    ros2,cartographer建图,rviz2不能显示submaps
    cartographer rviz2 submaps
    2.7k
    • 阿甘阿
      阿甘
      ros2,cartographer建图时,rviz2中submaps组件无法显示?
      • 阿甘阿
        阿甘
          小鱼 技术大佬 @阿甘
          @阿甘 平时没怎么注意submap,今天晚点我抽时间瞅瞅,图能正常建出来吗?carto配置参数怎么配的
          阿甘阿 2 条回复 最后回复 回复 引用 0
          • 阿甘阿
            阿甘 @小鱼
            @小鱼 感谢回复😃 可以正常建图
            配置参数:
            include "map_builder.lua"
            include "trajectory_builder.lua"
            options = {
              map_builder = MAP_BUILDER,
              map_frame = "map",
              tracking_frame = "base_link",  --imu_link
              published_frame = "base_link",  --base_link
              odom_frame = "odom",
              provide_odom_frame = true,
              publish_frame_projected_to_2d = false,
              use_pose_extrapolator = true,
              use_odometry = false,
              use_nav_sat = false,
              use_landmarks = true,
              num_laser_scans = 1,
              num_subdivisions_per_laser_scan = 1,--10
              num_point_clouds = 0,
              submap_publish_period_sec = 0.3,
              odometry_sampling_ratio = 1.,
              imu_sampling_ratio = 1.,
            MAP_BUILDER.num_background_threads=6 --7
            TRAJECTORY_BUILDER_2D.min_range = 0.1
            TRAJECTORY_BUILDER_2D.max_range = 15
            TRAJECTORY_BUILDER_2D.num_accumulated_range_data = 1
            TRAJECTORY_BUILDER_2D.motion_filter.max_distance_meters=0.08
            TRAJECTORY_BUILDER_2D.motion_filter.max_angle_radians=math.rad(6.)
            TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching =true
            TRAJECTORY_BUILDER_2D.ceres_scan_matcher.occupied_space_weight = 1.
            TRAJECTORY_BUILDER_2D.ceres_scan_matcher.translation_weight = 1.
            TRAJECTORY_BUILDER_2D.ceres_scan_matcher.rotation_weight = 1.
            TRAJECTORY_BUILDER_2D.submaps.num_range_data=100
            TRAJECTORY_BUILDER_2D.submaps.grid_options_2d.resolution = 0.05
            return options
            • 阿甘阿
              阿甘 @小鱼
              @小鱼 launch文件
              import os
              from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription
                  # 定位到功能包的地址
                  pkg_share = FindPackageShare(package='fishbot_cartographer').find('fishbot_cartographer')
                  #=====================运行节点需要的配置=======================================================================
                  # 是否使用仿真时间,我们用gazebo,这里设置成true
                  use_sim_time = LaunchConfiguration('use_sim_time', default='false')
                  # 地图的分辨率
                  resolution = LaunchConfiguration('resolution', default='0.05')
                  # 地图的发布周期
                  publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
                  # 配置文件夹路径
                  configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
                  # 配置文件
                  configuration_basename = LaunchConfiguration('configuration_basename', default='cartographer_slam.lua')
                  urdf_dir = os.path.join(pkg_share, 'urdf')
                  urdf_file = os.path.join(urdf_dir, 'jzdbot_base.urdf')
                  with open(urdf_file, 'r') as infp:
                      robot_desc = infp.read()
                  #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
                      package = 'robot_state_publisher',
                      executable = 'robot_state_publisher',
                      parameters=[
                          {'robot_description': robot_desc},
                          {'use_sim_time': use_sim_time}],
                      output = 'screen'
                  cartographer_node = Node(
                      package='cartographer_ros',
                      executable='cartographer_node',
                      name='cartographer_node',
                      output='screen',
                      arguments=['-configuration_directory', configuration_directory,
                                 '-configuration_basename', configuration_basename])
                  occupancy_grid_node = Node(
                      executable='cartographer_occupancy_grid_node',
                      name='cartographer_occupancy_grid_node',
                      output='screen',
                      arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
                  rviz_node = Node(
                      package='rviz2',
                      executable='rviz2',
                      name='rviz2',
                      # arguments=['-d', rviz_config_dir],
                      output='screen')
                  #===============================================定义启动文件========================================================
                  ld = LaunchDescription()
                  ld.add_action(robot_state_publisher_node)
                  ld.add_action(cartographer_node)
                  ld.add_action(occupancy_grid_node)
                  ld.add_action(rviz_node)
                  return ld
