    一键安装Foxy版本出现Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?问题,请问如何解决
    foxy ros 一键安装报错
    4.6k
    • HolaccH
      Holacc
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success st --upgradable' to see them.
      [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[/]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[|]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[-]cl-curry-compose-reader-macros - Reader macros for function partial applicati[-]flickcurl-doc - utilities to call the Flickr API from command line - document[]forensics-extra - Forensics Environment - extra console components (metapacka[|]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[/]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[]golang-github-ssgelm-cookiejarparser-dev - Go library that parses a curl cook[]kubuntu-wallpapers-focal - Selection of classic KDE wallpapers for Focal Foss[|]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[-]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[/]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[-]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[/]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[-]libresource-retriever-dev - Robot OS resource_retriever library - development[]librust-curl+force-system-lib-on-osx-dev - Rust bindings to libcurl for makin[|]librust-curl+http2-dev - Rust bindings to libcurl for making HTTP requests - [-]librust-curl+openssl-probe-dev - Rust bindings to libcurl for making HTTP req[/]librust-curl+openssl-sys-dev - Rust bindings to libcurl for making HTTP reque[]librust-curl+ssl-dev - Rust bindings to libcurl for making HTTP requests - fe[|]librust-curl+static-curl-dev - Rust bindings to libcurl for making HTTP reque[-]librust-curl+static-ssl-dev - Rust bindings to libcurl for making HTTP reques[/]librust-curl-dev - Rust bindings to libcurl for making HTTP requests - Rust s[]librust-curl-sys+http2-dev - Native bindings to the libcurl library - feature[|]librust-curl-sys+openssl-sys-dev - Native bindings to the libcurl library - f[-]librust-curl-sys-dev - Native bindings to the libcurl library - Rust source c[/]librust-git2+curl-dev - Bindings to libgit2 for interoperating with git repos[]librust-git2-curl-dev - Backend for an HTTP transport in libgit2 powered by l[|]librust-libgit2-sys+curl-dev - Native bindings to the libgit2 library - featu[-]librust-libgit2-sys+curl-sys-dev - Native bindings to the libgit2 library - f[|]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[]libwsman-curl-client-transport1 - Open Web Services Manager run-time librarie[|]php-symfony-http-client - methods to fetch HTTP resources synchronously or as[/]ros-noetic-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into []ros-foxy-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMake m[|]ros-foxy-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into me[-]ros-galactic-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMa[/]ros-galactic-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data int[]ros-rolling-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMak[|]ros-rolling-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into[-]Result:success
      [-]Result:success e and 213 not upgraded.
      [-]Result:success
      [-]Result:success
      [-]Result:success
      []Get:5 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease [4,679 [/]Get:8 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [833 B[]Get:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal/main amd64 Packag[|]Err:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu
      File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP[|]Get:10
      http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main amd64 Packag[-]Result:code:100
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 101.6.15.130 80]\n', ' Hashes of expected file:\n', ' - Filesize:1092928 [weak]\n', ' - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e\n', ' - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]\n', ' - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]\n', ' Release file created at: Fri, 01 Jul 2022 19:53:27 +0000\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
      [-]Result:success
      [/]Get:8 https://repo.huaweicloud.com/ros2/ubuntu focal/main amd64 Packages [1,0[|] File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP[|]Get:10 https://repo.huaweicloud.com/ros/ubuntu focal/main amd64 Packages [698[-]Result:code:100
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 59.39.0.151 443]\n', ' Hashes of expected file:\n', ' - Filesize:1092928 [weak]\n', ' - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e\n', ' - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]\n', ' - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]\n', ' Release file created at: Fri, 01 Jul 2022 19:53:27 +0000\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
      [-]Result:success
      [/]ros-noetic-end-effector - End-Effector package: provides a ROS-based set of s[]ros-noetic-mqtt-client - Provides a nodelet that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using the MQTT pro[|]ros-noetic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and plugin[-]ros-foxy-ros-base - A package which extends 'ros_core' and includes other bas[/]ros-galactic-ros-base - A package which extends 'ros_core' and includes other[]ros-rolling-ros-base - A package which extends 'ros_core' and includes other [-]Result:success
      RUN Choose Task:[请输入括号内的数字]
      [1]:noetic(ROS1)
      [2]:foxy(ROS2)
      [3]:galactic(ROS2)
      [4]:rolling(ROS2)
      [0]:quit
      请输入[]内的数字以选择:2
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:foxy(ROS2)桌面版
      [2]:foxy(ROS2)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      []apt-cacher - Caching proxy server for Debian/Ubuntu/Devuan software repositor[-]apticron-systemd - Simple tool to mail about pending package updates - system[]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[-]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[/]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[|]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[|]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[/]libcwidget-dev - high-level terminal interface library for C++ (development f[-]Result:success end for Debian
      • HolaccH
        Holacc
        Run CMD Task:[sudo apt install ros-foxy-desktop -y]
        Reading package lists... Done
        Building dependency tree
        The following additional packages will be installed:
        autoconf automake autotools-dev blt build-essential cpp-8 cppcheck cython3
        dbus dbus-x11 default-libmysqlclient-dev dpkg-dev fakeroot fonts-lyx
        freeglut3 g++ g++-9 gcc-7-base gcc-8 gcc-8-base gdal-data gfortran
        gfortran-8 gfortran-9 google-mock googletest graphviz hdf5-helpers
        i965-va-driver ibverbs-providers icu-devtools intel-media-va-driver libaacs0
        libaec-dev libaec0 libalgorithm-diff-perl libalgorithm-diff-xs-perl
        libalgorithm-merge-perl libann0 libaom0 libarmadillo-dev libarmadillo9
        libarpack2 libarpack2-dev libasan4 libasound2-dev libassimp-dev libassimp5
        libavcodec-dev libavcodec58 libavformat-dev libavformat58 libavresample-dev
        libavresample4 libavutil-dev libavutil56 libbdplus0 libblas-dev libblas3
        libblkid-dev libbluray2 libboost-all-dev libboost-atomic-dev
        libboost-atomic1.71-dev libboost-atomic1.71.0 libboost-chrono-dev
        libboost-chrono1.71-dev libboost-chrono1.71.0 libboost-container-dev
        libboost-container1.71-dev libboost-container1.71.0 libboost-context-dev
        libboost-context1.71-dev libboost-context1.71.0 libboost-coroutine-dev
        libboost-coroutine1.71-dev libboost-coroutine1.71.0 libboost-date-time-dev
        libboost-date-time1.71-dev libboost-dev libboost-exception-dev
        libboost-exception1.71-dev libboost-fiber-dev libboost-fiber1.71-dev
        libboost-fiber1.71.0 libboost-filesystem-dev libboost-filesystem1.71-dev
        libboost-graph-dev libboost-graph-parallel-dev
        libboost-graph-parallel1.71-dev libboost-graph-parallel1.71.0
        libboost-graph1.71-dev libboost-graph1.71.0 libboost-iostreams-dev
        libboost-iostreams1.71-dev libboost-locale-dev libboost-locale1.71-dev
        libboost-log-dev libboost-log1.71-dev libboost-log1.71.0 libboost-math-dev
        libboost-math1.71-dev libboost-math1.71.0 libboost-mpi-dev
        libboost-mpi-python-dev libboost-mpi-python1.71-dev
        libboost-mpi-python1.71.0 libboost-mpi1.71-dev libboost-mpi1.71.0
        libboost-numpy-dev libboost-numpy1.71-dev libboost-numpy1.71.0
        libboost-program-options-dev libboost-program-options1.71-dev
        libboost-program-options1.71.0 libboost-python-dev libboost-python1.71-dev
        libboost-python1.71.0 libboost-random-dev libboost-random1.71-dev
        libboost-random1.71.0 libboost-regex-dev libboost-regex1.71-dev
        libboost-regex1.71.0 libboost-serialization-dev
        libboost-serialization1.71-dev libboost-serialization1.71.0
        libboost-stacktrace-dev libboost-stacktrace1.71-dev
        libboost-stacktrace1.71.0 libboost-system-dev libboost-system1.71-dev
        libboost-system1.71.0 libboost-test-dev libboost-test1.71-dev
        libboost-test1.71.0 libboost-thread-dev libboost-thread1.71-dev
        libboost-timer-dev libboost-timer1.71-dev libboost-timer1.71.0
        libboost-tools-dev libboost-type-erasure-dev libboost-type-erasure1.71-dev
        libboost-type-erasure1.71.0 libboost-wave-dev libboost-wave1.71-dev
        libboost-wave1.71.0 libboost1.71-dev libboost1.71-tools-dev libbullet-dev
        libbullet2.88 libcaf-openmpi-3 libcdt5 libcfitsio-dev libcfitsio-doc
        libcfitsio8 libcgraph6 libcharls-dev libcharls2 libchromaprint1 libcilkrts5
        libclang1-10 libcoarrays-dev libcoarrays-openmpi-dev libcodec2-0.9
        libconsole-bridge-dev libconsole-bridge0.4 libcurl3-gnutls
        libcurl4-openssl-dev libdap-dev libdap25 libdapclient6v5 libdapserver7v5
        libdbus-1-3 libdbus-1-dev libdc1394-22 libdc1394-22-dev
        libdouble-conversion3 libdpkg-perl libegl-dev libegl1 libegl1-mesa-dev
        libeigen3-dev libepsilon-dev libepsilon1 libevent-core-2.1-7 libevent-dev
        libevent-extra-2.1-7 libevent-openssl-2.1-7 libevent-pthreads-2.1-7
        libexif-dev libexif-doc libexpat1 libexpat1-dev libfabric1 libfakeroot
        libffi-dev libflann-dev libflann1.9 libfontconfig1-dev libfreetype-dev
        libfreetype6-dev libfreexl-dev libfreexl1 libfyba-dev libfyba0 libgcc-7-dev
        libgcc-8-dev libgdal-dev libgdal26 libgdcm-dev libgdcm3.0 libgeos-3.8.0
        libgeos-c1v5 libgeos-dev libgeotiff-dev libgeotiff5 libgfortran-8-dev
        libgfortran-9-dev libgfortran5 libgif-dev libgl-dev libgl1 libgl1-mesa-dev
        libgl2ps-dev libgl2ps1.4 libgles-dev libgles1 libgles2 libgles2-mesa-dev
        libglew-dev libglew2.1 libglib2.0-dev libglib2.0-dev-bin libglu1-mesa-dev
        libglvnd-dev libglvnd0 libglx-dev libglx0 libgme0 libgphoto2-dev libgsm1
        libgtest-dev libgts-0.7-5 libgts-bin libgvc6 libgvpr2 libhdf4-0-alt
        libhdf4-alt-dev libhdf5-103 libhdf5-cpp-103 libhdf5-dev libhdf5-mpi-dev
        libhdf5-openmpi-103 libhdf5-openmpi-dev libhwloc-dev libhwloc-plugins
        libhwloc15 libibus-1.0-dev libibverbs-dev libibverbs1 libice-dev libicu-dev
        libigdgmm11 libilmbase-dev libilmbase24 libjbig-dev libjpeg-dev
        libjpeg-turbo8-dev libjpeg8-dev libjs-jquery-ui libjson-c-dev libjsoncpp-dev
        libkml-dev libkmlbase1 libkmlconvenience1 libkmldom1 libkmlengine1
        libkmlregionator1 libkmlxsd1 liblab-gamut1 liblapack-dev liblapack3 liblept5
        libllvm10 libltdl-dev liblz4-dev liblzma-dev liblzma5 libminizip-dev
        libminizip1 libmount-dev libmpx2 libmysqlclient-dev libmysqlclient21
        libnetcdf-c++4 libnetcdf-cxx-legacy-dev libnetcdf-dev libnetcdf15
        libnl-3-dev libnl-route-3-dev libnuma-dev libodbc1 libogdi-dev libogdi4.1
        libogg-dev libopencv-calib3d-dev libopencv-calib3d4.2 libopencv-contrib-dev
        libopencv-contrib4.2 libopencv-core-dev libopencv-core4.2 libopencv-dev
        libopencv-dnn-dev libopencv-dnn4.2 libopencv-features2d-dev
        libopencv-features2d4.2 libopencv-flann-dev libopencv-flann4.2
        libopencv-highgui-dev libopencv-highgui4.2 libopencv-imgcodecs-dev
        libopencv-imgcodecs4.2 libopencv-imgproc-dev libopencv-imgproc4.2
        libopencv-ml-dev libopencv-ml4.2 libopencv-objdetect-dev
        libopencv-objdetect4.2 libopencv-photo-dev libopencv-photo4.2
        libopencv-shape-dev libopencv-shape4.2 libopencv-stitching-dev
        libopencv-stitching4.2 libopencv-superres-dev libopencv-superres4.2
        libopencv-ts-dev libopencv-video-dev libopencv-video4.2
        libopencv-videoio-dev libopencv-videoio4.2 libopencv-videostab-dev
        libopencv-videostab4.2 libopencv-viz-dev libopencv-viz4.2 libopencv4.2-java
        libopencv4.2-jni libopenexr-dev libopenexr24 libopengl-dev libopengl0
        libopenjp2-7-dev libopenmpi-dev libopenmpi3 libopenmpt0 libopenni-dev
        libopenni-sensor-pointclouds0 libopenni0 libopenni2-0 libopenni2-dev
        libpathplan4 libpcl-apps1.10 libpcl-common1.10 libpcl-dev
        libpcl-features1.10 libpcl-filters1.10 libpcl-io1.10 libpcl-kdtree1.10
        libpcl-keypoints1.10 libpcl-ml1.10 libpcl-octree1.10 libpcl-outofcore1.10
        libpcl-people1.10 libpcl-recognition1.10 libpcl-registration1.10
        libpcl-sample-consensus1.10 libpcl-search1.10 libpcl-segmentation1.10
        libpcl-stereo1.10 libpcl-surface1.10 libpcl-tracking1.10
        libpcl-visualization1.10 libpcre16-3 libpcre2-16-0 libpcre2-dev
        libpcre2-posix2 libpcre3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpmix2
        libpng-dev libpng-tools libpoppler-dev libpoppler-private-dev libpq-dev
        libpq5 libproj-dev libproj15 libpsm-infinipath1 libpsm2-2
        libpthread-stubs0-dev libpulse-dev libpyside2-dev libpyside2-py3-5.14
        libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib libpython3-dev
        libpython3.8 libpython3.8-dev libpython3.8-minimal libpython3.8-stdlib
        libqhull-dev libqhull-r7 libqhull7 libqt5concurrent5 libqt5core5a
        libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help5
        libqt5network5 libqt5opengl5 libqt5opengl5-dev libqt5positioning5
        libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5quickparticles5
        libqt5quickshapes5 libqt5quicktest5 libqt5quickwidgets5 libqt5sensors5
        libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5test5 libqt5webchannel5
        libqt5webkit5 libqt5webkit5-dev libqt5widgets5 libqt5x11extras5 libqt5xml5
        libraw1394-dev libraw1394-tools librdmacm1 libsdl2-2.0-0 libsdl2-dev
        libselinux1-dev libsepol1 libsepol1-dev libshiboken2-dev
        libshiboken2-py3-5.14 libshine3 libsigsegv2 libsm-dev libsnappy1v5
        libsndio-dev libsndio7.0 libsocket++1 libspatialite-dev libspatialite7
        libspdlog-dev libspdlog1 libsqlite3-0 libsqlite3-dev libssh-gcrypt-4
        libssl-dev libssl1.1 libstdc++-7-dev libstdc++-9-dev libsuperlu-dev
        libsuperlu5 libswresample-dev libswresample3 libswscale-dev libswscale5
        libsz2 libtbb-dev libtbb2 libtcl8.6 libtesseract4 libtheora-dev libtiff-dev
        libtiff5 libtiffxx5 libtinyxml-dev libtinyxml2-6a libtinyxml2-dev
        libtinyxml2.6.2v5 libtk8.6 libtool libubsan0 libudev-dev liburiparser-dev
        liburiparser1 libva-drm2 libva-x11-2 libva2 libvdpau1 libvtk6.3 libvtk7-dev
        libvtk7-java libvtk7-jni libvtk7-qt-dev libvtk7.1p libvtk7.1p-qt
        libvulkan-dev libwayland-bin libwayland-dev libwebp-dev libx11-dev
        libx264-155 libx265-179 libxau-dev libxaw7-dev libxcb-xinerama0
        libxcb-xinput0 libxcb1-dev libxcursor-dev libxdmcp-dev libxerces-c-dev
        libxerces-c3.2 libxext-dev libxfixes-dev libxft-dev libxi-dev
        libxinerama-dev libxkbcommon-dev libxml2 libxml2-dev libxml2-utils
        libxmu-dev libxmu-headers libxnvctrl0 libxpm-dev libxrandr-dev
        libxrender-dev libxss-dev libxt-dev libxv-dev libxvidcore4 libxxf86vm-dev
        libyaml-dev libzstd-dev libzvbi-common libzvbi0 m4 mesa-va-drivers
        mesa-vdpau-drivers mpi-default-bin mpi-default-dev net-tools
        ocl-icd-libopencl1 odbcinst odbcinst1debian2 opencv-data openmpi-bin
        openmpi-common openni-utils proj-bin proj-data pydocstyle pyflakes pyflakes3
        pyqt5-dev python-matplotlib-data python-pkg-resources python-pyflakes
        python2 python2-minimal python2.7 python2.7-minimal python3-autobahn
        python3-automat python3-bs4 python3-cbor python3-constantly python3-cycler
        python3-dev python3-flake8 python3-hamcrest python3-html5lib
        python3-hyperlink python3-ifcfg python3-incremental python3-kiwisolver
        python3-lark python3-lxml python3-lz4 python3-matplotlib python3-mccabe
        python3-mock python3-mpi4py python3-numpy python3-openssl python3-pbr
        python3-png python3-psutil python3-pyasn1 python3-pyasn1-modules
        python3-pycodestyle python3-pydocstyle python3-pydot python3-pyflakes
        python3-pyqrcode python3-pyqt5 python3-pyqt5.qtsvg python3-pyside2.qtcore
        python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets
        python3-service-identity python3-sip python3-sip-dev python3-snappy
        python3-snowballstemmer python3-soupsieve python3-tk python3-trie
        python3-twisted python3-twisted-bin python3-txaio python3-u-msgpack
        python3-ubjson python3-vtk7 python3-webencodings python3-wsaccel
        python3-zope.interface python3.8 python3.8-dev python3.8-minimal qdoc-qt5
        qhelpgenerator-qt5 qt5-assistant qt5-gtk-platformtheme qt5-qmake
        qt5-qmake-bin qt5-qmltooling-plugins qtattributionsscanner-qt5 qtbase5-dev
        qtbase5-dev-tools qtchooser qtdeclarative5-dev qtdeclarative5-dev-tools
        qttools5-dev qttools5-dev-tools qttools5-private-dev qttranslations5-l10n
        ros-foxy-action-msgs ros-foxy-action-tutorials-cpp
        ros-foxy-action-tutorials-interfaces ros-foxy-action-tutorials-py
        ros-foxy-actionlib-msgs ros-foxy-ament-cmake ros-foxy-ament-cmake-auto
        ros-foxy-ament-cmake-copyright ros-foxy-ament-cmake-core
        ros-foxy-ament-cmake-cppcheck ros-foxy-ament-cmake-cpplint
        ros-foxy-ament-cmake-export-definitions
        ros-foxy-ament-cmake-export-dependencies
        ros-foxy-ament-cmake-export-include-directories
        ros-foxy-ament-cmake-export-interfaces ros-foxy-ament-cmake-export-libraries
        ros-foxy-ament-cmake-export-link-flags ros-foxy-ament-cmake-export-targets
        ros-foxy-ament-cmake-flake8 ros-foxy-ament-cmake-gmock
        ros-foxy-ament-cmake-gtest ros-foxy-ament-cmake-include-directories
        ros-foxy-ament-cmake-libraries ros-foxy-ament-cmake-lint-cmake
        ros-foxy-ament-cmake-pep257 ros-foxy-ament-cmake-pytest
        ros-foxy-ament-cmake-python ros-foxy-ament-cmake-ros
        ros-foxy-ament-cmake-target-dependencies ros-foxy-ament-cmake-test
        ros-foxy-ament-cmake-uncrustify ros-foxy-ament-cmake-version
        ros-foxy-ament-cmake-xmllint ros-foxy-ament-copyright
        ros-foxy-ament-cppcheck ros-foxy-ament-cpplint ros-foxy-ament-flake8
        ros-foxy-ament-index-cpp ros-foxy-ament-index-python ros-foxy-ament-lint
        ros-foxy-ament-lint-auto ros-foxy-ament-lint-cmake
        ros-foxy-ament-lint-common ros-foxy-ament-package ros-foxy-ament-pep257
        ros-foxy-ament-uncrustify ros-foxy-ament-xmllint ros-foxy-angles
        ros-foxy-builtin-interfaces ros-foxy-class-loader ros-foxy-common-interfaces
        ros-foxy-composition ros-foxy-composition-interfaces
        ros-foxy-console-bridge-vendor ros-foxy-cv-bridge ros-foxy-demo-nodes-cpp
        ros-foxy-demo-nodes-cpp-native ros-foxy-demo-nodes-py
        ros-foxy-depthimage-to-laserscan ros-foxy-diagnostic-msgs
        ros-foxy-domain-coordinator ros-foxy-dummy-map-server
        ros-foxy-dummy-robot-bringup ros-foxy-dummy-sensors
        ros-foxy-eigen3-cmake-module ros-foxy-example-interfaces
        ros-foxy-examples-rclcpp-minimal-action-client
        ros-foxy-examples-rclcpp-minimal-action-server
        ros-foxy-examples-rclcpp-minimal-client
        ros-foxy-examples-rclcpp-minimal-composition
        ros-foxy-examples-rclcpp-minimal-publisher
        ros-foxy-examples-rclcpp-minimal-service
        ros-foxy-examples-rclcpp-minimal-subscriber
        ros-foxy-examples-rclcpp-minimal-timer
        ros-foxy-examples-rclcpp-multithreaded-executor
        ros-foxy-examples-rclpy-executors
        ros-foxy-examples-rclpy-minimal-action-client
        ros-foxy-examples-rclpy-minimal-action-server
        ros-foxy-examples-rclpy-minimal-client
        ros-foxy-examples-rclpy-minimal-publisher
        ros-foxy-examples-rclpy-minimal-service
        ros-foxy-examples-rclpy-minimal-subscriber ros-foxy-fastcdr
        ros-foxy-fastrtps ros-foxy-fastrtps-cmake-module
        ros-foxy-foonathan-memory-vendor ros-foxy-geometry-msgs ros-foxy-geometry2
        ros-foxy-gmock-vendor ros-foxy-gtest-vendor ros-foxy-image-geometry
        ros-foxy-image-tools ros-foxy-image-transport ros-foxy-interactive-markers
        ros-foxy-intra-process-demo ros-foxy-joy ros-foxy-kdl-parser
        ros-foxy-laser-geometry ros-foxy-launch ros-foxy-launch-ros
        ros-foxy-launch-testing ros-foxy-launch-testing-ament-cmake
        ros-foxy-launch-testing-ros ros-foxy-launch-xml ros-foxy-launch-yaml
        ros-foxy-libcurl-vendor ros-foxy-libstatistics-collector
        ros-foxy-libyaml-vendor ros-foxy-lifecycle ros-foxy-lifecycle-msgs
        ros-foxy-logging-demo ros-foxy-map-msgs ros-foxy-message-filters
        ros-foxy-nav-msgs ros-foxy-orocos-kdl ros-foxy-osrf-pycommon
        ros-foxy-pcl-conversions ros-foxy-pcl-msgs ros-foxy-pendulum-control
        ros-foxy-pendulum-msgs ros-foxy-pluginlib ros-foxy-python-cmake-module
        ros-foxy-python-qt-binding ros-foxy-qt-dotgraph ros-foxy-qt-gui
        ros-foxy-qt-gui-cpp ros-foxy-qt-gui-py-common
        ros-foxy-quality-of-service-demo-cpp ros-foxy-quality-of-service-demo-py
        ros-foxy-rcl ros-foxy-rcl-action ros-foxy-rcl-interfaces
        ros-foxy-rcl-lifecycle ros-foxy-rcl-logging-spdlog
        ros-foxy-rcl-yaml-param-parser ros-foxy-rclcpp ros-foxy-rclcpp-action
        ros-foxy-rclcpp-components ros-foxy-rclcpp-lifecycle ros-foxy-rclpy
        ros-foxy-rcpputils ros-foxy-rcutils ros-foxy-resource-retriever ros-foxy-rmw
        ros-foxy-rmw-dds-common ros-foxy-rmw-fastrtps-cpp
        ros-foxy-rmw-fastrtps-shared-cpp ros-foxy-rmw-implementation
        ros-foxy-rmw-implementation-cmake ros-foxy-robot-state-publisher
        ros-foxy-ros-base ros-foxy-ros-core ros-foxy-ros-environment
        ros-foxy-ros-workspace ros-foxy-ros2action ros-foxy-ros2bag ros-foxy-ros2cli
        ros-foxy-ros2component ros-foxy-ros2doctor ros-foxy-ros2interface
        ros-foxy-ros2launch ros-foxy-ros2lifecycle ros-foxy-ros2multicast
        ros-foxy-ros2node ros-foxy-ros2param ros-foxy-ros2pkg ros-foxy-ros2run
        ros-foxy-ros2service ros-foxy-ros2topic ros-foxy-rosbag2
        ros-foxy-rosbag2-compression ros-foxy-rosbag2-converter-default-plugins
        ros-foxy-rosbag2-cpp ros-foxy-rosbag2-storage
        ros-foxy-rosbag2-storage-default-plugins ros-foxy-rosbag2-transport
        ros-foxy-rosgraph-msgs ros-foxy-rosidl-adapter ros-foxy-rosidl-cmake
        ros-foxy-rosidl-default-generators ros-foxy-rosidl-default-runtime
        ros-foxy-rosidl-generator-c ros-foxy-rosidl-generator-cpp
        ros-foxy-rosidl-generator-py ros-foxy-rosidl-parser
        ros-foxy-rosidl-runtime-c ros-foxy-rosidl-runtime-cpp
        ros-foxy-rosidl-runtime-py ros-foxy-rosidl-typesupport-c
        ros-foxy-rosidl-typesupport-cpp ros-foxy-rosidl-typesupport-fastrtps-c
        ros-foxy-rosidl-typesupport-fastrtps-cpp
        ros-foxy-rosidl-typesupport-interface
        ros-foxy-rosidl-typesupport-introspection-c
        ros-foxy-rosidl-typesupport-introspection-cpp ros-foxy-rpyutils
        ros-foxy-rqt-action ros-foxy-rqt-common-plugins ros-foxy-rqt-console
        ros-foxy-rqt-graph ros-foxy-rqt-gui ros-foxy-rqt-gui-cpp ros-foxy-rqt-gui-py
        ros-foxy-rqt-image-view ros-foxy-rqt-msg ros-foxy-rqt-plot
        ros-foxy-rqt-publisher ros-foxy-rqt-py-common ros-foxy-rqt-py-console
        ros-foxy-rqt-reconfigure ros-foxy-rqt-service-caller ros-foxy-rqt-shell
        ros-foxy-rqt-srv ros-foxy-rqt-top ros-foxy-rqt-topic ros-foxy-rttest
        ros-foxy-rviz-assimp-vendor ros-foxy-rviz-common
        ros-foxy-rviz-default-plugins ros-foxy-rviz-ogre-vendor
        ros-foxy-rviz-rendering ros-foxy-rviz2 ros-foxy-sdl2-vendor
        ros-foxy-sensor-msgs ros-foxy-shape-msgs ros-foxy-shared-queues-vendor
        ros-foxy-spdlog-vendor ros-foxy-sqlite3-vendor ros-foxy-sros2
        ros-foxy-sros2-cmake ros-foxy-statistics-msgs ros-foxy-std-msgs
        ros-foxy-std-srvs ros-foxy-stereo-msgs ros-foxy-tango-icons-vendor
        ros-foxy-teleop-twist-joy ros-foxy-teleop-twist-keyboard ros-foxy-tf2
        ros-foxy-tf2-bullet ros-foxy-tf2-eigen ros-foxy-tf2-geometry-msgs
        ros-foxy-tf2-kdl ros-foxy-tf2-msgs ros-foxy-tf2-py ros-foxy-tf2-ros
        ros-foxy-tf2-sensor-msgs ros-foxy-tf2-tools ros-foxy-tinyxml-vendor
        • HolaccH
          Holacc
          ros-foxy-tinyxml2-vendor ros-foxy-tlsf ros-foxy-tlsf-cpp
          ros-foxy-topic-monitor ros-foxy-tracetools ros-foxy-trajectory-msgs
          ros-foxy-turtlesim ros-foxy-uncrustify-vendor
          ros-foxy-unique-identifier-msgs ros-foxy-urdf ros-foxy-urdfdom
          ros-foxy-urdfdom-headers ros-foxy-visualization-msgs
          ros-foxy-yaml-cpp-vendor ros-foxy-zstd-vendor shiboken2 sip-dev
          tango-icon-theme tcl tcl-dev tcl-vtk7 tcl8.6 tcl8.6-dev tk tk-dev tk8.6
          tk8.6-blt2.5 tk8.6-dev ttf-bitstream-vera uncrustify unixodbc-dev uuid-dev
          va-driver-all vdpau-driver-all vtk7 x11proto-core-dev x11proto-dev
          x11proto-input-dev x11proto-randr-dev x11proto-scrnsaver-dev
          x11proto-xext-dev x11proto-xf86vidmode-dev x11proto-xinerama-dev
          xorg-sgml-doctools xtrans-dev zlib1g zlib1g-dev
          Suggested packages:
          autoconf-archive gnu-standards autoconf-doc gettext blt-demo gcc-8-locales
          cppcheck-gui cython-doc debian-keyring g++-multilib g++-9-multilib gcc-9-doc
          gcc-8-multilib gcc-8-doc gfortran-multilib gfortran-doc gfortran-8-multilib
          gfortran-8-doc gfortran-9-multilib gfortran-9-doc gsfonts graphviz-doc
          i965-va-driver-shaders libitpp-dev libasound2-doc liblapack-doc
          libbluray-bdj libboost-doc libboost1.71-doc gccxml libboost-contract1.71-dev
          libmpfrc++-dev libntl-dev xsltproc doxygen docbook-xsl default-jdk fop
          libcurl4-doc libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
          git bzr libeigen3-doc freetype2-doc libgdal-doc libgeotiff-epsg geotiff-bin
          gdal-bin glew-utils libgirepository1.0-dev libglib2.0-doc libhdf4-doc
          hdf4-tools libhdf5-doc libhwloc-contrib-plugins libice-doc icu-doc
          libjs-jquery-ui-docs libtool-doc liblzma-doc netcdf-bin netcdf-doc libmyodbc
          odbc-postgresql tdsodbc unixodbc-bin ogdi-bin opencv-doc openmpi-doc
          openni-doc openni2-doc libpcl-doc postgresql-doc-12
          qt5-image-formats-plugins qtwayland5 libraw1394-doc libsm-doc sndiod
          sqlite3-doc libssl-doc libstdc++-7-doc libstdc++-9-doc libsuperlu-doc
          libtbb-doc libtinyxml-doc gcj-jdk vtk7-doc vtk7-examples
          java-virtual-machine libwayland-doc libx11-doc libxaw-doc libxcb-doc
          libxerces-c-doc libxext-doc libxt-doc libyaml-doc m4-doc opencl-icd
          python-setuptools python2-doc python-tk python2.7-doc binfmt-support
          python-cycler-doc python3-genshi python-lark-doc python3-lxml-dbg
          python-lxml-doc dvipng ffmpeg inkscape ipython3 python-matplotlib-doc
          python3-cairocffi python3-gobject python3-nose python3-scipy python3-tornado
          texlive-extra-utils texlive-latex-extra ttf-staypuft python-mock-doc
          python-numpy-doc python3-numpy-dbg python-openssl-doc python3-openssl-dbg
          python-psutil-doc python3-pyqt5-dbg python-pyside2-doc python-sip-doc
          python3-stemmer tix python3-tk-dbg python-trie-doc python3-pampy python3-qt4
          python3-serial python3-wxgtk2.8 python3-twisted-bin-dbg python-txaio-doc
          mayavi2 python3.8-venv python3.8-doc qt5-doc firebird-dev
          ros-foxy-rosidl-typesupport-connext-c
          ros-foxy-rosidl-typesupport-connext-cpp gnome-icon-theme kdelibs-data
          tcl-doc tcl-tclreadline tcl8.6-doc tk-doc tk8.6-doc libvdpau-va-gl1
          nvidia-vdpau-driver nvidia-legacy-340xx-vdpau-driver
          nvidia-legacy-304xx-vdpau-driver
          The following NEW packages will be installed:
          default-libmysqlclient-dev dpkg-dev fakeroot fonts-lyx freeglut3 g++ g++-9
          gcc-7-base gcc-8 gcc-8-base gdal-data gfortran gfortran-8 gfortran-9
          google-mock googletest graphviz hdf5-helpers i965-va-driver
          ibverbs-providers icu-devtools intel-media-va-driver libaacs0 libaec-dev
          libconsole-bridge-dev libconsole-bridge0.4 libcurl4-openssl-dev libdap-dev
          libdap25 libdapclient6v5 libdapserver7v5 libdbus-1-dev libdc1394-22
          libdc1394-22-dev libdouble-conversion3 libegl-dev libegl1-mesa-dev
          libexif-dev libexif-doc libexpat1-dev libfabric1 libfakeroot libffi-dev
          libflann-dev libflann1.9 libfontconfig1-dev libfreetype-dev libfreetype6-dev
          libfreexl-dev libfreexl1 libfyba-dev libfyba0 libgcc-7-dev libgcc-8-dev
          libgdal-dev libgdal26 libgdcm-dev libgdcm3.0 libgeos-3.8.0 libgeos-c1v5
          libgeos-dev libgeotiff-dev libgeotiff5 libgfortran-8-dev libgfortran-9-dev
          libgfortran5 libgif-dev libgl-dev libgl1-mesa-dev libgl2ps-dev libgl2ps1.4
          libgles-dev libgles1 libgles2-mesa-dev libglew-dev libglew2.1 libglib2.0-dev
          libglib2.0-dev-bin libglu1-mesa-dev libglvnd-dev libglx-dev libgme0
          libgphoto2-dev libgsm1 libgtest-dev libgts-0.7-5 libgts-bin libgvc6 libgvpr2
          libhdf4-0-alt libhdf4-alt-dev libhdf5-103 libhdf5-cpp-103 libhdf5-dev
          libhdf5-mpi-dev libhdf5-openmpi-103 libhdf5-openmpi-dev libhwloc-dev
          libhwloc-plugins libhwloc15 libibus-1.0-dev libibverbs-dev libibverbs1
          libice-dev libicu-dev libigdgmm11 libilmbase-dev libilmbase24 libjbig-dev
          libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjs-jquery-ui libjson-c-dev
          libjsoncpp-dev libkml-dev libkmlbase1 libkmlconvenience1 libkmldom1
          libkmlengine1 libkmlregionator1 libkmlxsd1 liblab-gamut1 liblapack-dev
          liblapack3 liblept5 libllvm10 libltdl-dev liblz4-dev liblzma-dev
          libminizip-dev libminizip1 libmount-dev libmpx2 libmysqlclient-dev
          libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpmix2 libpng-dev
          libpng-tools libpoppler-dev libpoppler-private-dev libpq-dev libpq5
          libproj-dev libproj15 libpsm-infinipath1 libpsm2-2 libpthread-stubs0-dev
          libpulse-dev libpyside2-dev libpyside2-py3-5.14 libpython2-stdlib
          libpython2.7-minimal libpython2.7-stdlib libpython3-dev libpython3.8-dev
          libselinux1-dev libsepol1-dev libshiboken2-dev libshiboken2-py3-5.14
          libshine3 libsigsegv2 libsm-dev libsnappy1v5 libsndio-dev libsndio7.0
          libsocket++1 libspatialite-dev libspatialite7 libspdlog-dev libspdlog1
          libsqlite3-dev libssh-gcrypt-4 libssl-dev libstdc++-7-dev libstdc++-9-dev
          libsuperlu-dev libsuperlu5 libswresample-dev libswresample3 libswscale-dev
          libswscale5 libsz2 libtbb-dev libtbb2 libtcl8.6 libtesseract4 libtheora-dev
          libtiff-dev libtiffxx5 libtinyxml-dev libtinyxml2-6a libtinyxml2-dev
          libxinerama-dev libxkbcommon-dev libxml2-dev libxml2-utils libxmu-dev
          libxmu-headers libxnvctrl0 libxpm-dev libxrandr-dev libxrender-dev
          libxss-dev libxt-dev libxv-dev libxvidcore4 libxxf86vm-dev libyaml-dev
          libzstd-dev libzvbi-common libzvbi0 m4 mesa-va-drivers mesa-vdpau-drivers
          mpi-default-bin mpi-default-dev net-tools ocl-icd-libopencl1 odbcinst
          odbcinst1debian2 opencv-data openmpi-bin openmpi-common openni-utils
          proj-bin proj-data pydocstyle pyflakes pyflakes3 pyqt5-dev
          python-matplotlib-data python-pkg-resources python-pyflakes python2
          python2-minimal python2.7 python2.7-minimal python3-autobahn python3-automat
          python3-bs4 python3-cbor python3-constantly python3-cycler python3-dev
          python3-flake8 python3-hamcrest python3-html5lib python3-hyperlink
          python3-ifcfg python3-incremental python3-kiwisolver python3-lark
          python3-lxml python3-lz4 python3-matplotlib python3-mccabe python3-mock
          python3-mpi4py python3-numpy python3-openssl python3-pbr python3-png
          python3-psutil python3-pyasn1 python3-pyasn1-modules python3-pycodestyle
          python3-pydocstyle python3-pydot python3-pyflakes python3-pyqrcode
          python3-zope.interface python3.8-dev qdoc-qt5 qhelpgenerator-qt5
          qt5-assistant qt5-gtk-platformtheme qt5-qmake qt5-qmake-bin
          ros-foxy-depthimage-to-laserscan ros-foxy-desktop ros-foxy-diagnostic-msgs
          xorg-sgml-doctools xtrans-dev zlib1g-dev
          The following packages will be upgraded:
          dbus dbus-x11 libcurl3-gnutls libdbus-1-3 libdpkg-perl libegl1 libexpat1
          libgl1 libgles2 libglvnd0 libglx0 liblzma5 libmysqlclient21 libpcre3
          libpython3.8 libpython3.8-minimal libpython3.8-stdlib libsepol1 libsqlite3-0
          libssl1.1 libtiff5 libxml2 python3.8 python3.8-minimal zlib1g
          25 upgraded, 924 newly installed, 0 to remove and 188 not upgraded.
          Need to get 4,940 kB/476 MB of archives.
          After this operation, 2,611 MB of additional disk space will be used.
          Err:1 http://packages.ros.org/ros2/ubuntu focal/main amd64 ros-foxy-rviz-ogre-vendor amd64 8.2.6-1focal.20220204.165610
          Connection failed [IP: 140.211.166.134 80]
          E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-foxy-rviz-ogre-vendor/ros-foxy-rviz-ogre-vendor_8.2.6-1focal.20220204.165610_amd64.deb Connection failed [IP: 140.211.166.134 80]
          E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
          libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help[-] openmpi-common openni-utils proj-bin proj-data pydocstyle pyflakes pyflakes[/] ros-foxy-ament-cmake-export-interfaces ros-foxy-ament-cmake-export-librarie[-] ros-foxy-builtin-interfaces ros-foxy-class-loader ros-foxy-common-interface[/] ros-foxy-rcpputils ros-foxy-rcutils ros-foxy-resource-retriever ros-foxy-rm[] ros-foxy-ros-workspace ros-foxy-ros2action ros-foxy-ros2bag ros-foxy-ros2cl[] ros-foxy-rqt-graph ros-foxy-rqt-gui ros-foxy-rqt-gui-cpp ros-foxy-rqt-gui-p[-] cppcheck-gui cython-doc debian-keyring g++-multilib g++-9-multilib gcc-9-do[-] libbluray-bdj libboost-doc libboost1.71-doc gccxml libboost-contract1.71-de[] libcurl4-doc libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-de[] libjs-jquery-ui-docs libtool-doc liblzma-doc netcdf-bin netcdf-doc libmyodb[/] python3-cairocffi python3-gobject python3-nose python3-scipy python3-tornad[/] python3-stemmer tix python3-tk-dbg python-trie-doc python3-pampy python3-qt[/] libflann-dev libflann1.9 libfontconfig1-dev libfreetype-dev libfreetype6-de[] libgles-dev libgles1 libgles2-mesa-dev libglew-dev libglew2.1 libglib2.0-de[-] libgphoto2-dev libgsm1 libgtest-dev libgts-0.7-5 libgts-bin libgvc6 libgvpr[/] libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help[] python2-minimal python2.7 python2.7-minimal python3-autobahn python3-automa[/] ros-foxy-ament-cmake-export-interfaces ros-foxy-ament-cmake-export-librarie[-] ros-foxy-builtin-interfaces ros-foxy-class-loader ros-foxy-common-interface[/] ros-foxy-rcpputils ros-foxy-rcutils ros-foxy-resource-retriever ros-foxy-rm[] ros-foxy-ros-workspace ros-foxy-ros2action ros-foxy-ros2bag ros-foxy-ros2cl[] ros-foxy-rqt-graph ros-foxy-rqt-gui ros-foxy-rqt-gui-cpp ros-foxy-rqt-gui-p[/] libpython3.8 libpython3.8-minimal libpython3.8-stdlib libsepol1 libsqlite3-[|]25 upgraded, [-]Result:code:100 0]cal/main amd64 ros-foxy-rviz-ogre-vendor amd64 8.2.6-1focal.20220204.165610
          Run CMD Task:[sudo apt-cache search python3-colcon-common-extensions ]
          [-]Result:success ackage aggregating colcon-core and common extensions.
          [-]Result:success e and 213 not upgraded.0.3.0-1).
          [-]Result:success e and 213 not upgraded.tu1).
          Run CMD Task:[ls /opt/ros/foxy/setup.bash]
          [-]Result:code:2
          [-]Result:code:2
            小鱼 技术大佬 @Holacc
            @Holacc 试试这三句话,然后重新运行下一键安装试试
            sudo apt install --fix-missing
            sudo apt update
            sudo apt install ros-fox-desktop
            HolaccH 3 条回复 最后回复 回复 引用 0
            • HolaccH
              Holacc
              在第三段中出现了下列报错:
              • HolaccH
                Holacc @小鱼
                @小鱼 好的好的!
                • HolaccH
                  Holacc @小鱼
                  @小鱼 还是不行诶 他提示还是这样
                  ros2@ubuntu:~$ sudo apt install --fix-missing
                  0 upgraded, 0 newly installed, 0 to remove and 213 not upgraded.
                  ros2@ubuntu:~$ sudo apt update
                  Hit:1 https://mirrors.ustc.edu.cn/ubuntu focal InRelease
                  Hit:2 https://mirrors.ustc.edu.cn/ubuntu focal-updates InRelease
                  Hit:3 https://mirrors.ustc.edu.cn/ubuntu focal-backports InRelease
                  Hit:4 https://mirrors.ustc.edu.cn/ubuntu focal-security InRelease
                  Hit:5 http://packages.ros.org/ros2/ubuntu focal InRelease
                  Get:6 http://packages.ros.org/ros/ubuntu focal InRelease [4,676 B]
                  Ign:7 http://packages.ros.org/ros/ubuntu focal/main amd64 Packages
                  Err:7 http://packages.ros.org/ros/ubuntu focal/main amd64 Packages
                  Connection failed [IP: 64.50.236.52 80]
                  Fetched 4,676 B in 2min 3s (38 B/s)
                  213 packages can be upgraded. Run 'apt list --upgradable' to see them.
                  W: Failed to fetch http://packages.ros.org/ros/ubuntu/dists/focal/main/binary-amd64/Packages Connection failed [IP: 64.50.236.52 80]
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  ros2@ubuntu:~$ sudo apt install ros-foxy-desktop
                  autoconf automake autotools-dev blt build-essential cpp-8 cppcheck cython3 dbus dbus-x11 default-libmysqlclient-dev dpkg-dev fakeroot fonts-lyx
                  freeglut3 g++ g++-9 gcc-7-base gcc-8 gcc-8-base gdal-data gfortran gfortran-8 gfortran-9 google-mock googletest graphviz hdf5-helpers i965-va-driver
                  ibverbs-providers icu-devtools intel-media-va-driver libaacs0 libaec-dev libaec0 libalgorithm-diff-perl libalgorithm-diff-xs-perl
                  libalgorithm-merge-perl libann0 libaom0 libarmadillo-dev libarmadillo9 libarpack2 libarpack2-dev libasan4 libasound2-dev libassimp-dev libassimp5
                  libavcodec-dev libavcodec58 libavformat-dev libavformat58 libavresample-dev libavresample4 libavutil-dev libavutil56 libbdplus0 libblas-dev libblas3
                  libblkid-dev libbluray2 libboost-all-dev libboost-atomic-dev libboost-atomic1.71-dev libboost-atomic1.71.0 libboost-chrono-dev libboost-chrono1.71-dev
                  libboost-chrono1.71.0 libboost-container-dev libboost-container1.71-dev libboost-container1.71.0 libboost-context-dev libboost-context1.71-dev
                  libboost-context1.71.0 libboost-coroutine-dev libboost-coroutine1.71-dev libboost-coroutine1.71.0 libboost-date-time-dev libboost-date-time1.71-dev
                  libboost-dev libboost-exception-dev libboost-exception1.71-dev libboost-fiber-dev libboost-fiber1.71-dev libboost-fiber1.71.0 libboost-filesystem-dev
                  libboost-filesystem1.71-dev libboost-graph-dev libboost-graph-parallel-dev libboost-graph-parallel1.71-dev libboost-graph-parallel1.71.0
                  libboost-graph1.71-dev libboost-graph1.71.0 libboost-iostreams-dev libboost-iostreams1.71-dev libboost-locale-dev libboost-locale1.71-dev
                  libboost-log-dev libboost-log1.71-dev libboost-log1.71.0 libboost-math-dev libboost-math1.71-dev libboost-math1.71.0 libboost-mpi-dev
                  libboost-mpi-python-dev libboost-mpi-python1.71-dev libboost-mpi-python1.71.0 libboost-mpi1.71-dev libboost-mpi1.71.0 libboost-numpy-dev
                  libboost-numpy1.71-dev libboost-numpy1.71.0 libboost-program-options-dev libboost-program-options1.71-dev libboost-program-options1.71.0
                  libboost-python-dev libboost-python1.71-dev libboost-python1.71.0 libboost-random-dev libboost-random1.71-dev libboost-random1.71.0 libboost-regex-dev
                  libboost-regex1.71-dev libboost-regex1.71.0 libboost-serialization-dev libboost-serialization1.71-dev libboost-serialization1.71.0
                  libboost-stacktrace-dev libboost-stacktrace1.71-dev libboost-stacktrace1.71.0 libboost-system-dev libboost-system1.71-dev libboost-system1.71.0
                  libboost-test-dev libboost-test1.71-dev libboost-test1.71.0 libboost-thread-dev libboost-thread1.71-dev libboost-timer-dev libboost-timer1.71-dev
                  libboost-timer1.71.0 libboost-tools-dev libboost-type-erasure-dev libboost-type-erasure1.71-dev libboost-type-erasure1.71.0 libboost-wave-dev
                  libboost-wave1.71-dev libboost-wave1.71.0 libboost1.71-dev libboost1.71-tools-dev libbullet-dev libbullet2.88 libcaf-openmpi-3 libcdt5 libcfitsio-dev
                  libcfitsio-doc libcfitsio8 libcgraph6 libcharls-dev libcharls2 libchromaprint1 libcilkrts5 libclang1-10 libcoarrays-dev libcoarrays-openmpi-dev
                  libcodec2-0.9 libconsole-bridge-dev libconsole-bridge0.4 libcurl3-gnutls libcurl4-openssl-dev libdap-dev libdap25 libdapclient6v5 libdapserver7v5
                  libdbus-1-3 libdbus-1-dev libdc1394-22 libdc1394-22-dev libdouble-conversion3 libdpkg-perl libegl-dev libegl1 libegl1-mesa-dev libeigen3-dev
                  libepsilon-dev libepsilon1 libevent-core-2.1-7 libevent-dev libevent-extra-2.1-7 libevent-openssl-2.1-7 libevent-pthreads-2.1-7 libexif-dev
                  libexif-doc libexpat1 libexpat1-dev libfabric1 libfakeroot libffi-dev libflann-dev libflann1.9 libfontconfig1-dev libfreetype-dev libfreetype6-dev
                  libfreexl-dev libfreexl1 libfyba-dev libfyba0 libgcc-7-dev libgcc-8-dev libgdal-dev libgdal26 libgdcm-dev libgdcm3.0 libgeos-3.8.0 libgeos-c1v5
                  libgeos-dev libgeotiff-dev libgeotiff5 libgfortran-8-dev libgfortran-9-dev libgfortran5 libgif-dev libgl-dev libgl1 libgl1-mesa-dev libgl2ps-dev
                  libgl2ps1.4 libgles-dev libgles1 libgles2 libgles2-mesa-dev libglew-dev libglew2.1 libglib2.0-dev libglib2.0-dev-bin libglu1-mesa-dev libglvnd-dev
                  libglvnd0 libglx-dev libglx0 libgme0 libgphoto2-dev libgsm1 libgtest-dev libgts-0.7-5 libgts-bin libgvc6 libgvpr2 libhdf4-0-alt libhdf4-alt-dev
                  libhdf5-103 libhdf5-cpp-103 libhdf5-dev libhdf5-mpi-dev libhdf5-openmpi-103 libhdf5-openmpi-dev libhwloc-dev libhwloc-plugins libhwloc15
                  libibus-1.0-dev libibverbs-dev libibverbs1 libice-dev libicu-dev libigdgmm11 libilmbase-dev libilmbase24 libjbig-dev libjpeg-dev libjpeg-turbo8-dev
                  libjpeg8-dev libjs-jquery-ui libjson-c-dev libjsoncpp-dev libkml-dev libkmlbase1 libkmlconvenience1 libkmldom1 libkmlengine1 libkmlregionator1
                  libkmlxsd1 liblab-gamut1 liblapack-dev liblapack3 liblept5 libllvm10 libltdl-dev liblz4-dev liblzma-dev liblzma5 libminizip-dev libminizip1
                  libmount-dev libmpx2 libmysqlclient-dev libmysqlclient21 libnetcdf-c++4 libnetcdf-cxx-legacy-dev libnetcdf-dev libnetcdf15 libnl-3-dev
                  libnl-route-3-dev libnuma-dev libodbc1 libogdi-dev libogdi4.1 libogg-dev libopencv-calib3d-dev libopencv-calib3d4.2 libopencv-contrib-dev
                  libopencv-contrib4.2 libopencv-core-dev libopencv-core4.2 libopencv-dev libopencv-dnn-dev libopencv-dnn4.2 libopencv-features2d-dev
                  libopencv-features2d4.2 libopencv-flann-dev libopencv-flann4.2 libopencv-highgui-dev libopencv-highgui4.2 libopencv-imgcodecs-dev
                  libopencv-imgcodecs4.2 libopencv-imgproc-dev libopencv-imgproc4.2 libopencv-ml-dev libopencv-ml4.2 libopencv-objdetect-dev libopencv-objdetect4.2
                  libopencv-photo-dev libopencv-photo4.2 libopencv-shape-dev libopencv-shape4.2 libopencv-stitching-dev libopencv-stitching4.2 libopencv-superres-dev
                  libopencv-superres4.2 libopencv-ts-dev libopencv-video-dev libopencv-video4.2 libopencv-videoio-dev libopencv-videoio4.2 libopencv-videostab-dev
                  libopencv-videostab4.2 libopencv-viz-dev libopencv-viz4.2 libopencv4.2-java libopencv4.2-jni libopenexr-dev libopenexr24 libopengl-dev libopengl0
                  libopenjp2-7-dev libopenmpi-dev libopenmpi3 libopenmpt0 libopenni-dev libopenni-sensor-pointclouds0 libopenni0 libopenni2-0 libopenni2-dev
                  libpathplan4 libpcl-apps1.10 libpcl-common1.10 libpcl-dev libpcl-features1.10 libpcl-filters1.10 libpcl-io1.10 libpcl-kdtree1.10 libpcl-keypoints1.10
                  libpcl-ml1.10 libpcl-octree1.10 libpcl-outofcore1.10 libpcl-people1.10 libpcl-recognition1.10 libpcl-registration1.10 libpcl-sample-consensus1.10
                  libpcl-search1.10 libpcl-segmentation1.10 libpcl-stereo1.10 libpcl-surface1.10 libpcl-tracking1.10 libpcl-visualization1.10 libpcre16-3 libpcre2-16-0
                  libpcre2-dev libpcre2-posix2 libpcre3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpmix2 libpng-dev libpng-tools libpoppler-dev libpoppler-private-dev
                  libpq-dev libpq5 libproj-dev libproj15 libpsm-infinipath1 libpsm2-2 libpthread-stubs0-dev libpulse-dev libpyside2-dev libpyside2-py3-5.14
                  libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib libpython3-dev libpython3.8 libpython3.8-dev libpython3.8-minimal libpython3.8-stdlib
                  libqhull-dev libqhull-r7 libqhull7 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help5
                  libqt5network5 libqt5opengl5 libqt5opengl5-dev libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5quickparticles5 libqt5quickshapes5
                  libqt5quicktest5 libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5test5 libqt5webchannel5 libqt5webkit5
                  libqt5webkit5-dev libqt5widgets5 libqt5x11extras5 libqt5xml5 libraw1394-dev libraw1394-tools librdmacm1 libsdl2-2.0-0 libsdl2-dev libselinux1-dev
                  libsepol1 libsepol1-dev libshiboken2-dev libshiboken2-py3-5.14 libshine3 libsigsegv2 libsm-dev libsnappy1v5 libsndio-dev libsndio7.0 libsocket++1
                  libspatialite-dev libspatialite7 libspdlog-dev libspdlog1 libsqlite3-0 libsqlite3-dev libssh-gcrypt-4 libssl-dev libssl1.1 libstdc++-7-dev
                  libstdc++-9-dev libsuperlu-dev libsuperlu5 libswresample-dev libswresample3 libswscale-dev libswscale5 libsz2 libtbb-dev libtbb2 libtcl8.6
                  libtesseract4 libtheora-dev libtiff-dev libtiff5 libtiffxx5 libtinyxml-dev libtinyxml2-6a libtinyxml2-dev libtinyxml2.6.2v5 libtk8.6 libtool libubsan0
                  libudev-dev liburiparser-dev liburiparser1 libva-drm2 libva-x11-2 libva2 libvdpau1 libvtk6.3 libvtk7-dev libvtk7-java libvtk7-jni libvtk7-qt-dev
                  libvtk7.1p libvtk7.1p-qt libvulkan-dev libwayland-bin libwayland-dev libwebp-dev libx11-dev libx264-155 libx265-179 libxau-dev libxaw7-dev
                  libxcb-xinerama0 libxcb-xinput0 libxcb1-dev libxcursor-dev libxdmcp-dev libxerces-c-dev libxerces-c3.2 libxext-dev libxfixes-dev libxft-dev libxi-dev
                  libxinerama-dev libxkbcommon-dev libxml2 libxml2-dev libxml2-utils libxmu-dev libxmu-headers libxnvctrl0 libxpm-dev libxrandr-dev libxrender-dev
                  libxss-dev libxt-dev libxv-dev libxvidcore4 libxxf86vm-dev libyaml-dev libzstd-dev libzvbi-common libzvbi0 m4 mesa-va-drivers mesa-vdpau-drivers
                  mpi-default-bin mpi-default-dev net-tools ocl-icd-libopencl1 odbcinst odbcinst1debian2 opencv-data openmpi-bin openmpi-common openni-utils proj-bin
                  proj-data pydocstyle pyflakes pyflakes3 pyqt5-dev python-matplotlib-data python-pkg-resources python-pyflakes python2 python2-minimal python2.7
                  python2.7-minimal python3-autobahn python3-automat python3-bs4 python3-cbor python3-constantly python3-cycler python3-dev python3-flake8
                  python3-hamcrest python3-html5lib python3-hyperlink python3-ifcfg python3-incremental python3-kiwisolver python3-lark python3-lxml python3-lz4
                  python3-matplotlib python3-mccabe python3-mock python3-mpi4py python3-numpy python3-openssl python3-pbr python3-png python3-psutil python3-pyasn1
                  python3-pyasn1-modules python3-pycodestyle python3-pydocstyle python3-pydot python3-pyflakes python3-pyqrcode python3-pyqt5 python3-pyqt5.qtsvg
                  python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-service-identity python3-sip python3-sip-dev
                  python3-snappy python3-snowballstemmer python3-soupsieve python3-tk python3-trie python3-twisted python3-twisted-bin python3-txaio python3-u-msgpack
                  python3-ubjson python3-vtk7 python3-webencodings python3-wsaccel python3-zope.interface python3.8 python3.8-dev python3.8-minimal qdoc-qt5
                  qhelpgenerator-qt5 qt5-assistant qt5-gtk-platformtheme qt5-qmake qt5-qmake-bin qt5-qmltooling-plugins qtattributionsscanner-qt5 qtbase5-dev
                  qtbase5-dev-tools qtchooser qtdeclarative5-dev qtdeclarative5-dev-tools qttools5-dev qttools5-dev-tools qttools5-private-dev qttranslations5-l10n
                  ros-foxy-action-msgs ros-foxy-action-tutorials-cpp ros-foxy-action-tutorials-interfaces ros-foxy-action-tutorials-py ros-foxy-actionlib-msgs
                  ros-foxy-ament-cmake ros-foxy-ament-cmake-auto ros-foxy-ament-cmake-copyright ros-foxy-ament-cmake-core ros-foxy-ament-cmake-cppcheck
                  ros-foxy-ament-cmake-cpplint ros-foxy-ament-cmake-export-definitions ros-foxy-ament-cmake-export-dependencies
                  ros-foxy-ament-cmake-export-include-directories ros-foxy-ament-cmake-export-interfaces ros-foxy-ament-cmake-export-libraries
                  ros-foxy-ament-cmake-export-link-flags ros-foxy-ament-cmake-export-targets ros-foxy-ament-cmake-flake8 ros-foxy-ament-cmake-gmock
                  ros-foxy-ament-cmake-gtest ros-foxy-ament-cmake-include-directories ros-foxy-ament-cmake-libraries ros-foxy-ament-cmake-lint-cmake
                  ros-foxy-ament-cmake-pep257 ros-foxy-ament-cmake-pytest ros-foxy-ament-cmake-python ros-foxy-ament-cmake-ros ros-foxy-ament-cmake-target-dependencies
                  ros-foxy-ament-cmake-test ros-foxy-ament-cmake-uncrustify ros-foxy-ament-cmake-version ros-foxy-ament-cmake-xmllint ros-foxy-ament-copyright
                  ros-foxy-ament-cppcheck ros-foxy-ament-cpplint ros-foxy-ament-flake8 ros-foxy-ament-index-cpp ros-foxy-ament-index-python ros-foxy-ament-lint
                  ros-foxy-ament-lint-auto ros-foxy-ament-lint-cmake ros-foxy-ament-lint-common ros-foxy-ament-package ros-foxy-ament-pep257 ros-foxy-ament-uncrustify
                  ros-foxy-ament-xmllint ros-foxy-angles ros-foxy-builtin-interfaces ros-foxy-class-loader ros-foxy-common-interfaces ros-foxy-composition
                  ros-foxy-composition-interfaces ros-foxy-console-bridge-vendor ros-foxy-cv-bridge ros-foxy-demo-nodes-cpp ros-foxy-demo-nodes-cpp-native
                  ros-foxy-demo-nodes-py ros-foxy-depthimage-to-laserscan ros-foxy-diagnostic-msgs ros-foxy-domain-coordinator ros-foxy-dummy-map-server
                  ros-foxy-dummy-robot-bringup ros-foxy-dummy-sensors ros-foxy-eigen3-cmake-module ros-foxy-example-interfaces
                  ros-foxy-examples-rclcpp-minimal-action-client ros-foxy-examples-rclcpp-minimal-action-server ros-foxy-examples-rclcpp-minimal-client
                  ros-foxy-examples-rclcpp-minimal-composition ros-foxy-examples-rclcpp-minimal-publisher ros-foxy-examples-rclcpp-minimal-service
                  ros-foxy-examples-rclcpp-minimal-subscriber ros-foxy-examples-rclcpp-minimal-timer ros-foxy-examples-rclcpp-multithreaded-executor
                  ros-foxy-examples-rclpy-executors ros-foxy-examples-rclpy-minimal-action-client ros-foxy-examples-rclpy-minimal-action-server
                  ros-foxy-examples-rclpy-minimal-client ros-foxy-examples-rclpy-minimal-publisher ros-foxy-examples-rclpy-minimal-service
                  ros-foxy-examples-rclpy-minimal-subscriber ros-foxy-fastcdr ros-foxy-fastrtps ros-foxy-fastrtps-cmake-module ros-foxy-foonathan-memory-vendor
                  ros-foxy-geometry-msgs ros-foxy-geometry2 ros-foxy-gmock-vendor ros-foxy-gtest-vendor ros-foxy-image-geometry ros-foxy-image-tools
                  ros-foxy-image-transport ros-foxy-interactive-markers ros-foxy-intra-process-demo ros-foxy-joy ros-foxy-kdl-parser ros-foxy-laser-geometry
                  ros-foxy-launch ros-foxy-launch-ros ros-foxy-launch-testing ros-foxy-launch-testing-ament-cmake ros-foxy-launch-testing-ros ros-foxy-launch-xml
                  ros-foxy-launch-yaml ros-foxy-libcurl-vendor ros-foxy-libstatistics-collector ros-foxy-libyaml-vendor ros-foxy-lifecycle ros-foxy-lifecycle-msgs
                  ros-foxy-logging-demo ros-foxy-map-msgs ros-foxy-message-filters ros-foxy-nav-msgs ros-foxy-orocos-kdl ros-foxy-osrf-pycommon ros-foxy-pcl-conversions
                  ros-foxy-pcl-msgs ros-foxy-pendulum-control ros-foxy-pendulum-msgs ros-foxy-pluginlib ros-foxy-python-cmake-module ros-foxy-python-qt-binding
                  ros-foxy-qt-dotgraph ros-foxy-qt-gui ros-foxy-qt-gui-cpp ros-foxy-qt-gui-py-common ros-foxy-quality-of-service-demo-cpp
                  ros-foxy-quality-of-service-demo-py ros-foxy-rcl ros-foxy-rcl-action ros-foxy-rcl-interfaces ros-foxy-rcl-lifecycle ros-foxy-rcl-logging-spdlog
                  ros-foxy-rcl-yaml-param-parser ros-foxy-rclcpp ros-foxy-rclcpp-action ros-foxy-rclcpp-components ros-foxy-rclcpp-lifecycle ros-foxy-rclpy
                  ros-foxy-rcpputils ros-foxy-rcutils ros-foxy-resource-retriever ros-foxy-rmw ros-foxy-rmw-dds-common ros-foxy-rmw-fastrtps-cpp
                  ros-foxy-rmw-fastrtps-shared-cpp ros-foxy-rmw-implementation ros-foxy-rmw-implementation-cmake ros-foxy-robot-state-publisher ros-foxy-ros-base
                  ros-foxy-ros-core ros-foxy-ros-environment ros-foxy-ros-workspace ros-foxy-ros2action ros-foxy-ros2bag ros-foxy-ros2cli ros-foxy-ros2component
                  ros-foxy-ros2doctor ros-foxy-ros2interface ros-foxy-ros2launch ros-foxy-ros2lifecycle ros-foxy-ros2multicast ros-foxy-ros2node ros-foxy-ros2param
                  ros-foxy-ros2pkg ros-foxy-ros2run ros-foxy-ros2service ros-foxy-ros2topic ros-foxy-rosbag2 ros-foxy-rosbag2-compression
                  ros-foxy-rosbag2-converter-default-plugins ros-foxy-rosbag2-cpp ros-foxy-rosbag2-storage ros-foxy-rosbag2-storage-default-plugins
                  ros-foxy-rosbag2-transport ros-foxy-rosgraph-msgs ros-foxy-rosidl-adapter ros-foxy-rosidl-cmake ros-foxy-rosidl-default-generators
                  ros-foxy-rosidl-default-runtime ros-foxy-rosidl-generator-c ros-foxy-rosidl-generator-cpp ros-foxy-rosidl-generator-py ros-foxy-rosidl-parser
                  ros-foxy-rosidl-runtime-c ros-foxy-rosidl-runtime-cpp ros-foxy-rosidl-runtime-py ros-foxy-rosidl-typesupport-c ros-foxy-rosidl-typesupport-cpp
                  ros-foxy-rosidl-typesupport-fastrtps-c ros-foxy-rosidl-typesupport-fastrtps-cpp ros-foxy-rosidl-typesupport-interface
                  ros-foxy-rosidl-typesupport-introspection-c ros-foxy-rosidl-typesupport-introspection-cpp ros-foxy-rpyutils ros-foxy-rqt-action
                  ros-foxy-rqt-common-plugins ros-foxy-rqt-console ros-foxy-rqt-graph ros-foxy-rqt-gui ros-foxy-rqt-gui-cpp ros-foxy-rqt-gui-py ros-foxy-rqt-image-view
                  ros-foxy-rqt-msg ros-foxy-rqt-plot ros-foxy-rqt-publisher ros-foxy-rqt-py-common ros-foxy-rqt-py-console ros-foxy-rqt-reconfigure
                  ros-foxy-rqt-service-caller ros-foxy-rqt-shell ros-foxy-rqt-srv ros-foxy-rqt-top ros-foxy-rqt-topic ros-foxy-rttest ros-foxy-rviz-assimp-vendor
                  ros-foxy-rviz-common ros-foxy-rviz-default-plugins ros-foxy-rviz-ogre-vendor ros-foxy-rviz-rendering ros-foxy-rviz2 ros-foxy-sdl2-vendor
                  ros-foxy-sensor-msgs ros-foxy-shape-msgs ros-foxy-shared-queues-vendor ros-foxy-spdlog-vendor ros-foxy-sqlite3-vendor ros-foxy-sros2
                  ros-foxy-sros2-cmake ros-foxy-statistics-msgs ros-foxy-std-msgs ros-foxy-std-srvs ros-foxy-stereo-msgs ros-foxy-tango-icons-vendor
                  ros-foxy-teleop-twist-joy ros-foxy-teleop-twist-keyboard ros-foxy-tf2 ros-foxy-tf2-bullet ros-foxy-tf2-eigen ros-foxy-tf2-geometry-msgs
                  ros-foxy-tf2-kdl ros-foxy-tf2-msgs ros-foxy-tf2-py ros-foxy-tf2-ros ros-foxy-tf2-sensor-msgs ros-foxy-tf2-tools ros-foxy-tinyxml-vendor
                  ros-foxy-tinyxml2-vendor ros-foxy-tlsf ros-foxy-tlsf-cpp ros-foxy-topic-monitor ros-foxy-tracetools ros-foxy-trajectory-msgs ros-foxy-turtlesim
                  ros-foxy-uncrustify-vendor ros-foxy-unique-identifier-msgs ros-foxy-urdf ros-foxy-urdfdom ros-foxy-urdfdom-headers ros-foxy-visualization-msgs
                  • HolaccH
                    Holacc @小鱼
                    ros-foxy-yaml-cpp-vendor ros-foxy-zstd-vendor shiboken2 sip-dev tango-icon-theme tcl tcl-dev tcl-vtk7 tcl8.6 tcl8.6-dev tk tk-dev tk8.6 tk8.6-blt2.5
                    tk8.6-dev ttf-bitstream-vera uncrustify unixodbc-dev uuid-dev va-driver-all vdpau-driver-all vtk7 x11proto-core-dev x11proto-dev x11proto-input-dev
                    x11proto-randr-dev x11proto-scrnsaver-dev x11proto-xext-dev x11proto-xf86vidmode-dev x11proto-xinerama-dev xorg-sgml-doctools xtrans-dev zlib1g
                    zlib1g-dev
                    Suggested packages:
                    autoconf-archive gnu-standards autoconf-doc gettext blt-demo gcc-8-locales cppcheck-gui cython-doc debian-keyring g++-multilib g++-9-multilib
                    gcc-9-doc gcc-8-multilib gcc-8-doc gfortran-multilib gfortran-doc gfortran-8-multilib gfortran-8-doc gfortran-9-multilib gfortran-9-doc gsfonts
                    graphviz-doc i965-va-driver-shaders libitpp-dev libasound2-doc liblapack-doc libbluray-bdj libboost-doc libboost1.71-doc gccxml
                    libboost-contract1.71-dev libmpfrc++-dev libntl-dev xsltproc doxygen docbook-xsl default-jdk fop libcurl4-doc libidn11-dev libkrb5-dev libldap2-dev
                    librtmp-dev libssh2-1-dev git bzr libeigen3-doc freetype2-doc libgdal-doc libgeotiff-epsg geotiff-bin gdal-bin glew-utils libgirepository1.0-dev
                    libglib2.0-doc libhdf4-doc hdf4-tools libhdf5-doc libhwloc-contrib-plugins libice-doc icu-doc libjs-jquery-ui-docs libtool-doc liblzma-doc netcdf-bin
                    netcdf-doc libmyodbc odbc-postgresql tdsodbc unixodbc-bin ogdi-bin opencv-doc openmpi-doc openni-doc openni2-doc libpcl-doc postgresql-doc-12
                    qt5-image-formats-plugins qtwayland5 libraw1394-doc libsm-doc sndiod sqlite3-doc libssl-doc libstdc++-7-doc libstdc++-9-doc libsuperlu-doc libtbb-doc
                    libtinyxml-doc gcj-jdk vtk7-doc vtk7-examples java-virtual-machine libwayland-doc libx11-doc libxaw-doc libxcb-doc libxerces-c-doc libxext-doc
                    libxt-doc libyaml-doc m4-doc opencl-icd python-setuptools python2-doc python-tk python2.7-doc binfmt-support python-cycler-doc python3-genshi
                    python-lark-doc python3-lxml-dbg python-lxml-doc dvipng ffmpeg inkscape ipython3 python-matplotlib-doc python3-cairocffi python3-gobject python3-nose
                    python3-scipy python3-tornado texlive-extra-utils texlive-latex-extra ttf-staypuft python-mock-doc python-numpy-doc python3-numpy-dbg
                    python-openssl-doc python3-openssl-dbg python-psutil-doc python3-pyqt5-dbg python-pyside2-doc python-sip-doc python3-stemmer tix python3-tk-dbg
                    python-trie-doc python3-pampy python3-qt4 python3-serial python3-wxgtk2.8 python3-twisted-bin-dbg python-txaio-doc mayavi2 python3.8-venv
                    python3.8-doc qt5-doc firebird-dev ros-foxy-rosidl-typesupport-connext-c ros-foxy-rosidl-typesupport-connext-cpp gnome-icon-theme kdelibs-data tcl-doc
                    tcl-tclreadline tcl8.6-doc tk-doc tk8.6-doc libvdpau-va-gl1 nvidia-vdpau-driver nvidia-legacy-340xx-vdpau-driver nvidia-legacy-304xx-vdpau-driver
                    autoconf automake autotools-dev blt build-essential cpp-8 cppcheck cython3 default-libmysqlclient-dev dpkg-dev fakeroot fonts-lyx freeglut3 g++ g++-9
                    gcc-7-base gcc-8 gcc-8-base gdal-data gfortran gfortran-8 gfortran-9 google-mock googletest graphviz hdf5-helpers i965-va-driver ibverbs-providers
                    icu-devtools intel-media-va-driver libaacs0 libaec-dev libaec0 libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libann0
                    libaom0 libarmadillo-dev libarmadillo9 libarpack2 libarpack2-dev libasan4 libasound2-dev libassimp-dev libassimp5 libavcodec-dev libavcodec58
                    libavformat-dev libavformat58 libavresample-dev libavresample4 libavutil-dev libavutil56 libbdplus0 libblas-dev libblas3 libblkid-dev libbluray2
                    libboost-all-dev libboost-atomic-dev libboost-atomic1.71-dev libboost-atomic1.71.0 libboost-chrono-dev libboost-chrono1.71-dev libboost-chrono1.71.0
                    libboost-container-dev libboost-container1.71-dev libboost-container1.71.0 libboost-context-dev libboost-context1.71-dev libboost-context1.71.0
                    libboost-coroutine-dev libboost-coroutine1.71-dev libboost-coroutine1.71.0 libboost-date-time-dev libboost-date-time1.71-dev libboost-dev
                    libcodec2-0.9 libconsole-bridge-dev libconsole-bridge0.4 libcurl4-openssl-dev libdap-dev libdap25 libdapclient6v5 libdapserver7v5 libdbus-1-dev
                    libdc1394-22 libdc1394-22-dev libdouble-conversion3 libegl-dev libegl1-mesa-dev libeigen3-dev libepsilon-dev libepsilon1 libevent-core-2.1-7
                    libevent-dev libevent-extra-2.1-7 libevent-openssl-2.1-7 libevent-pthreads-2.1-7 libexif-dev libexif-doc libexpat1-dev libfabric1 libfakeroot
                    libffi-dev libflann-dev libflann1.9 libfontconfig1-dev libfreetype-dev libfreetype6-dev libfreexl-dev libfreexl1 libfyba-dev libfyba0 libgcc-7-dev
                    libgcc-8-dev libgdal-dev libgdal26 libgdcm-dev libgdcm3.0 libgeos-3.8.0 libgeos-c1v5 libgeos-dev libgeotiff-dev libgeotiff5 libgfortran-8-dev
                    libgfortran-9-dev libgfortran5 libgif-dev libgl-dev libgl1-mesa-dev libgl2ps-dev libgl2ps1.4 libgles-dev libgles1 libgles2-mesa-dev libglew-dev
                    libglew2.1 libglib2.0-dev libglib2.0-dev-bin libglu1-mesa-dev libglvnd-dev libglx-dev libgme0 libgphoto2-dev libgsm1 libgtest-dev libgts-0.7-5
                    libgts-bin libgvc6 libgvpr2 libhdf4-0-alt libhdf4-alt-dev libhdf5-103 libhdf5-cpp-103 libhdf5-dev libhdf5-mpi-dev libhdf5-openmpi-103
                    libhdf5-openmpi-dev libhwloc-dev libhwloc-plugins libhwloc15 libibus-1.0-dev libibverbs-dev libibverbs1 libice-dev libicu-dev libigdgmm11
                    libilmbase-dev libilmbase24 libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjs-jquery-ui libjson-c-dev libjsoncpp-dev libkml-dev
                    libkmlbase1 libkmlconvenience1 libkmldom1 libkmlengine1 libkmlregionator1 libkmlxsd1 liblab-gamut1 liblapack-dev liblapack3 liblept5 libllvm10
                    libltdl-dev liblz4-dev liblzma-dev libminizip-dev libminizip1 libmount-dev libmpx2 libmysqlclient-dev libnetcdf-c++4 libnetcdf-cxx-legacy-dev
                    libnetcdf-dev libnetcdf15 libnl-3-dev libnl-route-3-dev libnuma-dev libodbc1 libogdi-dev libogdi4.1 libogg-dev libopencv-calib3d-dev
                    libopencv-calib3d4.2 libopencv-contrib-dev libopencv-contrib4.2 libopencv-core-dev libopencv-core4.2 libopencv-dev libopencv-dnn-dev libopencv-dnn4.2
                    libopencv-features2d-dev libopencv-features2d4.2 libopencv-flann-dev libopencv-flann4.2 libopencv-highgui-dev libopencv-highgui4.2
                    libopencv-imgcodecs-dev libopencv-imgcodecs4.2 libopencv-imgproc-dev libopencv-imgproc4.2 libopencv-ml-dev libopencv-ml4.2 libopencv-objdetect-dev
                    libopencv-objdetect4.2 libopencv-photo-dev libopencv-photo4.2 libopencv-shape-dev libopencv-shape4.2 libopencv-stitching-dev libopencv-stitching4.2
                    libopencv-superres-dev libopencv-superres4.2 libopencv-ts-dev libopencv-video-dev libopencv-video4.2 libopencv-videoio-dev libopencv-videoio4.2
                    libopencv-videostab-dev libopencv-videostab4.2 libopencv-viz-dev libopencv-viz4.2 libopencv4.2-java libopencv4.2-jni libopenexr-dev libopenexr24
                    libopengl-dev libopengl0 libopenjp2-7-dev libopenmpi-dev libopenmpi3 libopenmpt0 libopenni-dev libopenni-sensor-pointclouds0 libopenni0 libopenni2-0
                    libopenni2-dev libpathplan4 libpcl-apps1.10 libpcl-common1.10 libpcl-dev libpcl-features1.10 libpcl-filters1.10 libpcl-io1.10 libpcl-kdtree1.10
                    libpcl-keypoints1.10 libpcl-ml1.10 libpcl-octree1.10 libpcl-outofcore1.10 libpcl-people1.10 libpcl-recognition1.10 libpcl-registration1.10
                    libpcl-sample-consensus1.10 libpcl-search1.10 libpcl-segmentation1.10 libpcl-stereo1.10 libpcl-surface1.10 libpcl-tracking1.10
                    libpcl-visualization1.10 libpcre16-3 libpcre2-16-0 libpcre2-dev libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpmix2 libpng-dev
                    libpng-tools libpoppler-dev libpoppler-private-dev libpq-dev libpq5 libproj-dev libproj15 libpsm-infinipath1 libpsm2-2 libpthread-stubs0-dev
                    libpulse-dev libpyside2-dev libpyside2-py3-5.14 libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib libpython3-dev libpython3.8-dev
                    libspatialite-dev libspatialite7 libspdlog-dev libspdlog1 libsqlite3-dev libssh-gcrypt-4 libssl-dev libstdc++-7-dev libstdc++-9-dev libsuperlu-dev
                    libsuperlu5 libswresample-dev libswresample3 libswscale-dev libswscale5 libsz2 libtbb-dev libtbb2 libtcl8.6 libtesseract4 libtheora-dev libtiff-dev
                    libtiffxx5 libtinyxml-dev libtinyxml2-6a libtinyxml2-dev libtinyxml2.6.2v5 libtk8.6 libtool libubsan0 libudev-dev liburiparser-dev liburiparser1
                    libva-drm2 libva-x11-2 libva2 libvdpau1 libvtk6.3 libvtk7-dev libvtk7-java libvtk7-jni libvtk7-qt-dev libvtk7.1p libvtk7.1p-qt libvulkan-dev
                    libwayland-bin libwayland-dev libwebp-dev libx11-dev libx264-155 libx265-179 libxau-dev libxaw7-dev libxcb-xinerama0 libxcb-xinput0 libxcb1-dev
                    libxcursor-dev libxdmcp-dev libxerces-c-dev libxerces-c3.2 libxext-dev libxfixes-dev libxft-dev libxi-dev libxinerama-dev libxkbcommon-dev libxml2-dev
                    libxml2-utils libxmu-dev libxmu-headers libxnvctrl0 libxpm-dev libxrandr-dev libxrender-dev libxss-dev libxt-dev libxv-dev libxvidcore4 libxxf86vm-dev
                    libyaml-dev libzstd-dev libzvbi-common libzvbi0 m4 mesa-va-drivers mesa-vdpau-drivers mpi-default-bin mpi-default-dev net-tools ocl-icd-libopencl1
                    odbcinst odbcinst1debian2 opencv-data openmpi-bin openmpi-common openni-utils proj-bin proj-data pydocstyle pyflakes pyflakes3 pyqt5-dev
                    python-matplotlib-data python-pkg-resources python-pyflakes python2 python2-minimal python2.7 python2.7-minimal python3-autobahn python3-automat
                    python3-bs4 python3-cbor python3-constantly python3-cycler python3-dev python3-flake8 python3-hamcrest python3-html5lib python3-hyperlink
                    python3-ifcfg python3-incremental python3-kiwisolver python3-lark python3-lxml python3-lz4 python3-matplotlib python3-mccabe python3-mock
                    python3-mpi4py python3-numpy python3-openssl python3-pbr python3-png python3-psutil python3-pyasn1 python3-pyasn1-modules python3-pycodestyle
                    python3-pydocstyle python3-pydot python3-pyflakes python3-pyqrcode python3-pyqt5 python3-pyqt5.qtsvg python3-pyside2.qtcore python3-pyside2.qtgui
                    python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-service-identity python3-sip python3-sip-dev python3-snappy python3-snowballstemmer
                    python3-soupsieve python3-tk python3-trie python3-twisted python3-twisted-bin python3-txaio python3-u-msgpack python3-ubjson python3-vtk7
                    python3-webencodings python3-wsaccel python3-zope.interface python3.8-dev qdoc-qt5 qhelpgenerator-qt5 qt5-assistant qt5-gtk-platformtheme qt5-qmake
                    qt5-qmake-bin qt5-qmltooling-plugins qtattributionsscanner-qt5 qtbase5-dev qtbase5-dev-tools qtchooser qtdeclarative5-dev qtdeclarative5-dev-tools
                    qttools5-dev qttools5-dev-tools qttools5-private-dev qttranslations5-l10n ros-foxy-action-msgs ros-foxy-action-tutorials-cpp
                    ros-foxy-action-tutorials-interfaces ros-foxy-action-tutorials-py ros-foxy-actionlib-msgs ros-foxy-ament-cmake ros-foxy-ament-cmake-auto
                    ros-foxy-ament-cmake-copyright ros-foxy-ament-cmake-core ros-foxy-ament-cmake-cppcheck ros-foxy-ament-cmake-cpplint
                    ros-foxy-ament-cmake-export-definitions ros-foxy-ament-cmake-export-dependencies ros-foxy-ament-cmake-export-include-directories
                    ros-foxy-ament-cmake-export-interfaces ros-foxy-ament-cmake-export-libraries ros-foxy-ament-cmake-export-link-flags
                    ros-foxy-ament-cmake-export-targets ros-foxy-ament-cmake-flake8 ros-foxy-ament-cmake-gmock ros-foxy-ament-cmake-gtest
                    ros-foxy-ament-cmake-include-directories ros-foxy-ament-cmake-libraries ros-foxy-ament-cmake-lint-cmake ros-foxy-ament-cmake-pep257
                    ros-foxy-ament-cmake-pytest ros-foxy-ament-cmake-python ros-foxy-ament-cmake-ros ros-foxy-ament-cmake-target-dependencies ros-foxy-ament-cmake-test
                    ros-foxy-ament-cmake-uncrustify ros-foxy-ament-cmake-version ros-foxy-ament-cmake-xmllint ros-foxy-ament-copyright ros-foxy-ament-cppcheck
                    ros-foxy-ament-cpplint ros-foxy-ament-flake8 ros-foxy-ament-index-cpp ros-foxy-ament-index-python ros-foxy-ament-lint ros-foxy-ament-lint-auto
                    ros-foxy-ament-lint-cmake ros-foxy-ament-lint-common ros-foxy-ament-package ros-foxy-ament-pep257 ros-foxy-ament-uncrustify ros-foxy-ament-xmllint
                    ros-foxy-angles ros-foxy-builtin-interfaces ros-foxy-class-loader ros-foxy-common-interfaces ros-foxy-composition ros-foxy-composition-interfaces
                    ros-foxy-console-bridge-vendor ros-foxy-cv-bridge ros-foxy-demo-nodes-cpp ros-foxy-demo-nodes-cpp-native ros-foxy-demo-nodes-py
                    ros-foxy-depthimage-to-laserscan ros-foxy-desktop ros-foxy-diagnostic-msgs ros-foxy-domain-coordinator ros-foxy-dummy-map-server
                    x11proto-randr-dev x11proto-scrnsaver-dev x11proto-xext-dev x11proto-xf86vidmode-dev x11proto-xinerama-dev xorg-sgml-doctools xtrans-dev zlib1g-dev
                    dbus dbus-x11 libcurl3-gnutls libdbus-1-3 libdpkg-perl libegl1 libexpat1 libgl1 libgles2 libglvnd0 libglx0 liblzma5 libmysqlclient21 libpcre3
                    libpython3.8 libpython3.8-minimal libpython3.8-stdlib libsepol1 libsqlite3-0 libssl1.1 libtiff5 libxml2 python3.8 python3.8-minimal zlib1g
                    Do you want to continue? [Y/n] y
                      小鱼 技术大佬 @Holacc
                      @Holacc sudo apt-get update 之后呢
                      HolaccH 1 条回复 最后回复 回复 引用 0
                      • HolaccH
                        Holacc @小鱼
                        @小鱼 它显示这样
                        sudo apt-get update
                        W: Failed to fetch http://packages.ros.org/ros/ubuntu/dists/focal/main/binary-amd64/Packages Connection failed [IP: 140.211.166.134 80]
