    ros noetic 报错 ImportError: No module named rospkg
    雷达 noetic 报错 importerror
    • 17670492071
      1767049207
      雷达 ros noetic 报错
      [map_manager-6] process has died [pid 11242, exit code 1, cmd /home/tan/robot_ws/src/world_canvas_server/src/world_canvas_server/map_manager.py __name:=map_manager __log:=/home/tan/.ros/log/fb14cde2-34e9-11ed-88a9-73e8a92000fd/map_manager-6.log].
      log file: /home/tan/.ros/log/fb14cde2-34e9-11ed-88a9-73e8a92000fd/map_manager-6*.log
      File "/home/tan/robot_ws/src/transbot_nav/scripts/scan_compression.py", line 3, in <module>
      import rospy
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/init.py", line 49, in <module>
      from .client import spin, myargv, init_node,
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/client.py", line 52, in <module>
      import roslib
      File "/opt/ros/noetic/lib/python3/dist-packages/roslib/init.py", line 50, in <module>
      from roslib.launcher import load_manifest # noqa: F401
      File "/opt/ros/noetic/lib/python3/dist-packages/roslib/launcher.py", line 42, in <module>
      import rospkg
        小鱼 技术大佬 @1767049207
        @1767049207 装了ros了吗,有装的记得source环境,不行手动安装下rospkg
        sudo apt install python3-pip
        sudo pip install rospkg
        17670492071 1 条回复 最后回复 回复 引用 0
        • 17670492071
          1767049207 @小鱼
          @小鱼 有裝的。但是就是説我沒有。。
