    运行gazebo_sim.launch.py文件打不开gazebo
    仿真错误 gazebo11
    1.7k
      lqh3256948861
      ubuntu版本22.04. 用的是<<ROS2机器人开发>>配套的源码
      终端信息
      lqh@lqh-virtual-machine:~/ros2bookcode-master/chapt6/chapt6_ws$ ros2 launch fishbot_description gazebo_sim.launch.py
      [INFO] [launch]: All log files can be found below /home/lqh/.ros/log/2024-12-27-16-50-13-067270-lqh-virtual-machine-23566
      [INFO] [robot_state_publisher-1]: process started with pid [23580]
      [INFO] [gzserver-2]: process started with pid [23582]
      [INFO] [gzclient-3]: process started with pid [23584]
      [INFO] [spawn_entity.py-4]: process started with pid [23586]
      [robot_state_publisher-1] [INFO] [1735289416.609378691] [robot_state_publisher]: got segment back_caster_link
      [robot_state_publisher-1] [INFO] [1735289416.609762074] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-1] [INFO] [1735289416.609789459] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1735289416.609807065] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-1] [INFO] [1735289416.609821652] [robot_state_publisher]: got segment camera_optical_link
      [robot_state_publisher-1] [INFO] [1735289416.609836778] [robot_state_publisher]: got segment front_caster_link
      [robot_state_publisher-1] [INFO] [1735289416.609851925] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-1] [INFO] [1735289416.610069414] [robot_state_publisher]: got segment laser_cylinder_link
      [robot_state_publisher-1] [INFO] [1735289416.610103868] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-1] [INFO] [1735289416.610119831] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-1] [INFO] [1735289416.610135977] [robot_state_publisher]: got segment right_wheel_link
      [gzclient-3]
      [gzserver-2]
      [spawn_entity.py-4] [INFO] [1735289418.868044069] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-4] [INFO] [1735289418.880349399] [spawn_entity]: Loading entity published on topic /robot_description
      [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-4]   warnings.warn(
      [spawn_entity.py-4] [INFO] [1735289418.931277538] [spawn_entity]: Waiting for entity xml on /robot_description
      [spawn_entity.py-4] [INFO] [1735289418.951562022] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-4] [INFO] [1735289418.965709454] [spawn_entity]: Waiting for service /spawn_entity
      [gzserver-2] [Msg] Waiting for master.
      [gzserver-2] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
      [gzserver-2] [Msg] Publicized address: 192.168.204.128
      [gzserver-2] [Err] [RTShaderSystem.cc:480] Unable to find shader lib. Shader generating will fail. Your GAZEBO_RESOURCE_PATH is probably improperly set. Have you sourced <prefix>/share/gazebo/setup.bash?
      [gzclient-3] [Msg] Publicized address: 192.168.204.128
      [gzclient-3] [Err] [RTShaderSystem.cc:480] Unable to find shader lib. Shader generating will fail. Your GAZEBO_RESOURCE_PATH is probably improperly set. Have you sourced <prefix>/share/gazebo/setup.bash?
      [gzclient-3] [Wrn] [GuiIface.cc:120] Could not find the Qt platform plugin "wayland" in ""
      [spawn_entity.py-4] [INFO] [1735289423.308325407] [spawn_entity]: Calling service /spawn_entity
      [gzclient-3] [Err] [RenderEngine.cc:197] Failed to initialize scene
      [gzclient-3] [Err] [GLWidget.cc:177] GLWidget could not create a scene. This will likely result in a blank screen.
      [gzserver-2] [Msg] Loading world file [/home/lqh/ros2bookcode-master/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/world/custom_room.world]
      [gzserver-2] [Err] [RenderEngine.cc:197] Failed to initialize scene
      [gzserver-2] gzserver: /usr/include/boost/smart_ptr/shared_ptr.hpp:728: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::rendering::Scene; typename boost::detail::sp_member_access<T>::type = gazebo::rendering::Scene*]: Assertion `px != 0' failed.
      [gzclient-3] gzclient: /usr/include/boost/smart_ptr/shared_ptr.hpp:728: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::rendering::Camera; typename boost::detail::sp_member_access<T>::type = gazebo::rendering::Camera*]: 断言 "px != 0" 失败。
      [ERROR] [gzserver-2]: process has died [pid 23582, exit code -6, cmd 'gzserver /home/lqh/ros2bookcode-master/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/world/custom_room.world --verbose -slibgazebo_ros_init.so -slibgazebo_ros_factory.so -slibgazebo_ros_force_system.so'].
      [gzserver-2]
      [ERROR] [gzclient-3]: process has died [pid 23584, exit code -6, cmd 'gzclient --verbose'].
      [gzclient-3]
        从您提供的终端信息来看,您遇到的问题主要涉及以下几个方面:
        1. Shader 库找不到:
          这个错误提示表明 Gazebo 无法找到其所需的 shader 库,这通常是因为 GAZEBO_RESOURCE_PATH 环境变量没有正确设置。您需要确保已经正确运行了 Gazebo 的环境设置脚本。
        2. Qt 平台插件找不到:
          这个警告表明 Gazebo 无法找到 Qt 的 Wayland 平台插件。如果您使用的是非 Wayland 环境(例如标准的 X11),这可能不是主要问题,但如果是 Wayland 环境,您可能需要确保 Qt 的插件路径正确。
        3. 场景初始化失败:
          这通常与图形驱动或 OpenGL 相关的问题有关。确保您的系统具有支持 OpenGL 的图形驱动,并且这些驱动是最新的。
        4. Gazebo 服务器和客户端崩溃:
          [gzserver-2] gzserver: /usr/include/boost/smart_ptr/shared_ptr.hpp:728: Assertion `px != 0' failed.
          [gzclient-3] gzclient: /usr/include/boost/smart_ptr/shared_ptr.hpp:728: 断言 "px != 0" 失败。
          这些错误表明 Gazebo 的内部组件(可能是场景或相机对象)在尝试访问一个未初始化的对象时发生了断言失败。
        解决步骤:
        1. 确保 Gazebo 环境变量设置正确:
          打开一个新的终端,运行以下命令来设置 Gazebo 的环境变量:
          source /opt/ros/humble/local/setup.bash
          source /path/to/gazebo/setup.bash  # 替换为实际的 Gazebo 安装路径
        2. 检查图形驱动:
          确保您的系统安装了正确的图形驱动,并且支持 OpenGL。如果您使用的是虚拟机,可能需要确保虚拟机配置允许使用硬件加速。
        3. 重新运行 Gazebo:
          在设置了正确的环境变量后,尝试再次运行您的 launch 文件:
        4. 检查依赖和插件:
          如果您使用的是 Wayland,确保 Qt 的 Wayland 插件可用。如果是 X11,确保没有其他与图形相关的冲突。
        5. 查看日志文件:
          如果问题仍然存在,查看 Gazebo 的日志文件,这可能会提供更多关于问题的详细信息。日志文件通常位于 ~/.ros/log/ 目录下。
        通过上述步骤,您应该能够诊断并解决启动 Gazebo 时遇到的问题。如果问题仍然存在,可能需要更详细地检查您的系统配置或寻求社区的帮助。
          小鱼 技术大佬 @lqh3256948861
          @lqh3256948861 在 运行gazebo_sim.launch.py文件打不开gazebo 中说:
          [gzserver-2]
          [gzclient-3]
          换一个空的环境试试,另外就是你有按照前面的步骤安装依赖吗
          L 1 条回复 最后回复 回复 引用 0
            lqh3256948861 @小鱼
            @小鱼 之前是更着foxy版本的文档学的,然后更新了Ubuntu换成humble版本学了,所以我直接从仿真导航开始了
