    ROS2 humble 编译自定义话题接口报错
    ros2-humble msg ubuntu22.04
    3.4k
    • 20996845742
      浮阑
      ubuntu 22.02 双系统
      ROS2 humble
      根据赵虚左的视频教程建立工作空间、功能包base_interfaces_demo,无其他依赖,建立msg文件夹并编写Student.msg文件
      Student.msg文件:
      string name
      int32 age
      float64 height
      package.xml文件(添加了三项依赖):
      <?xml version="1.0"?>
      <package format="3">
          <name>base_interfaces_demo</name>
          <version>0.0.0</version>
          <maintainer email="wuwenxiang@todo.todo">wuwenxiang</maintainer>
          <license>TODO: License declaration</license>
          <build_depend>rosidl_default_generators</build_depend>
          <exec_depend>rosidl_default_runtime</exec_depend>
          <export>
          </export>
      </package>
      CMakeList.txt文件:
      project(base_interfaces_demo)
      endif()
      # find dependencies
          "msg/Student.msg"
      if(BUILD_TESTING)
      endif()
      ament_package()
      colcon build编译后报错:
      Starting >>> pkg01_helloworld_cpp
      --- stderr: base_interfaces_demo
      CMake Error at /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
        list index: 1 out of range (-1, 0)
        CMakeLists.txt:14 (rosidl_generate_interfaces)
      CMake Error at /opt/ros/humble/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:69 (message):
        Target dependency
        '/ros/ws01/build/base_interfaces_demo/rosidl_adapter/base_interfaces_demo/msg/Student.idl'
        does not exist
      Failed   <<< base_interfaces_demo [0.97s, exited with code 1]
      报错中
      Target dependency
        does not exist
      该Student.idl在工作空间ws01/build/base_interfaces_demo/rosidl_adapter/base_interfaces_demo/msg/下可以找到,发现报错的路径前缀居然是从根目录/开始的,所以尝试将整个文件夹复制到根目录下/,删除掉build文件夹后重新编译,居然通过了。
      查看报错中的/opt/ros/humble/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake文件,产生报错的地方
      set(target_dependencies
        "${rosidl_generator_c_BIN}"
        ${rosidl_generator_c_GENERATOR_FILES}
        "${rosidl_generator_c_TEMPLATE_DIR}/action__type_support.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/idl.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/idl__functions.c.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/idl__functions.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/idl__struct.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/idl__type_support.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/msg__functions.c.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/msg__functions.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/msg__struct.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/msg__type_support.h.em"
        "${rosidl_generator_c_TEMPLATE_DIR}/srv__type_support.h.em"
        ${rosidl_generate_interfaces_ABS_IDL_FILES}
        ${_dependency_files})
      foreach(dep ${target_dependencies})
        if(NOT EXISTS "${dep}")
          message(FATAL_ERROR "Target dependency '${dep}' does not exist")
        endif()
      endforeach()
      怀疑是这几个变量有bug
        小鱼 技术大佬 @2099684574
        @2099684574 应该是工作空间搞混了,建议删除所有编译相关文件重新测试
        20996845742 1 条回复 最后回复 回复 引用 0
        • 20996845742
          浮阑 @小鱼
          @小鱼 我懂了,是路径里有中文,所以${rosidl_generate_interfaces_ABS_IDL_FILES}这个变量中中文字段缺少,文件路径就错了
          之前看到论坛里有个类似的问题,报错和我一样,估计也是这个原因
