    rosdepc update常见错误及解决方案
    rosdepc update
    18
    29
    9.8k
      这两天有不少小伙伴遇到rosdepc update更新失败问题,主要有两个,这里小鱼介绍下并提供解决方案。
      一、使用rosdepc update后出现Expected file type is 'distribution'
      这个问题,应该是rosdistro仓库修改了些东西造成的humble版本更新时的bug,可以通过下面的命令指定更新的ros版本解决。
      ERROR: Rosdep experienced an error: Expected file type is 'distribution'
      Please go to the rosdepc page [1] and file a bug report with the stack trace below.
      [1] : http://www.ros.org/wiki/rosdepc
      发生错误了,请关注微信公众号:鱼香ROS,找小鱼反馈哦
      rosdepc version: 0.21.0
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 146, in rosdep_main
          exit_code = _rosdep_main(args)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 446, in _rosdep_main
          return _no_args_handler(command, parser, options, args)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 455, in _no_args_handler
          return command_handlers[command](options)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 677, in command_update
          ros_distro=options.ros_distro)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/sources_list.py", line 516, in update_sources_list
          rosdep_data = get_gbprepo_as_rosdep_data(dist_name)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/gbpdistro_support.py", line 149, in get_gbprepo_as_rosdep_data
          distro_file = get_release_file(gbpdistro)
        File "/usr/local/lib/python2.7/dist-packages/roscdep2/rosdistrohelper.py", line 77, in get_release_file
          dist_file = rosdistro.get_distribution_file(get_index(), distro)
        File "/usr/local/lib/python2.7/dist-packages/rosdistro/__init__.py", line 120, in get_distribution_file
          return create_distribution_file(dist_name, data)
        File "/usr/local/lib/python2.7/dist-packages/rosdistro/distribution_file.py", line 134, in create_distribution_file
          dist_file = DistributionFile(dist_name, d)
        File "/usr/local/lib/python2.7/dist-packages/rosdistro/distribution_file.py", line 45, in __init__
          assert 'type' in data, "Expected file type is '%s'" % DistributionFile._type
      AssertionError: Expected file type is 'distribution'
      解决方案
      使用下面的命令代替rosdepc update
      rosdepc update --rosdistro=$ROS_DISTRO
      如果遇到错误可以将$ROS_DISTRO替换为你的ROS版本名称
      rosdepc update --rosdistro=你的ROS版本名称
      比如
      rosdepc update --rosdistro=melodic
      rosdepc update --rosdistro=kinetic
      二、Ubable to process source [xxxx/fuerte.yaml]
      这个直接忽略即可,不影响使用。
      • 毛哥成山轮胎机油保养毛
        毛哥成山轮胎机油保养 活跃VIP
        @小鱼 在 rosdepc update常见错误及解决方案 中说:
        一键装机里面的 rosdepc update 应该是没有问题,大概是网络的原因,我第一次也没有成功,多来了几次就成功了
        29644875142 1 条回复 最后回复 回复 引用 0
        • 15825734081 1582573408 在 中 引用了 这个主题
        • 13004528441 1300452844 在 中 引用了 这个主题
        • 16553045171 1655304517 在 中 引用了 这个主题
        • 7173412157
          逐。
          @小鱼 你好,我希正在制作一个ros的docker镜像,但是在ubuntu容器中只能通过root权限运行指令(可能是镜像太简洁所以没有用户管理系统,只有root),所以运行rosdep update也是在root下面进行的,报错说无法运行,请问有何解决方法么
            小鱼 技术大佬 @717341215
            @717341215 支持的,你要安装和init update 都用root权限就行
            • 4908725614
              490872561
              @小鱼 这边提示安装成功了但是我使用rosdepc update显示找不到命令rosdepc
              小鱼小 1 2 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @490872561
                @490872561 没装成功
                • 4975059194
                  497505919
                  请问出现图中could not detect OS 算更新有问题吗?
                  我跑gazebo仿真程序的时候也会报这个错误。
                  4975059194 1 条回复 最后回复 回复 引用 0
                  • 4975059194
                    497505919 @497505919
                    @小鱼 您好,能帮忙看一下我这个是什么问题嘛?
                    9 1 条回复 最后回复 回复 引用 0
                    • jingjumoJ
                      jingjumo
                      为什么会这个样子呢?
                        小鱼 技术大佬 @jingjumo
                        @jingjumo sudo rosdepc init
                        • 26246021242
                          2624602124
                          ros1@DESKTOP-LAT9F3M:~$ sudo rosdepc init
                          欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
                          欢迎关注公众号《鱼香ROS》加入交流群
                          小鱼rosdepc正式为您服务
                          --2023-08-14 10:07:28-- https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
                          正在解析主机 mirrors.tuna.tsinghua.edu.cn (mirrors.tuna.tsinghua.edu.cn)... 101.6.15.130, 2402:f000:1:400::2
                          正在连接 mirrors.tuna.tsinghua.edu.cn (mirrors.tuna.tsinghua.edu.cn)|101.6.15.130|:443... 已连
                          接。
                          已发出 HTTP 请求,正在等待回应... 200 OK
                          长度: 550 [application/octet-stream]
                          正在保存至: “/etc/ros/rosdep/sources.list.d/20-default.list”
                          /etc/ros/rosdep/sources 100%[==============================>] 550 --.-KB/s 用时 0s
                          2023-08-14 10:07:31 (118 MB/s) - 已保存 “/etc/ros/rosdep/sources.list.d/20-default.list” [550/550])
                          小鱼提示:恭喜你完成初始化,快点使用
                          rosdepc update
                          更新吧
                          因为有一些小伙伴更新使用rosdep update,老是搞错,小鱼就直接帮你进行更新了!请稍等!
                          reading in sources list data from /etc/ros/rosdep/sources.list.d
                          Warning: running 'rosdep update' as root is not recommended.
                          You should run 'sudo rosdep fix-permissions' and invoke 'rosdep update' again without sudo.
                          Hit https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/osx-homebrew.yaml
                          Hit https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/base.yaml
                          Hit https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/python.yaml
                          ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/ruby.yaml]:
                          <urlopen error [Errno 101] Network is unreachable> (https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/ruby.yaml)
                          Query rosdistro index https://mirrors.tuna.tsinghua.edu.cn/rosdistro/index-v4.yaml
                          Skip end-of-life distro "ardent"
                          Skip end-of-life distro "bouncy"
                          Skip end-of-life distro "crystal"
                          Skip end-of-life distro "dashing"
                          Skip end-of-life distro "eloquent"
                          Skip end-of-life distro "foxy"
                          Skip end-of-life distro "galactic"
                          Skip end-of-life distro "groovy"
                          Add distro "humble"
                          Skip end-of-life distro "hydro"
                          Skip end-of-life distro "indigo"
                          Add distro "iron"
                          Skip end-of-life distro "jade"
                          Skip end-of-life distro "kinetic"
                          Skip end-of-life distro "lunar"
                          Skip end-of-life distro "melodic"
                          Add distro "noetic"
                          ERROR: error loading sources list:
                          <urlopen error <urlopen error [Errno 101] Network is unreachable> (https://mirrors.tuna.tsinghua.edu.cn/rosdistro/noetic/distribution.yaml)>
                          小鱼恭喜:rosdepc已为您完成更新!!
                          如果在上述更新中遇到错误,请查看rosdepc常见错误解决方案:https://fishros.org.cn/forum/topic/676
                          如果在使用过程中遇到任何问题,欢迎通过fishros.org.cn反馈,最后加入QQ交流群 686914208(入群口令:一键安装)
                          这样是安装成功了嘛
                          17803785431 1 条回复 最后回复 回复 引用 0
                          • 26246021242 2624602124 在 中 引用了 这个主题
                          • 26246021242
                            2624602124
                            ros1@DESKTOP-LAT9F3M:~$ rosdepc update
                            欢迎关注公众号《鱼香ROS》加入交流群
                            小鱼rosdepc正式为您服务
                            ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/osx-homebrew.yaml]:
                            <urlopen error [Errno 101] Network is unreachable> (https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/osx-homebrew.yaml)
                            Hit https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/ruby.yaml
                            Add distro "humble"
                            Add distro "iron"
                            Add distro "noetic"
                            Add distro "rolling"
                            updated cache in /home/ros1/.ros/rosdep/sources.cache
                            ERROR: Not all sources were able to be updated.
                            • 15306634141
                              MZJ罒比伯
                              15306634141 1 条回复 最后回复 回复 引用 0
                              • 15306634141
                                MZJ罒比伯 @1530663414
                                @1530663414你好,请问这个是什么问题,运行rosdepc update 出现
                                • 678156746
                                  夜起惊澜
                                  请问下这个问题可能是什么原因,全网好像没看到过我这种错误
                                  • 4357638524 435763852 在 中 引用了 这个主题
                                  • 17803785431
                                    略 @2624602124
                                    @2624602124 你的问题最后解决了吗
                                    • 9
                                      1 @497505919
                                      @497505919 老哥,你的问题解决了吗,我也遇到了这个问题
                                        贾永豪
                                        大佬你好,我在使用resdepc update中报错如下:
                                        Add distro "humble"
                                        ERROR: Rosdep experienced an error: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'raspbian', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'conda', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora-asahi', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
                                        Please go to the rosdep page [1] and file a bug report with the stack trace below.
                                        rosdep version: 0.23.1
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 146, in rosdep_main
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 450, in _rosdep_main
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 459, in _no_args_handler
                                        return command_handlerscommand
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 676, in command_update
                                        quiet=options.quiet)
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 517, in update_sources_list
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/gbpdistro_support.py", line 148, in get_gbprepo_as_rosdep_data
                                        ctx = create_default_installer_context()
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/init.py", line 91, in create_default_installer_context
                                        m.register_platforms(context)
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/platforms/arch.py", line 53, in register_platforms
                                        register_manjaro(context)
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/platforms/arch.py", line 58, in register_manjaro
                                        (os_name, os_version) = context.get_os_name_and_version()
                                        File "/usr/lib/python2.7/dist-packages/rosdep2/installers.py", line 115, in get_os_name_and_version
                                        os_name = self.os_detect.get_name()
                                        File "/usr/lib/python2.7/dist-packages/rospkg/os_detect.py", line 638, in get_name
                                        self.detect_os()
                                        File "/usr/lib/python2.7/dist-packages/rospkg/os_detect.py", line 608, in detect_os
                                        OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'raspbian', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'conda', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora-asahi', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
                                        目前已经尝试了换源、本地编译等方法,但是都不能解决,并且尝试了rosdepc update --rosdistro=melodic仍然不能正常运行,我是ubuntu 1804的,应该是指令没有问题的
                                        2 19775388121 2 条回复 最后回复 回复 引用 0
                                          贾永豪 @2269810364
                                          @2269810364 请问大佬有什么解决方法没有
                                            凌@乱
                                            大佬怎么解决这个问题啊@小鱼
