazebo尝试读取这个参数的地方。
          • 检查Gazebo的日志文件,看是否有更详细的错误信息。
        6. 环境问题:
          • 确保您的ROS 2和Gazebo环境配置正确,所有依赖都已正确安装。
        通过上述步骤,您应该能够定位问题的根源,并找到解决方法。如果问题仍然存在,可能需要更详细地检查Gazebo的ROS 2插件的源代码,看看它是如何处理robot_description参数的。
        4 1 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @yepraywong
          @yepraywong urdf格式错误吧,仔细检查
          Y 1 条回复 最后回复 回复 引用 0
          • Y
            yepraywong @小鱼
            @小鱼 解决啦!把注释里的冒号全部删除就不报错了,应该是冒号影响了解析。
            S 1 条回复 最后回复 回复 引用 1
            • 4
              开心 @小伊
              @小伊 运行ros2 param get /robot_state_publisher robot_description
              提示Node not found
                小鱼 技术大佬 @43996173
                @43996173 先运行节点
                • S
                  solito1 @yepraywong
                  @yepraywong 注释里的冒号是指的哪里呢,我也遇到了相同的报错
                    注释中不能出现": "(英文冒号+空格)这样的结构,可能会影响解析。
                    可以通过下面的方案快速判断是不是注释中冒号导致的问题:
                    使用xacro fishbot.urdf.xacro > fishbot.urdf生成文件fishbot.urdf,在里面全局查找": ",全部替换掉,然后在gazebo_sim.launch.py中的
                    robot_description = launch_ros.parameter_descriptions.ParameterValue(
                        launch.substitutions.Command(
                            ['xacro ', launch.substitutions.LaunchConfiguration('model')]),
                        value_type=str)
                    改为
                            ['cat', 'fishbot.urdf']),
                        value_type=str)
                    注意上面的fishbot.urdf是你的实际路径。
                    再重新编译运行一遍,如果成功,则说明是注释中冒号的问题。
                    (被折磨了半天T_T)
                    • X
                      xsbxbx
                          substitutions_command_result = launch.substitutions.Command(['xacro ', launch.substitutions.LaunchConfiguration('model')])
                          robot_description_value = ParameterValue(substitutions_command_result,value_type=str)
                      把value_type=str改成value_type=None,然后launch启动,看报错信息,看哪里有文件格式错误。
                      一般错误就发生在注释信息里面,目前看到注释里带有“:”或者“#”的都会导致解析失败,这是gazebo_ros2_control这个插件带出来的问题。
                      把这些顿号、井号删了,再构建运行就没问题了。
                      https://errorism.dev/issues/ros-controls-gazebo_ros2_control-parser-error-couldnt-parse-parameter-override-rule---loading-tricycle_controller-from-ros2_control
                      可以看看链接里的文章,我就是跟着这个解决的。
