    [Gazebo仿真] 启动时出现错误 Unable to start server[bind: Address already in use]
    gazebo 仿真错误
    1.7k
      平台信息
      • Ubuntu22.04
      • ROS2 Foxy
      • FishBot建图仿真
      运行指令
      ros2 launch fishbot_description gazebo.launch.p
      报错如下
      [gazebo-1] [Err] [Master.cc:96] EXCEPTION: Unable to start server[bind: Address already in use]. There is probably another Gazebo process running.
      [gazebo-1]
      [gazebo-1]
      [ERROR] [gazebo-1]: process has died [pid 493, exit code 255, cmd 'gazebo --verbose -s libgazebo_ros_factory.so /root/d2lros2/d2lros2/chapt10/chapt10_ws/install/fishbot_description/share/fishbot_description/world/fishbot.world'].
      [gazebo-1]
      • 小鱼小 小鱼 将这个主题转为问答主题,在
        小鱼 技术大佬 @小鱼
        @小鱼 原因是启动多个Gazebo或者原有Gazebo没有退出导致
        Gazebo分为server和client两端,根据错误提示是多个服务端启动了,可以用下面的命令杀死对应进程。
        killall gzserver
        killall gzclient
        没有killall可以安装
        sudo apt install psmisc -y
        • 小鱼小 小鱼 将这个主题标记为已解决,在
