    如何使用Moveit2做距离检测
    ros2 moveit2 碰撞检测 humble
    4.9k
    • J
      Jason_Duan
      如题,需要做距离检测,比如,想要知道某状态下距离发生碰撞还有多少距离。我看CollisionResult中是有distance和DistanceResult信息的,CollisionRequest中也将distance属性设为了true,但是CollisionResult中还是拿不到距离数据,结果总是1.79769e+308,即std::numeric_limits<double>::max()的值。
      也试了其他的方法,都不行。
      Ros2版本为humble。
      以下是我的代码(请忽略引用过多的头文件):
      #include <iostream>
      #include <ostream>
      #include <memory>
      #include <vector>
      #include <rclcpp/rclcpp.hpp>
      #include <moveit/robot_model_loader/robot_model_loader.h>
      #include <moveit/planning_scene/planning_scene.h>
      #include <moveit/kinematic_constraints/utils.h>
      #include <moveit/moveit_cpp/moveit_cpp.h>
      #include <moveit/robot_model/robot_model.h>
      #include <moveit/robot_state/robot_state.h>
      #include <moveit_msgs/msg/planning_scene.hpp>
      #include <moveit/collision_detection_fcl/collision_common.h>
      #include <moveit/collision_detection_fcl/collision_env_fcl.h>
      #include <moveit/collision_detection/collision_detector_allocator.h>
      #include <moveit/collision_detection_fcl/collision_detector_allocator_fcl.h>
      #include <moveit/collision_detection_fcl/collision_detector_fcl_plugin_loader.h>
      #include <moveit/collision_detection_fcl/fcl_compat.h>
      #include <moveit/rdf_loader/rdf_loader.h>
      // #include <shape_msgs/msg/solid_primitive.hpp>
      #define PI 3.1415926
      using namespace std;
      static const rclcpp::Logger LOGGER = rclcpp::get_logger("collision_node");
        // ROS2 init
        rclcpp::init(argc, argv);
        rclcpp::NodeOptions node_options;
        node_options.automatically_declare_parameters_from_overrides(true);
        auto collision_node = rclcpp::Node::make_shared("collision_node", node_options);
        rclcpp::executors::SingleThreadedExecutor executor;
        executor.add_node(collision_node);
        std::thread([&executor]()
                    { executor.spin(); })
            .detach();
        robot_model_loader::RobotModelLoader robot_model_loader(collision_node, "robot_description");
        const moveit::core::RobotModelPtr &robot_model = robot_model_loader.getModel();
        planning_scene::PlanningScene planning_scene(robot_model);
        moveit::core::RobotState &current_state = planning_scene.getCurrentStateNonConst();
        // ----- check SRDF ----- //
        srdf::ModelConstSharedPtr model_srdf = robot_model->getSRDF();
        RCLCPP_INFO_STREAM(LOGGER, "SRDF model load " << (model_srdf ? "SUCCESSED." : "FAILED!"));
        // ----- check ACM ----- //
        collision_detection::AllowedCollisionMatrix &acm = planning_scene.getAllowedCollisionMatrixNonConst();
        RCLCPP_INFO_STREAM(LOGGER, "acm.Size = " << acm.getSize());
        std::vector<std::string> allEntrynames;
        acm.getAllEntryNames(allEntrynames);
        for (auto name : allEntrynames)
          RCLCPP_INFO_STREAM(LOGGER, "Entryname : " << name);
        // acm.print(std::cout);
        // ----- check disabled and enabled collision pairs ----- //
        std::vector<srdf::Model::CollisionPair> disabled_collision_pairs = model_srdf->getDisabledCollisionPairs();
        std::vector<srdf::Model::CollisionPair> enabled_collision_pairs = model_srdf->getEnabledCollisionPairs();
        RCLCPP_INFO_STREAM(LOGGER, "enabled collision pair size: " << enabled_collision_pairs.size());
        // for (auto it : enabled_collision_pairs) RCLCPP_INFO_STREAM(LOGGER, "enabled collision pair: (" << it.link1_ << "  -  " << it.link2_ << ")");
        RCLCPP_INFO_STREAM(LOGGER, "disabled collision pair size: (" << disabled_collision_pairs.size());
        for (auto it : disabled_collision_pairs)
          RCLCPP_INFO_STREAM(LOGGER, "disabled collision pair: (" << it.link1_ << "  -  " << it.link2_ << ") | reason: " << it.reason_);
        // ----- use CollisionEnvFCL -> distanceRobot() ----- //
          RCLCPP_INFO_STREAM(LOGGER, "----- use CollisionEnvFCL -> distanceRobot() -----");
          RCLCPP_INFO_STREAM(LOGGER, "std::numeric_limits<double>::max = " << std::numeric_limits<double>::max());
          current_state.setToDefaultValues();
          collision_detection::CollisionEnvFCL collision_env(robot_model, 0.0, 1.0);
          collision_detection::DistanceRequest distance_request;
          distance_request.enable_nearest_points = true;
          distance_request.enable_signed_distance = true;
          distance_request.type = collision_detection::DistanceRequestType::GLOBAL;
          distance_request.distance_threshold = 10;
          collision_detection::DistanceResult distance_result;
          collision_detection::DistanceResultsData distance_res_data = distance_result.minimum_distance;
          auto min_dis_link_names = distance_res_data.link_names;
          double distance_res_data_min_distance = distance_res_data.distance;
          collision_detection::DistanceMap distance_map = distance_result.distances;
          distance_result.clear();
          RCLCPP_INFO(LOGGER, "  Default Positions >>>");
          collision_env.distanceRobot(distance_request, distance_result, current_state);
          RCLCPP_INFO_STREAM(LOGGER, "\tMinimum distance between: " << min_dis_link_names[0] << " and " << min_dis_link_names[1]);
          RCLCPP_INFO_STREAM(LOGGER, "\tMinimum distance is : " << distance_result.minimum_distance.distance);
          RCLCPP_INFO_STREAM(LOGGER, "\tdistance_result.minimum_distance.distance : " << distance_res_data_min_distance);
          RCLCPP_INFO_STREAM(LOGGER, "\tdistance_map is " << (distance_map.empty() ? "" : "not") << " empty");
          current_state.setToRandomPositions();
          RCLCPP_INFO_STREAM(LOGGER, "  Random Positions >>>");
          RCLCPP_INFO_STREAM(LOGGER, "===== END : use CollisionEnvFCL -> distanceRobot() =====" << std::endl);
        // ----- use PlanningScene -> checkSelfCollision() ----- //
          RCLCPP_INFO_STREAM(LOGGER, "----- use PlanningScene -> checkSelfCollision() -----");
          collision_detection::CollisionRequest collision_request;
          collision_request.distance = true;
          collision_detection::CollisionResult collision_result;
          double distance = collision_result.distance;
          collision_detection::DistanceResult distance_result = collision_result.distance_result;
          collision_result.clear();
          planning_scene.checkSelfCollision(collision_request, collision_result);
          RCLCPP_INFO_STREAM(LOGGER, "\tCurrent state is " << (collision_result.collision ? "in" : "not in") << " self collision");
          RCLCPP_INFO_STREAM(LOGGER, "\tdistance : " << distance);
          bool loopFlag = true;
          while (loopFlag)
            if (collision_result.collision)
              loopFlag = false;
          RCLCPP_INFO_STREAM(LOGGER, "===== END : use PlanningScene -> checkSelfCollision() =====" << std::endl);
        // ----- use PlanningScene -> distanceToCollision() ----- //
          double distance_default_pos = planning_scene.distanceToCollision(current_state);
          RCLCPP_INFO_STREAM(LOGGER, "    distance : " << distance_default_pos);
          RCLCPP_INFO(LOGGER, "  Random Positions >>>");
          double distance_random_pos = planning_scene.distanceToCollision(current_state);
          RCLCPP_INFO_STREAM(LOGGER, "    distance : " << distance_random_pos);
        // ----- use PlanningScene -> checkCollision() ----- //
          RCLCPP_INFO_STREAM(LOGGER, "----- use PlanningScene -> checkCollision() -----");
          planning_scene.checkCollision(collision_request, collision_result);
          while (loopFlag)
              loopFlag = false;
          RCLCPP_INFO_STREAM(LOGGER, "===== END : use PlanningScene -> checkCollision() =====" << std::endl);
        rclcpp::shutdown();
        return 0;
      J 2 条回复 最后回复 回复 引用 0
      • J
        Jason_Duan @Jason_Duan
        • J
          Jason_Duan
          @Jason_Duan 在 如何使用Moveit2做距离检测 中说:
          补充说明:在PlanningScene -> checkCollision()这个方式中,将collision_request.distance设为true,也不行
          • J
            Jason_Duan
            自顶一下,不要沉啊
            • J
              Jason_Duan
              更新:新增使用CollisionEnvFCL::distanceSelf,设置方式和上述代码中使用CollisionEnvFCL::distanceRobot的一致,结果一样
              • J
                搞定了,有需要的自己看吧
                #include <iostream>
                #include <ostream>
                #include <memory>
                #include <vector>
                #include <moveit/planning_scene_interface/planning_scene_interface.h>
                #include <moveit/move_group_interface/move_group_interface.h>
                #include <moveit_visual_tools/moveit_visual_tools.h>
                  // ROS2 init
                      .detach();
                  // srdf::ModelConstSharedPtr model_srdf = robot_model->getSRDF();
                  // RCLCPP_INFO_STREAM(LOGGER, "SRDF model load " << (model_srdf ? "SUCCESS." : "FAILED!")); // success
                  // acm.setEntry("panda_link5", "panda_hand", true); // in collision,-0.045408
                  // acm.setEntry("panda_link5", "panda_link7", true); // in collision,-0.0131087
                  // acm.setEntry("panda_link5", "panda_rightfinger", true); // not in collision,0.00929973
                  // acm.setEntry("panda_link5", "panda_leftfinger", true); // 0.0284744
                  // acm.setEntry("panda_link5", "panda_link2", true); // 0.241446
                  // RCLCPP_INFO_STREAM(LOGGER, "acm.Size = " << acm.getSize());
                  // std::vector<std::string> allEntrynames;
                  // acm.getAllEntryNames(allEntrynames);
                  // for (auto name : allEntrynames) RCLCPP_INFO_STREAM(LOGGER, "Entryname : " << name);
                  // std::vector<srdf::Model::CollisionPair> disabled_collision_pairs = model_srdf->getDisabledCollisionPairs();
                  // std::vector<srdf::Model::CollisionPair> enabled_collision_pairs = model_srdf->getEnabledCollisionPairs();
                  // RCLCPP_INFO_STREAM(LOGGER, "enabled collision pair size: " << enabled_collision_pairs.size()); // empty
                  // RCLCPP_INFO_STREAM(LOGGER, "disabled collision pair size: (" << disabled_collision_pairs.size());
                  // for (auto it : disabled_collision_pairs)
                  //   RCLCPP_INFO_STREAM(LOGGER, "disabled collision pair: (" << it.link1_ << "  -  " << it.link2_ << ") | reason: " << it.reason_);
                  // ----- 01:use CollisionEnvFCL -> distanceRobot() ----- //
                    RCLCPP_INFO_STREAM(LOGGER, "----- 01:use CollisionEnvFCL -> distanceRobot() -----");
                    // RCLCPP_INFO_STREAM(LOGGER, "std::numeric_limits<double>::max = " << std::numeric_limits<double>::max());
                    // distance_request.enableGroup();
                    if (nullptr == distance_request.active_components_only)
                      RCLCPP_INFO(LOGGER, "active_components_only is not NULL");
                    else
                      RCLCPP_INFO_STREAM(LOGGER, "active_components_only is " << distance_request.active_components_only);
                    collision_detection::DistanceResultsData min_distance = distance_result.minimum_distance;
                    auto min_dis_link_names = min_distance.link_names;
                    double min_distance_min_distance = min_distance.distance;
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_result.minimum_distance.distance : " << min_distance_min_distance);
                    RCLCPP_INFO_STREAM(LOGGER, "\tMinimum distance between: " << min_dis_link_names[0] << " and " << min_dis_link_names[1]); // both are empty
                    RCLCPP_INFO_STREAM(LOGGER, "\tMinimum distance is : " << distance_result.minimum_distance.distance);                     // 1.79769e+308
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_result.minimum_distance.distance : " << min_distance_min_distance);          // 1.79769e+308
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_map is " << (distance_map.empty() ? "" : "not") << "empty");                      // empty
                    RCLCPP_INFO_STREAM(LOGGER, "===== END : 02:use CollisionEnvFCL -> distanceRobot() =====" << std::endl);
                  // ----- 02:use CollisionEnv -> distanceSelf() ----- //
                    RCLCPP_INFO_STREAM(LOGGER, "----- 02:use CollisionEnvFCL -> distanceSelf() -----");
                    else
                    collision_env.distanceSelf(distance_request, distance_result, current_state);
                    RCLCPP_INFO_STREAM(LOGGER, "===== END : 02:use CollisionEnvFCL -> distanceSelf() =====" << std::endl);
                  // ----- 03:use PlanningScene -> checkSelfCollision() ----- //
                    collision_request.verbose = true;
                    double minimum_distance_distance;
                    collision_detection::DistanceResult distance_result = collision_result.distance_result; // Result of a distance request
                    collision_detection::DistanceResultsData minimum_distance = distance_result.minimum_distance; // ResultsData for the two objects with the minimum distance
                    minimum_distance_distance = minimum_distance.distance; // distance for the two objects with the minimum distance
                    std::string* link_names = minimum_distance.link_names; // link names for the two objects with the minimum distance
                    collision_detection::DistanceMap distances_map = distance_result.distances; // A map of distance data for each link in the req.Notice : active_components_only !!!
                    RCLCPP_INFO_STREAM(LOGGER, "\tCurrent state is " << (collision_result.collision ? "in" : "not in") << " self collision"); // in self collision
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance : " << collision_result.distance);
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_result.minimum_distance.distance : " << minimum_distance_distance);           // 1.79769e+308????
                    RCLCPP_INFO_STREAM(LOGGER, "\tBetween " << link_names[0] << " and " << link_names[1]); // empty!!!
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_map.size = " << distances_map.size()); // empty!!!
                    while (loopFlag)
                      if (collision_result.collision) loopFlag = false;
                  // ----- 04:use PlanningScene -> distanceToCollision() ----- //
                    RCLCPP_INFO_STREAM(LOGGER, "    distance : " << distance_default_pos); // 1.79769e+308
                    RCLCPP_INFO_STREAM(LOGGER, "    distance : " << distance_random_pos); // 1.79769e+308
                  // ----- 05:use PlanningScene -> checkCollision() ----- //
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance : " << distance);                                                        // 1.79769e+308
                    RCLCPP_INFO_STREAM(LOGGER, "\tdistance_map is " << (distance_map.empty() ? "" : "not") << " empty");            // empty
                    while (loopFlag)
                      // if (collision_result.collision)
                        loopFlag = false;
                  // ----- 06:use collision_env = planning_scene.getCollisionEnv() ----- //
                    RCLCPP_INFO_STREAM(LOGGER, "----- use collision_env = planning_scene.getCollisionEnv() -----");
                    // collision_detection::CollisionEnvFCL collision_env(robot_model, 0.0, 1.0);
                    auto collision_env = planning_scene.getCollisionEnv();
                    // distance_request.type = collision_detection::DistanceRequestType::GLOBAL;
                    distance_request.type = collision_detection::DistanceRequestType::ALL;
                    distance_request.acm = &acm;
                    // if (nullptr == distance_request.active_components_only)
                    //   RCLCPP_INFO(LOGGER, "active_components_only is not NULL");
                    // else
                    //   RCLCPP_INFO_STREAM(LOGGER, "active_components_only is " << distance_request.active_components_only); // 0?
                    collision_detection::DistanceResultsData minimum_distance;
                    // double min_distance_min_distance = min_distance.distance;
                    collision_detection::DistanceMap distances_map;
                    std::vector<double> joint_values;
                    // current_state.setToRandomPositions();
                    current_state.copyJointGroupPositions("panda_arm", joint_values);
                    for (auto joint_value : joint_values)
                      RCLCPP_INFO_STREAM(LOGGER, "    joint_value: " << joint_value);
                    // collision_env->distanceRobot(distance_request, distance_result, current_state);
                    collision_env->distanceSelf(distance_request, distance_result, current_state);
                    // collision_env->distanceSelf(current_state, acm);
                    // RCLCPP_INFO_STREAM(LOGGER, "  distance with ACM is : " << distance);
                    RCLCPP_INFO_STREAM(LOGGER, "  Current state is " << (distance_result.collision ? "in" : "not in") << " self collision"); // in self collision
                    // RCLCPP_INFO_STREAM(LOGGER, "  Minimum distance is : " << collision_env->distanceSelf(current_state, acm, true));
                    RCLCPP_INFO_STREAM(LOGGER, "  Minimum distance is : " << minimum_distance.distance);
                    // auto min_dis_link_names = minimum_distance.link_names;
                    std::string *min_dis_link_names = minimum_distance.link_names;
                    RCLCPP_INFO_STREAM(LOGGER, "  Minimum distance between: " << min_dis_link_names[0] << " and " << min_dis_link_names[1]);
                    RCLCPP_INFO_STREAM(LOGGER, "  distance_map.size = " << distances_map.size());
                    if(0 != distances_map.size())
                      for(auto distance_pair : distances_map)
                        RCLCPP_INFO_STREAM(LOGGER, "  distance between " << distance_pair.first.first << " and " << distance_pair.first.second << " : " << distance_pair.second.at(0).distance);
                    // int loop_times = 3;
                    // while (loop_times--)
                    //   distance_result.clear();
                    //   RCLCPP_INFO_STREAM(LOGGER, "  distance after clear: " << distance_result.minimum_distance.distance); //
                    //   RCLCPP_INFO_STREAM(LOGGER, "  Random Positions >>>");
                    //   current_state.copyJointGroupPositions("panda_arm", joint_values);
                    //   for (auto joint_value : joint_values)
                    //     RCLCPP_INFO_STREAM(LOGGER, "    joint_value: " << joint_value);
                    //   // collision_env->distanceRobot(distance_request, distance_result, current_state);
                    //   collision_env->distanceSelf(distance_request, distance_result, current_state);
                    //   // auto = distance_result.minimum_distance.link_names;
                    //   // RCLCPP_INFO_STREAM(LOGGER, "\tMinimum distance between: " << min_dis_link_names[0] << " and " << min_dis_link_names[1]); // both are empty
                    //   RCLCPP_INFO_STREAM(LOGGER, "\t  Minimum distance is : " << distance_result.minimum_distance.distance); //
                    //   RCLCPP_INFO_STREAM(LOGGER, "\tdistance_map is " << (distance_map.empty() ? "" : "not") << "empty");                      // empty
                    RCLCPP_INFO_STREAM(LOGGER, "===== END : use collision_env = planning_scene.getCollisionEnv() =====" << std::endl);
                  rclcpp::shutdown();
                  return 0;
                17879744031 1 条回复 最后回复 回复 引用 0
                • 17879744031
                  渐入佳境 @Jason_Duan
                  @Jason_Duan 太强了
