    启动rviz2时报错无法启动
    rviz2 autoware arm
    1.8k
    • MoveOnM
      MoveOn
      系统为Ubuntu20.04,架构为arm64架构,英伟达jetson agx Xavier开发套件,ROS版本为ROS2-foxy
      不使用autoware.auto时可以启动rviz2
      在使用autoware.auto启动rviz2时报错为
      rviz2 -d /opt/AutowareAuto/share/autoware_auto_examples/rviz2/autoware_perception_stack.rviz
      QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-s305'
      libGL error: No matching fbConfigs or visuals found
      libGL error: failed to load driver: swrast
      [ERROR] [1657360674.363586724] [rviz2]: Failed to create an OpenGL context. BadValue (integer parameter out of range for operation)
      [ERROR] [1657360674.363849687] [rviz2]: RenderingAPIException: Unable to create a suitable GLXContext in GLXContext::GLXContext at /tmp/binarydeb/ros-foxy-rviz-ogre-vendor-8.2.1/obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GLSupport/src/GLX/OgreGLXContext.cpp (line 60)
      [ERROR] [1657360674.364741910] [rviz2]: rviz::RenderSystem: error creating render window: RenderingAPIException: Unable to create a suitable GLXContext in GLXContext::GLXContext at /tmp/binarydeb/ros-foxy-rviz-ogre-vendor-8.2.1/obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GLSupport/src/GLX/OgreGLXContext.cpp (line 60)
        小鱼 技术大佬 @MoveOn
        @MoveOn 在 启动rviz2时报错无法启动 中说:
        看着里基本是显卡和libGL问题了
        25119376242 1 条回复 最后回复 回复 引用 0
        • 25119376242
          remember🍑you @小鱼
          @小鱼 请问怎么解决的呢
