    nav2导航-amcl没有显示
    Nav2
    nav2 amcl
    963
    • 26312318682
      Cry with smile
      使用nav2进行导航,配置文件
      amcl:
        ros__parameters:
          use_sim_time: false
          alpha1: 0.2
          alpha2: 0.2
          alpha3: 0.2
          alpha4: 0.2
          alpha5: 0.2
          base_frame_id: "base_link"
          beam_skip_distance: 0.5
          beam_skip_threshold: 0.3
          do_beamskip: false
          global_frame_id: "map"
          lambda_short: 0.1
          laser_max_range: 100.0
          laser_min_range: -1.0
          max_beams: 60
          max_particles: 2000
          min_particles: 500
          odom_frame_id: "odom"
          pf_err: 0.05
          pf_z: 0.99
          recovery_alpha_fast: 0.0
          recovery_alpha_slow: 0.0
          resample_interval: 1
          robot_model_type: "nav2_amcl::DifferentialMotionModel"
          save_pose_rate: 0.5
          sigma_hit: 0.2
          tf_broadcast: true
          transform_tolerance: 10.0
          update_min_a: 0.2
          update_min_d: 0.25
          z_hit: 0.5
          z_max: 0.05
          z_rand: 0.5
          z_short: 0.05
          scan_topic: scan
      amcl_map_client:
        ros__parameters:
          use_sim_time: false
      amcl_rclcpp_node:
        ros__parameters:
          use_sim_time: false
      bt_navigator:
        ros__parameters:
          use_sim_time: false
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          plugin_lib_names:
          - nav2_smooth_path_action_bt_node
          - nav2_spin_action_bt_node
          - nav2_wait_action_bt_node
          - nav2_back_up_action_bt_node
          - nav2_drive_on_heading_bt_node
          - nav2_globally_updated_goal_condition_bt_node
          - nav2_is_path_valid_condition_bt_node
          - nav2_truncate_path_local_action_bt_node
          - nav2_recovery_node_bt_node
          - nav2_path_expiring_timer_condition
          - nav2_single_trigger_bt_node
          - nav2_controller_cancel_bt_node
          - nav2_path_longer_on_approach_bt_node
          - nav2_wait_cancel_bt_node
          - nav2_spin_cancel_bt_node
          - nav2_back_up_cancel_bt_node
          - nav2_drive_on_heading_cancel_bt_node
      bt_navigator_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      controller_server:
        ros__parameters:
          use_sim_time: false
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          failure_tolerance: 0.3
          progress_checker_plugin: "progress_checker"
          goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
          controller_plugins: ["FollowPath"]
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          #precise_goal_checker:
          #  plugin: "nav2_controller::SimpleGoalChecker"
          #  xy_goal_tolerance: 0.25
          #  yaw_goal_tolerance: 0.25
          #  stateful: True
          general_goal_checker:
            stateful: True
          # DWB parameters
          FollowPath:
            plugin: "dwb_core::DWBLocalPlanner"
            debug_trajectory_details: True
            min_vel_x: 0.0
            min_vel_y: 0.0
            max_vel_x: 0.26
            max_vel_y: 0.0
            max_vel_theta: 1.0
            min_speed_xy: 0.0
            max_speed_xy: 0.26
            min_speed_theta: 0.0
            # Add high threshold velocity for turtlebot 3 issue.
            # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
            acc_lim_x: 2.5
            acc_lim_y: 0.0
            acc_lim_theta: 3.2
            decel_lim_x: -2.5
            decel_lim_y: 0.0
            decel_lim_theta: -3.2
            vx_samples: 20
            vy_samples: 5
            vtheta_samples: 20
            sim_time: 1.7
            linear_granularity: 0.05
            angular_granularity: 0.025
            transform_tolerance: 0.2
            trans_stopped_velocity: 0.25
            short_circuit_trajectory_evaluation: True
            stateful: True
            critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
            BaseObstacle.scale: 0.02
            PathAlign.scale: 32.0
            PathAlign.forward_point_distance: 0.1
            GoalAlign.scale: 24.0
            GoalAlign.forward_point_distance: 0.1
            PathDist.scale: 32.0
            GoalDist.scale: 24.0
            RotateToGoal.scale: 32.0
            RotateToGoal.slowing_factor: 5.0
            RotateToGoal.lookahead_time: -1.0
      controller_server_rclcpp_node:
        ros__parameters:
          use_sim_time: false
      local_costmap:
        local_costmap:
          ros__parameters:
            update_frequency: 5.0
            publish_frequency: 2.0
            global_frame: odom
            use_sim_time: false
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            robot_radius: 0.22
            plugins: ["voxel_layer", "inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.55
            voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
                topic: /scan
                clearing: True
                marking: True
                data_type: "LaserScan"
                raytrace_max_range: 3.0
                raytrace_min_range: 0.0
                obstacle_max_range: 2.5
                obstacle_min_range: 0.0
            static_layer:
        local_costmap_client:
          ros__parameters:
            use_sim_time: false
        local_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: false
      global_costmap:
        global_costmap:
          ros__parameters:
            update_frequency: 1.0
            publish_frequency: 1.0
            global_frame: map
            use_sim_time: false
            robot_radius: 0.22
            resolution: 0.05
            track_unknown_space: true
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
            static_layer:
            inflation_layer:
        global_costmap_client:
          ros__parameters:
            use_sim_time: false
        global_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: false
      map_server:
        ros__parameters:
          use_sim_time: false
          yaml_filename: "turtlebot3_world.yaml"
      map_saver:
        ros__parameters:
          use_sim_time: false
          save_map_timeout: 5.0
          free_thresh_default: 0.25
          occupied_thresh_default: 0.65
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          use_sim_time: false
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner/NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      planner_server_rclcpp_node:
        ros__parameters:
          use_sim_time: false
      smoother_server:
        ros__parameters:
          use_sim_time: false
          smoother_plugins: ["simple_smoother"]
          simple_smoother:
            plugin: "nav2_smoother::SimpleSmoother"
            tolerance: 1.0e-10
            max_its: 1000
            do_refinement: True
      behavior_server:
        ros__parameters:
          costmap_topic: local_costmap/costmap_raw
          footprint_topic: local_costmap/published_footprint
          cycle_frequency: 10.0
          behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
          spin:
            plugin: "nav2_behaviors/Spin"
          backup:
            plugin: "nav2_behaviors/BackUp"
          drive_on_heading:
            plugin: "nav2_behaviors/DriveOnHeading"
          wait:
            plugin: "nav2_behaviors/Wait"
          global_frame: odom
          transform_tolerance: 0.1
          use_sim_time: false
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      robot_state_publisher:
        ros__parameters:
          use_sim_time: false
      waypoint_follower:
        ros__parameters:
          loop_rate: 20
          stop_on_failure: false
          waypoint_task_executor_plugin: "wait_at_waypoint"
          wait_at_waypoint:
            plugin: "nav2_waypoint_follower::WaitAtWaypoint"
            enabled: True
            waypoint_pause_duration: 200
      launch文件
      作者: 小鱼
      公众号: 鱼香ROS
      QQ交流群: 2642868461
      描述: file content
      import os
      from launch.actions import IncludeLaunchDescription
          fishbot_navigation2_dir = get_package_share_directory('fishbot_navigation2')
          use_sim_time = LaunchConfiguration('use_sim_time', default='false')
          map_yaml_path = LaunchConfiguration('map',default=os.path.join(fishbot_navigation2_dir,'maps','fishbot_map.yaml'))
          nav2_param_path = LaunchConfiguration('params_file',default=os.path.join(fishbot_navigation2_dir,'param','fishbot.yaml'))
          rviz_config_dir = os.path.join(nav2_bringup_dir,'rviz','nav2_default_view.rviz')
          return LaunchDescription([
              DeclareLaunchArgument('use_sim_time',default_value=use_sim_time,description='Use simulation (Gazebo) clock if true'),
              DeclareLaunchArgument('map',default_value=map_yaml_path,description='Full path to map file to load'),
              DeclareLaunchArgument('params_file',default_value=nav2_param_path,description='Full path to param file to load'),
              IncludeLaunchDescription(
                  PythonLaunchDescriptionSource([nav2_bringup_dir,'/launch','/bringup_launch.py']),
                  launch_arguments={
                      'map': map_yaml_path,
                      'use_sim_time': use_sim_time,
                      'params_file': nav2_param_path}.items(),
              Node(
                  package='rviz2',
                  executable='rviz2',
                  name='rviz2',
                  output='screen'),
      • 26312318682
        Cry with smile
        [rviz2-10] [INFO] [1669974238.244804084] [rviz2]: Message Filter dropping message: frame 'odom' at time 1669974234.432 for reason 'Unknown'
        Connectivity Error looking up robot pose: Could not find a connection between 'odom' and 'base_link' because they are not part of the same tree.Tf has two or more unconnected trees.
        报错
        LorryL 1 条回复 最后回复 回复 引用 0
        • LorryL
          Lorry @2631231868
          @2631231868 感觉你这个是缺少了里程计信息,你指定了小车的起始位姿了吗
          26312318682 1 条回复 最后回复 回复 引用 0
          • 26312318682
            Cry with smile @Lorry
            @Lorry 确定了,现在有了路径规划,每次重启就有了,第二次就不行了,但是没有amcl定位。
            • 26312318682
              Cry with smile
              Invalid frame ID "base_footprint" passed to canTransform argument target_frame - frame does not exist
              [amcl-2] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp
              现在又报错这个
