    RViz中Map Status:Warn Message No map received
    rviz2不显示地图 odom map
    • A
      ALSKDJFHGG
      rviz中Map no map received,没有接受到地图信息
      目前发现是时间不一致导致的,问如何解决
      rviz显示如下
      rqt显示如下
      查看 map 无数据输出 odom无相关话题
      scan有输出
      gazebo_sim.launch.py 代码
      import launch
      import launch_ros
          # 获取默认路径
          robot_name_in_model = "fishbot"
          urdf_tutorial_path = get_package_share_directory('fishbot_description')
          default_model_path = urdf_tutorial_path + '/urdf/fishbot/firstbot.urdf.xacro'
          default_world_path = urdf_tutorial_path + '/world/custom_room.world'
          # 为 Launch 声明参数
              name='model', default_value=str(default_model_path),
              description='URDF 的绝对路径')
          # 获取文件内容生成新的参数
          robot_description = launch_ros.parameter_descriptions.ParameterValue(
              launch.substitutions.Command(
                  ['xacro ', launch.substitutions.LaunchConfiguration('model')]),
              value_type=str)
          robot_state_publisher_node = launch_ros.actions.Node(
              parameters=[{'robot_description': robot_description}]
          # 通过 IncludeLaunchDescription 包含另外一个 launch 文件
          launch_gazebo = launch.actions.IncludeLaunchDescription(
              PythonLaunchDescriptionSource([get_package_share_directory(
                  'gazebo_ros'), '/launch', '/gazebo.launch.py']),
            	# 传递参数
              launch_arguments=[('world', default_world_path),('verbose','true')]
          # 请求 Gazebo 加载机器人
          spawn_entity_node = launch_ros.actions.Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-topic', '/robot_description',
                         '-entity', robot_name_in_model, ])
          # 加载并激活 fishbot_joint_state_broadcaster 控制器
          load_joint_state_controller = launch.actions.ExecuteProcess(
              cmd=['ros2', 'control', 'load_controller', '--set-state', 'active',
                  'fishbot_joint_state_broadcaster'],
              output='screen'
          # 加载并激活 fishbot_effort_controller 控制器
          load_fishbot_effort_controller = launch.actions.ExecuteProcess(
              cmd=['ros2', 'control', 'load_controller', '--set-state', 'active','fishbot_effort_controller'],
              output='screen')
          load_fishbot_diff_drive_controller = launch.actions.ExecuteProcess(
              cmd=['ros2', 'control', 'load_controller', '--set-state', 'active','fishbot_diff_drive_controller'],
              output='screen')
              action_declare_arg_mode_path,
              robot_state_publisher_node,
              launch_gazebo,
              spawn_entity_node,
              # 事件动作,当加载机器人结束后执行
              launch.actions.RegisterEventHandler(
                  event_handler=launch.event_handlers.OnProcessExit(
                      target_action=spawn_entity_node,
                      on_exit=[load_joint_state_controller],)
              # 事件动作,load_fishbot_diff_drive_controller
                  target_action=load_joint_state_controller,
                  on_exit=[load_fishbot_diff_drive_controller],)
      • A
        ALSKDJFHGG
        最后由 ALSKDJFHGG 编辑
        之前的问题已解决原因为/odom话题名称没有对上
        目前最新问题,无法接受信息因为队列已满求教如何解决
